Offline EMD_645
#1 Posted : 26 July 2024 14:03:06(UTC)
EMD_645
Views messages in topic : 25
Hi guys!
On a recent trip to my local hobby shop I picked up a used Br 64, 39646. It was only about 130 euros and showed only moderate use. So I thought, why not?
After some tinkering with CV values, some cleaning up of the excess oil that the previous owner had bestowed upon it and a good run on a temporary oval track. I got it to run pretty good for a 14 year old loco. The running characteristics must have been extremely good at the time.
However, the itch to put a modern ESU loksound decoder into this beautiful loco is getting stronger and stronger. But before committing i’d like to hear if there is any problems you know of when doing the conversion? What should I consider? The C-sine armature is a bit different from a normal DC-motor.
Kind regards!
Emil
thanks 1 user liked this useful post by EMD_645
#2 Posted : 26 July 2024 14:48:25(UTC)
Hi Emil
A true Märklinist would NEVER replace the decoder with a non- Märklin one.
I have 10 SDS / CSine, / Normal sine locos and they all run fantastic.
One of these (an Electric SNCF CC40108) loco with its gorgeous passenger cars was factory-fitted with a cheap probably chinese sound module that gave way.
So I replaced it with an MSD3, programmed the sounds using Märklin sound project, the CS3, not forgetting to change the motor type et voilà!
Now I have all the sounds, and it still runs great.
ESU MFX decoders are half made (you cannot edit the MFX variables unless going through DCC) and you MUST have a Lokprogrammer.
My BR64 with an SDS runs well, here it is on my marshalling yard
You must be very carefull working on SDS locos as I had a failure on my SDS Schienenbus probably due to electrostatic. Märklin repaired it at the time but not anymore
#3 Posted : 26 July 2024 15:04:25(UTC)
Would an ESU decoder even operate a drum style C-sine motor? Did ESU ever use one?
#4 Posted : 26 July 2024 15:47:24(UTC)
Originally Posted by: EMD_645 Go to Quoted Post
Hi guys!
Kind regards!
Emil
It is possible but there are problem about Märklins PCB.
It means if you shall use ESU decoder you have to set parametres and be careful to start program.
In fact you do make sense if you have ESU lokprogrammer too.
Be attention to switch BEMF off at CV 49 adress before you start program.
Offline EMD_645
#5 Posted : 26 July 2024 16:36:13(UTC)
EMD_645
Hi Emil
Thanks Jean!
I´d lie if I said I was a true Märklinist...I run everything I like, both DC and AC. BigGrin But I love the Märklin brand and the feeling I get from their product. Their trains are always solid and most of the time they run perfectly just as they come out the box. Some CV setting-work to fit your preferences and you are good to go. The command-stations are also impressive. Especially the Mobile Station. With the latest update it´s become such a competent tool for controlling your layout. Seeing what you get, I´d also say most Märklin products are good value for money compared to many offerings from other manufacturers.
The suggestion to go with the MSD3 decoder is really interesting. I´ve been wanting to try the Märklin decoders and see what possibilites they can give. I have the ESU lokprogrammer and quite alot of experience with the ESU-Ecosystem. But I have never tried those decoders in a loco with C-sine armature. Hence, my question. Razz
Yep, they can. They use AUX 3 And AUX 4 as additional controls for the complex electronics of the C-sine motors. Thats why there is Loksound MKL and Lokpilot MKL decoders with "amplified"
Aux 3 and 4.
Thanks! Have you tried this yourself? Did the new decoder improve running?
I have the Lokprogrammer and feel comfortable using it. Smile
#6 Posted : 26 July 2024 19:11:02(UTC)
Aux 3 and 4.
It's the other way around: If a C-Sine locos needs AUX3 or AUX4, then the MKL version of the ESU decoders cannot be used.
No ESU decoder ever controlled a C-Sine motor directly.
No Märklin mfx decoder ever controlled a C-Sine motor directly.
If the loco has a 21MTC socket, then both ESU decoders and Märklin decoders can be used. Just check which configuration is required for AUX 3 and AUX 4. MSD/3 has CVs for that, MSD was made in two different versions - regular and special.
Offline EMD_645
#7 Posted : 26 July 2024 19:19:29(UTC)
EMD_645
Aux 3 and 4.
If the loco has a 21MTC jsocket, then both ESU decoders and Märklin decoders can be used. Just check which configuration is required for AUX 3 and AUX 4. MSD/3 has CVs for that, MSD was made in two different versions - regular and special.
Thanks for the correction!
