2 Pages<12
Offline osoraku
#51 Posted : 02 April 2025 21:54:22(UTC)
osoraku
Dear Adrian -
Sorry it wasn't clear - both marklin.py and threadsafe.py are at the github site where the rest of the code is.
Osoraku
thanks 2 users liked this useful post by osoraku
Online xxup
#52 Posted : 05 April 2025 11:21:23(UTC)
Good news! Everything is working and I am up to the point of connecting to Rocrail.
I had a little stumble, when I forgot to change the pin assignments for the waveshare board in the TCP-CAN.py file. I was too focused on getting the wifi working - I needed to set up the new MRR VLAN on the switch so that the pico would get the correct IP address. I keep my networks isolated.
If I have some time tomorrow, I will figure out Rocrail (I normally use WinDigiPet) and try the connection.
Hopefully, there will be an s88 pico pi solution so that I can try automation on the test track.
One question. Now that main.py is loaded on to the pico. Will it autostart when I start the pico, the track box and Rocrail?
Offline osoraku
#53 Posted : 06 April 2025 01:35:12(UTC)
osoraku
Dear Adrian -
Yes.
I reworked the code to auto-configure the CAN board.
Osoraku
Edited by user 27 April 2025 14:17:05(UTC)  | Reason: Updated code to auto-configure
Offline revmox
#54 Posted : 10 April 2025 12:48:09(UTC)
revmox
As a side issue to the CAN control capability, does anyone have a full circuit diagram of a track box - any version. I have searched several times both in English and via gleisbox schaltplan and found what looked like promising links but no luck - but usually just dead links or access barred.
Also, cables for the track box can sometimes be found cheap on eBay or Amazon under 10 pin S video cables - if you get a male to male version you get two usable project cables for the price of one.
Mark
thanks 2 users liked this useful post by revmox
Offline revmox
#55 Posted : 13 April 2025 02:53:48(UTC)
revmox
Find the circuit for a 60113 gleisbox in my cloud storage using the link below-
Also in there you will find data sheets for the chips it uses.
C5081F502 MCU processor
MAX3058 CAN transceiver
CD4555 dual 1 of 4 decoder
SAA6579 and PT2579 RDS decoder, my 60116 track box has the PT2579 equivalent
ZXCT1009 high-side current monitor - a nifty device that I haven't seen before that produces an isolated output current proportional to the voltage on its input terminals, I think it picks up the mfx feedback from decoders and also provides the over current protection sensing?
https://mega.nz/folder/g...I#59XJTLCZ9wx1t5pihgbrww
Offline osoraku
#56 Posted : 13 April 2025 09:58:32(UTC)
osoraku
Dear Mark -
That makes sense to me (though I am no electronics wizard).
The 60113/60116 are DCC & MFX capable so they both use a form of current loop feedback from the decoder. This schematic should be helpful for Roland's MFX decoder feedback work.
Osoraku
Offline bobyAndCo
#57 Posted : 13 April 2025 10:22:11(UTC)
bobyAndCo
Thanks for sharing but what you present here uses an RDS component (SAA6579 or PT2579). These components are difficult to find today and expensive.
I tested the MFX feedback with these RDS components and another schematic but I couldn't isolate the useful information. So I gave up on the piss.
I was very interested when you published this schematic that didn't use RDS components. Is this the wrong way to go?
If not, I'd be very interested if you could provide some clarification, particularly on the choice of coil.
I'll then try to implement it and share my results.
MFX feedback is the only thing missing from my otherwise perfectly functioning power plant.
https://www.marklin-user...es-without-CS-2-3-or-MS2
Christophe
Online xxup
#58 Posted : 13 April 2025 10:53:01(UTC)
@osoraku
Sorry to digress, but have you had time to check out the S88 solution using a Pico? I realise that a pico-based automated layout would be small due to the current (as in electric) limitations of the track box, but I would like to make a modest automated layout to show some people how easy it is to set up and use.
