#1 Posted : 26 February 2020 12:21:07(UTC)
I want to repaint some older Märklin locos;
For example;
1. A very old metal BR141/E41 From blue/beige to blue epoch III.
2. Plastic akku-treibwagen BR515 from blue/beige to red epoch III.
I have never done anything like this, although I am getting quite handy with the airbrush and painting in general...
Questions;
1. Can I strip the old paint with brake-fluid and a toothbrush?
2. Is it necessary to strip the paint from plastic-models? (is brake-fluid OK for plastic?)
3. Is "satinated" the right surface-finish for the job?
4. Where can I buy all the needed decals to apply after painting?
5. Would it be worth the effort (is it at all feasable???) to try to repaint a V200, with its5detailed V-shaped decorations?
Offline thing fish
#2 Posted : 26 February 2020 13:26:35(UTC)
thing fish
Turkey
Questions;
1) Brake fluid is NO GO! You'll ruin the plastic.
2) Better to strip ... no brake fluid, you can find paint removers that won't ruin plastic.
3) Satin finish is my favorite but up to your liking.
4) I don't know but if you're up to it you can make them yourself. Search internet; there is a product called "liquid decal film".
5) Feasible, imo worth it ... I've done the V200 twice and I'm very happy with the results.
C.
thanks 3 users liked this useful post by thing fish
#3 Posted : 26 February 2020 13:38:44(UTC)
So the brake fluid is OK for the metal-shells?
Can I see a photo of your V200 jobs, please?
Offline thing fish
#4 Posted : 27 February 2020 12:25:28(UTC)
thing fish
Turkey
Yes, brake fluid is ok on metal.
I'll post photos of the one I still have, the other one painted to blue-beige livery I sold some time ago and unfortunately I don't have photos of it - maybe I have but have to search my archives.
Best,
C.
thanks 2 users liked this useful post by thing fish
#5 Posted : 27 February 2020 12:51:21(UTC)
Thanks Thing Fish!
Guys, I still need help with what product to buy for stripping plastic shells, and some some names/adresses for getting the decals.
I know of course how to use Google, but it would be nice with some verified OKAY names and brands to start out with!
Thing fish; The V200 is especially daring to paint. I cant really imagine how to paint the V-shaped design on the epoch III version?!
I mean... I´m only interessted in a completely professional look! lol
Offline Carim
#6 Posted : 27 February 2020 21:35:02(UTC)
Carim
I used Deluxe Materials "Strip Magic" (https://deluxematerials.co.uk/) to strip the paint off Z scale carriages; it was very effective and didn't damage the plastic - but I don't know if Märklin uses different plastic in HO scale from Z scale. For decals, I used Andreas Nothaft: https://www.modellbahndecals.de/
Carim
Offline Dave Banks
#7 Posted : 28 February 2020 00:22:47(UTC)
Dave Banks
For my two cents worth this is how I do it "Downunder". I go down to my local brake / CV joint / engineering shop & they give the naked body a light sandblasting & it's all done in a minute. Then you have a perfect rough surface to spray your etching primer etc on. The rest of the story is all up to you BigGrin.
Edited by user 28 February 2020 06:29:19(UTC)  | Reason: Not specified
D.A.Banks
Offline PhredD
#8 Posted : 28 February 2020 02:20:18(UTC)
PhredD
For stripping paint off metal bodies my go-to is Rust-Oleum brand "Aircraft Remover" - fairly easy to find here in the US, but I have no idea on the availability elsewhere. While i haven't used it on Märklin loks, I have used it to remove paint from tin plate car bodies and roofs and die-cast cars - spray, wait 10 minutes, scrub with toothbrush, repeat.
For paint removal from plastic bodies, I use "Easy Off" oven cleaner, a spray foam product that I've found safe to use on various types of plastic. As above, the process is spray, wait 10 minutes, scrub with toothbrush (under running water is my technique), keep repeating as necessary. I've also used 90% denatured alcohol to remove paint off plastic - attached is a photo of my repainted BR212 from a starter set that I'm pretty sure I used that technique. (Paint was Testors Model master "British Crimson" over Tamiya primer, with decals from TL Modelbau.
