Offline bobboone
#1 Posted : 28 September 2004 17:07:48(UTC)
bobboone
I am making a new track with around 60 switches and will use for this viessmann 5211 and marklin K83.
how can I make it work when using a intellibox and 2 boosters and 4 marklin 32VA power supplies. Can I find anywhere some drawings how to connect properly all the 5211 and how to diverse the power to the different 5211 and K83's.
I hope I am clear enough?
Thanks in advance
Offline McLae
#2 Posted : 28 September 2004 20:03:22(UTC)
McLae
Each K83 has red and brown sockets (Pair on each side). Connect these to track power. They do not draw much power unless you are throwing a switch, and then only one is active at a time.
5211 has the same (4) Red and brown sockets, connect these the same as k83. 5211 also has extra Red socket (with red dot *). You can connect this to seperate red (or yellow) wire if you wish. I just jumper this to other Red sockets.
5211 and k83 use so little power that it may not be worth the bother to assign each k83/5211 to specific booster/traffo.
Hope this helps.
The McLae
Offline Lars Westerlind
#3 Posted : 28 September 2004 20:14:26(UTC)
Lars Westerlind
[size=1" face="Verdana" id="quote]quote:Originally posted by McLae
Hope this helps.
True,
unless you connect turnouts which have lamps connected to yellow cable (M-track) or signals with the same (70xx and 7188). These items could be changed internally with a new cable for the lamp.
Or, connect such items to 5211 and use the extra socket.
There is no need to connect k83 and 5211 to different trafos. However, it could make some sense not to drive trains on this circuit; it makes throwing safer.
/Lars
Offline kimmo
#4 Posted : 29 September 2004 18:26:08(UTC)
kimmo
[size=1" face="Verdana" id="quote]quote:Originally posted by Lars Westerlind
<br />There is no need to connect k83 and 5211 to different trafos. However, it could make some sense not to drive trains on this circuit; it makes throwing safer.
Like Lars above, I also recommend to separate the accessory decoders from track power. When a solenoid throws, it can draw as much as 700mA. If you have several trains running at the same time, and they are in the same circuit, behind one 32VA trafo, the switching may become unreliable. A simplified wiring diagram for separate track and accessory circuits can be found from my web-site:
http://personal.inet.fi/...kinen/Power%20Scheme.gif
Kimmo
Offline McLae
#5 Posted : 29 September 2004 22:19:51(UTC)
McLae
Very good diagram Kimmo.biggrinbiggrin
Much easier to see than to say (for me at least[:p])
The McLae
How to register viessmann 5211 on cs3 (Digital)
by geir 25/01/2025 18:28:43(UTC)
75491 turnout solenoids + Viessmann 5211 (Sanity check) (Model railroad wiring)
by Roland 09/11/2020 19:08:01(UTC)
Viessmann 5211 burnt diode (Digital)
by PMPeter 05/06/2019 22:27:00(UTC)
Marklin HO electric uncoupler and Viessmann 5211 digital decoder (H0-scale)
by zev kahn 19/04/2017 05:55:22(UTC)
Wiring the Viessmann 5211 Decoder (Digital)
by Jabez 13/10/2016 19:47:58(UTC)
Viessmann 5211 and turnout problem (Digital)
by Rwill 25/03/2016 20:03:02(UTC)
Semaphore signal Viessmann 4500 and digital decoder Viessmann 5211 (Digital)
by nasargy 14/09/2015 10:24:40(UTC)
Problem with Viessmann 5211 (Digital)
by DumbGuy 14/12/2013 07:25:47(UTC)
12 V DC power supply to Viessmann 5211 (Digital)
by DaleSchultz 10/11/2013 17:21:36(UTC)
Viessmann 5211 connection question (Digital)
by gachar001 16/04/2009 18:07:58(UTC)
Viessmann 5211 question (Digital)
by gachar001 16/03/2009 22:34:18(UTC)
Viessmann 5211 Decoders (Digital)
by dpg001 24/11/2008 00:43:49(UTC)
Viessmann 5211 Decoder conn. Marklin Central Stat (Digital)
by dpg001 28/10/2008 14:18:20(UTC)
Viessmann 5211 connection to 24630 3-way turnout (Digital)
by svgeorgiad 19/05/2007 20:29:36(UTC)
Buiding a Viessmann 5211 (k83) from a kit (Digital)
by DaleSchultz 19/03/2007 04:50:32(UTC)
CS can't see my Viessmann 5211 decoder (Digital)
by soeren 21/05/2006 17:56:47(UTC)
CS and Viessmann 5211: nothing happens (Digital)
by soeren 11/03/2006 10:19:45(UTC)
Viessmann 5211 - M-track switches failure (Digital)
by fvri 14/11/2005 18:04:33(UTC)
Fried Viessmann 5211 (Digital)
by kimmo 23/03/2004 11:45:14(UTC)
Viessmann 5211 Question (Digital)
by mascagni 02/12/2003 19:22:03(UTC)
Viessmann 5211 Wiring (Digital)
by xxup 23/08/2003 16:42:46(UTC)
This page was generated in 0.389 seconds.
