#1 Posted : 26 February 2020 07:10:17(UTC)
Bryan
Dear All
I am currently trying to upgrade a Marklin 39563 crocodile to a 60977 mSD/3 decoder. These locos have a C-Sinus motor, however it is the later version with the small vertical C-Sinus motor. Also the original decoder is the later 21 pin type.
The 60977 instructions denote the following:
CV52 must be ‘1’ for C-Sinus type motors.
CV56 must be ‘0’ for control influence.
CV51 is either 24 or 0
AUX3 is set to ‘S’ status
AUX4 is set to ‘F’ running
When using the both the dPT software or the CS 2 (60214) I have set the following correctly, both have latest software.
However the remaining 3 parameters, I cannot locate to set correctly in either of the progamming tools. These are
Can anybody tell me how to set these three CV's, which key stokes or menues in either the Programming tool or the CS2.Also is the CS3+ better for such jobs.
The Marklin instructions are very cryptic with all their digital software and need help.
The only decoder functionality is the front and rear lights work when setting the direction.
Has anyone successfully used an mSD/3 decoder successfully on a 21 pin loco with SDS.
Thanking for any assistance.
David
Edited by moderator 10 July 2021 11:21:14(UTC)  | Reason: Not specified
Offline ktsolias
#2 Posted : 26 February 2020 08:30:03(UTC)
ktsolias
AUX 4 must be on "Logical level" and "always on"
You can do that with the mDT3 software
https://www.marklin-user...-conversion-to-Sound-mfx
Costas
#3 Posted : 26 February 2020 11:14:50(UTC)
Bryan
Dear Costas
I have read your posting. Within it, it states also that AUX 4 must be on logical level and always on. The problem is I cannot find where the 'AUX4' is displayed in the mDecoderTool3 screen displays. Would it be under the Functions menu somewhere.
Thanks for your help.
David
Offline ktsolias
#4 Posted : 26 February 2020 11:56:56(UTC)
ktsolias
Yes David...
You are right: everything is hidden, complicated and not documented...
Here we are
1st step: Decoder - Decoder setting conceal - AUX 4 logic check
2nd step: Functions - Special functions - Always - check
3rd step: Functions - Always - Action for always - Outputs + - Output 4
I think that is more clear now
You can't use AUX 4 for anything else
Regards and good luck
Costas
#5 Posted : 26 February 2020 12:10:16(UTC)
Bryan
Dear Costas
I will try that, and thank you.
David
Bowral NSW
#6 Posted : 27 February 2020 06:27:08(UTC)
Bryan
Dear Costas
I have tried the decoder settings and correctly, the locomotive is now running. A great piece of information.
The front and rear lights work and reverse on direction. It does have a red heart light, this does not work with the new decoder only with the old decoder.
The next problem now is the sound functions do not work. This crocodile 39563 has a special small sound board mounted in the cab. It also has two small speakers connected in series. Does anyone know why these units had a special separate sound board? The main issue is how do we get the sound to work. Do the speakers need replacing. Do we need the extra original sound board in the circuitry.
The loco just for added information still has the original decoder mounting board and wiring to the LED lights. The whole aim was to plug in the new mSD/3 21 pin decoder and use all existing components. I expect there are a number of Marklin runners that will undertake this procedure sometime.
David
Offline ktsolias
#7 Posted : 27 February 2020 08:57:51(UTC)
ktsolias
Dear David
I am happy that I helped you
For the sound: Remove the old sound module and connect the speakers directly to the decoder (The speakers must be 4-8Ω)
Τhe problem with the lights is that the Swiss lights system is used. They need special mapping and I think that in this loco is a special board for the light mapping
Any way some photos of the inside of the loco and of the PCB will help a lot to see what exactly happen.
The 3956x locos use a special PCB the 606218 or 606228 for the lihgts
Costas
#8 Posted : 27 February 2020 09:01:22(UTC)
To use the light and sound functions as with the original decoder, you have to make sure AUX1 through AUX3 do the same as with the old decoder.
Plug the old decoder in and check the function mapping with a Central Station.
#9 Posted : 27 February 2020 11:53:22(UTC)
Bryan
Thank you Costas and Tom.