Offline osoraku
#59 Posted : 13 April 2025 11:33:24(UTC)
osoraku
Dear Adrian -
Sorry, not yet. I am away from my hardware for a few weeks and can't test anything attached to the real world.
I'm sure that Christophe's design works. Of interest to me is whether enough of the spare pins on the Joy-IT or Waveshare CAN boards can be used the same way and integrated into a single device (with, say, 8 or so S88-equivalent feedback inputs). That would be a simple, cheap, integrated device to go with a starter set.
(Edited later): This has now been tested and the code is updated
Osoraku
Edited by user 27 April 2025 14:18:33(UTC)  | Reason: Tested and updated
Offline revmox
#60 Posted : 13 April 2025 12:42:41(UTC)
revmox
Christophe
Yes, some work has gone on in the background to eliminate the need for a dedicated RDS chip and a transformer. I am working on a method to do the extraction using common MCUs or even a common-as-muck Arduino Nano as an RDS co-processor - seems quite promising so far. Getting the signal to feed into it without using a current transformer was the issue. The ZXCT1009 is cheap and plentiful - even down here, close to the South Pole.
Once the RDS carrier is cleanly extracted you can sync into an edge in the early part of the waveform, shift timing by quarter of a pulse (4.75uS), then sample every 9.5uS at the centre of the pulses. If the second part of the waveform stays in sync with the first then you have a 1, if it reverses you have a 0. Then it's just processing ...
Cheers.
Offline bobyAndCo
#61 Posted : 13 April 2025 21:18:54(UTC)
bobyAndCo
revmox
Thanks for the feedback. Can you give me more details on the electronic schematic that would be suitable.
Is the schematic obsolete???
I have the skills and equipment to decode binary signals. But not enough electronics.
I know that the MFX return signal can be analyzed either by an Arduino, an ESP32, an RP Pi Pico or even an ATTiny.
If I could have the schematic of this feedback part alone, I could make a great contribution, and the control unit I've proposed is open source and works very well. It would be a great plus for the community.
Thanks in advance.
Christophe
PS: It would probably be better to continue on another thread or by private message!
thanks 1 user liked this useful post by bobyAndCo
Offline patnaik
#62 Posted : 13 April 2025 23:39:56(UTC)
patnaik
I have just gotten my setup to work. I have manually added a DCC loco separately to the MS2 and Rocrail. I am able to control the loco from either Rocrail or the MS2 controller. My question how do I add a MFX loco to Rocrail? The MS2 does it automatically.
Gopal
Offline revmox
#63 Posted : 14 April 2025 02:04:25(UTC)
revmox
Hi Christophe,
I’ve posted the gleisbox information here as it might in some way be useful to people working through it. I’m not trying to produce a train controller – RDS is just an interesting technical puzzle for me to solve that seems to be an obstacle for those that are.
The circuit using the 567 tone decoder works but is NOT recommended – it uses a current transformer and these are always difficult for others to replicate. It has a high component count and either needs 1% components or some decent electronic equipment to set up the PLL centre frequency. The tone decoder output momentarily drops lock when an RDS phase reversal occurs and this is what must be detected. If you want to push ahead (and obviously you have seen my previous posts) then the only information you are missing is the transformer. Unfortunately, it has gone out with the trash, as I’m cleaning up in preparation for moving house but it used the same unknown core from my glory box as shown on the right in the picture of the bread boarded circuit, 17 OD, 10 ID, 5H, 2T primary, 8T secondary loaded with 10 ohms as best I can recall.
It would seem the far better approach would be to lean on Marklin’s mass produced method that is working satisfactorily in so many gleisboxes. Tracing the gleisbox path from the current monitor chip to the RDS chip MUX input should provide what is needed – and also give the possibility of overload protection to those that don’t already have it. Here’s a copy of some private chatter that may help you if you go down that path, it works on the bench detecting 1s and 0s from an RDS generator.
I’ve used an Arduino Nano, with the more advanced platforms you gain many, many things but lose that level of visibility and control. (My staff used to call it the “Rule of 4” – 4 cores, 4GHz, 4GB and 4 obscure, deprecated libraries to turn one LED on in 4 seconds. Defence contractors, who charge by the line, just love it).