The Lokprogrammer has ”automated” much of the CV-setting for the C-sine motor. If you choose the preset for C-Sine in the ”motor-menu” it changes all the neccessary motor-CV’s. Then you change the function mapping for: Stop,Forward, Stop, Reverse, Drive, Forward and Drive, Reverse to always use Aux 3 and Aux 4.
#8 Posted : 26 July 2024 21:40:29(UTC)
It will in the Br64, as the Br3964x series locos had a seperate driver for the C-Sine motor that is driven by a standard 21 pin decoder.
In actual fact the decoder in the loco is probably an ESU one that ESU was providing to Marklin for the earliest versions of this series. The 39646 may be late enough that Marklin had moved to their own decoders, but I don't have the timeline handy to check this.
Offline EMD_645
#9 Posted : 26 July 2024 21:47:32(UTC)
EMD_645
It will in the Br64, as the Bre3964x series locos had a seperate driver for the C-Sine motor that is driven by a standard 21 pin decoder.
Hopefully I can tinker a bit with this tomorrow. I’ll read out CV 8 of the decoder in the loco. If the value is 151, then we know that it’s an ESU. 😜 I’ll post my findings here.
The loco is made in 2010 according to the Märklin archives.
Offline jonas_sthlm
#10 Posted : 27 July 2024 08:50:33(UTC)
jonas_sthlm
Remember that all engines like 441 002-3 HR "Croft" Art. 39894 doesn't us both AUX3 and AUX4 for C-Sinus motor....
This one has its High beam light on AUX3 and C-Sinus only on AUX4... original assembled decoder was LP V.3.0 M4 21MTC with sound modul in the old good days Huh
Decoder: Märklin mSD3 21MTC Art. 60975 (sound project M39867_BR189-RRF.mdtp)
Speaker: Märklin 20mm 100 ohm Art. E100622
thanks 2 users liked this useful post by jonas_sthlm
Offline PeFu
#11 Posted : 27 July 2024 09:24:57(UTC)
PeFu
If there is enough space in the engine, you could also consider to install an additional decoder, an ESU Loksound 5 Fx, and a speaker. This decoder has no motor outputs, but when configured using the same address and protocol (MM/DCC/Mfx) as the origin decoder, it will provide sound. Of course, running capabilities will not be changed.
?si=KS01Hj-lvtdf2YjH
thanks 2 users liked this useful post by PeFu
Offline EMD_645
#12 Posted : 27 July 2024 10:06:19(UTC)
EMD_645
Thanks! I do have a Loksound 5 - 21 MTC already though. So I’ll try this first before buying anything else. I also kind of think that using a newer decoder HAS to improve the running characteristics. Even if they are good. The smoothness of the start-up and running at low speed could use some improvement. It judders a bit more than I’d like.
Even if the signal has to pass through the driver. 14 years of development will probably yield some difference. Like Jonas wrote in his post. If the factory installed Märklin-decoder in the loco is made OEM by ESU, it’s probably similar to the ”Kastrat-LoPi” that Roco used at the time. And those are technically similar to a simplified Lokpilot 3. You can’t compare the technology in these to a v.5 decoder when it comes to motor control etc.
Offline EMD_645
#13 Posted : 28 July 2024 18:17:03(UTC)
EMD_645
So, I’ve spent some time today tinkering with this. Unfortunately I managed to get the wires for the speaker damaged when reassembling the loco, this shorted out the decoder and I suspect, fried the sound module of my only MKL decoder. The loco runs, but no sound.Glare
The lokprogrammer reports that the sound memory of the decoder is (- - -) not 128 MB as it should and the bar showing how much sound memory you have left is marked red.
So….yeah. Fried…ThumbDown
Much of why i tinker with this is to learn. And something I’ve found out is that the C-sine motors require a MKL decoder with powered Aux 3 and 4 to work.
A ”regular” DCC decoder can’t drive the motor even if the loco has an MTC 21 interface. The sound will work but the motor won’t react. Even if the CV settings are identical to that of a MKL decoder. I have tried several regular DCC Loksound decoders I have. The results were the same with all of them.
A new MKL decoder is ordered and hopefully with me in a few days time. ThumpUp
Even if the sound did´nt work on my only MKL decoder. The drive module still does. And boy does it drive that little loco. Even if it´s good with the factory decoder you really can´t compare to this.
I have a number of locos with Maxon motors and I´d say the performance of the C-sine when driven by the Loksound 5 is very close to these. Unbelievably smooth and in speedstep 1 it´s barely moving, I really mean barely. Like, 1 cm takes 6-7 seconds to move. It´s also pretty judder-free compared to before. The only thing I miss (being used to DCC and DC-motors) is the ability to work with the PID-regulation to dial out the last kinks. But for a 14 year old loco I really can´t fault it. I´m very happy! BigGrin
As for the factory decoder. It´s very much the same one suggested by Jonas in a previous post. Lokpilot v. 3.0 M4. See the image below.