A good primer is key for both. For metal bodies, look for an etching primer for a good use coat for the color to grab on to. For plastic bodies, whether finishing with an acrylic or enamel finish, I really like Tamiya's fine light gray primer - covers really well, dries quickly, and is thin so that it doesn't hide details.
Hope this is useful info.
PhredD
Burke, VA USA
thanks 3 users liked this useful post by PhredD
Offline thing fish
#9 Posted : 28 February 2020 12:05:31(UTC)
thing fish
Turkey
Oh, easy, use Tamiya masking tape; it is a bit flexible and holds pretty good. When you finish painting the body let it dry completely and apply masking tape. Make sure it adheres propery by rubbing with your finger. Once you're satisfied cut out the tape with a hobby knife with a fresh (very sharp) tip. This operation is relatively easy since the V shape line is embossed all the way. Then hand-paint the lining. That's it! Enjoy the new looks.
C.
Offline Vincent727
#10 Posted : 05 March 2020 20:38:38(UTC)
Vincent727
Here are examples of redecoration of Marklin Lok's that I did ...
Wheels still to improve ... Black paint is not nicely done ...
All paint is gone thanks to a bath in brake fluid for cars.
Then clean with soap
Then Primer
Then paint with Bomb ...
Offline dominator
#11 Posted : 05 March 2020 20:56:24(UTC)
dominator
My 3053 started loosing its paint, so after reading on this forum, I used brake fluid to remove the rest of the paint. In this case, it did not effect the plastic body.
Dereck
Northland. NZ
Offline thing fish
#12 Posted : 07 March 2020 09:05:41(UTC)
thing fish
Turkey
Dereck
Dereck hi,
Brake fluid makes plastic detoriate, this may not be visible if you keep the part in brake fluid for a short period of time. Try this: leave a plastic thing in brake fluid for 6 hours or so. You can see the result. Now, problem is detoriation starts rightaway but will not be visible even if it is there. Not a risk worth to take in my opinion since there are products that wouldn't harm plastic.
C.
thanks 1 user liked this useful post by thing fish
#13 Posted : 30 June 2020 09:00:38(UTC)
Some time since I posted in this thread, but my project is still very much ON!
I have now researched the colours and the new numbering that I have to give the 1st loco.
An ocean-bue BR141, which I want to paint blue. Now, according to what I can find on the internet, I would "need" to give it the number E41-068, as this was one of very few that came with double headlights AND in blue colour.
So, I found a german website that offers transfers for a series of locos, -and for a modest sum also offer to change the lettering and numbering. BUT... he has no products in stock, and now it seems impossible to receive anything from Germany anyway, because of the covid interruptions. :-(((
So what other ways are there to give the loco all the right writings, texts and symbols?
Any good links? -as I havent been able to find anybody else.
(The BR141 that I want to paint has all the original lettering printed. Nothing embossed on the shell!)
Also, about painting; Should I use a primer, once the old Märklin paint has been removed? -I dont quite get it with the "priming"; why not just give it an additional hand of the same paint that I am going to use anyway??? (I will be painting with an airbush and Humbrol enamel colours)
On another note, ThingFish says that the V-shape is embossed on the V200 body. Not so. Mine is a terrible ocean-blue version w.o. any embossment, nor "DEUTSCHE BUNDESBAHN" lettering on the side. Making a curved V-shape with masking tape seems like a daring task... lol
#14 Posted : 01 July 2020 07:30:12(UTC)
This is the site that I mentioned in my previous mail;
https://www.modellbahndecals.de/Decals-Loks/
Anybody has experience with this vendor?
Offline Carim
#15 Posted : 01 July 2020 13:07:30(UTC)
Carim
Yes, I used Andreas a few times for Z-scale decals and I have been very happy with the product and the service.
