Online xxup
#1 Posted : 05 February 2022 03:13:20(UTC)
What are some of the options for attaching this track to the Noch Preformed layouts? Confused
#2 Posted : 05 February 2022 06:47:38(UTC)
Hi Adrian,
I was interested in your post.
Are you into Z track?
Philip
Online xxup
#3 Posted : 05 February 2022 09:59:03(UTC)
Ah no.. I bought FD a z scale Christmas start set and the Noch St Anton layout for Christmas after we realised we would not be able to set up the 1 Gauge set and the big tree last Christmas. We have the track and some tiny tiny pins that don't look like they will hold the track down properly.
#4 Posted : 06 February 2022 00:47:27(UTC)
ADrian, be v. Careful of the track pins, it is very easy to deform the track. ( I have the cap and tee shirt). Use PVA glue or Hot glue as both easy to take up. as easy to take up if needed
thanks 3 users liked this useful post by nevw
Offline zscalehobo
#5 Posted : 06 February 2022 08:44:51(UTC)
zscalehobo
Märklin 8999 track nails works fine into the foam layouts ... can also use Peter Post 08056 screws. Yes screws for Märklin z tracks.
Frank Daniels
Owner - z.scale.hobo
A Noch "Top Dealer"
Irvine, California, USA
www.zscalehobo.com
thanks 2 users liked this useful post by zscalehobo
Offline veloboldie
#6 Posted : 17 February 2022 00:12:53(UTC)
veloboldie
I used a pin vice to pre-drill holes and then pushed in the Marklin Z scale nails using tweezers to attach track to my Cortina layout. It was a painstaking and time consuming task.
Edited by user 21 March 2022 15:07:22(UTC)  | Reason: Not specified
thanks 1 user liked this useful post by veloboldie
Online xxup
#7 Posted : 04 March 2022 23:30:37(UTC)
Two hundred of the tiny tiny screws arrived on Thursday. I am on the hunt for a suitable screwdriver. I may already have one, but I would really like one with a sleeve.
I have a few house things to get done first and then I will resume the layout project for FD.
Offline hennabm
#8 Posted : 01 October 2022 21:31:29(UTC)
hennabm
Im also in the process of wondering how to secure the tracks. Having purchased some M nails, I too am not sure of their ability. Plus if I need to raise the track, a nail is not as easy to remove as a screw.
I’ve had a look at the small screws but can only find them in the USA. The packets containing the screws appear to be written in German, so is there a European supplier, or is the USA the sole provider?
Many thanks
1957 - 1985 era
What's digital?
#9 Posted : 01 October 2022 23:21:52(UTC)
Many thanks
Mike,
Have a look at Peco track pins. One Z scale layout I obtained used track pins to hold the track down. I think they were Peco ones. Instead of having a round head like a dressmaking pin these had the top bent sideways almost like a full size track nail. See https://peco-uk.com/products/track-fixing-pins for what I'm thinking of.
Offline Toosmall
#10 Posted : 02 October 2022 01:47:12(UTC)
Toosmall
The Marklin nail is 0.55mm x 8.5mm 1.25mm head ∅. The Peco nail is 0.60mm x 14mm 1.5mm head ∅.
The Peco nail head does look a touch large on the sleeper, but it is acceptable.
Pre push a nail through the sleeper hole with the sleeper pre warmed in your hand, as holes are a bit tight, or at least warm up a touch with hair dryer, you don't need to over do the heating. If you need holes in other sleepers pre-drill with 0.5mm drill bit in a pin vise.
Because the Peco nail is so long, if you need push it into a timber base you will need to pre-drill holes or you will end up bending a few nails & breaking sleepers getting them in. You don't need the nails in so tight like a masonry anchor.
You can cut them shorter, but file or Dremel a point.
P.S. What gradient do have at the back. If you raise all the track a bit, then lower the lower rear track to split the gradient between the upper and lower level. Any gradient more than 2.5% will give you headaches later on. Just avoid it like the plague.
Offline Toosmall
#11 Posted : 02 October 2022 05:35:56(UTC)
Toosmall
I noticed you are using the 8590 power feed track. They are ugly on a finished layout and one item that can be avoided. Unless you can hide them, solder wire on the rail. Use lead/tin solder, it's easier than tin only.
Offline Toosmall
#12 Posted : 02 October 2022 10:07:06(UTC)
Toosmall
Marklin nail left, Peco nail right.
I have a few old Marklin nails and they were 5.5mm long. Depending how tough the timer is, a 0.4mm pilot hole for the Marklin nail will help.
Also use a nail punch, trying to hit the nail directly will cause you not to hit it square.
Offline Toosmall
#13 Posted : 02 October 2022 10:16:41(UTC)
Toosmall
If you use the Marklin 7599 countersunk phillips head screws. Quite handy for fixing problems. They are 1.45mm ∅, so drill a pilot hole 1mm ∅ so you don't snap them off. Really hard timber say 1.2mm ∅ pilot hole.
Offline hennabm
#14 Posted : 02 October 2022 10:16:52(UTC)
hennabm
The gradient uses standard Marklin pillars at the moment and so ends up 40mm above the base. To get the height quickly the pillared are every 55mm (half straight). I have tested it with a Bo Bo electric and a 4-6-2 steamer and both climb it well. I plan to use only a rail bus or an engine and one thunder box up there as it is quite steep.
1957 - 1985 era
What's digital?
Offline Toosmall
#15 Posted : 02 October 2022 11:01:06(UTC)
Toosmall
Try a few carriages on the loco. Most people get a bit frustrated in the long run. Even massaging the track here and there can knock off a few gradient percentage points without too much effort.
Soldered power connections
This page was generated in 0.512 seconds.
