Offline wally45
#1 Posted : 10 September 2020 14:26:05(UTC)
wally45
I have streamline loco with 60760 conversion chassis very quite, metal body makes ringing sound when fitted,be grateful for any suggestions Phil.
Offline mbarreto
#2 Posted : 10 September 2020 17:36:30(UTC)
mbarreto
Tthe description you made has very few content. A photo of the locomotive chassis (locomotive without the metal body) could help we understand what is wrong.
If you also have a diagram of the connections you made, it could be useful.
Miguel
Mostly Märklin H0.
#3 Posted : 10 September 2020 18:52:50(UTC)
I have a similar problem with this loco 3489 A streamlined BR 03 from the DRG. I have converted it with a 60760 kit
The loco runs very well but indeed, the metal casing acts like a bell to amplify the motor noise.
This is too bad as the loco looks very nice and I was considering to install a sound decoder in it but unless some of our friends comes with a suggestion to dampen the noise, it will stay like this.
Note: Yes I could set the sound to maximum volume but as I operate 31 sound locos at the same time it would be a cacophony (very un-attractive)
Please help
#4 Posted : 10 September 2020 20:11:06(UTC)
have you tried pushing some putty into places on the inside of the shell?
#5 Posted : 10 September 2020 20:57:11(UTC)
Thanks Dale
Have some specific putty in mind? What is it?
I believe I must be able to re-open the casing on occasions (lube the motor).
When I can go near my trains (my wife is very sick at the moment), I will otherwise try a thin layer of foam inserted around the casing guiding pins.
It probably will raise the casing by 0.5 to 1 mm just to try if it works (then I will lower the rest points.
May be your putty if it is special?
#6 Posted : 10 September 2020 21:04:25(UTC)
no specific putty in mind, but you could try plasticine, poster tack/presstick/blue tack and if that works, use an epoxy putty (Pratley's) . (Not sure what brands are available in France)
Hop your wife recovers soon.
#7 Posted : 10 September 2020 21:28:24(UTC)
Thanks Dale. I hope dearly too. She is my "preferred wife for more than 48 years.
When that happens I will do some tests and report
Offline Br502362
#8 Posted : 11 September 2020 08:49:44(UTC)
Br502362
#9 Posted : 11 September 2020 12:38:48(UTC)
Hi Åke
Sounds very encouraging. I will try it before installing an expensive sound decoder.
Thank you
Offline ausland
#10 Posted : 11 September 2020 15:24:24(UTC)
ausland
Many years ago I made my living stopping odd noises in cars. What you might try, and what you have to do is change the 'frequency' of the vibrating part, is putting a piece of adhesive foam tape, if there's room, near where the vibration is most prominent. Tape does not have to be large, perhaps 8-10 mm roughly square or round, but should be 2-3 mm thick. If this does not work, remove the tape and put it in a slightly different position.
Ausland
thanks 2 users liked this useful post by ausland
#11 Posted : 11 September 2020 15:57:01(UTC)
Hi Ausland
In this case the loco's metal body is shaped like a bell and is attached by one screw in the center with 2 resting surfaces:
- in front where the light conduit is
- at the rear (engineer's cabin) where the wires go to the tender
So I would try:
- to insert a dampening sheet on these resting places
- if this is not enough by inserting a plastic bar between the 2 sides of the body between 2 driving wheels (to stop the resonance)
Thanks to you all, you gave me great ideas
Offline ausland
#12 Posted : 11 September 2020 18:51:36(UTC)
ausland
Hi Ausland
So I would try:
I don't have that particular loco either here or in US, but the principle is to change the shape, internally, of the boiler housing, hence the sticky foam tape. It's also mayhap possible to secure the boiler housing a little stronger to the frame, if that will not affect the running characteristics of the machine, by inserting a soft shim between the housing and the frame. Doing that stops the vibration which produces the sound. I'd go with the sticky tape inside the boiler and if needs be move it's position around a bit. Nothing ventured, nothing gained.
Ausland
thanks 1 user liked this useful post by ausland
Offline DTaylor91
#13 Posted : 14 September 2020 00:19:26(UTC)
DTaylor91
I would like to add another material to play with: Thick, high density felt. I do a lot of work on high end audio equipment, and most good speakers are not hollow, but stuffed with poly fiber (as in pillow stuffing), or lined with foam, or high-density felt, or a combination of these materials. The idea is to break up the sound waves so that standing waves (resonance) cannot form inside the cabinet (Yes, this is simplified). High-density felt or foam is sometimes used around a speaker's tweeter to diffuse high frequency sound and keep odd high frequency reflections from bouncing off the baffle, or front surface. If you can find something similar to piano felt, that would do nicely. It comes in strips, and sometimes can be found with self-adhesive backing.
As an aside, when I got my 37082, a BR 10, I was not happy with the timbre of the sound, it was too hollow and "plastic-y", so I stuffed the top of the tender with some speaker stuffing from an old, sadly dead Bang & Olufsen speaker, and it made the sound much more tolerable.
thanks 2 users liked this useful post by DTaylor91
#14 Posted : 14 September 2020 13:16:31(UTC)
Thats a thought, I was most disappointed with the sound on my Insider Br95 from a few years back. it sounds like the microphone was at the other end of a tube. Maybe I should raid my wifes batting that she uses for quilting and put some of that in the loco.
Offline wally45
#15 Posted : 20 September 2020 21:13:23(UTC)
wally45
Many thanks to everyone for your help regarding noisy Streamline 01 PhilBigGrin
Offline wally45
#16 Posted : 04 December 2020 19:29:24(UTC)
wally45
Further to my post on noisy streamline loco, i put some sticky sound deadening strip in the body which reduced the noise a little. On looking at the loco it appeared that the suppressor connecting both motor terminals was touching the body, repositioned it hey presto much better. Phil.
thanks 1 user liked this useful post by wally45
Offline Michael4
#17 Posted : 04 December 2020 23:40:57(UTC)
Michael4
Guest (4)
Vintage Streamline Locomotives- Which one is best? (H0-scale)
by Philipj 24/11/2024 18:05:24(UTC)
German Streamline Locomotive Class 05 002 (Pre WWII) (Prototype)
by ShannonN 21/04/2018 17:44:19(UTC)
This page was generated in 0.458 seconds.