I have attached a photo of the crocodile chassis displaying the wiring and decoder mounting board.
From the original mounting board, 3 wires are taken to the sound board. These are orange, white and black.
From the sound board two white wires go two the speakers.
Which of the three input wires should be used to connect to the speaker.
Also a great idea about mapping the AUX1 etc from the original board. The idea could be used for matching other functionality in future projects as well.
Best regards to both of you
David
Offline ktsolias
#10 Posted : 27 February 2020 13:44:48(UTC)
ktsolias
David
You are in a very complicated situation
1st Don't touch the PCB of the Decoder 21 pin mount and the driving electronics for the motor
2nd The PCB under the sound module is the follow
Check the No on the boards
This is for the Swiss lights changeover in cooperation with the correct mapping of the AUX fx used to control the lights plus of course the f0 f/r
3rd: For the speakers you can take away speakers and PCB and use one of the speakers included with the decoder connecting the speaker directly on the 21 pin pins for the sound (are the two lower ones on the left side (the side with the 10 pins).
Of course you need experience to do all that. Have in mind that any problem with the main board means that the loco is off forever!!! There are no spares available.
May be is better to leave this beautiful kroko as it is with the original tooling.
Otherwise you my find yourself with a beautiful display crocodille
Costas
Offline Bart
#11 Posted : 27 February 2020 23:32:38(UTC)
Bart
David
Just to clarify: the 39563 had a single sound function, generated by a separate sound board, not a sound decoder.
The board is driven by a pulse from a regular Aux output of the (non-sound) decoder (which, at that time, likely was Esu LP3-based).
So the 3 wires to the sound board are +, -, and Aux; and NOT speaker leads.
Now that you have a sound decoder, get rid of the sound board and remove the 3 leads from the decoder board, they are useless.
Your new speaker should be connected to the dedicated speaker output of your new sound decoder, not to an Aux output.
Those pads should be indicated in your mSD/3 manual; they should be present on the original decoder board, even when no sound decoder was installed.
Also, don't use the old speaker, as it is likely 100Ω (or in this case, a 2x50Ω double speaker).
AFAIK, at those times, M* sound decoders were Loksound3 based (100Ω), and this separate sound board probably as well.
You may want to check the printing on the speaker. Newer sound decoders require 4-8Ω speakers, as provided with the mSD/3.
The Swiss light configuration, including the 1 white / 1 red tail light switching, is provided by the separate 606218 circuit board. This should remain wired to the original decoder board (and the leds) as it was.
As Costas mentioned, the Aux mapping of the original decoder should be copied, as this is required to drive the 606218 board for the specific light configurations.
*Bart
thanks 2 users liked this useful post by Bart
#12 Posted : 28 February 2020 11:33:59(UTC)
Bryan
Dear Bart and Costas
Firstly must I say I find both of your replies fascinating. The bottom line with this project is to find out what is happening within the 39563 locomotive at an electronic and digital level. I had no idea why Marklin put all these different PC boards in the loco and what functions they actually performed. When I first started the project I thought it would be a basic decoder swap and with decoder CV changes. It is not, and agree with Costas, the crocodile mechanism as originally setup in the articulated chassis, is on an engineering level, quite beautiful. I will probably not now go through with the conversion. I will though attempt a conversion with the notes taken, later. This would be on one that has had the driver board already broken and the only alternative is a conversion.
Another question I could ask is, how have you both learnt this depth of detail about Marklin, it is not in any written form anywhere. So once again thanks for sharing this knowledge, I am sure others would agree.
David
#13 Posted : 08 May 2021 12:02:10(UTC)
I am working on one of these at the moment, but things are not going too well.
I managed to get the sound working by soldering the speaker that is supplied with the mSD3/3 kit directly on to the tabs next to the male decoder connector on the original board.. A big tick here.
I also managed to get the motor working with the AUX4 trick mentioned in a post above this one. The loco runs really smoothly, but it has a very low top speed. So, I need help fixing this problem.
