#1 Posted : 08 November 2023 19:21:39(UTC)
I was reading on several German language forums about potential derailment issues of these new models on switch tracks, as can be seen in this video:
More specifically: https://youtu.be/V_Ib0MO9ZTg?t=734
If you look a few seconds earlier, the locomotive seems to run fine, but just prior to the accident, you hear a "clack" as the locomotive enters the video frame
This seems to have destabilized the locomotive, causing the front bogie to take the wye while the rear bogie continues straight. I can't see on the video the exact track structure coming out of the tunnel on the right side, but it seems that something occurred which triggered the issue, either the slider was knocked out of alignment or perhaps one of the wheelsets?
I don't have the model and have not seen it in person, so I cannot comment on more than what I saw in the video.
I would rather have liked to have seen the train run without the shell, so that we can better see how the bogies move.
Running it with the V320 and BR103 doesn't really help that much.
A second run through https://youtu.be/V_Ib0MO9ZTg?t=885 shows that the locomotive passes through an S-curve on the exit from the tunnel.
A third run through https://youtu.be/V_Ib0MO9ZTg?t=904 shows a derailment of the rear bogie. This suggests to me that the slider (front bogie) may not be the issue
A shot of the chassis from earlier in the video does not show any obvious sign of a potential issue https://youtu.be/V_Ib0MO9ZTg?t=178
I wonder if the bogie completely clears the coupling assembly.
A shot of the model running solo over the problematic spot would be helpful here, even better without the shell.
If any of you have this or the other UP or KCS models, have you experienced any issues?
#2 Posted : 09 November 2023 13:06:35(UTC)
Some of the video comments are enlightening:
"@werhaski8158" reported 7 days ago the same problem with derailment of the front wheelset on the slim turnout on the C track. The middle front wheelset is spring-mounted and protrudes slightly. The slightest unevenness on the points, e.g. if they are not flat, or the slightest unevenness the track, especially in tight radii, have levered the front wheelset out of the guide. He has leveled two places on turnouts and radii, now it runs on all tracks and turnouts without derailing. Moving the points a little can also help. Now it runs perfectly with good traction on tight radii and two helixes.
"paulchensundfranksmodellba8756" reported 12 days ago that there is an extremely strong spring under the bogies to press the chassis onto the rails. Having shortened this spring, a lot of removal work is necessary, so the bogie is more flexible and adaptable to small bumps. After the intervention the locomotive runs perfectly over all turnouts.
"JeremyCRunge" reported 12 days ago that the front truck fell off when unboxing the loco. After reassembly the loco ran well on R1 curves, but it derailed on a turnout, too. Dissassembling the truck, he saw that one of the small clips that holds the axle in the correct position was not clipped in correctly. A test run after fixing the clip resulted in the loco mastering again R1 curves, but the turnout derailments continued...
"railwaysinh0771" reported 13 days ago the same problem with the turnout. In his opinion it is because the bogies have enough play on the line parallel to the track up and down, but almost none on the line perpendicular to the track. No problem in the straight position, but when branching off. Having shimmed the turnout a little in the direction of the branch it works now.
#3 Posted : 09 November 2023 13:23:58(UTC)
I will check mine Saturday evening and i will let you know.
Offline bph
#4 Posted : 09 November 2023 16:06:52(UTC)
One interesting thing here is that, compared to the Broadway Limited version which has all 3 axels powered in each truck, it seems like Marklin has redesigned it with "only" two axels powered in each truck. This is when comparing the exploded drawings......
#5 Posted : 09 November 2023 16:58:08(UTC)
Is the Maerklin/Trix version adapted from the Broadway Limited model or is it a separate model of the same type of locomotive by a different company?
If it is a separate model, then there is no redesign, but only an interpretation by the designers and engineers who created the model for Maerklin.