First, I’ve written a program to lock into the initial RDS waveform edges – then shift by a quarter of the RDS period 4.75uS to place sampling at mid-pulse – then sample every 9.5uS to capture the phase of the RDS signal. I then take 30 samples pre the phase change point and 30 samples post the phase change point. This gives a tolerance of tens of microseconds in response time for the loco decoder. If >27 of the samples in Sample 1 are in phase with the start then I consider it a valid RDS start (allows for some noise), if >27 of the 30 samples in Sample 2 are also in phase then I consider it a valid RDS logic 1, if <3 of the 30 samples in Sample 2 are in phase then I consider it a valid RDS logic 0. If those overall conditions aren’t met then I consider the reading invalid. Easier than focusing on the exact point of phase reversal. I’ll christen this the Mox Method and work on seeing if it comes together in the real world.
Good luck with your project.
Revmox
thanks 1 user liked this useful post by revmox
Offline osoraku
#64 Posted : 14 April 2025 10:56:18(UTC)
osoraku
Dear Gopal -
Originally Posted by: patnaik Go to Quoted Post
... My question how do I add a MFX loco to Rocrail? The MS2 does it automatically.
In Rocrail, navigate to Tables -> Locomotive. Under the Interface tab, you select the protocol with the Protocol menu. MFX is one of the choices.
Osoraku
Offline patnaik
#65 Posted : 15 April 2025 03:47:12(UTC)
patnaik
I can add in a MFX loco by hand. I don’t know what address to put in. Is there a way to make Rocrail auto detect the MFX loco?
Gopal
thanks 1 user liked this useful post by patnaik
Online xxup
#66 Posted : 15 April 2025 13:52:23(UTC)
I have had a look at the other s88 solution, but it requires special boards. I think that I will use my old LDT HSI-S88-RS232 with the normal s88 decoders to talk to rocrail directly. For this small layout, I only need 5 contact points.
If I do this, does this mean that I need to switch the pico setup to UDP from the TCP I have set currently?
Offline osoraku
#67 Posted : 15 April 2025 20:24:34(UTC)
osoraku
Dear Adrian -
...If I do this, does this mean that I need to switch the pico setup to UDP from the TCP I have set currently?
No. With Rocrail, there's no need to use UDP unless you want multiple controllers/throttles to run locos. Anything coming over the CAN bus will get forwarded. Your other hardware will have its own comm path (over RS232?) to Rocrail and won't be using WiFi.
Osoraku
thanks 1 user liked this useful post by osoraku
Online xxup
#68 Posted : 15 April 2025 21:56:06(UTC)
Originally Posted by: osoraku Go to Quoted Post
... (over RS232?) ...
I have two HSI-88 units. The HSI-88-USB will be used on the main layout with the CS3 running WinDigiPet on one laptop, while the HSI-SS-RS232 will be used with a RS232 to USB adaptor on a separate test layout with the pico-can controller and running Rocrail on another laptop. Looking at the Rocrail documentation suggests that the newer HSI-88-USB unit is not supported. (In any case, it is packed in a box somewhere waiting to be unpacked, when the shed is built later this year).
Offline osoraku
#69 Posted : 15 April 2025 22:43:28(UTC)
osoraku
Dear Adrian -
... The HSI-88-USB will be used on the main layout with the CS3 running WinDigiPet on one laptop, while the HSI-SS-RS232 will be used with a RS232 to USB adaptor on a separate test layout with the pico-can controller and running Rocrail on another laptop. Looking at the Rocrail documentation suggests that the newer HSI-88-USB unit is not supported....
If you're concerned that the pico-can controller will use up the USB ports on your computer, you can hook it up to USB power from a wall plug. Then the RS232↔︎USB adapter is available for your feedback device, making it look like an RS232 connection to Rocrail. Or do I misunderstand?
