Offline Harlov
#1 Posted : 22 January 2022 20:24:32(UTC)
Harlov
I have a Faller Gantry crane 120162 that I want to control (remotely) the direction of rotation of the Faller gantry crane. The crane is designed for the Faller motor 180629 but would like to replace it with some type of motor and so that I can control the crane in both directions, the Faller 180629 can only be set manually through a mechanical rod built into the motor gear itself.
Did anyone try to replace the Faller 180629 with a stepper motor or a servo? Any other ideas and pictures would be grateful?
/ Peter
#2 Posted : 22 January 2022 23:46:41(UTC)
/ Peter
You could always work the reversing rod with a servo.
#3 Posted : 23 January 2022 14:51:07(UTC)
Hi Peter
You may find it easier to fit DC motors like the Faller 180722 https://www.faller.de/de/de/Prod...cm.at/Getriebemotor.html
I purchased mine in China for less than 5 Euros
Here is one https://www.ebay.de/itm/18439516...ef1be:g:k0EAAOSwYh5hwFie
Total length of 35 mm (including the axle), 4 mm Diameter axle, start rotating at 6 V, powerful
Unlike with a servo, you can use the motor axle directly to fit to the crane cabin.
With a servo you need to construct a solid and low friction axle for the cabin. Then all is simple but most servos are rotating only 90° with little torque.
Here is an example of the implementation on a bridge to stop and direct traffic on a Car System using 2 servos. Video of the underside of the bridge. Control using an ESU SwitchPilot 3 Servo
Offline Harlov
#4 Posted : 27 January 2022 14:45:27(UTC)
Harlov
Yes such an engine would fit well, the question is what speed to choose I thought in that case 20 rpm or lower rpm for rotation of the crane, i found Dc engine on Aliexpress
Hi Peter
How to control the Faller gantry crane 120162 (H0-scale)
by cgarlati 13/05/2008 05:06:53(UTC)
This page was generated in 0.377 seconds.