I tried to follow the instructions to set CV7 to 77 (for the auto-calibration), but I can't find a way to actually add or access a CV that is not listed in the configuration part of the decoder edit section on the CS3. In fact, I can't seem to work out how to do it on the Marklin decoder programmer either. ESU make this stuff so easy for the user.
The last problem is the Swiss rear light. Part of the problem is my unfamiliarity with the CS3 (the other guy owns this). We could not read the original decoder with the Marklin programmer, but we could read it with my ECOS. The eCOS stated that it was using AUX3, so I set the new decoder to use OutPut3, using the Marklin programmer, but it seems that something else is needed to get the light working. Any ideas?
Edited by user 12 July 2021 13:44:49(UTC)  | Reason: Not specified
#14 Posted : 08 May 2021 15:26:55(UTC)
I tried to follow the instructions to set CV7 to 77 (for the auto-calibration), but I can't find a way to actually add or access a CV that is not listed in the configuration part of the decoder edit section on the CS3.In fact, I can't seem to work out how to do it on the Marklin decoder programmer either.ESU make this stuff so easy for the user.
Adrian ,on the CS3 you have a direct screen to adjust the maximum speed. On the CS2 the screen presentation is slightly different but you have it also.
The last line in English should read Maximum speed Here set to 255 the maximum speed.
On the ECOS it may be less clear. The CV is CV 5 must be set to 255 for max speed.
With a CS3 or CS2 it is easy and you don't need a programmer (I am sorry if you don't have a CS2 or CS3).
The idea is to add to an exiting function, 2 physical outputs (one of which is the Swiss rear light
In this case, you must edit F0 (Headlights) and add another output (AUX1 for instance) and set it as a dimmer and active in both directions.
Then you must wire each lower right beam to be controlled by AUX1 (in this example).
Finish.
Sadly I don't know how to do it with an ECOS
#15 Posted : 08 May 2021 23:09:46(UTC)
Thanks for the info Jean.
The top speed was already set to 255 and I have checked the running gear. The loco runs faster with the original decoder.. So there must be something else. Does every new loco need to be calibrated by the CS3?
Ah so I need to link the F1 function to the F2 function for the Swiss lights to work.. Okay.. I will try this next weekend..
I only used the eCOS, because I could not get the Marklin programmer to read the original decoder.. My friend has the CS3 and the loco..
Offline bph
#16 Posted : 08 May 2021 23:42:55(UTC)
Its recommended :)
Here is a screenshot from the cs3, just replace the 3 with 77. pres ok, and give it some speed as described in the manual.
the decoder should also respond to CV 7 command in MM and DCC mode. (also works with the old 6021)
#17 Posted : 09 May 2021 00:27:57(UTC)
That's nuts!
I did see the -/7, but I thought it was just some weird code for the firmware version.
How on earth is anyone supposed to work that one out? Marklin make great trains, but they really need to outsource their software development to another organisation (e.g. ESU) that know what they are doing!
@bph -> Thank you for sharing the screenshot. There is no way I could have worked that one out for myself.
#18 Posted : 09 May 2021 03:15:12(UTC)
That's nuts!
Read the section titled "Automatic Calibration for All Protocols" on page 30 of the manual
#19 Posted : 26 June 2021 12:12:39(UTC)
Okay.. I have the sounds and motor working correctly, but I am still struggling with the red swiss light. I have confirmed that there is a red led and it seems to be powered or grounded through a blue wire. However, I can't determine the correct auxiliary and I am unable to link it properly using a CS3.
Some images...
The CS3 hardware information
This is the blue wire on the decoder base - it seems to connect to pin 20 on the 21 pin socket.
This is the two blue wires on the middle board. Left lower wire comes from the above-mentioned board, while the right-hand one goes to the LED lights.
This is an image of the LED board - rear one.. The blue wire is connected to a pin above the gray one (i.e. they are separate pins)
This is the CS3 screen for the current settings for F0. These lights work correctly.. Three whites in the front and one white light at the rear right side.
This setting is from the default project download from Marklin for F1 (Swiss Lights). I don't think that there is an AUX 3, but I tried AUX 1-6 in that position with no change..
I know that something is not set correctly, but I can't figure it out.. I wish that I had access to a 39563 with a working original decoder so I could see how it is set up in the CS3..
