Offline s2sticks@gmail.com
#1 Posted : 14 July 2020 16:48:00(UTC)
s2sticks@gmail.com
I am just getting into Marklin Spur 1 and was curious which track is preferred, Marklin or LGB?
#2 Posted : 14 July 2020 17:54:36(UTC)
marklin track is code 200, LGB is code 250. My memories of looking at Marklin running on LGB track is that the rails do look over size.
Peco also make code 200 track that should mate with Marklin. If setting it up outside their plastic sleepers may be more UV resistant than marklin from what I have heard.
#3 Posted : 14 July 2020 19:36:28(UTC)
Also Km1 produce tracks in scale 1.
Km1 do have both in plastic and real wood ties for the rail too.
#4 Posted : 14 July 2020 20:37:37(UTC)
Here's a few things for you to look at:
https://www.marklin-user...cale-tracks-and-turnouts
https://www.marklin-user...6-Track-for-marklin-1-32
Since then, Märklin have bought the company Hübner, and introduced their rang of tracks under the Märklin name.
The "Hübner" track system is very nice made; probably the most prototypical looking tracks you can get;
but also very expensive and not made for outdoor use.
thanks 5 users liked this useful post by Purellum
#5 Posted : 15 July 2020 00:08:03(UTC)
Since then, Märklin have bought the company Hübner, and introduced their range of tracks under the Märklin name.
In fact, you can't buy the Märklin stainless steel track new anymore - you can only buy the Märklin Hübner track
Offline TEEWolf
#6 Posted : 15 July 2020 01:29:44(UTC)
What do you mean by prefer Märklin 1 or LGB? I only have gauge H0, but at my MIST club I was told Maerklin 1 has a gauge of 1:32, LGB 1:22,5. Maerklin 1 is only for indoor use whereas LGB is weather resistant. LGB is the abbreviation for "Lehmann Garten Bahn", in English: Lehmann (a name) Garden Railroad.
#7 Posted : 15 July 2020 12:03:28(UTC)
Märklin is gauge I, LGB is gauge 2m aka gauge G. Both happen to be 45 mm.
AIUI Spur 1 can be used on LGB tracks with some limitations, but not vice versa.
Both have the same rail spacing becauce LGB happens to be narrow gauge.
#8 Posted : 15 July 2020 20:10:23(UTC)
Those who told you have mixed things up, or you have lost some of it in translation Cool
The scale of Märklin 1 is 1:32 and the scale of LGB i 1:22,5 BigGrin
In both cases the gauge is 45 mm BigGrin
Both are weather resistant, the original stainless Märklin even better than the LGB, which have brass tracks.
The "new" Märklin-Hübner is more fragile, since it's very finely detailed; the tracks are nickel-silver, just as PECO. Cool
There's plenty around, in Denmark several of the dealers still have some of it in stock, an on Ebay you can get everything BigGrin
thanks 4 users liked this useful post by Purellum
Offline Rwill
#9 Posted : 15 July 2020 21:44:32(UTC)
Rwill
I have always understood that LGB stands for Lehmann Gross Bahn not Garten Bahn. Seems to me in one short sentence you have as usual got everything wrong!
Offline phils2um
#10 Posted : 17 July 2020 02:32:56(UTC)
phils2um
First a correction. Rail code is a measure of the rail height in thousandth's of an inch. LGB rail is code 332 not code 250.
Second, LGB rail is very robust. I'm using a lot of it on my outdoor layout. However it is nominally a scale of IIm , 1:22.5 meaning the tie spacing and size are way out of proportion to what looks prototypical in scale 1 which is 1:32. I would recommend you look a Sunset Valley code 250 stainless steel rail as you are in the US. They have tie strips for 1:32 if you intend to run mostly scale 1. You'll save loads of money you can spend on locos and turnouts. Plus, long sections of "flex" track work better outside.
I also highly recommend you look at the MyLargeScale.com and gscalecentral.net web sites before committing to any brand or type of track.
Phil S.
thanks 2 users liked this useful post by phils2um
Offline KingMarklin
#11 Posted : 17 July 2020 17:28:02(UTC)
KingMarklin
Hi....Originally used the Marklin 1 scale track, I started with the earlier version of Marklin's track with the older style track clips but eventually moved to their current snap clip version. Since I was setting the track mainly around the Christmas tree and occasionally in the yard, I noticed it started having connectivity issues and also it never provided good stability when set up on carpet.
