Offline Tom Thomson
#1 Posted : 09 January 2017 13:46:35(UTC)
Tom Thomson
I have a Marklin 1 Scale starter set with normal radius curves. Some longer cars and locomotives require wider radius curves. Sellers on eBay and elsewhere rarely specify the required radius. Is there a resource or guideline I can use to see if specific cars will require wider radius curves? Many thanks.
#2 Posted : 09 January 2017 16:29:05(UTC)
The Märklin product database and the Märklin catalogues usually indicate the minimum radius (600 mm for short items, 1020 mm for long items).
The product database includes items since 2000/2001 and for older rolling stock you should be able to find similar items in the database.
#3 Posted : 09 January 2017 19:30:46(UTC)
Hi Tom,
Tom (H0) has already answered with what you need but if it also helps, all Marklin track has the code printed/embossed on the track-bed or sleepers/tie and G1 is no exception. This may be useful if you get a seller who does not have the boxes and doesn't know the track reference.
If you are ever in any doubt, ask the seller to check and confirm the code - but be prepared for those who either won't check, or will swear they cannot find the code. It's not always that easy to see.
3600 TRACK Radius options ? (Collector's Corner general)
by 20-VOLT-AC 03/03/2012 13:59:12(UTC)
Biggest C-Track radius? (H0-scale)
by Eisenhower 13/08/2004 19:12:22(UTC)
C-Track Radius Compared to 18-24 inch Curves (H0-scale)
by Karl Pann 01/02/2004 16:25:52(UTC)
C Track Radius (H0-scale)
by tomh. 12/10/2003 13:09:26(UTC)
This page was generated in 0.368 seconds.