Offline bph
#6 Posted : 09 November 2023 17:41:47(UTC)
According to Broadway Limited, Märklin leased the tooling from them.
ref this post: https://www.stummiforum.de/t211171f2-USA-Neuheiten-Maerklin-Trix-H.html#msg2509713
also posted on this forum by Alsterstreek
Offline bph
#7 Posted : 09 November 2023 19:15:36(UTC)
A user on a HAG forum reported that the wheel spacing was too wide. he measured approximately 14,3 so he squeezed the wheels together a bit and according to him, it solved the issue......
ref: https://www.forum.hag-info.ch/forum/index.php?thread/10989-m%C3%A4rklin-neuheiten-2023/&postID=155230#post155230
Offline Unholz
#8 Posted : 10 November 2023 07:18:53(UTC)
Unholz
Yes indeed, and the next user has discovered additional flaws: https://www.forum.hag-in...postID=155231#post155231
Offline einotuominen
#9 Posted : 10 November 2023 08:23:42(UTC)
einotuominen
What I've learned from converting several two rail (Athearn, Kato, Proto2000) DC locos to Märklin three rail is that the 14,3 mm DC inner flange width will need to be reduced to 13,8 or 13,9 mm. Othervise derailments on turnouts will happen most of the time. After the modification, it basically never happens. It is also an easy task to do, at least with the Athearn / Walthers / Kato wheelsets.
BR,
Eino
thanks 4 users liked this useful post by einotuominen
Offline jonas_sthlm
#10 Posted : 10 November 2023 08:24:02(UTC)
jonas_sthlm
Do I really see tension brackets has Märklin developed this model on their own Confused
This is exactly the issue with Scandinavian produced models from China, broken on the first maintenance so let's hope the building up their spare parts storage Mellow
Should it start to end like this, no thanks ThumbDown
It is time for Märklin to ensure its so-called quality brand Angry
thanks 2 users liked this useful post by jonas_sthlm
Offline bph
#11 Posted : 10 November 2023 12:10:31(UTC)
I was very tempted to get this model, but I wanted to see some reviews before ordering, and these flaws have put me off. So, I'm glad I did hold back a bit before ordering.
#12 Posted : 10 November 2023 13:10:36(UTC)
Jonas, seeing your pictures, it seems to me this does not look AT ALL like a Märklin design. So it may be NO WONDER it does not work on Märklin Tracks
Just a guess on my part, maybe, this is a foreign design of an american loco slightly modified, apparently not thourougly tested on Märklin 3 rail tracks and the protruding Pukos at points
Offline jonas_sthlm
#13 Posted : 10 November 2023 14:06:50(UTC)
jonas_sthlm
Its the general Chinese constructions (cheap and poor plastic) they should not copy the bad selution, go back to screws...
Hope they have control over which metals are used for bogies... like Hobbytrade and some other Asian factories did not have.
#14 Posted : 10 November 2023 21:46:46(UTC)
I guess I'm about to find out, my first ES44 arrives today, the second is in transit!
#15 Posted : 10 November 2023 21:58:24(UTC)
einotuominen
The above photo leaves me speechless 😮
-Eino
#16 Posted : 11 November 2023 06:23:02(UTC)
Upon seeing this comment I measured the inner flange on my 38440 ES44 when it arrived today - the measurement was 14.17mm.
Compare that with my 37040 BR 50 which measured at 14.3mm. I've had the BR 50 on my friend's layout pulling a long train through multiple types of turnouts with no issues.
I put the ES44 on a small loop of C track with curved points and also a pair of 24612 turnouts providing a crossover from outer to inner rail. The loco has been running through that with no issues although I did notice the first time around the loco jumped a bit on the front bogie as it went through both set of turnouts. For lap 2 and subsequent ones there has been no issue.
Next test will be pulling some UP hopper cars (not the new ones but the 48500 brown ones).
#17 Posted : 11 November 2023 07:27:12(UTC)
einotuominen
Yeah it’s most likely the combination of inner flange width AND the height/shape of the flange.
With DC wheels the wheel falls down to the gap in the turnout fork, because the flange is very low. For that reason having narrower flange width will cause the wheels to pilot themselves over the gap without derailing. I guess this is not true for Märklin flanges that do not fall in to the gap.