Any thoughts?
Offline dickinsonj
#20 Posted : 27 June 2021 01:31:36(UTC)
I don't have an answer for you Adrian, but that is the most clearly stated question that I have ever seen on a forum.
Nice. ThumpUp
Offline bph
#21 Posted : 27 June 2021 13:31:53(UTC)
recommend that you check the blue wire connection with a multi meter, check what pin it's actually connected to on the mtc interface. that way you should be able to identify the correct aux out. (it's not aux 4 or higher).
if it's aux 3, you have to check if the aux 3 original was a logic signal, and is amplified somewhere. e.g. if aux 3 need to be configured as a logic level output. I don’t have the locomotive, so unfortunately, I cannot be of more help.
You might find some more info here: (But please note that there might be some errors, so you have to check the information.)
https://moba-hgh.de/modellbahn/digital/decoder/fuer-lokomotiven/maerklin/mfx/sonderbauweisen/2307-39563-ce-6-8-güterzug-lokomotive-der-sbb#funktionsbelegung-2
http://www.web-hgh.de/index_jsm_moba.htm?http://www.web-hgh.de/p01_45217_t.htm
http://www.web-hgh.de/images/slw/606218_LWP_kroko/606218%20LWP-SP%203956x.jpg
#22 Posted : 27 June 2021 14:00:45(UTC)
Thanks for that additional information. I traced the Aux3 pin and it seems to go nowhere and the first link suggests that the Swiss lighting should be Aux1 anyway. I need to play around with the Aux 1 settings.
When I tracked the blue wire, the only pin that gave a result was pin 20 (GND).
The risk is that the board is blown in someway and will never switch to the red LED.. So I need to really look longer at this special board to understand how it actually works to see if I can test it in some way.
It's a journey.. RollEyes
Offline bph
#23 Posted : 27 June 2021 15:12:31(UTC)
yes, it’s a journey RollEyes , I'm currently struggling on a journey, with another project with undocumented functions in the MSD3 decoder.
whats a strange is this picture from 39562 on the moba-hgh.de site
39562
it seems like the blue wire in your locomotive is brown and yellow in this picture, that indicates Aux 3. But then the decoder board might be different.
#24 Posted : 28 June 2021 00:30:18(UTC)
Bryan
Just one question about using the mSD/3 in the softsine 39563. I thought that you need a driver board for the SDS motor. These are available from Switzerland and there are 3 types for the 3 different sine motors. From what I can workout, you seem to have got around the driver board problem, or are you using the existing decoder. Best of luck with this and tell us how it all progresses. All very complicated, however fascinating at the same time.
David
#25 Posted : 28 June 2021 00:55:50(UTC)
David,
I am using the original base board, which I assume has the driver for the SDS. The ribbon cable from the motor plugs into the board. If I used the whole, mSD/3 kit that includes a replacement base board, then I would need to have the special driver board. The motor and sound are not a problem to set up, but the ^*&%^&*% Swiss light is a pain. I WILL solve the problem and post the solution on here so some other poor soul does not have to go through this pain again..
#26 Posted : 28 June 2021 01:01:43(UTC)
I noticed that too, but AUX 3 on the pin-out is the second pin down from the top on the left hand set of pins.. As you can see, like the base board on my loco, it does not seem to have a connection. The next two pins down AUX 2 and AUX 1 do have tracks coming from the pins. The boards look the same to me..
#27 Posted : 28 June 2021 10:56:28(UTC)
All SDS locos come with that board. All C Sine locos with mfx already have that board.
Some locos require AUX4 to be always on and to be logic level. Some do not need that logic level at all. Maybe some C Sine locos need AUX3 to be always on.
Would be good to have a 39563 with the original decoder to read out the settings.
Older decoders have AUX3/4 always as logic level outputs, but IIRC with MSD/3 this is not the default.
#28 Posted : 10 July 2021 09:32:07(UTC)
Finally, I managed to crack the problem.
The key was the "Logic AUX3" setting in the Misc section of the Configuration tab of the decoder edit page on the CS3.