To be continued...Smile
Offline PeFu
#14 Posted : 28 July 2024 20:23:36(UTC)
PeFu
A Softdrive Sinus motor (which it seems as if you have) can be controlled e.g. with an ESU decoder, an example to be found in this posting:
https://www.marklin-user...ecoder-issues#post561035
(The Lokpilot decoder was later replaced by a Loksound with the same CV settings.)
Offline EMD_645
#15 Posted : 28 July 2024 20:29:43(UTC)
EMD_645
It definitely can PeFu. I have been using a (slightly damaged) Loksound decoder to run my 39646 today. To work as intended though, it has to be a special version of the ESU Decoder called MKL (as in Märklin). Any Lokpilot or Loksound does’nt work unfortunately.
Offline jonas_sthlm
#16 Posted : 28 July 2024 22:40:13(UTC)
jonas_sthlm
Yes its need to have logic output or use mSD3 then you can decide... so in the old days M4 and now MKL.
I am using AUX3 for cabin light and on some other T44 telex....
Remember the both side telex needs to be connected in series on AUX3.
thanks 3 users liked this useful post by jonas_sthlm
#17 Posted : 29 July 2024 12:43:02(UTC)
As I wrote before: the non-MKL version has the logic outputs.
Yep, that's right.
But in the case of a C Sine motor, the motor control of the decoder is disabled, so there should be no difference between v3 and v5 when it comes to motor control.
Sound is better, light functions have been improved - but motor control stays the same.
Offline EMD_645
#18 Posted : 29 July 2024 13:58:48(UTC)
EMD_645
Yep, that's right.
Not sure if we’re writing past each other here. But a
”normal” non-mkl decoder in my experience cannot drive the C-sine motor. The sound will play but the motor won’t move. I’ve tried this.
As for the running, I beg to differ. There is a definite difference between using the factory v.3.0 and the new v.5. It’s like night and day. The v.5 is ALOT smoother.
#19 Posted : 29 July 2024 14:49:32(UTC)
You are correct for a standard motor, but the motor control for a C-Sine is done on a separate board, the decoder just tells it the speed to go and it does the rest. The motor control PID in the decoder has no effect on the C-Sine because that is all done in the separate board.
Offline EMD_645
#20 Posted : 29 July 2024 14:59:42(UTC)
EMD_645
Yes, I know this Alan. But I can also tell that there is a definite difference in how it runs. I’m not sure exactly why and how this works. But the newer decoder is alot smoother. The v.3.0 was juddering alot if you lowered Vmin too much. With the V5 you can lower CV2 to 1 and still have judder-free super slow running. If you put Vmin to 1 with the v.3.0 it would’nt move.
If someone that is knowledgeable about the inner workings of the ESU-decoder in regards to running the 3-phase C-sine motor is reading this. Please share how it works with us. Smile
Offline bph
#21 Posted : 29 July 2024 16:03:52(UTC)
Yep, that's right.
sorry to say, but it seems like you have it the wrong way. the SDS sine motor controller needs AUX 3/4 on logic level voltage. I guess that when you activated the sine motor in the programmer the ESU software put the AUX 3/4 on logic level automatically?. if you are actually using amplified aux 3/4 you risk blowing the sine controller. so I strongly recommend that you check the AUX 3/4 and make sure they are set to logic level.
This is described in both Marklin and ESU decoder manuals.
(if the board e.g only needs AUX 4 on logic level voltage the other aux is free to be used on other things as mentioned by others above)
ang e.g. Lippe simply says the MKL decoder is Not suitable for:- all Softdrive sine motors https://www.modellbahnshop-lippe.com/Digital/Decoder+with+sound/ESU%2D58449/gb/modell_311386.html
When replacing older decoders with new it's also recommended to check the speaker, as older speakers are often 100 Ohms. If it is 100 Ohm, you need to replace it with an 8 or 4 Ohm speaker.
Offline EMD_645
#22 Posted : 29 July 2024 16:41:33(UTC)
EMD_645
Yep, that's right.
Thanks bph!
I am no expert. And will gladly stand corrected. A few minutes ago I got a delivery notice for the new decoder. I think it will be with me on Wednesday.
