Offline kokomo
#1 Posted : 30 September 2018 00:02:21(UTC)
kokomo
Argentina
Hi everybody!
I found out that one of my UIC-X passenger coaches has a missing coupler. I took a photo of the remaining one so as to try to get a spare part.
Any help identifying the type or model number?
thanks
Modeling Central European trains. Eras III, IV and V
Mostly UserPostedImage UserPostedImage UserPostedImage but can also get some French or Italian articles too
thanks 1 user liked this useful post by kokomo
#2 Posted : 30 September 2018 01:58:46(UTC)
I think we need more information if you want us to help you with your inquiry: what is the catalogue number of your carriage ?
regards.,
Offline kokomo
#3 Posted : 30 September 2018 02:06:34(UTC)
kokomo
Argentina
It is a TEE coach #4059, I guess. It has this specific type of coupler which I would like the type of name or #article
#4 Posted : 30 September 2018 12:16:24(UTC)
I don't think this coupler is from a 4059, which is a 24cm long tin-plate coach. It looks like a standard plastic 701570 coupler similar to this one:
Offline Markus Schild
#5 Posted : 30 September 2018 14:13:00(UTC)
Markus Schild
The couplers shown were used from the mid 1970s until the early 1980s at the 409X 27 cm cars. They are no longer available since decades. The number was 701620, but this is just academic knowledge.
Markus
#6 Posted : 30 September 2018 14:35:43(UTC)
The coupling similar to 44xx and 44xxx hobby series freight stock.
#7 Posted : 30 September 2018 14:49:49(UTC)
Markus Schild
No,
that is not the same coupler. That version above has longer arms than 701570 which is used on the 44XX series and many modern cars.
Markus
#8 Posted : 30 September 2018 15:47:34(UTC)
It's not the same coupler but couldn't a 701570 fit? The "spring" arms are shorter and might not be as effective but it might at least allow coupling with other coaches
Offline kokomo
#9 Posted : 30 September 2018 17:31:05(UTC)
kokomo
Argentina
Hello and thanks for all the fruitful and interesting responses.
My mistake. Indeed it was not a 4059 coach. I had it labeled under such erroneously it seems (which would be the proper number, 4095 perhaps?) but I do posses a real 4059 and it's a metallic one, and not plastic, as mentioned.
I enclose a couple of additional photos in case it's helpful.
If you can notice, I placed a Relex coupler on the right side of the coach to make a contrast how shorter it is.
thanks 2 users liked this useful post by kokomo
#10 Posted : 30 September 2018 18:34:35(UTC)
Markus Schild
Yes 4095 is the correct number for the coach shown. That coupler is a nice project to 3D-print. Give me some weeks and I will draw it and publish the files. I think that PLA is flexible enough to produce usable parts.
Markus
#11 Posted : 08 October 2018 09:22:25(UTC)
Markus Schild
I haven't forgotten this topic. This is the first concept for the coupler. Next will be finding the best material to print it and test the samples.
Markus
thanks 12 users liked this useful post by Markus Schild
Offline nick.r
#12 Posted : 01 February 2024 04:59:22(UTC)
nick.r
Markus
OMG!
I know I'm late to the party but do you have the STL by any chance? Those couplers are just impossible to find.
thanks 1 user liked this useful post by nick.r
Offline revmox
#13 Posted : 02 February 2024 05:45:25(UTC)
revmox
3D printing entire couplers is beyond my skill level so I just make NEM adapters that let me use stock Marklin couplings.
I couldn't get enough strength and precision in the small plastic parts for a reliable coupling that I would trust with my rolling stock.
Possibly some of the NEM adapters that I made for Startup rolling stock could be modified.
thanks 3 users liked this useful post by revmox
Offline seatrains
#14 Posted : 02 February 2024 05:48:47(UTC)
seatrains
All, not trying to hijack the thread, but what are the Marklin current conducting couplers for the 409X 27cm coaches?
Thanks in advance...
Thom
Offline mvd71
#15 Posted : 02 February 2024 07:45:31(UTC)
That would depend if your 27cm coach has close couplers or not.
#16 Posted : 02 February 2024 15:47:26(UTC)
#17 Posted : 02 February 2024 20:29:39(UTC)
There were two or three different couplings for the 4091-4099 coach models (DB Blue/Beige/TEE/IC). The original 27cm models had centre mounted bogies with a clip on relex coupler. Then there was the newer version of the coupling part from the period 1980-1984 and then, some models were delivered with offset mounted bogies and a shorter coupling part without the relex part. Finally, around 1985, the models were replaced by new models (4291-4298) with offset mounted bogies and close coupling mechanism and shaft with NEM coupler head.
To find these harder to find couplers, you can check with Ritter Restaurationen in Germany, possibly Eckert in USA and maybe Amiba in Switzerland.
I believe that if you can't find the oldest ones, you can install the intermediate ones as long as the pins are the same.
#18 Posted : 02 February 2024 20:35:00(UTC)
I would also suggest that with some coaches going for as little as 10 EUR on ebay, it is probably cheaper just to buy one of those and to repurpose the couplers or bogie and coupler to repair your model.
I might even have a spare pair here.
#19 Posted : 06 February 2024 17:54:06(UTC)
Originally Posted by: kokomo Go to Quoted Post
Hi everybody!
thanks
I have a spare set of bogies with couplers (newer version) from a 1980s TEE coach.
Corresponds to top image in photo of post #4 https://www.marklin-user...older-autotransportwagen
#20 Posted : 09 February 2024 02:23:00(UTC)
These are the spare bogies I have here (from a 4099):
This page was generated in 0.663 seconds.