However on every Märklin loco I have, the inner width seems to be 13,8mm…
I’d say it’s still worth trying if having issues. There’s a great tool for it: https://www.fohrmann.com/en/rail-gauge-h0.html
Also taking out the middle wheel set could take away the issue, but would obviously introduce other visual issues 😅
-Eino
thanks 1 user liked this useful post by einotuominen
Offline blid
#18 Posted : 11 November 2023 11:37:09(UTC)
blid
Bigdaddy,
Just curious. Do you have lanterns on your turnouts?
My MTH 3-rail only passed the lanterns on slim turnouts.
#19 Posted : 12 November 2023 21:46:39(UTC)
On my layout I do, but not on my carpetbahn test track.
I ran the loco on my layout for a bit, but this wasn't very successful but only because the layout hadn't been used for some time and some dead spots were encountered. I rescued the ES44 before it disappeared into an area not easily reached, but the loco did not have any point issues on the turnouts it did go over including ones with lanterns. I did notice that because of the locos length there was limited clearance for catenary masts, but at no time did it hit any masts.
#20 Posted : 20 November 2023 09:35:29(UTC)
Finally i find the time to run the loco,i had no problem running her forward or backward via turnouts 24611,24612 and 24620 i have to my layout.The loco running perfect to all speeds and have brilliant sounds.The only thing i have to do is to set accelaration delay and breaking delay the way it fits to my layout.ThumpUp
thanks 5 users liked this useful post by foumaro
#21 Posted : 20 November 2023 09:57:35(UTC)
Originally Posted by: blid Go to Quoted Post
Bigdaddy,
I ran a friend's MTH ES44 loco to my layout.The loco broke the lanterns on 24612 and 24611 turnouts when i do not ran her straight.
Offline vmsysprog
#22 Posted : 21 November 2023 01:00:19(UTC)
vmsysprog
I’ve had problems with switches/points that have the lantern kits installed. A low riding locomotive or rolling stock with come in contact with the lantern to the point of causing a derailment.
Steve
thanks 3 users liked this useful post by vmsysprog
Offline klarinettmeister
#23 Posted : 22 November 2023 10:02:38(UTC)
klarinettmeister
Hi all!
There are alot of negative posts about these models.
I received my 38441 the other day. I've only tried it this morning and found out that my unit gets stuck in a normal R2 K track right hand turnout. It only gets stuck riding the cab front to the turnout and running on the switched track. The surface isn't perfect supported. I will investigate but I have a guess that it's the pick-up shoe getting stuck in the rail. Maybe it's too much tension in the pick-up shoe.
It works fine when turning the loco running backwards and no problems at the other right-hand switch.
It works perfectly on my K track slim turnouts, even 4-way. I will do more testing.
The same setup with perfect flatness and also next step is with lanterns and also catenary.
The model is huge compared to German models. It's almost as long as the Big Boy without the tender and the front.
In the picture attached with the normal R2 turnouts is the switch in the middle that the loco gets stuck at.
thanks 3 users liked this useful post by klarinettmeister
#24 Posted : 22 November 2023 10:21:00(UTC)
We had a 38440 at the club meeting yesterday. It worked fine on two slim C track turnouts, but had short circuits most of the time on a third slim C track turnout. Exact cause not yet found.
Not my loco, so cannot investigate further.
The loco really looks big when it stands next to a Flying Scotsman.
#25 Posted : 22 November 2023 13:20:25(UTC)
These running issues are horrible! Is it possible the wheel flanges are too shallow for C track, and or the wheel diameter? There are two or three different ho rail profiles.
#26 Posted : 22 November 2023 14:31:08(UTC)
The issue we saw at our club meeting was most likely caused by a short circuit between centre-rail slider and the crossing outer rail. On slim C track turnouts, those crossing rails are powered and the height difference between rail and pukos is fractions of a millimetre.
If the centre-rail slider slightly tilts to the left or right, it can touch the rail.
Some sliders have plastic bars left and right to prevent that.
