Offline Varun R
#1 Posted : 22 October 2014 11:11:30(UTC)
Varun R
I am trying to run 3 locos on the HO track with the 60653 mobile station. While all 3 locos are entered and recognised in the mobile station, the locos in the first 2 slots do not operate when the control knob is in these slots, and all 3 locos move simultaneously when the control knob is in the 3rd slot. Can any one advise how this can be sorted out?
thanks, Varun
#2 Posted : 22 October 2014 11:27:15(UTC)
Sounds like you have programmed the 3rd locomotives address and forgot to make sure it was the only locomotive on the track at the time. As such all 3 locos now have the same address.
You need to reprogram each loco one at a time ensuring it is the only one on the track.
Offline Varun R
#3 Posted : 22 October 2014 13:00:25(UTC)
Varun R
Thanks for your reply, but i have pragrammed each locomotive seperately, with only one locomotive on the track. I still can't figure out the problem.
Anyways, thanks for your help.
Varun
#4 Posted : 22 October 2014 13:03:57(UTC)
If they all move together then they must all have the same address. Maybe they came from Marklin on the same address. This is common for the "Hobby" and "My World" locos. Can you tell us the model numbers of the locos involved?
Offline Varun R
#5 Posted : 23 October 2014 04:32:18(UTC)
Varun R
Hi, thanks for your reply. Here are the 3 locomotives numbers:
29450 E 186 103
36140 T3 994
36740 BR 74 838
Offline BrandonVA
#6 Posted : 23 October 2014 14:40:07(UTC)
BrandonVA
Originally Posted by: Varun R Go to Quoted Post
29450 E 186 103
36140 T3 994
36740 BR 74 838
Every locomotive decoder has an address set. FX decoders like these can have duplicate addresses. I am not sure about 29450, but the other two locomotives (T3 and BR74) both have a digital address of 78. I am guessing 29450 is also 78. Since they all have the same address, when you sent them a command (drive, headlights, whatever), they will all react to that command.
What you should do is put one locomotive on the track at a time, and change the address so they are all unique. Many people suggest using the class under of the loco (e.g. BR74, use address 74) for the locomotive, so it's easy to remember the custom address.
On the MS2, if you hold down the red "shift" button, and press the button on the lower right with the locomotive picture, you will get a menu to modify the locomotive. You want to select "change loco", and then "address" in the next menu. You should be able to select unique numbers here. It may take a minute for the address to update on the locomotive.
-Brandon
#7 Posted : 23 October 2014 17:57:22(UTC)
What Brandon writes is correct.
Offline Varun R
#8 Posted : 24 October 2014 05:38:52(UTC)
Varun R
29450 E 186 103
36140 T3 994
36740 BR 74 838
-Brandon
Thank you so much for your help!
I programmed each locomotive seperately with different addresses, and now they are working fine.
Thanks guys for your help!
Varun
thanks 2 users liked this useful post by Varun R
Mobile Station 60653 (Digital)
by mramstedt 23/10/2021 18:53:42(UTC)
Mobile Station 60653 (H0-scale)
by Gunnar 27/09/2020 12:28:37(UTC)
Mobile station 60653 (Digital)
by Gunnar 09/09/2020 16:30:50(UTC)
by charles Sharpe 27/06/2020 13:54:42(UTC)
Mobile Station 60653 software ver. 3.3.5 (H0-scale)
by ParisTsirchoglou 12/02/2020 20:19:24(UTC)
Upgrading between Mobile Station 60653 and 60657 (Digital)
by aclassifier 13/02/2016 12:33:27(UTC)
Troubleshooting Mobile Station 60653 (Digital)
by elite194 22/05/2015 14:47:12(UTC)
Mobile Station 60653 (Big scale)
by Rocca 29/11/2014 14:38:58(UTC)
Mobile Station 60653 Freezing (Digital)
by Cyborg 10/03/2014 03:22:03(UTC)
Mobile Station 60653 Replacement Cable (Digital)
by chrisisrang 09/06/2013 02:47:25(UTC)
Mobile station 60653 (H0-scale)
by jackmac 21/09/2011 16:33:23(UTC)
Mobile Station 60653 - Reg 1 & 75 change (Digital)
by huttel 17/10/2010 12:44:54(UTC)
This page was generated in 1.088 seconds.
