#1 Posted : 19 May 2011 07:25:05(UTC)
Troops and digital experts,
I have a problem and I think what I want to do is maybe not possible.
Problem.
I am going to have a shuttle train but wanted to run 2 shuttles, so put in a passing loop on the shuttle line, installed some isolating tracks and S88 box.
For testing I used one train only and 2 S88 ports.
When setting up for the second train, eg more contact tracks and Ports 3 & 4.
Now without trying, in my mind it will not work as train no 2 when starting from Station 2 will trigger S88 Port 2 stopping Train one where ever it is and reverse it.
Same Train one starting from Station 1 will trigger Port 4 stopping train 2 and reversing it.
Is there a solution to allow the 2 trains to go the full distance from station 1 to station 2
Or is the only solution is to have a station at the mid point.
Thanks Nev
Offline supermoee
#2 Posted : 19 May 2011 09:36:50(UTC)
supermoee
Hello Nev,
you need to add a relais which is switching the S88 contacts dependig on which train is in the station at the moment.
So you will have 2 separated shuttle lines with different S88 numbers on the same track.
to be clear, the S88 contact is n° 4 when train two is in the station and n° 5 when train one is in the station.
You can foresee for example, that train one has a magnet and comanding a reed contact. when he enters into the station, he will switch the relais on his contact numbers. when coming out from the station, he is switching the contact for train two through a normal pick up shoe contact.
there are a lot of possibilities.
rgds
Stephan
#3 Posted : 19 May 2011 09:45:41(UTC)
I am not very familiar with the S88 and circuits required for automatic operation. My knowledge is more related to prototypical operations in this regard.
That being said, there are several ways to operate two shuttle trains on the same route. You could build a passing lane (or intermediate station) where the trains would meet. This would be similar to a traditional funicular and can be found on many local and regional routes in normal train operation. It would not be necessary for both trains to stop. You could designate one as local (with stop) and the second as a through train that would continue straight through.
Another option would be to equip the end stations with dual tracks. This way, you could program your operation so that the train on track X would depart once the train on track Y had entered the station. The same sequence would occur on tracks A and B in the other station. This would mean that only one of the two trains would be in motion at any point in time.
#4 Posted : 19 May 2011 10:37:58(UTC)
You could make it dead easy and just run two separate tracks. Might not be what you want but one of the tracks can then branch off for bit to another station etc. Makes life simple.
dave
Offline frankie
#5 Posted : 19 May 2011 12:37:13(UTC)
frankie
I had a similar need while using LocCommander, not shuttle trains, but using the same contact for various purposes.
In that case I have used the train speed as a condition for the contact to be activated or not or to excute different tasks.
Then you can use different speeds for different shuttles and execute different routes depending the condition set.
Alessandro
I have a CS1 Reloaded!
Offline dntower85
#6 Posted : 19 May 2011 19:19:28(UTC)
dntower85
You have been a member since:: 08/01/2006(UTC)
Nev,
You could try using magnetic Read contacts,
mount one read on each side of the track at the stopping point
On shuttle train 1, mount the magnet on the left side of the train
On shuttle 2, mount on the right.
Now the trains are programed to their own feed back circuits.
Now the ECos and other programs will thank that they are on two separate tracks.
DT
Offline dntower85
#7 Posted : 19 May 2011 20:20:35(UTC)
dntower85
Running by computer
You could have a block at either end at the stations
Then have a one block for each passing track
4 sensors still required.
For give the crude text drawing.
fb = s88 feed back sensors.
........................................... block P1.....................................
..........................//========fb4===========\\.................
=fb1=================fb3=====================fb2=
Station....................................block P2.................................Station
..A...........................................................................................B...
DT
Offline Nielsenr
#8 Posted : 19 May 2011 20:39:40(UTC)
Nielsenr
It would be great to have a section here on the forum that would list details on these types of circuits and operating modes. Detailed wiring diagrams could be added. Both computer controlled and CS controlled circuits could be added. I am sure what some people have done could spawn new ideas from others. As an example, I have been playing around with a concept of having a two track layout split into four tracks at a station with trains alternating stopping at the station. But if a freight train comes to the station, it would bypass the station to a fifth track. Any other trains approaching or in the station would have to wait until the freight passes. Although I normally use contact tracks, the freights would be recognized by reed contacts. Still an idea in development, I haven't tried anything yet. Maybe if the Wiki would be a good place to put it if the Wiki gets off the ground. Just a thought ...
Robert
Offline dntower85
#9 Posted : 19 May 2011 20:48:32(UTC)
dntower85
Robert
Robert
RocRail allows you to define blocks with permission you could set it up so that the fifth block would allow freight and the others would deny it.
I have only been working with Rocrail for a few weeks now but after fighting with it for a few weeks I now like it.
DT
Offline kbvrod
#10 Posted : 19 May 2011 21:37:35(UTC)
kbvrod
Nev,sorry but what type of train are you shuttling?Smile
Dr D0
#11 Posted : 19 May 2011 23:21:59(UTC)
Nevie, did Peter's software not work for you?
#12 Posted : 21 May 2011 11:11:05(UTC)
OOOOOooooohhhhhh a very serious Seniors moment . It was so long ago I forgot.
Found it today now to work out how to use it.
Help Peter??????
Peter. will it work with S88 Contacts?????
NN
Edited by user 22 May 2011 01:14:29(UTC)  | Reason: Not specified
Guest (4)
Wiring for shuttle trains. (Model railroad wiring)
by IBtrain 22/11/2021 20:46:29(UTC)
shuttle trains. (Digital)
by charles Sharpe 03/07/2008 23:10:36(UTC)
Help with shuttle trains- solved (Digital)
by ria 04/04/2008 14:13:09(UTC)
This page was generated in 0.398 seconds.