Online Bill L
#27 Posted : 01 December 2023 04:28:34(UTC)
Bill L
I just received my 38440 yesterday. It is very heavy and has a lot of fragile plastic details. I am afraid I will break some of these details down the road. Actually when I opened the box and took the lok out, a very very small piece of grey plastic something fell out. Still have not figured out where it dropped off from.
Here is the more important question:
I am having trouble running it on my metal M track where it loses power and stops on my 5207 double slip switches when running at slow speeds. Not sure if the wheel lost electrical power or the center pickup shoe lost contact with the center studs. Bending the shoe up or down does not seem to help.
Anyone have this issue and know how to correct it. Thanks.
thanks 1 user liked this useful post by Bill L
#28 Posted : 01 December 2023 08:07:15(UTC)
I've had 38440 for several weeks now, and 38441 arrived yesterday.
I've ran 38440 around a friend's layout which has many turnouts and curved turnouts and the loco ran with no problems. Two weeks ago we had our Railex exhibition to which we took our Club's H0 modular layout. Unfortunately the loco didn't get very far around the layout but not because of track issues but because someone built a module with a low hanging arch bridge (a non Marklin one) which the loco could not get through through being too tall for the bridge!
It was relegated to yard duties driving between a storage yard and turntable module, which consists of lots of turnouts and a few 3 way turnouts. It traversed everything fine all weekend with no issues.
Shot of the yard part of the layout
thanks 6 users liked this useful post by Bigdaddynz
#29 Posted : 01 December 2023 10:26:15(UTC)
Perfect locomotive,now we are waiting for the 18 car hopper combo by the end of the year.Love LOL ThumpUp
#30 Posted : 01 December 2023 12:17:11(UTC)
Big Daddy, your club layout is mainly wide sweeping curves. As for small plastic parts, Roco was the predominant brand before. Why even attach them to only be lost? With Marklin, it was mostly a buffer,or a little tow hook mounted behind the coupler on the buffer beam.
Offline dickinsonj
#31 Posted : 26 January 2024 03:09:55(UTC)
I am bumping this thread to see if there is any more feedback on how well these locos track.
I talked myself out of getting them initially due to the BLI design. My BLI derived UP 844 does not track nearly as well as my Big Boys or Challengers, so that was a red flag for me. I understand why Marklin would want to save development costs by buying the design from BLI, but these locos were not designed to run on Marklin track and have just been adapted for that use.
Just recently I have been reconsidering them but this thread reminds me of why I held back earlier. Two ES44AC locos and that hopper set would not be inexpensive and if they don't run well I would be very, very disappointed.
So after more track time, have the problems been sorted out or are they still causing problems?
Online Bill L
#32 Posted : 30 January 2024 05:40:00(UTC)
Bill L
Jim:
My 38440 can only run on K track.
It cannot run on my metal M track. Loses power on the 5207 double slip switches, and sometimes when I push it, it starts to run, and sometimes derails also.
For K track, I do not use the 2210 small curves on my layout. I do not use the curved turnouts 2267. Removed them from my layout years ago, due to lots of derailing.
Do not use the 3-way turnouts due to problems with derailing.
I do use the high speed turnouts 2271 everywhere else, and they work fine for the 38440.
Please note that I also have the ALCO PA (also 6 axles) made in the early 2000s and they run fine on my metal M tracks due to older type wheel flanges (similar to those in the 3015 crocodile wheel flanges). These do not derail and the larger diameter wheel flanges can pick up the wheel current on the M 5207 double slip switches, and runs right through them.
So I only run the 38440 on my K track. I do not have any C track on my layout. They were commercialized after my layout had already been mostly completed.
#33 Posted : 30 January 2024 06:33:46(UTC)
einotuominen
How about changing the wheels to ones with bigger flange? What is the diameter of the axle? 🤔
-Eino
Offline dickinsonj
#34 Posted : 30 January 2024 14:25:53(UTC)
Thanks for your feedback Bill. ThumpUp
I am just about to start a new layout and I think that most of the mainlines will be K track, so that is good to know. I have a large amount of C track however which I will be using in less visible areas, so I am also concerned about how these run on C track. I already have issues with some locos on C track turnouts and I really don't want to add any additional problems locos. Most of those problems are slider related and derailments are rare except in those tricky three ways!