Osoraku
Online xxup
#70 Posted : 16 April 2025 06:37:22(UTC)
Nup. I am not worried about the USB ports as I can always buy a USB hub.
There are two versions of the LDT HSI-88:
- HSI-88-USB - https://www.ldt-infocent...oku.php?id=en:hsi-88-usb
- HSI-88 - https://www.ldt-infocent...ki/doku.php?id=en:hsi-88
The USB version is not supported on Rocrail (according to the Rocrail and LDT documentation), but looks like I can use the older unit with a USB to serial cable.
https://wiki.rocrail.net/doku.php?id=hsi88-en
I plan to use the RS232 version to test out the pico controller on a test layout so that I can understand the limitations for automation.
Does this make sense?
Offline osoraku
#71 Posted : 16 April 2025 11:18:01(UTC)
osoraku
Dear Adrian -
No worries. Rocrail will do the feedback integration and control via its separate comm paths. It makes no odds to the pico-can controller.
From the links that you posted, Rocrail apparently handles the HSI-88 as a feedback route to it via a serial port (RS232). You must have one of the USB dongles to connect RS232 to your Macbook Air test bed. Rocrail will probably see the HSI-88 as a serial device at /dev/cu.usbmodemxxxxx and show it as a choice on its setup page.
I may have a combined CAN-WiFi and feedback hub tested in a week or so. A Waveshare board is on its way to me as I type but I'll need some way to simulate feedback for testing. Pushbuttons, maybe. Fingers crossed.
Osoraku
Online xxup
#72 Posted : 16 April 2025 11:38:57(UTC)
Hello osoraku,
There is no hurry, but I am interested in testing a feedback enhancement based on the PICO.
One thing to note. When I first started with a computer controlled layout, I used an Intellibox connected to a PC running WinDigiPet. When I got to six or seven locos (even with two boosters) the Intellibox would run out of steam. By this I mean that the Intellibox would miss instructions and not switch a turnout or slow down a loco resulting in a crash. One way to fix this problem was to separate the role of occupancy detection from the Intellibox's control of the locos, turnouts and signals. This is how the first HSI-88 came into being - it used to be connected to a serial board on the original layout's Windows PC.
When I updated to the eCOS I retained the separation and had no problems running even more trains automatically. It was a change of PC that required me to replace the original HSI-88 with the HSI-88-USB.
It will be interesting to see if the Pico can handle all the tasks without being overwhelmed. Of course, the limitation here will be the maximum current output from the Gleisbox, which means that we will probably be limited to 3-4 locos anyway.
Kind regards,
Offline osoraku
#73 Posted : 16 April 2025 13:27:32(UTC)
osoraku
Dear Adrian -
After reading the CS2 protocol definition (version 1.0 and 2.0) and how they implement feedback, it is pretty clear that there is an "old" way and a "new" way to implement feedback. The "old" way broadcast the whole 16 state bits of an S88 module 10 times a second. This wastes bandwidth and clogs comms paths. In version 2.0 this use is deprecated. The "new" way only reports state changes, which lowers bandwidth demands enormously. I plan to use that approach, which shouldn't burden the pico at all.
As before:- fingers crossed; testing required.
Osoraku
Online xxup
#74 Posted : 16 April 2025 21:56:54(UTC)
Awesome! Count me in for testing. BigGrin
Offline osoraku
#75 Posted : 17 April 2025 20:42:10(UTC)
osoraku
Dear Adrian -
You're enlisted then! I got the code running and tested (TCP & UDP versions) as well as I can with what hardware I have at the moment. You can download it from the github repository. The pins to use for the feedback connections are documented in the README for it.
The main problem is how to hook up feedback devices: neither board offers easy connections. (I tested the hardware with breadboard jumpers and Rocrail reporting the feedback.) Male breadboard jumpers work best with the Joy-IT board and female with the Waveshare board.
