Offline kaav800
#1 Posted : 19 July 2019 21:30:43(UTC)
kaav800
Hello again folks !!
Like to show you a zincpest-issue on a Märklin F800 steamer.Must bee careful when buying these old trains,things may bee
not as it seams on the first look.
Bought this from a privat seller i Oslo.Not him to blame as the lokomotive vas stored away for decades,and seller has
no experience with old Märklin stuff.
So it depends how it is stored,i guess it must be stored dry too prevent this from happening.And of course during poor
zincquality postwar this appears on a lot of models. So have this in mind when buying.Here are som pictures.
thanks 1 user liked this useful post by kaav800
Offline dominator
#2 Posted : 19 July 2019 23:19:40(UTC)
dominator
That's a bit of a bugger. I don't think these are that rare so you might use that one as spares for another one. Is it all zinc pest or has it just been roughly handled. Not sure if you could repair it as the metal is quite thin and probably not enough room for a thicker section to be grafted on.
Offline kaav800
#3 Posted : 20 July 2019 00:16:30(UTC)
kaav800
Hello dominator!!
Its zincpest all right,its cracked everywhere.The pieces shown did i broke out with a screwdriver.The hole frame is full of cracks.If you zomm out the picture you can see
even the red airtank is cracked.i have never seen zincpest on a F800 before.But i have got a complete new frame from a german seller on EBAY.
And as allways it has outstanding quality.So the F800 is now complete and nearly as new.
Best regards kaav800
Offline dominator
#4 Posted : 21 July 2019 09:37:55(UTC)
dominator
THATS GREAT. Mine is ok luckily.
Offline White Buffalo
#5 Posted : 13 August 2019 23:45:23(UTC)
White Buffalo
das ist good to hear, the F800 is one of my favorite models. Glad you found what you needed and got her running again.......BigGrin
F800
thanks 2 users liked this useful post by White Buffalo
#6 Posted : 14 August 2019 13:58:52(UTC)
Sad to see.
The method of storage has no effect on the progression of Zinkpest. It is time that does it.
Offline kaav800
#7 Posted : 14 August 2019 15:51:43(UTC)
kaav800
Sad to see.
Yes its sad with this issue regarding postwar models.I have allways been lucky with bying the ccs800 st800 dt 800 dl800
they have never had any,exept one boggie on the st800.Its wery dangerous bying some of these maschines because somtimes
you will not be able too se the cracks.It broke apart when i was servicing the gears.So maybee there is more on this
loko but i dont thing i will try finding out.the model works fine now,i repaired it with superglue.The glue works really
good on this metal.
Offline LMS800
#8 Posted : 14 August 2019 19:32:28(UTC)
LMS800
Sad to see.
I don't agree. The method of storage has an effect on the progress of zinkpest - by change of temperature and humidity !!
Wolf
thanks 1 user liked this useful post by LMS800
Offline kaav800
#9 Posted : 14 August 2019 20:51:11(UTC)
kaav800
Originally Posted by: LMS800 Go to Quoted Post
Sad to see.
Wolf
Hello again !!
Yes i also think that storage is a part of this.Air cold/heat working over long period,and wet condition in the room i think
increase the process.Bad metalquality back in those days are the head cause i guess.
And it is a sad issue that the most beautiful models are made of bad quality zinkmetal and probably be destroyed in
a distant future.They scould built them in brass like the E800 LMS,but ofcourse it had been too expensive.
Marklin F800 BR 01-097 is it 3008 or 3026 (H0-scale)
by tandrschaefer 11/11/2013 06:45:51(UTC)
Marklin F800 01097 era 1958 or so? (Collector's Corner general)
by chrisleisure 28/01/2013 04:01:58(UTC)
This page was generated in 0.342 seconds.