I also have an Alco PA loco that is lovely to look at but amazingly noisy, and It does fine running through most of my turnouts. It would be interesting to know if the tracking issues stem from the difference is the wheel flanges, or something about the basic design, which was not made for Marklin track.
Offline Grand trunk
#35 Posted : 30 January 2024 15:32:44(UTC)
Grand trunk
The problem I had with the 38441 is that the front coupler is too low it get caugh in turnout, which had it change lane each time it pass a turnout.
thanks 1 user liked this useful post by Grand trunk
#36 Posted : 30 January 2024 16:12:51(UTC)
I think it depends too on the ramp approach grades. The Vectrons seem to have a lower coupler too.
Offline dickinsonj
#37 Posted : 30 January 2024 16:58:09(UTC)
Is that with the knuckle coupler, the Marklin coupler, or both?
Online Bill L
#38 Posted : 30 January 2024 21:00:28(UTC)
Bill L
Responding to Eino in post #33.
I would love to change the wheels. If someone would post the step-by-step instructions as to how to disassemble the wheel assembly to get the axles/wheels out, that would be greatly appreciated.
This model was not designed by Marklin and I do not know which screws to unscrew. There are a lot of screws, and some are covered by the easily breakable plastic detailing parts, and even when the locomotive is placed upside down on a sponge, I am afraid I will break the plastic details on the sides of the lok. This lok is extremely heavy.
thanks 2 users liked this useful post by Bill L
#39 Posted : 30 January 2024 22:48:38(UTC)
I don't think the issue here is Broadway Limited's fault, I have several of their newer-design locomotives and they have given me less trouble than recent Marklin has...
Points to consider:
Standard Marklin turnouts use R2 for the curved arm/element, which is 17 1/4". A Broadway Limited ES44AC has a minimum radius of 18". That is likely (but not objectively) related to the issues you guys are having, in particular in areas involving multiple curves or S curves surrounding the switch/point of trouble. Or S curves and other problem points of regular R1 & 2 trackage in general...
K track is code 100 rail, that shouldn't be an issue, and actually help with the center pickup and slider clearance. C track, however is less. For C (and for K on the "raised" pukos of switches), I'd check slider compression anywhere that is causing the loco to derail. I have to wonder if the slider is "bottoming out" of clearance on these. I can easily see this being an issue if marklin cut a corner on (locomotive) R&D....
Just ideas, but with logic behind them. I saw these locomotives in real life at the Amhearst Model RR show last weekend, they look great! (and no issues running on the factory display layout...)
Edited by user 29 February 2024 19:29:34(UTC)  | Reason: Not specified
#40 Posted : 31 January 2024 11:21:29(UTC)
einotuominen
Posts #10 and #13 show the bogies opened.
Thou the axle would have to be of the same diameter as the usual Märklin high flanged wheels. The wheels would also have to be of the same diameter in order to fit in to the plastic detailing like brake shoes etc.
The job itself is not a difficult one and all the tools are available from https://www.fohrmann.com/en/ with very affordable pricing.
-Eino
#41 Posted : 31 January 2024 12:37:14(UTC)
I've been experimenting with different wheels for some cars that derail frequently. I have C track, and it hasn't made much difference. I wonder if trains derail less with K track? A Swiss modeler built a huge layout with K track and says he wouldn't use it again, but rather Roco track because of appearance. He has recreated the entire BLS route. Personally I think K track looks great.
Note that Roco has both code 83 and code 100 rail profile,or at least they did.
I think that Marklin designed the C turnouts in particular to operate well over appearance and are durable. The puko studs are higher than the adjoining tracks. I realize that a certain tolerance is required for good operation but I don't think it is optimal for some cars or locomotives.
#42 Posted : 31 January 2024 18:31:06(UTC)
There is no question that C-Track is way more precise and up-to present day standards.
