2 Pages12>
Offline TrainIride
#1 Posted : 10 December 2016 11:04:00(UTC)
TrainIride
Hello Friends,
After the purchase of this mysterious and intriguing model,
I decided to restore its youth, as it was in 1959.
Thank you to marklincafe website for these 1958 catalog extracts:
thanks 8 users liked this useful post by TrainIride
Offline TrainIride
#2 Posted : 10 December 2016 11:20:46(UTC)
TrainIride
An interesting point:
This model has reversing lights :
thanks 5 users liked this useful post by TrainIride
Offline TrainIride
#3 Posted : 10 December 2016 11:48:30(UTC)
TrainIride
So,
let's start.
When I first put the lady on tracks, when feeding AC current, the loco was not moving.
I heard buzzing noise, lights blinking, well something wrong...
I thought it was a faulty reversing unit spring.
So I removed the loco body and saw this supernatural thing,
taking place instead of the reversing unit:
thanks 6 users liked this useful post by TrainIride
#4 Posted : 10 December 2016 11:50:15(UTC)
So,
let's start.
(snip repeated image)
yep! 3 rail DC.
Very popular in France Laugh
Edited by moderator 07 February 2017 02:25:11(UTC)  | Reason: Not specified
thanks 6 users liked this useful post by jvuye
Offline TrainIride
#5 Posted : 10 December 2016 11:56:41(UTC)
TrainIride
using a 9V DC battery between pickup shoe and wheels,
in one direction, and then in the other, showed me this weird component
was a kind of rectifier that was selecting one of the motor coils, depending on the current direction.
The wheels were turning OK in both directions with the DC current.
So let's remove this and see what's left in the loco :
Offline TrainIride
#6 Posted : 10 December 2016 12:01:08(UTC)
TrainIride
So,
let's start.
yep! 3 rail DC.
Hi Jacques,
Do you know what it is exactly ? a relay, a rectifier ?
Edited by moderator 07 February 2017 02:26:02(UTC)  | Reason: Not specified
Offline TrainIride
#7 Posted : 10 December 2016 12:29:44(UTC)
TrainIride
Give her back a heart:
fahrtrichtungsschalter #20824 needed
Done !
#8 Posted : 10 December 2016 12:58:07(UTC)
all the numbers you see on the spare part list you must add a "0" at the end your spare part number than becomes 208240
Offline TrainIride
#9 Posted : 10 December 2016 13:16:49(UTC)
TrainIride
Thank you John for the information,
now I have this table to fill ....
thanks 3 users liked this useful post by TrainIride
Offline TrainIride
#10 Posted : 10 December 2016 13:22:01(UTC)
TrainIride
And now the thing that intrigued me a lot.
20824 or 208240 wiring is like this :
thanks 7 users liked this useful post by TrainIride
Offline TrainIride
#11 Posted : 10 December 2016 13:30:41(UTC)
TrainIride
But it's written in then catalog that this model has reversing lights.
And the reversing unit has only one switch Blink .
So, how did Märklin engineers do to reverse lights and loco direction with only one switch ?
After many enquiries on internet
(and I would like to thank all the people who have posted these informations)
I found the documentation.
Offline TrainIride
#12 Posted : 10 December 2016 13:35:08(UTC)
TrainIride
The solution is described in chapter 13.2
of the Märklin Service Manual Handbook:
Offline TrainIride
#13 Posted : 10 December 2016 13:39:36(UTC)
TrainIride
which leads to this :
Offline TrainIride
#14 Posted : 10 December 2016 13:54:36(UTC)
TrainIride
So, to summarize this,
we use the opposite motor coil to feed current to the light bulbs.
Regarding documentation, it can only be done with old motor coils,
maybe because of a lower impedance.
The current for the bulbs must be lower than the current for the motor.
This way, the current fot the bulbs can be considered as a "leakage current"
With more recent motors, the magnetic field mus be totally cancelled.
So for the 3024 :
Offline TrainIride
#15 Posted : 10 December 2016 16:18:40(UTC)
TrainIride
Well,
this problem solved, let's continue with the beginning ...BigGrin
thanks 2 users liked this useful post by TrainIride
Offline TrainIride
#16 Posted : 10 December 2016 16:26:44(UTC)
TrainIride
To remove the body
The loco has two sides BigGrin
Side 1
Side 2
They are different
Side 1 is where the body is labelled "1" and where the chassis has the selector for catenary feeding
thanks 4 users liked this useful post by TrainIride
Offline TrainIride
#17 Posted : 10 December 2016 16:44:25(UTC)
TrainIride
Gently remove each bulb holder by turning the front screw.
The screws from each sides have different part numbers :
Do not mix them !