I worked out a way to get sensor feedback into the Raspberry Pi using the header pins on the Joy-IT board. The Waveshare board could be attached similarly. Tests OK with Rocrail and JMRI.
feedback setup image
Another way to get sensor feedback into the Raspberry Pi pico (RPP) without a breadboard+jumpers is through this board. It provides breakouts of all the RPP pins with screw terminals and plugs into the headers on the Waveshare board.
Osoraku
Edited by user 06 May 2025 15:14:33(UTC)  | Reason: Added image of connected feedback devices & JMRI testing; also add breakout board image
Offline revmox
#76 Posted : 20 April 2025 00:02:48(UTC)
revmox
Has anybody tried this method to increase the number of devices working through a gleisbox? In my case it could be 2 x MS2s and a direct control panel for accessories or it could allow CAN bus sniffing while two devices are in use.
There are plenty of CAN bus hubs out there but I've never seen anything in 10 pin.
Offline osoraku
#77 Posted : 20 April 2025 09:10:25(UTC)
osoraku
Dear Mark - The connector provides power & CAN signals. Because you can daisy-chain CAN devices with the bus wiring (a sniffer with a comms/output path), methinks the main benefit for this cable would be to power > 2 MS2s.
Osoraku
Online xxup
#78 Posted : 17 May 2025 02:41:31(UTC)
Guess what I am doing today!
More soon.
Online xxup
#79 Posted : 17 May 2025 09:11:40(UTC)
Things didn't go great, but the problem seems to be Rocrail or my understanding of how it works.
After I started the track box and before Rocrail.
After Rocrail starts it starts chatting away. If I press F0 for a loco in Rocrail you can see F0 in the messages, but nothing happens on the loco.
I thought it might be a mFx problem, so I tried a second loco and set it to MM 13 (it does not have mFx) and it would not go either.
All the testing was done without using the MS2 (and with the Pico-wave set to "master" in rocrail.
Any thoughts?
Offline osoraku
#80 Posted : 17 May 2025 10:11:46(UTC)
osoraku
Dear Adrian -
Any thoughts?
The trace shows that Rocrail is talking to the RPP & Gleisbox.
Is the power button on in Rocrail? Is the loco using the MBUS controller with the name you gave it for the RPP?
Osoraku
Online xxup
#81 Posted : 17 May 2025 10:33:42(UTC)
...Is the power button on in Rocrail? Power Button? There's a power button?
Is the loco using the MBUS controller with the name you gave it for the RPP? Yes
Osoraku
I deleted all the old code from the pico and my computer, and followed your new instructions. It recognised the waveboard automatically, which means that the only file that needs to be edited is the one with the WiFi information.
Looks like your code works fine and the problem is with Rocrail. I will spend some more time on that side of the problem tomorrow.
Offline bobyAndCo
#82 Posted : 17 May 2025 12:31:37(UTC)
bobyAndCo
Hello everyone,
I haven't been following this very regularly lately and as I read you I have to admit I'm having a bit of trouble keeping up.
First, it talks about connecting Rocrail to the Gleisbox, then I see that it talks about feedback and I see what I think are presence detectors by current consumption.
I assume you want to use the S88 protocol for feedback. Why not? It's a possibility.
Personally, I would create a specific S88/TCP gateway (a new Raspberry or ESP32) specifically for this.
Where's your problem? There shouldn't be any. It's really very simple to convert S88 frames to TCP for Rocrail. Then to create an "mbus" controller in Rocrail that will receive the TCP messages and activate the right sensors. Is this the problem? If so, I can tell you how to do it, so don't hesitate.
Take a look here: https://forum.3rails.fr/...passerelle-can-tcp/28552
The project is a little different because the feedback bus is CAN, but between the gateway and Rocrail, it's exactly the same.
Don't hesitate if I can help.
Christophe
Offline bobyAndCo
#83 Posted : 17 May 2025 12:39:17(UTC)
bobyAndCo
And don't buy consumer detectors. They're easy to make and much cheaper to DIY.
https://www.locoduino.org/spip.php?article359
Offline osoraku
#84 Posted : 17 May 2025 16:11:44(UTC)
osoraku
Dear Adrian -
Osoraku
This turns on the juice to the track - gives the Gleisbox the SYSTEM GO packet (pressing the red STOP button on the MS2). The Gleisbox, in your packet log snippet, reports a TRACK current draw of 0.00 A and an idle loco should draw about 10 mA.