With a "normal" C-track (not broken, aging track) most of the derailments are caused by things no related to the track.
Here are possible causes:
- incorrect wheel spacing (the track is made for an interflange spacing of 14.0 to 14.2 mm. DC standard call for 14.4 mm which may be the upper limit for Märklin frogs/counter rails
- fine-scale wheels with a narrower rolling surface and smaller flanges may case them to "fall" into the frogs
- stuck mechanism for close coupling: this seldom appears on Märklin goods wagons but is not seldom with long Märklin coaches with provision for surrent-conducting couplers
- track not laid on a flat surface (sometime just a little "hill" or a little "valley" allows couplers to be caught on switches / crossing elevated studs
Online Bill L
#43 Posted : 16 November 2024 03:35:04(UTC)
Bill L
Success in running with no hesitation of my ES44AC on my metal M track. Here is what I did to my ES44AC to modify and make it run well now on all my Metal M tracks including the 5207 double slip switches (see my posts 27 and 32), where it would lose power pickup from the wheels. I finally found some time to take it apart and see what I can do to improve it. (see posts 33 and 40 by Eino).
Loosen 6 small philips screws to remove the shell. The instruction pamphlet that comes in the box shows the picture. I was disappointed that this body shell is made of plastic and not metal. Removing the body ensures you do not break any of the plastic details when working with it. Put the chassis upside down on a piece of soft sponge.
Remove the bottom tension bracket (see post #10) with a sharp screwdriver to push it off. (Not a Marklin design, Marklin would have designed and used philips screws).
Found out only 2 of the 3 axles in each bogie are geared. If counting from the front, it is the axles #1 and #3. Wheels on axle #3 have tires. Axle #2 is not geared and no tires. Important to see 2 very small coiled springs in the PLASTIC bogie that rub against this axle #2. So good grounding is done with this axle only thru the metal springs. Using my meter I found the 2 coiled springs are electrically connected to the motor shaft in the bogie and is the GROUND power for the whole lok and decoder. So for the whole locomotive, if the axles #2 and #5 (in second bogie) lose power, the lok stops dead- no electrical power. The 2 bogies, and gears are all plastic. Axles #1, 3, 4, 6 do not pass current to the decoder/ground.
So I was lucky in my box of cannibilized motor parts, I have the axle/wheels from my broken ALCO New York Central (make by Marklin in the early year 2001 and that it runs well on metal M track. So with luck, the axle diameter are the same, and metal wheels can be used to replace the ES44AC and I did that. You need a good gear/wheel puller to do this. It is brand Mascot. I also have an old COX slot car gear puller and pusher that is also helpful. I changed the wheels for axles #1, 2, 3, 5, 6. Used the original axles. I think just changing wheels in axle #2 and #5 axles may have been enough.
If you compare the wheels, the flange diameter for the wheels from the ALCO and ES44AC are the same. BUT, the wheel diameter (that runs on and touches the rail) in the ALCO wheels is just a very slightly smaller. So the wheel flange is able to dig deeper and touch the shiny silver metal conductors at the bottom of the 5207 double slip switches. Very happy now, can now run this lok at extremely slow speed on my metal M track (half my layout is M track, other half is all K track, I have no C track).
Correction: Nov25-2024
1) After all the parts were put back together again, I checked using the meter, and found out all 6 axles/wheels are grounded. So there is some metal piece in the bogie that conducts current to all the 6 axles. That is good.
2) After closer examination, I found out the body/shell is made of metal. It is thin, actually very thin, though, and very light weight, and that is what made me to believe the shell was plastic initially. Most other Marklin body shells weigh heavy when you hold them, but this one is light weight.
So this is a good running lok, and I am happy the way it runs now.
Edited by user 26 November 2024 04:18:20(UTC)  | Reason: made corrections
thanks 5 users liked this useful post by Bill L
#44 Posted : 16 November 2024 07:36:01(UTC)
einotuominen
Good job!
-Eino
Guest (11)
This page was generated in 1.062 seconds.
