Offline Wohnrade
#1 Posted : 25 August 2020 19:33:22(UTC)
Wohnrade
I have a new i.e/. 'unused' S 3/6, BR 18.4 lok. Lights will work but lok does not respond to any other command. When I attempt to turn wheels by hand they wlll not budge, Thoughts?
Offline franciscohg
#2 Posted : 25 August 2020 19:53:41(UTC)
franciscohg
Chile
Hardened oil for sure, dismantle it and make a good ckeaning with lighter fluid or isopropyl alcohol, then a drop of oil and it will surely run as heaven
Offline 1borna
#3 Posted : 25 August 2020 20:29:28(UTC)
1borna
Croatia
I use contact spray for baked parts, it works quickly and efficiently and does not damage paint, plastic or rubber
Offline analogmike
#4 Posted : 26 August 2020 01:46:23(UTC)
analogmike
Never attempt to turn the wheels by hand. The wheels will slip on the axles. Your trouble is from hardened oil.
thanks 4 users liked this useful post by analogmike
Offline rugauger
#5 Posted : 28 September 2020 17:40:13(UTC)
rugauger
The "unused" part could very well be the source of the problem, as others have said. Your best option is to open the loco and disassemble the motor to check for solidified oil. Give it a thorough clean. Whilst you are there, check all connections and solder points. You did not specify is it's digital or analog. If the motor is clean and it's a digital loco, the decoder might be at fault.
Richard
E-Lok Problem (General MRR)
by Eurobahnfan 29/09/2009 07:50:06(UTC)
Start and Stop Lok problem (H0-scale)
by McLae 26/12/2005 06:22:08(UTC)
This page was generated in 0.406 seconds.
