Offline Bernt
#1 Posted : 31 January 2013 21:37:36(UTC)
Bernt
I have an old analog 3034 with a worn out motor.
Then i bought a 60943 motor but not with a decoder, i just want a new motor on my old ac system.
It does not work.
Can I expect it to work or do i need to upgrade to digital dc?
Offline tulit
#2 Posted : 31 January 2013 21:42:42(UTC)
tulit
The 60943 converts your motor into a DC motor, so no, just replacing the motor won't work on your conventional AC system.
If you put a appropriate decoder however (say the mLD or 60760), you can run it on your conventional AC layout with that new DC motor (make sure you have one of the newer white transformers otherwise you risk damaging the decoder!). In this case, even though you have a digital decoder inside, you don't necessarily have to run the train in digital.
thanks 1 user liked this useful post by tulit
Offline Mark5
#3 Posted : 31 January 2013 21:47:50(UTC)
Mark5
It does not work.
Hi Bernt,
Welcome to the Forum!
You should be able to find a replacement or repair it without having to convert to digital.
Are the gears worn out, or just the motor?
Photos would be helpful.
If you just want to run the one loco on the existing set, then just getting a new 3pole motor might do it, if there is indeed a problem.
Have you tried changing brushes and cleaning the motor, etc?
... I love the 3034. Was one of my first engines years ago!
And my first and only electric until 35 years later.
Mark
Offline Bernt
#4 Posted : 31 January 2013 22:31:01(UTC)
Bernt
Thanks for the swift responses!
The 3034 is my first locomotive. I got it 45 years ago. It is a bit of nostalgia.
Think it is the motor that needs to be replaced.
No problem to buy a decoder.
I have a grey trafo.
Do i Also have to Get New lamp holders?
Offline franciscohg
#5 Posted : 31 January 2013 23:24:44(UTC)
franciscohg
Chile
only if you plan to run on digital and are too annoyed by the flicker lights....
and you can always do it later
Offline eroncelli
#6 Posted : 01 February 2013 12:45:34(UTC)
eroncelli
What do you mean with "worn out": may be just new copper/graphite brushes would do to fix the problem.
Or a full clean out.
Pictures and bettre description would be useful for a bettter advice
No need to install a decoder if you just plan to keep it "analog".
Anyway spare parts are available on internet (and some also from Maerklin and local dealers)
Offline Bernt
#7 Posted : 03 February 2013 17:38:22(UTC)
Bernt
Thank you for your advice!
I installed a decoder and now it works excellent
Offline pa-pauls
#8 Posted : 03 February 2013 19:36:18(UTC)
pa-pauls
Good evening Bernt,
If you need any help in the future send me a pm (private message)
I live in the city Moss just south of Oslo,,,
Pål
Pål Paulsen
#9 Posted : 03 February 2013 21:16:56(UTC)
That's the first and best thing to do to start repairing any old motor.
I'm glad you got it going!
Offline Dennis H.
#10 Posted : 13 February 2013 13:20:38(UTC)
Dennis H.
Great news you got it running with the decoder.
I just wanted to say one could also install a rectifier off of the old reverse unit before the new dc motor. I've done that with MTH O loco's when the board fried. Worked fine...but of course there is more room in O LOL
Dennis H.
If it's old and broken, I like it
#11 Posted : 13 February 2013 22:31:52(UTC)
Velkommen Bernt!
I can also be of assistance, like Pål I also live south of Oslo, on the way to Moss...
#12 Posted : 24 February 2013 03:22:52(UTC)
Welcome Berndt,
I sometimes can solve problems also but my assistance is miles away.
I have 2 of the later versions DB BR 141 one of them is Primex.
Motor upgrade (Digital)
by Mjn2ts 19/01/2025 22:44:27(UTC)
Motor upgrade for Marklin 34641 and 34642 (General MRR)
by rustya 03/09/2024 02:14:25(UTC)
Märklin Motor Upgrade, Which Kit? (H0-scale)
by frickwg 29/01/2020 23:09:29(UTC)
Marklin motor upgrade questions (H0-scale)
by lewistrain 05/03/2018 11:12:17(UTC)
Marklin 29785 motor upgrade (Digital)
by acwertheim 27/08/2012 02:29:24(UTC)
Marklin decoder and motor upgrade kits (Digital)
by RayF 16/03/2012 10:49:02(UTC)
6094X Motor Upgrade Kits (Digital)
by mmervine 10/12/2011 19:59:48(UTC)
This page was generated in 0.396 seconds.
