Offline SteamNut
#1 Posted : 21 September 2013 02:08:43(UTC)
SteamNut
My set is M track and is all analoge and will likely remain so. My questions deal with smoke units as I have to replace some and maybe add some.
Will smoke unit 7226 work with Delta lok 33911?
Will smoke unit 72270 work with lok 39390?
For loks 3048 and 3047 is 7226 the correct replacement number?
Thanks in advance, Fred
Offline franciscohg
#2 Posted : 21 September 2013 02:13:18(UTC)
franciscohg
Chile
Hi, 7226 is correct for 3048 and 3047
Dont have the two others, but check your manual......
Offline SteamNut
#3 Posted : 21 September 2013 02:25:58(UTC)
SteamNut
Thanks for the information I know the other ones are the correct number but I am not sure if they would work on a analoge layout,
#4 Posted : 21 September 2013 03:00:06(UTC)
Originally Posted by: SteamNut Go to Quoted Post
.......... but I am not sure if they would work on a analoge layout,
Yes, they do work on analog.
The 7226 is a Seuthe 10, and is designed for a voltage between 10 - 16v.
The Seuthe 11 is designed for voltages between 16 - 22v, and is more suited if being feed directly from the track power on a digital layout. AFAIR, the only time that Marklin hasn't recommended a 7226 smoke unit for their locos that take them was for one of the Big Boys - 37992 I think it was, and for that you need 2 Seuthe 11's.
Likewise, 72270 is the same as a Seuthe 20, and is designed for a voltage between 10 - 16v. The Seuthe 24 is designed for voltages between 16 - 22v, but otherwise is the same size as 72270 / Seuthe 20.
From memory 39390 is the Br39 (I have one myself) and the correct smoke unit is 72270 - this will be detailed in the loco's manual.
I haven't fitted the 72270 I have to my 39390 as yet, but I believe you have to be careful in fitting it, as there have been some issues with wires, etc (or something to that effect) touching the smoke unit and burning through as a result.
There are some previous threads in the forum about that, try to search on '39390 smoke unit' to find them.
Bigdaddynz attached the following image(s):
#5 Posted : 21 September 2013 03:12:47(UTC)
That search only brought up this thread! So much for my searching skills!
Here's the main thread re the 39390, and in page 6 and onwards there are mentions of the smoke unit issue.
https://www.marklin-user...osts&t=13930&p=6
Offline SteamNut
#6 Posted : 21 September 2013 04:17:06(UTC)
SteamNut
Thanks for all the info ! Tomorrow I will go shopping.
Ac analog smoke units (H0-scale)
by Keim 09/03/2024 02:10:54(UTC)
Smoke units - can you tell the difference? (General MRR)
by ocram63_uk 21/01/2023 17:14:26(UTC)
eCig fluid in smoke units (General MRR)
by ocram63_uk 10/03/2019 14:16:06(UTC)
Adding Wires to Seuthe Smoke Units (General MRR)
by skeeterbuck 03/11/2018 17:21:56(UTC)
Smoke units and there use (H0-scale)
by danmarklinman 27/12/2017 23:15:25(UTC)
Why Do Smoke Units Fail? (General MRR)
by SteamNut 26/10/2017 22:12:54(UTC)
smoke units for Lady C (Württembergerin) locos? (H0-scale)
by DaleSchultz 11/03/2017 04:50:53(UTC)
3102 with 6090 - Smoke Units and Lights not working anymore (General MRR)
by mb300e4m 27/02/2017 21:39:06(UTC)
Marklin 7226 & Marklin 72270 Smoke Units (General MRR)
by skeeterbuck 20/01/2016 19:36:23(UTC)
7226 Smoke Units - does anybody try to maintain these ? (H0-scale)
by Johnvr 07/09/2013 12:51:23(UTC)
Smoke Units identifications (H0-scale)
by ac jacko 18/06/2011 04:42:10(UTC)
smoke units for dummies (H0-scale)
by dlarson 22/05/2008 19:20:01(UTC)
smoke units for buildings (Model kits & layout details, kitbashing and such)
by prc 04/01/2006 05:04:47(UTC)
This page was generated in 0.426 seconds.