Hopefully I can get it into the loco then. And we´ll know. Smile
Regarding logic and Aux 3 and 4. I set them to be logic functions under "function mapping" with the Lokprogrammer and active as this in the following states:
Stop,Forward - Stop, Reverse - Drive, Forward and Drive, Reverse. So hopefully the Sine controller is safe. Wink
For anyone interested. The following CV´s are the ones that you change to use an ESU v.5 Decoder with the C-sine motors:
CV 2 = 3
CV 9 = 40
CV 51 10
CV 52 = 10
CV 53 = 130
CV 54 = 50
CV 55 = 100
CV 56 = 255
CV 116 = 50
CV 117 = 80
CV 118 = 15
CV 119 = 20
CV 31= 16
CV 32 = 2
CV 257 = 48
CV 273 = 48
CV 289 = 48
CV 305 = 48
CV 49 = 0
CV 124 = 28
thanks 2 users liked this useful post by EMD_645
Offline bph
#23 Posted : 29 July 2024 17:09:38(UTC)
Yep, that's right.
Thanks bph!
I have also made my share of mistakes ;).
I'm no expert on ESU decoders, yes I have some but only use mSD3/mLD3 for retrofitting/upgrade.
But keep in mind that there is a difference between logic functions and AUX logic level voltage. So I don't know what CV's that control AUX logic level on ESU decoders.
Offline EMD_645
#24 Posted : 29 July 2024 17:19:59(UTC)
EMD_645
Yep, that's right.
Thanks bph!
The Lokprogrammer takes care of assigning AUX 3 and 4 as logic state AUX-es. So you don´t have to know the exact CV´s.
I have used an MKL decoder already with great success, so I guess I´ll be fine. We´ll see.
Thanks for getting involved! Much appreciated! BigGrin
#25 Posted : 29 July 2024 20:48:16(UTC)
The MKL decoders are wrong for C Sine locos that require AUX 3 or AUX 4 to be logic level. That's true for early C Sine models, but was no longer required for later models.
Certain C Sine locos cannot run with the MKL decoder variant, no matter how you set the CVs.
Offline EMD_645
#26 Posted : 29 July 2024 22:35:29(UTC)
EMD_645
OK, thanks! I´ve just ordered a "regular" MTC 21 decoder as well just to be sure. You can never have too many decoders...Razz
Offline jonas_sthlm
#27 Posted : 30 July 2024 08:57:24(UTC)
jonas_sthlm
Yes it's true with different variants of settings for individual models
39894 (2008/2009) 441 002-3 HR "Croft" - logic outputs needs even for AUX3 to get the high beam to work
37940 (2008/2009) T44 - needs only logic outputs on AUX4 and AUX3 is free to use
37941 (2009/2010) T44 - needs only logic outputs on AUX4 and AUX3 is free to use
37943 (2014/2015) T44 - needs only logic outputs on AUX4 and AUX3 is free to use (M replace PCB and motor after this model)
Perhaps there is a reason why they chose to make it possible to have different settings on the outputs in mSD3 decoders.
Its 14 years ago sense I replace my first T44 for ESU LS4 M4 but now all has got mSD3 decoder....
Offline EMD_645
#28 Posted : 30 July 2024 11:29:47(UTC)
EMD_645
Nice! Is that the ESU or the Jeco/Mj-Hobbyexperten T44 sound?
Offline jonas_sthlm
#29 Posted : 30 July 2024 12:13:57(UTC)
jonas_sthlm
It's ESU original sound project that also Jeco put inside their models.
Offline EMD_645
#30 Posted : 30 July 2024 12:36:06(UTC)
EMD_645
Thanks! Hopefully ESU will update this sound project soon. It’s getting a bit old. The T44 and T43 has a distinct EMD sound that is very unlike most other locos with EMD engines.
Offline EMD_645
#31 Posted : 01 August 2024 17:41:29(UTC)
EMD_645
Hi everyone,
The new decoder is now in the loco and it works beautifully. I´m very happy. I used the non-MKL decoder, the sound quality is good and the running is also a lot better.
As we´ve discussed, the decoder is running the loco without BEMF though. So the steam chuffs don´t sync with the wheels turning like it would on a loco with a traditional DC motor.
I’ll check if I can adjust this with the ”chuff-settings” in the Lokprogrammer.
Another remedy to fix this is fitting a hall sensor and magnets to one of the wheels. Any tips on fitting a sensor like this will be very much appreciated. One thing I´m thinking about is how close the sensor has to be to the magnet? Do they have to pass a special side of the sensor? Does polarity of the magnet make a difference or will the sensor react to the field regardless of polarity?
Thanks for all the help so far! BigGrin
#32 Posted : 02 August 2024 10:39:27(UTC)
Bryan
Dear All
I have been following this post with interest.