Carim
Offline Carim
#16 Posted : 01 July 2020 13:18:11(UTC)
Carim
......the V-shape is embossed on the V200 body. Not so. Mine is a terrible ocean-blue version w.o. any embossment, nor "DEUTSCHE BUNDESBAHN" lettering on the side. Making a curved V-shape with masking tape seems like a daring task... lol
Have you considered getting a single colour decal sheet, cutting out a thin line and then curving that to get your V-shape?
Carim
Offline marklin81
#17 Posted : 09 July 2020 01:21:37(UTC)
marklin81
I've also used Modellbahndecals.de. Very happy with results.
thanks 1 user liked this useful post by marklin81
#18 Posted : 08 August 2020 20:32:43(UTC)
I´ve started with an epoch IV BR140.
It should end up being an epoch III E40.
Some DOT-4 brake fluid;
This is after just a few minutes in the bath. It´s extremely effective!
After a couple of hours, and a light scrubbing with a toothbrush.
After a couple of more hours and scrubbing.
After that, a rinse in water, and then to dry;
Question; What should I paint first;The black bottom+silver roof or the green body?
I mean; If I paint it green first, I would have to use masking tape on the finished sides. Wouldnt that put the green in danger? -Any masking damage would probably be easier to fix on the bottom and roof??
#19 Posted : 09 August 2020 00:57:06(UTC)
I would paint it with a primer first, then decide what colour to do BigGrin
I guess it comes down to which way you feel it would be easiest to mask it. Generally it is easier to mask a flat surface, so I would do whatever you want the main body colour first without worrying about masking. Then mask around the top of the body to paint the roof color. Then if you are doing the bottom of the body in a different colour to the main colour mask that and then paint.
#20 Posted : 13 August 2020 22:22:04(UTC)
So far I have painted 4 times.
I primed with a little thinner green, and then just masked and painted the green, black and silver/alu en that order.
Lots of touching up to do, as the masking didnt hold against the silver.Crying
First I will spray the ventilation grills though...
Actually I´ve also painted some red; Roof; Pantos and other electrical details details. -and wheels. (no photo)
#21 Posted : 14 August 2020 19:34:33(UTC)
The side-vents was painted.
I think this deserves it´s own photo, as only NOW can you see some of the real E40´s character;
This time the masking withstood the silver paint. I only wish that I had known how-to before painting the roof...
thanks 6 users liked this useful post by hxmiesa
#22 Posted : 16 August 2020 17:37:51(UTC)
Repainting is finished.
I tried to touch-up a couple of areas, but it sometimes makes things worse, necessitating yet another touch-up to fix the touch-up Bored
Anyway, I have been able to paint a few more details, than is normally painted on the original model. (Of course we are talking about an older model here, 80´es like)
Here are some photos of the ready loco, but BEFORE decals and a final clear coat of satin-varnish.
I´m pretty happy with the result, although it is not as professional-looking as I had hoped for.
All in all the process went very well, only the silver/alu paint has caused practically all the problems visible in the photos.
Both black and green are easy to control with the masking and the airbrush pistol.
I might try to do the silver colour first, on the next model. (An even older Märklin E41)
thanks 4 users liked this useful post by hxmiesa
#23 Posted : 31 August 2020 23:19:13(UTC)
So... The next (E41) is already well underway!
Same procedure; A day (or two) in DOT-4 brake-fluid.
Then priming with a thin "cobalt blue".
Then doing the silver/alu colour first, as I had some problems with bleeding under the masking tape with the E40.
The old Märklin mold of the E41 has most electrical details on the roof MOLDED in metal, with very reduced detailing. This was ground away with the Dremel;
I will rebuild these details with accessories from the Hobbex catenary system, some 0,2mm wire, paint and superglue.
Holes for the electrical isolators has been bored out.
The rest of the loko gets the same treatment as the E40; Wheels and pantos painted red.
To be continued...
#24 Posted : 01 September 2020 21:38:41(UTC)
Hey,
Yesterday's update wasnt really with the correct photos, so here's a quick re-update with a little more interesting photos;
Colour seems to be off Confused
The finish of the colour is matte. I tried to counter that with a coat of clear gloss varnish, but it doesn't help. It even seems to throw the tone of the colour a little off...
