Offline Brian_BR96
#1 Posted : 27 May 2020 22:40:42(UTC)
Brian_BR96
I'm getting back into Marklin and I'm trying to add two home signals so I can run two trains at once. I have a small analog setup with some older trains using a 6646 transformer and C track. I have a 72710 control box for my turnouts and I'm trying to see which signals are compatible with that control box.
I'd like to use a newer signal, if possible. The 76391 is in the current catalog, but it looks like it needs a different control box due to the connector, and that control box won't work with my transformer, because of the connector. My question is can I snip off 76391's connector and use a 74043 wiring set instead? Or am I better off finding a couple old 7241 signals on ebay? Or is there a better option?
The 72710 is listed as a "turnout/signal" controller, and I'm wondering which signals in the current catalog it's designed to control. Wish there was a "compatible items" tab in the online catalog.
It seems like there's a million options now compared to when I was younger. Searching the web and reading up on all the users manuals only got me so far, so I thought I'd ask!
Marklin Semaphore Analog Signals (H0-scale)
by MALAVIKA 30/05/2024 14:45:23(UTC)
How to mount analog signals to table? (H0-scale)
by Brian_BR96 06/10/2022 02:44:03(UTC)
using old analog signals on digital layout? (Digital)
by rockingtrain 15/07/2011 19:30:07(UTC)
sticky analog signals, help requested (H0-scale)
by BillJ 22/12/2009 19:31:28(UTC)
This page was generated in 0.292 seconds.