One thing I would like to know is, where is the driver board in using mSD/3 or latest ESU decoders. The main thing discussed is CV settings for C sine etc. There needs to be a driver board as well, ie inverter or a sine generator. A lot of Marklin C sine locos had an integral driver board with the decoder, not possible to seperate. Driver boards are no longer available from Marklin, however they do outsource C sine locos to be repaired.
David
Offline bph
#33 Posted : 02 August 2024 12:20:35(UTC)
Originally Posted by: Bryan Go to Quoted Post
Dear All
David
In the latest locomotives with SDS motors, the driver is located on the decoder board so replacing the decoder is possible, as long as you configure it properly.
In locomotives with the older original C-sine motor, the driver was often integrated with the decoder, so if broken, you need a new decoder and driver.
(note there are some variations, and remember to also check the Speaker ohm)
3'rd party C-sine drivers can be purchased from rail4you.ch
https://www.rail4you.ch/remotorisierung/dsm-2-0-der-treiber
(note that a power pack is often a "requirement")
Offline EMD_645
#34 Posted : 02 August 2024 13:01:02(UTC)
EMD_645
Dear All
David
Yep, you either have the early locos with a separate driver and the later ones with the driver integrated. I believe my Br 64, 39646. Was one of the last locos with the C-sine armature and these have a standard MTC-21 socket with the motor driver integrated in the circuit board.
I have made a quick Youtube clip from my kitchen table for those interested in seeing how the loco runs with the new decoder. Enjoy! :)
Edited by user 02 August 2024 22:39:01(UTC)  | Reason: Not specified
Offline Kiko
#35 Posted : 04 August 2024 04:58:25(UTC)
Kiko
Nice video! Congratulations on your success. Nice work.
I have a BR64 (39640), which also has the SoftDrive C-Sine motor and have been contemplating replacing that old MFX decoder with a LokSound 5. You have given me hope that this could be easily accomplished! If I understand correctly, you used a standard ESU LokSound 5 decoder (58419: "LokSound 5 DCC/MM/SX/M4 "blank decoder", 21MTC NEM6660") for your conversion. What "project" from the ESU website did you use as a starting point for your customization?
Thanks for sharing your learning process. Cheers,
Andry
Andry
thanks 1 user liked this useful post by Kiko
Offline EMD_645
#36 Posted : 04 August 2024 10:10:16(UTC)
EMD_645
I have a BR 64 (39640), which also has the SoftDrive C-Sine motor and have been contemplating replacing that old MFX decoder with a LokSound 5. You have given me hope that this could be easily accomplished! If I understand correctly, you used a standard ESU LokSound 5 decoder (58419: "LokSound 5 DCC/MM/SX/M4 "blank decoder", 21MTC NEM6660") for your conversion. What "project" from the ESU website did you use as a starting point for your customization?
Andry
Thanks Andy!
It´s a very easy conversion to put this decoder into the BR 64. Mostly just plug and play. After the advice I got from our friends here on the forum. I used the decoder that you specified in your post: Article no: 58419, which is a "regular" multiprotocol Loksound with logic AUX 3 and 4 and not powered Aux 3 and 4. This was used together with the sugarcube speaker that comes attached to the decoder using all of the plastic baffle parts included. It´s very easy to place the speaker on the floor of the drivers cabin with some double sided tape. Make sure that you do a cutout in the plastic part that make up the floor of the drivers cabin so that you can safely let the cables through though. I squeezed my speaker cables when reassembling the model the first time round, this created a short that damaged the decoder.
I used the project for the BR 64 that is available for download on the ESU homepage:
https://projects.esu.eu/...amp;type=all&q=br+64
You should also change the following CV´s:
CV 2 = 3
CV 9 = 40
CV 51 = 10
CV 52 = 10
CV 53 = 130
CV 54 = 50
CV 55 = 100
CV 56 = 255
CV 116 = 50
CV 117 = 80
CV 118 = 15
CV 119 = 20
CV 31= 16
CV 32 = 2
CV 257 = 48
CV 273 = 48
CV 289 = 48
CV 305 = 48
CV 49 = 0
CV 124 = 28
If you want to set the chuffing sound to match the wheel rotation like I did. You put the following values in the Lokprogrammer, controlling CV 57 and 58:
Distance of steam chuffs at speedstep 1 (CV 57) = 5,97 seconds
Adjustment at higher speedsteps (CV 58) = 60
Good luck with your project! Smile
Offline Kiko
#37 Posted : 04 August 2024 15:50:50(UTC)
Kiko
Thanks Andy!
Thank you so much for the quick reply. I appreciate the detailed explanation you provided -- it will make the conversion so much easier! Now I need to order a decoder.
Andry
Andry
Guest (15)
This page was generated in 1.012 seconds.