Osoraku
Online xxup
#85 Posted : 18 May 2025 00:04:10(UTC)
Thank you Osoraku,
I will check this after breakfast and my morning hit of the marklin-users forum news.
I have downloaded the whole "getting started" tutorial from the wiki - I tried Rocrail twenty years ago and had the same problems getting started with it, which is why I went with WinDigiPet. It might cost money, but I find it much easier and more logical to use.
When I get my shed and build a new layout, I will test your solution with WinDigiPet, but that is still months away for me.
Kind regards,
Online xxup
#86 Posted : 18 May 2025 06:46:48(UTC)
Not so good today, but a bit further with the diagnosis.
The power button is not the issue.
I removed the PICO from being a "master" on RocRail and added the MS2.
It seems that the pico is chatting well with the track box, and the track box talks to the layout and when I use the the MS2 to control the loco I can see the commands being issued from the MS2 and sent to the loco - for example I see F0 = 0 and when the lights go on, I see F0=1.
The problem is that the PICO is not talking to RocRail. Adding to this issue is that the PICO wants to connect to the WAP that is furthermost away instead of the one that is just above where I was testing. This might explain the next two screenshots.
I did not get any of these issues yesterday.
I think that the next test is to find a compliant, but cheap, controller that is known to work and see what is going on with RocRail - I am convinced that the problem is with Rocrail (or my use of it) and not your software. I seem to be missing some subtle information.
Online xxup
#87 Posted : 22 June 2025 10:12:02(UTC)
I had a much better day today. The patched marklin.py seems to have addressed most of my issues. I was able to control a loco and two switches, but the running was not without problems. It seemed like RocRail would not recognise the loco until I moved it with the MS2. After that it was happy for me to manually control it. At one stage I seemed to lose the connection between Rocrail and the loco. I tried a ctrl-D in the rshell to soft boot the pico-pi, but that made no difference. Only shutting down Rocrail enabled me to regain control. The switches, might not be properly configured in Rocrail. They work by clicking on the track plan, but only after a lengthy delay. At one stage the delay was so long that it basically just rattled the switches for a minute until everything caught up. A bit like the water flow after the stuck dead rat gets ejected from the pipe.
Unfortunately, the laptop I am using is an old Mac Air 2013 (i5 or i3 with 8Mb) running Ubuntu 24.04 (from memory) and the power pack died a few days ago. So when the laptop's battery dropped to 21% I had to call it a day. A new power pack is coming Tuesday or Wednesday. With the new pack, I expect to be able to access the Rocrail logs to see if there are any useful error messages.
#88 Posted : 22 June 2025 11:46:27(UTC)
I have looked at this and have no idea what it is about other than somebody has a raspberry. My question is this a different aspect of the model rail hobby which is good as it might might interest the younger generation who love computer things. Why not just use a CS3 which runs a railway well. If trying different controls for a model railway takes on this can be good for the hobby but not good for Marklin if it stops there stuff selling.
However I am all for anything that helps to increase the interest in the hobby and although I dont understand the thread will be interested in the final result.
Online xxup
#89 Posted : 22 June 2025 14:26:49(UTC)
This is about a cheap way to provide computer (or automation) on a layout without the expense of a CS3 (or eCOS). It is a worthwhile project for nerdy people like me, but it is not so good for people, who don't have a technology background.
This solution will never power a large layout as it is limited by the use of the trackbox, which limits the current output. There are also potential limitations around the processing power of the Pico unit itself, but it is too early to tell as there may also be limitations in the Rocrail application.
Anyway, I am enjoying the project and I wish that there weren't so many things in my personal life, at the moment, that get in the way of progressing it more quickly.
Guest (12)
2 Pages<12
This page was generated in 1.087 seconds.
