Offline gachar001
#1 Posted : 16 March 2009 22:34:18(UTC)
gachar001
India
Does the Viessmann 5211 work with the CS2? I am planning to digitize my turnouts and the reviews for the Viessmann decoders in this forum were better than the ones for M*. Also, the fact that the Viessmann decoders can be powered by a separate transformer is appealing.
Thanks.
Gautham
Atlanta, GA USA
#2 Posted : 17 March 2009 07:43:36(UTC)
Gautham, they should do. The V5211 is functionally equivalent to the Marklin 60830 K83 decoders.
Offline frankie
#3 Posted : 17 March 2009 12:15:47(UTC)
frankie
I use that configuration with a CS1, 5211+5215, quite effective for a small layout.
Alessandro
I have a CS1 Reloaded!
#4 Posted : 17 March 2009 12:23:25(UTC)
<u></u>ATTENTION...!
The warranty dissapears,if you are using unknown digital products instead than of Marklins products...!
Offline Writhdar
#5 Posted : 17 March 2009 23:42:01(UTC)
Writhdar
Frankie,
If you use a separate transformer (e.g., 6646 or 6647) to power the turnouts & 5211's, can the 5211's be connected directly to the transformer or do you need the 5215 between the 5211 and the transformer? Thank you
Dan
Offline frankie
#6 Posted : 18 March 2009 10:09:40(UTC)
frankie
Either way, you can power them directly from the transformer, Bigdaddy I believe use this config, or use the 5215 in between for that extra pulse.
Inside the 5215 there is just a relatively big capacitor, that's all.
Alessandro
#7 Posted : 18 March 2009 10:13:11(UTC)
Yes that is correct Alessandro. I'm using a direct transformer feed with no 5215. Haven't had any issues as yet.
Viessmann 5211 Question (Digital)
by mascagni 02/12/2003 19:22:03(UTC)
This page was generated in 0.542 seconds.
