Offline choochin3
#1 Posted : 16 May 2009 07:18:44(UTC)
choochin3
Hello Folks,
I purchased two Trix Express coaches that I beleive were made in the late 80's.
Are these compatible with my Marklin equipment?
The couplers are some strange type of loop couplers.
Carl T.
I'm Out Choochin!
#2 Posted : 16 May 2009 15:19:36(UTC)
Hi Carl, welcome to the forum. You could send an email to TTRExpress (Maurice), he is our resident Trix Express expert. Look him up in the list of members.
Offline spitzenklasse
#3 Posted : 16 May 2009 16:29:04(UTC)
spitzenklasse
I think they are Marklin compatible.
Offline WelshMatt
#4 Posted : 16 May 2009 19:50:00(UTC)
WelshMatt
Only one way to find out, put them on the track and see if they run! biggrin
Matt from Wales.
Offline TTRExpress
#5 Posted : 16 May 2009 23:27:04(UTC)
TTRExpress
Hi Carl,
Welcome to the forum. Thank you Bigdaddy for the compliment, I know enough about TRIX Express to be dangerous..... expert I am not sure yet!!
TRIX Express coaches will run on your Maerklin track but you will need to change out the wheel sets. If the TRIX Express coaches came with the larger flange wheels they will not operate properly on any Maerklin track as the rail profile height is too low for them. Which TRIX Express coaches did you acquire? I can then let you know which wheel sets to exchange them with.
In order to use these coaches with other Maerklin ones you will also have to exchange the couplers. TRIX Express (TE) had many different coupler types on its coaches etc. so without knowing what models you have I cannot recommend anything at present. If the coaches have NEM pockets then the fix is easy, you simply remove the TE ones and replace with close-or Maerklin loop NEM couplers.
Let me know what models you have and I can further advise.
#6 Posted : 17 May 2009 01:20:08(UTC)
Welcome to the forum, Carl.
Offline obxbill
#7 Posted : 17 May 2009 01:26:56(UTC)
obxbill
Views messages in topic : 1,300
Welcome to the forum, Carl! It's a good place to be.
Bill
Offline mmervine
#8 Posted : 17 May 2009 01:29:40(UTC)
mmervine
Welcome Carl! The forum members here have lots of great ideas and are eager to help!
Offline choochin3
#9 Posted : 17 May 2009 07:00:16(UTC)
choochin3
Thanks for the welcome,and the info.
I'll get up in the attic tomorrow to get the numbers of those coaches.
I have always been a fan of European type trains,and only in the past 2 years I have strated to collect them.
I only have 2 Marklin small tank locos,a 0-6-0t,and a 2-6-0t.
I hope sometime soon to get some diesel,or electric power.
Carl T.
I'm Out Choochin!
Offline Brakepad
#10 Posted : 17 May 2009 10:52:48(UTC)
Brakepad
France, Metropolitan
Maurice,
May be this post is slightly off-topic, but can you help me?
I got some time ago a Trix-Express TEE car set, like this in the picture, to use it with my 3053
As you can see, the set has some kind of "mixed" couplers. It seems that couplers can not be dissassembled from the bogie. Is it possible to replace these ones or should I replace the complete bogie? Is there a source for spare parts?
In addition, in some cases the small part which holds the buffers (a sliding bar which includes the buffers) is missing. This part is very similar to some Rowa cars I've seen. Is it possible to find this part somewhere? I like the detailing on these cars very much and I'd like to keep them, but If I can not find suitable couplers for Märklin I'll sell them. Any advice on their value?
Many thanks.
Offline TTRExpress
#11 Posted : 17 May 2009 23:16:20(UTC)
TTRExpress
Hello Brakepad,
The couplings you have on these TRIX Express/Roewa coaches come as a single unit that is attached to underside of the bogies. These coupling types (you have a combination of Express and International) are no longer manufactured and spares of them are hard to find. The old catalogue numbers are 43-3377-78 (Express) 56-6660-00 (International).
I think the easiest "fix" for you is to simply install a TRIX Express NEM coupler part number 33336258 in the NEM pocket of your locomotive or of a coach of similar type that has an NEM pocket. That way you can keep the integrity of the TRIX Express coaches and couple them as is.
The buffers may be replaced by TRIX part number 42-2478-88. You could also do a search on E-bay. There is a gentleman in Canada who offers replacement buffers for Fleischmann, Roco, TRIX. I have a couple of sources through IG TRIX Express that I may be able to put you contact with for those buffers if that does not work for you. Just send me an E-mail and we can proceed if you would like.
Offline choochin3
#12 Posted : 18 May 2009 00:17:51(UTC)
choochin3
Well I dug those passenger cars out of the attic today.
The first is numbered 53 3352 00,and is Cream/Blue with a grey roof.
The roadname is DB,and looks like a baggage car.
The second car is numbered 53 3383 00,and is maroon/yellow with a silver roof.
It has DSG Schlafwagen on the side,looks like a sleeping car.
Sorry I can take photos of them though.
Carl T.
I'm Out Choochin!
Offline TTRExpress
#13 Posted : 18 May 2009 01:04:31(UTC)
TTRExpress
Hi Carl,
I have images of these coaches and in fact have some myself. They are mid 1980's vintage. As I mentioned to Brakepad in a prior post, you will not be able to change the couplings as they are unique to that series of coaches so exchanging them for Maerklin ones will not be easy without major changes to the bogies.
You can exchange the wheels with Maerklin AC wheels sets. If your locomotives have NEM coupler pockets you will be able to use them to pull these coaches if you exchange the Maerklin couplers with TRIX Express NEM coupler part number 33336258.
Hope this helps.
Offline choochin3
#14 Posted : 18 May 2009 01:49:02(UTC)
choochin3
I'll probably just leave everything as is.
That way I have an excuse to buy some TTR epuipment.biggrin
Carl T.
I'm Out Choochin!
Offline TTRExpress
#15 Posted : 18 May 2009 04:52:21(UTC)
TTRExpress
Hi Carl,
There are items for TRIX Express and TRIX Twin that come up for sale on E-bay. Remember TRIX Express and TRIX Twin operate on a different circuitry than Maerklin and different track. You can operate Maerklin on TRIX track but not vice-versa.
Good luck in your endeavors.
Offline Brakepad
#16 Posted : 20 May 2009 01:23:53(UTC)
Brakepad
Thanks for your informations, Carl.
Best regards.
Trix Express tree 5529 (H0-scale)
by Allen Lee 01/01/2025 06:15:05(UTC)
Trix Express with four locomotives. (Faller collectibles and other vintage accessories)
by pamgb1963 23/10/2019 22:21:59(UTC)
Trix Express club day 20 November 2016 at De Bilt - Holland (Events, forum member meets, exhibitions & TV shows)
by kweekalot 20/11/2016 20:12:00(UTC)
Trix EXPRESS conversion (H0-scale)
by nevw 16/02/2013 23:40:55(UTC)
TRIX Express VT75 from the 1950’s converted to Märklin (Collector's Corner general)
by Micha 19/10/2012 19:21:46(UTC)
What's Trix Express ? (General MRR)
by 2ndChancer 31/08/2007 06:01:17(UTC)
Trix Express (H0-scale)
by DamonKelly 05/03/2007 14:51:31(UTC)
old TRIX EXPRESS trains (Digital)
by marklinologos 09/12/2006 12:18:17(UTC)
Trix Express? (H0-scale)
by rugauger 11/03/2006 17:48:00(UTC)
This page was generated in 0.479 seconds.