On side 1, the body has a small center hole :
On side 2, the body has a wider center hole :
On side 2, the body fits in a chassis kind of nose:
So to remove the body, it is necessary to slide the body horizontally a bit to extract the nose:
This one is a bit damaged ....
On side 1 chassis, there is no nose:
Offline TrainIride
#18 Posted : 10 December 2016 16:56:36(UTC)
TrainIride
The two sides from the chassis :
#19 Posted : 10 December 2016 18:15:46(UTC)
So,
let's start.
yep! 3 rail DC.
Hi Jacques,
A double diode (=rectifier) in fact. To make it compatible with 3 rail DC systems (e.g. JEP)
#20 Posted : 10 December 2016 18:20:30(UTC)
So for the 3024 :
In fact, it uses the dual wound coil as a "poor" (= inefficient) 1:1 transformer. Wink
Offline TrainIride
#21 Posted : 10 December 2016 19:23:15(UTC)
TrainIride
Hi Jacques,
thank you for these informations !
Joël
Offline TrainIride
#22 Posted : 10 December 2016 19:26:57(UTC)
TrainIride
Well, now the body :
Inside, no contact plate for the catenary power !!! Blink
I did not find any information on this. Crying
So If you have one ....
Offline TrainIride
#23 Posted : 10 December 2016 19:36:23(UTC)
TrainIride
and now replacing wear parts...
Well , everything ?? Smile
The loco has certainly run a lot (under DC current), considering all the brushes dust inside .
I did not recognise between the two brushes, which was the copper mesh, and which was the graphite Scared
Offline TrainIride
#24 Posted : 10 December 2016 19:40:26(UTC)
TrainIride
then, after a little make-up :
Offline TrainIride
#25 Posted : 10 December 2016 19:59:25(UTC)
TrainIride
By the way, let us talk about the brushes now.
#60030 and now 600300
the question is :
"is there a special place for the copper mesh ?"
The answer is "YES" found in the Service Manual:
There is a straight spring for the graphite one that press to the notch.
There is a bent spring that needs to enter in the mesh center.
Offline TrainIride
#26 Posted : 10 December 2016 21:39:25(UTC)
TrainIride
Now replacing the front and back couplers.
#201331 or now 2013310
the flat spring will press (enough ?) upon the front wheels to avoid derailment .
Due to the shape of these front gears,
the wheels will follow the coupler direction, and vice versa
Offline TrainIride
#27 Posted : 10 December 2016 21:53:41(UTC)
TrainIride
...And the new pickup-shoe
the unavailable #7174 is replaced by a #212010
even if the pickup shoe previously mounted on the loco seemed inappropriate,
the new one look a bit too long, (hoping this is the good part number, I had it in a box without reference)
The old locomotive uses a very thin contact plate to collect the current from shoe.
#28 Posted : 11 December 2016 11:19:50(UTC)
You're heading in the right direction....
So far your "trip of discovery" is perfect.
I suppose that when you cleaned the rotor you also cleaned the gear train that's behind it.
You'll soon have earned your Certificate of Aptitude for Official Vintage Märklin Maintenance and Repair Engineer!
Wink Smile
thanks 5 users liked this useful post by jvuye
Offline Unholz
#29 Posted : 11 December 2016 11:48:12(UTC)
Unholz
I agree with Jacques - although I don't have one of these models, this thread is better than any instruction manual. ThumpUp
Offline TrainIride
#30 Posted : 11 December 2016 13:23:35(UTC)
TrainIride
Wink Smile
Hi Jacques,
It is an honor for me to be selected for this C.A.O.V.M.M.R.E diploma ! Cool
Thank you very much !
Of course I cleaned the rotor gear, and the other ones around.
Unfortunately, I did not take a picture of it.
When I saw the 7 teeth gear condition, I told myself, "well, let's go to the dentist " BigGrin .
But it seems that in spite of its used state, everything is turning round...
We will see, with the future tests on tracks.
If not, it will be shown in the future "Troubleshooting" chapter.
Best Regards
Joël
Offline TrainIride
#31 Posted : 11 December 2016 13:31:03(UTC)
TrainIride
Thank you so much !
I have spent time to gather these informations and to make a synthesis,
so I wanted to share them on the Forum
that gave me the Vintage Märklin Repair Fever RollEyes
Don't hesitate to [THANK/LIKE] my posts BigGrin
Best Regards
Joël
Jayxxup
#32 Posted : 11 December 2016 14:47:15(UTC)
... When I saw the 7 teeth gear condition, I told myself, "well, let's go to the dentist " BigGrin .
Best Regards
Joël
Hi Joël
If you need some of these old 3 pole rotors with large or small flat commutators, let me know.
