Offline Mjn2ts
#1 Posted : 21 March 2025 01:21:10(UTC)
Mjn2ts
So I’ve upgraded my F7 from analog to digital and using Marklin’s decoder programmer I’ve added the appropriate running sounds and whistle sounds for the F7. My problem is, now all of the other pre-loaded sounds are not working, most importantly the break squealing sounds. Is this normal when programming new sounds or did I mess something up?
Jeff
thanks 1 user liked this useful post by Mjn2ts
Offline bph
#2 Posted : 21 March 2025 13:14:56(UTC)
Jeff
Note that when you are using mDecoderTool and sending a decoder project to the decoder, all previous sounds and settings on the decoder are overwritten. (when sound and settings are selected for transfer).
And e.g. a good start with an old F7 might be the 39622 F7 decoder project. and you can add and map the extra sounds you want.
It's also recommended to check/select the correct type of motor and perform the auto calibration. ref the manual.
This video might help in understanding the brake squeal settings:
Offline rhfil
#3 Posted : 21 March 2025 14:19:39(UTC)
rhfil
In addition to the above, the brake squeal is dependent on the rate of deceleration and the speed before decelerating. So you might check to see if the deceleration rate needs to be higher.
#4 Posted : 21 March 2025 14:46:58(UTC)
Yers, and the brakesqueal/threshold also changes when you change the CV for the braking threshold in the CS 3 edit Loco decoder menu.
60971 Decoder programmer (Digital)
by Mjn2ts 12/03/2025 21:47:58(UTC)
by rytter 15/10/2022 17:04:12(UTC)
Decoder programmer 60917, Roco motors (Digital components and Software reviews)
by digana 16/12/2019 21:47:22(UTC)
decoder programmer 60971 (Digital)
by 3gleise 31/10/2018 22:26:16(UTC)
How easy or difficult or user friendly is the Märklin Decoder programmer ? (Digital)
by river6109 18/04/2018 03:54:46(UTC)
Marklin 60971 Decoder Programmer and mDT3 software (Digital)
by BrandonVA 21/09/2015 20:09:29(UTC)
This page was generated in 0.358 seconds.