By default it was set off. When we first played with this setting the red light would come on and not go off if you pressed F2. I am not 100% sure what we changed, but after we set this setting, we deleted all the other changes (as shown in the images below) and added them in later. I suspect that there is a minor bug in the decoder editing part of the CS3. These are the other settings, which follow the recommendations provided by Costas and Jean in earlier posts. Looking at the original decoder was not useful as the "Logic AUX3" setting was concealed, because it was a factory decoder. Marklin needs to be less precious about its intellectual property and provide better information to help customers using their marklin-branded decoders.
The other settings shown for consolidation reasons are:
F0 settings
In the Always setting we added "Auxiliary 2"
Click on Auxiliary 2 to see the default settings - shown in case the default changes in the future.
Finally we set F2 to use Auxiliary 3 - using the same default settings that were used for Auxiliary 2
I hope that this helps someone else avoid the pain we went though converting this loco.
It runs beautifully and looks great.
thanks 9 users liked this useful post by xxup
Offline tsenthia
#29 Posted : 08 August 2022 13:55:49(UTC)
tsenthia
India
Post initiated on 08-Aug-2022
Dear All,
I am in a similar fix, in my case the Sinus Motor bus, just snapped out of the decoder when i tried to plug the new marklin msd/3 60977 decoder to the original mother board and the motor STOPPED running.....then i had to buy a new DC brushless motor and replaced it.
For your info i soldered the Pin - No 18 and 19 To the Motor terminals and the motor is running, i kept the other wirings and the onboard circuits intact to save the Swiss Headlights, Sound & Pantograph Operation switch.
This is the video after doing the work, as it would appear, the sound features not fully functional and also the Red color break lights not visible.
Tonight i am going to trouble shoot this with CS5, to restore the sound and headlights by playing with CV values, i have given good reading of all of your post, hope it will help me to bring back the engine alive completely. i will keep you all posted with my findings. _/\_
Updated as on 11-Aug-2022
Hello everyone,
Further to update on my previous note, i couldn't succeed in retro fitting a DC - Motor to the original Marklin 39562 mother board with 60977 decoder, Apparently the sound did not come through and the motor in itself was not driving with full efficiency.
So i decided to strip all the wires to barebone and connect the 60977 mSD/3 decoder with motor, supplied speaker and the existing led lights. But here also there was challenge as the lighting had separate control circuit.
The control circuit on the left in pic was serving 3 purpose -
1.Providing Connection to Pantograph and Centre pickup shoe
2.Swiss LED Lights as was mentioned earlier in the post by bph was very useful study the functions of the LED, reposting the same link for ease of reference (Courtesy bph: https://moba-hgh.de/mode...weizer-lichtwechsel.html
3.To receive the Orange and Brown wires from Loco chassis and connect to decoder.
The only reason to keep this secondary board was for the 2nd point. (Switching yellow/red combination)
Here is the wiring connection diagram i made, so that it could of some use to people who want to retro fit Motor and Sound functions into the complex SSB 6/8 crocodile loco Marklin 39562
The only hurdle i faced was, the 2 wires from the Light Control Board (Purple and Brown with yellow strips - refer picture), There is no option to connect this wire, i really wondered where to connect it ?, if left open without any connection what would be the impact.
So i went back to the old Mother board and traced where these wires connected.
Here if you observe the purple was connected to Ground - Pin 20 of the Decoder and Brown-yellow was connected Indirectly connected to Aux 3 Port via what appeared to 3-pin MOSFET transistor, which is usually used to drive SMD LED's. Since it was connected to Aux 3 Port, it gave me relief that this was only optional and i can do away with its functionality and and decided to leave the Purple and Brown-Yellow wire open.
The Central Station, i only calibrated the CV 51 value to set it to 5 - (Soft DC motor)
Here is the videos of the loco test run. The pickup shoe and motor & gear mechanism did face of runtime challenges, but functionally its working now.
With Pantograph connected. Slow Operation Mode.
Thank you _/\_
Senthil
Edited by user 11 August 2022 10:47:55(UTC)  | Reason: Not specified
thanks 2 users liked this useful post by tsenthia
Guest (4)
This page was generated in 0.857 seconds.