I have a pile of them here, recovered from 5-pole (hi-efficiency Wink Wink ) conversions.
Just tell me the number of teeth on the gear.
Jacques
Offline TrainIride
#33 Posted : 11 December 2016 15:55:47(UTC)
TrainIride
Hi Joël
Jacques
Thank you Jacques, Yes, I am interested.
it is very nice.
If the rotor is malfunctioning, I'll let you know.
Best Regards
Joël
Offline kamstutz
#34 Posted : 11 December 2016 21:27:47(UTC)
kamstutz
Wink Smile
Hi Jacques,
Best Regards
Joël
Joël - I too lust after the C.A.O.V.M.M.R.E diploma, but first I'll have to stop skipping classes on this forum (such as the thread you started) and return to the workbench. Many thanks for documenting the process you went through - both informative and entertaining (since I like to see vintage toys live again too.)
Kurt
Offline TrainIride
#35 Posted : 14 December 2016 20:47:43(UTC)
TrainIride
Kurt
Hi Kurt.
Thank you for being interested in my posts,
For sure you will have your diploma soon Smile .
To like resuscitating vintage toys is the first requirement to enter this school.
So you have already your first level ThumpUp
Best Regards
Joël
Offline TrainIride
#36 Posted : 14 December 2016 20:52:05(UTC)
TrainIride
Page 47 of the 1959 catalog...
...where we can see Lady E18 ( but in blue dress #3023)
Offline TrainIride
#37 Posted : 14 December 2016 20:59:11(UTC)
TrainIride
Well,
I wanted to take pictures of the wiring inside, but I found that the pictures were not clear enough.
So I decided to create drawings to explain the method.
1. At first, we need to solder a pair of wires on each poles of the reversing unit.
It is easier to to this before installing it, and by this way,
we do not have to touch the reversing unit too much.
Offline TrainIride
#38 Posted : 14 December 2016 21:02:53(UTC)
TrainIride
2. we need to solder the black wire of the reversing unit on the catenary switch :
Offline TrainIride
#39 Posted : 14 December 2016 21:07:15(UTC)
TrainIride
3. we need to connect the motor coils to the reversing unit.
For each coil, a test must be done to see in which direction the wheels are turning :
Offline TrainIride
#40 Posted : 14 December 2016 21:11:41(UTC)
TrainIride
4. the lights.
Once we have located which coil is which direction,
we can connect respectively the corresponding bulbs to the opposite coil Blink
And that's it !
Offline TrainIride
#41 Posted : 17 December 2016 16:23:20(UTC)
TrainIride
Now the wiring diagram is clearer,
Let us have a look to the inside.
Not a lot of wires, thanks to the common ground chassis ThumpUp
Offline TrainIride
#42 Posted : 17 December 2016 16:28:10(UTC)
TrainIride
Even if the reversing unit is "viewable",
You can understand it is better to solder on it before installing :
See the two pair of wires upon the reversing unit poles:
Offline TrainIride
#43 Posted : 17 December 2016 16:31:33(UTC)
TrainIride
The motor coils wires left after dismounting the rectifier were too short.
I used heat shrink tube to insulate the connections with the reversing unit cables.
Offline TrainIride
#44 Posted : 17 December 2016 16:33:30(UTC)
TrainIride
The wires for the light bulbs were soldered this way:
Offline TrainIride
#45 Posted : 17 December 2016 16:39:35(UTC)
TrainIride
Now the wiring is finished,
just a look at some outside details
The "Bicycle" logo on sides 1 and 2 :
"MARKLIN E18 35" on one side :
"3024E18 35" on the other side :
Offline TrainIride
#46 Posted : 17 December 2016 16:41:20(UTC)
TrainIride
The Lady is now ready to run !!
Offline TrainIride
#47 Posted : 17 December 2016 16:46:43(UTC)
TrainIride
A bit noisy, maybe because of the rotor gear teeth Smile ,
And great both flashing lights when reversing due to this special wiring.
Both coils are "opened" during this transition, so both coils are feeding current to the bulbs...
And see how the loco appreciates wide radius C-track turnouts !!
thanks 9 users liked this useful post by TrainIride
Offline DB Fan
#48 Posted : 17 December 2016 18:04:51(UTC)
DB Fan
Great video. Thanks for sharing the restoration from start to finish. Very helpful.
Robert
thanks 2 users liked this useful post by DB Fan
Offline TrainIride
#49 Posted : 17 December 2016 18:26:07(UTC)
TrainIride
Robert
Thank you very much Robert !
Best Regards
Joël
#50 Posted : 18 December 2016 04:28:17(UTC)
A seminar work,congratulations.ThumpUp
Guest (13)
2 Pages12>
This page was generated in 1.468 seconds.