What to do?
Partly assembled;
Still to do;
Minor colour touch-ups.
Roof details to be scratch-built.
Windows, railings, etc. to be reapplied.
(Decals/lettering and clear varnish much further into the future...)
Offline Michael4
#25 Posted : 02 September 2020 16:58:59(UTC)
Michael4
I got as far as this with a repaint and then, losing enthusiasm, I put it back together still in primer.
UserPostedImageIMG_3946 by dralowid, on Flickr
When restoring things I find it all goes well until the last coat!
#26 Posted : 02 September 2020 17:43:50(UTC)
I´m sorry that you lost faith in it. The primer coat looks really smooth.
I am definitely NOT losing faith or interest. Especially after doing the E40, which I am very happy with.
I just don't know what to do to save the texture (matte) or the E41, as I need it to be satin or slightly gloss. I mean; I have both varnishes from Humbrol, but even a generous coat of gloss on the E41, didn't really help out.
Yesterday I ordered the decals that I need for both lokos, and so far I am very happy with Andreas Nothaft from www.modellbahndecals.de! ThumpUp
Offline Br502362
#27 Posted : 03 September 2020 08:07:56(UTC)
Br502362
Humbrol varnishes today are just s**t! Old Humbrols were good.
Try AK Interactive satin varnish AK11238
Åke
Offline dominator
#28 Posted : 03 September 2020 11:58:40(UTC)
dominator
What gives with the mat finishes mentioned here???Confused The originals were finished in gloss!!!!!Huh
Northland. NZ
#29 Posted : 03 September 2020 13:07:06(UTC)
First off; "Gloss" isn't really the ideal finish to go for with the models. No MR manufacturer does this, afaik. "Satin" works better, which is what my Märklin, Roco, Piko lokos seems to use. (I would even call my Piko E41 more matte than satin...)
Second is, that the color that I need was only available in "matte" finish from Humbrol. So, searching through internet, it seemed to me that people corrected the finish by applying layers of clear varnish. My question is why this didn't seem to work for me with the Humbrol gloss varnish, and what I could do the fix that. (As it seems fixable).
#30 Posted : 04 September 2020 16:16:42(UTC)
I quite like it in grey!
#31 Posted : 06 September 2020 19:01:28(UTC)
Reconstruction of the electrical roof-details; (Before painting);
The isolators from the Hobbex series of catenary (and their 0,8mm copper wire)
Most wires are from Faller Car System (guide-wire)
Everything super-glued together (Tried to solder it, but that was a failure)
Ciao
Offline Johnvr
#32 Posted : 07 September 2020 08:00:26(UTC)
Johnvr
Hello
If I can make a suggestion, would you paint the springs for the pantographs in black to stand out from the red ?
RegardsBigGrin
Offline Michael4
#33 Posted : 07 September 2020 11:04:28(UTC)
Michael4
My problem with repainting things is that my last and final coat of paint is never as good as the one before!
The OP's work is great but I agree with John regarding the springs though don't know what they would have been on the original..
#34 Posted : 07 September 2020 23:21:12(UTC)
I made the springs of the pantos red, because Märklin and Piko does them in red too. I haven't even studied photos of the real thing...
It makes these home-painted loks look more like the rest of my loks.
Here it is again, with electrical details painted; red color for lights and brass for whistle;
Ciao...
#35 Posted : 25 October 2020 03:26:01(UTC)
Location:: On 1965 Märklin Boulevard just around from Roco Square
Are your locos analog or digital driven ? have you thought of drilling out the marker lights ?
#36 Posted : 25 October 2020 09:55:41(UTC)
Analog driven.
On the E41 I have drilled out the red lights in one end only.
I did that more than 30 years ago, but did a terrible job at it, so it is not perfect. I installed a couple of red leds, and use it for push-pull operation with Silberlingen. The light changes direction with a friction-contact using the same method as the drivers cab of the Silberlinge.
This page was generated in 1.366 seconds.
