Offline obb_taurus
#1 Posted : 20 May 2019 18:06:11(UTC)
obb_taurus
Hi Everyone,
I'm wondering if there is a difference between motors in 36xxx and 37xxx locomotives. I haven't purchase a new 37xxx series engine for quite some time, I think the last one must have been around 2006 otherwise any locomotive I've purchased since that time has a sinus motor. I was unaware until I received my newest engine (37127) that Marklin has moved to mainly a can motor/drive shaft setup. I naturally expected it to be super quiet and run like butter but that is not the case, what I did find is that at certain speeds it growls as much as my 36xxx engines so this got me to wondering, am I paying a lot of money for a 37xxx engine which is very detailed on the outside but has the same technology under the hood as a 36xxx engine?
#2 Posted : 20 May 2019 18:18:26(UTC)
The catalogue number is no longer a good guide to the motor installed in the loco. Most new locos are now bringing can type motors. Some are very good quality, others not so good. Some locos are still being sold with the old DCM type motor, but these are being phased out.
The more expensive locos will usually have a better motor installed than the cheaper "Hobby" locos. If you look at the spare parts lists on the Marklin website you can see a whole range of prices for replacement motors.
Offline obb_taurus
#3 Posted : 20 May 2019 18:46:30(UTC)
obb_taurus
I had a feeling that would be the answer, the other thing that made me suspicious of this is the paint job, I noticed on the 37127 the paint is more of a matte finish and somewhat coarse while my older engines are smooth and glossy.
Is it possible to upgrade the motor if you want or are you pretty well stuck with what's in there?
Offline marklinguyfromSA
#4 Posted : 20 May 2019 18:53:15(UTC)
marklinguyfromSA
Hi there.
I had a look at the exploded parts diagram for item number 37127 and the can motor inside that locomotive is different to those found in the 36xxx-series. It looks smaller or more compact very much like the SoftDrive Sinus or the ones manufactured by Maxon.
Also if the DCM motor type is being phased out, then will be there any motor conversion kits by Marklin? For owners of older Marklin locomotives, which used the larger flat commutators, there are motor conversion kits by Marklin that they can use to convert their older locomotives to DCM.
Keith.
Offline HO Collector
#5 Posted : 20 May 2019 22:06:59(UTC)
HO Collector
A beginner question.
What are these motors that you are talking about? What are the differences?
I know the old motors in the analogue engines (e.g. 3003, 3025) that had 3 poles then there were the motors with 5 poles but I have no idea about the rest that were mentioned (Google didn't help).
Ben
Online Jimmy Thompson
#6 Posted : 20 May 2019 22:51:00(UTC)
Jimmy Thompson
Here is an ancient note from within the m-u.net
https://www.marklin-users.net/html/service/SEmotors.html
There is a C-Sine in the mix, also somewhere
Hope this helps a bit!
Jimmy
Jimmy T
Dr Dirt's Rule #1 and
Offline applor
#7 Posted : 20 May 2019 23:03:17(UTC)
applor
Ben
Here are the old Marklin motors and Faulhaber:
https://www.marklin-user...ml/service/SEmotors.html
Can motor:
https://dccwiki.com/Can_Motor
C-Sine motors (Marklin only):
With the C-sine motors you have the older 'big' style C-sine and the newer compact C-sine motor.
The big C-sine is not very common and its decoder cannot be changed as there are no new decoders that can run the motor.
The compact C-sine had some issues with power sensitivity and had a driver board upgrade, whereby it was renamed Softdrive C-sine - the most common.
Compact C-sine locomotives could be returned to Marklin for this upgrade, so there are not many compact C-sine locos left either.
More reading here:
https://www.marklin-user...e-sine-and-C-sine-motors
There are also other various motor types, all DC motors and all typically quiet and run well - such as Faulhaber and Maxon but many more which are not named.
This company provides upgrade kits for a large range of models to Faulhaber/Maxon motors:
https://www.sb-modellbau.com/
Note that the cause of significant noise in many models is actually the transmission and not the motor. Hence why modellbau also provide transmission upgrades.
Marklins numbering initially assigned the 39XXX series to C-sine locomotives but this is no longer the case, you will find 39XXX models with other DC motor types and some 37XXX models with C-sine.
I don't think Marklin are releasing new models with anything less than a quiet DC motor, so it's of little concern now.
In recent years there have still been some issued with DCM motors (coffee grinder) because they were still using old moulds.
With the release of the new BR44 chassis I don't think there are any more, except maybe the BR78.
I am not sure about the new Marklin 37068, BR80. Previously it had a DCM motor but maybe the new one has a motor upgrade - the brochure does not say.
thanks 6 users liked this useful post by applor
#8 Posted : 21 May 2019 10:21:49(UTC)
HO Collector
Thank you guys. Learnt something new.
#9 Posted : 22 May 2019 10:41:55(UTC)
Here's a little more info on the Sine drive, from 2007 - hard to believe 12 years ago already.....
#10 Posted : 22 May 2019 20:36:54(UTC)
It seems like a great idea, that soft sinus, but the required specialty drive mother boards (with control semiconductors on it) which cannot be sourced anymore makes those locos have a single point of failure, right?
This page was generated in 0.537 seconds.
