Offline Ted
#1 Posted : 21 October 2025 10:03:49(UTC)
Ted
I intend to use a 60822 to power k and m83. One source says to use a special power supply unit, another says you can use a a train. controller using the accessories output. Any comments.
#2 Posted : 22 October 2025 10:12:59(UTC)
By the time the 60822 got to market, the option to use a legacy transformer (... train controller accessory output..) had been forgotten.
Its only power source to use is a 18/19V DC power supply, originally of the 6636x type (i.e. same as a MS2).
Personally I would not bother using it for a m8x item - you can plug the external power supply directly into these without the 60822.
For the k83 items there is some merit, should you already have acquired a 60822 (and power supply).
However generally I would suggest using existing booster solutions (for your track) and driving Accessories like k83s from the main controller
M83 + Switch Powerpack + 60822 (Digital)
by MarcelV 11/08/2019 06:04:29(UTC)
Märklin 60822 Universal Supply Unit (Digital)
by Jabez 04/08/2019 17:08:15(UTC)
power supply 60822 (General MRR)
by Thewolf 03/02/2019 02:10:39(UTC)
60822 universal power supply / 66367 power pack for M83/M84 (H0-scale)
by ae66green 17/01/2018 17:08:46(UTC)
A Power supply for new M83. Is a 60822 needed? (Digital)
by frickwg 19/03/2015 22:30:36(UTC)
m83=60831/60832 m84=60841/60842 ( 60821 60822 ) - Dec17= mfx sync of addresses (CS3 <> m8*.2) (Digital)
by clapcott 27/10/2013 07:22:18(UTC)
This page was generated in 0.304 seconds.