In the last few years I was turned onto Piko G scale Track, and was able to find it on Ebay priced much lower than retail. Now Piko may not be prototypical looking track compared to the Marklin track, but its robust, sturdy and functions exceptionally. Set up is a breeze and I never had any connectivity issues since. Some people I know that use Piko and the similar LGB track and I can say that the rail also weathers nicely in garden layouts.
I have since sold off all my Marklin 1 scale track on Ebay.
Ken
thanks 2 users liked this useful post by KingMarklin
#12 Posted : 20 July 2020 03:08:58(UTC)
Lehmann Gross Bahn is correct.
Maerklin 1 is only for indoor use......
Also incorrect, you just need to read the manual for any Marklin G1 loco where they make reference to outside running. Also see Per's comments above re stainless steel track.
Online hxmiesa
#13 Posted : 20 July 2020 11:34:53(UTC)
Lots of answers, but I cant see anybody stating the REAL reason for why to use LGB tracks instead of Märklin;
You can run Märklin rolling stock on LGB tracks, but you cant run LGB rolling stock on Märklin tracks; The bigger flanges of the 1:22,5 scale wheels will bump into the sleepers of the Märklin 1:32 rails.
Offline phils2um
#14 Posted : 21 July 2020 08:38:24(UTC)
phils2um
Another very real reason - $$$$$
Phil S.
#15 Posted : 21 July 2020 09:50:43(UTC)
Correct, as can be seen in the links I gave, they are really big BigGrin
Correct; but Märklin rolling stock can also have problems on LGB turnouts, by "Falling down",
due to not being lifted when they cross over at the "heart-piece" Cool
Also, the smaller radius LGB is too tight for "real" 1-gauge Märklin; the MAXI range is usually OK BigGrin
Offline nygma
#16 Posted : 25 September 2020 11:38:04(UTC)
nygma
Hungary
I hope it is not too late. I have Peco gauge 1 track outside for about 7 years. I have no issues with that in general, UV, hot and cold weather, falling apples from the tree are not a problem.
I choose Peco because I wanted flexi track and it is cheaper than Marklin. The downside is that there is only 1 foot long flexi track and a single left and right turnout. That is the entire lineup. At least the turnout is nice a wide, the radius is around 3 meters.
Few things to consider:
- The turnouts are electrofrog, so you need a small microswitch which switched the polarity of the frog. There is a place for the microswitch in the turnout itself, but you have yo buy it separately and solder/install it. None of them have failed so far.
- The point rails are spot welded to a small copper plate which screws down onto the moving part of the turnout. I have a few turnouts where this weld failed after a few years. But you can just solder it back.
- There is no turnout motor from Peco, you have to come up with a custom solution for that
- Rails need cleaning, if I don't run trains for more than a week, it needs to be cleaned before a running session.
- Fishplates only work with about 2-3 years, after that they corrode and stop conducting properly. So consider soldering jumper wires across the fishplates and many separate power feed points.
- Peco track is bullhead, so does not have the wide feet as Marklin track. But both are code 200, so the rails are same height, but connecting Peco and Marklin tracks need some fiddling around.
Let me know if you need more, I can send pictures as well.
thanks 3 users liked this useful post by nygma
Offline artfull dodger
#17 Posted : 28 December 2020 22:48:14(UTC)
artfull dodger
I have had my LGB track outside for 15+ years now with no major issues. Its been taken up and put down on new railways 3 times now. From ground level in PA to ground level in Indiana to now a raised line for live steam operation. I did use Piko curves as LGB did not offer the right radius for the prebuilt layout I bought. In the USA its easier to find second hand LGB over the Marklin track. And with the variety of trains between myself and my friends its best to use so all can run. If I was going lone wolf with just gauge one equipment and had no other track, I would seriously look at either Marklin or Peco track for its more fine scale look. That said, I have zero complaints about my LGB "girder rail" track. It has served me well for many years. Mike
thanks 1 user liked this useful post by artfull dodger
This page was generated in 1.169 seconds.
