Offline Don Morris
#1 Posted : 28 July 2023 03:13:33(UTC)
Don Morris
Not sure whether this is the right place to ask this or not.I am considering installing a set of staging yards on my layout. I wonder if this setup would work, i think it would but probably quite wrong. A onntract track, (wheel activated), connected to a s88 which goes to an cs3, cs3 linked to k83 which would activate the signal or turnout. Am i dreaming? Thanks in anticipation, i cannot find this option in any Marklin publications. Ted
thanks 1 user liked this useful post by Don Morris
#2 Posted : 28 July 2023 12:50:29(UTC)
Of course you're dreaming, we all conceive ideas that way. Firstly, yes you need a contact track block section, to trigger the events for turnouts, and signals which the CS3 can be set up to do. K83s are older, first generation digital. I have a CS3 plus, so I didn't need an S88 connect module. In either set up, the S88 decoders connect to the contact tracks. Using the feedback triggers from these, the CS3 activates the turnout decoders and or signals as programmed in the events.
Others will chime in,so you'll get plenty of advice.
I began with the big CS3 book, and watching the tutorial webinars on YouTube.
Offline Don Morris
#3 Posted : 30 July 2023 23:17:43(UTC)
Don Morris
Thanks for that, i am using analogue signals and turnouts, so I presume I need decoders on each of these>
#4 Posted : 30 July 2023 23:44:19(UTC)
The Marklin running trains digitally book I would say will give you all you want to know. After reading if you have problems then this is the place to ask. With your CS3 you can fit turnout decoders which will register themselves and along with signals can be added to an event in the CS3.
Going slowly is best just adding one item at a time to see how it works.
#5 Posted : 31 July 2023 01:38:24(UTC)
Hi Don
It is up to us to make our dreams come true.
Not sure if it would help, but on my layout I have 3 hidden fiddle yards to store trains in shadow stations.
Here is the layout during the testing phase without any landscape
In my case, I use Rocrail, a Märklin CS3 and train detection by occupation zones which are scanned by the CS3 and then the info is shared with my laptop on which Rocrail is installed.
Rocrail operation
- RR follows in real time where is each loco / train and can execute complex decisions based on train length, train type (electric, diesel, steam) train category (slow good, express, international, railcars, etc
- RR allows to declare (not obliged but this is an added possibility) each loco and wagon length, which wagon making each each train
- this allows to avoid sending a train in a block that is too short.
- in complex track arrangements, RR allows to reserve itineraries to avoid collisions
What is the difference between RR management and a set of events programmed on a CS3
- one major difference is that a CS3 is blind (does not know which loco is where. The result is to control trains by signals using stop and slow-down sections
- on RR, because it knows which loco / train is where, to stop or slow down a loco at a block, NOTHING is needed (signals relays, track insulation) except the detection zone. The result is a simplified wiring.
- because trains are controlled by digital (and not by switching off the current), the result is ANY train can be pushed from the rear (Shuttle operation) and STILL obey signal location (stop at the right place w/o complex slider inversion relay, etc.
Here is another video of the RR train management
Notice at the end of the video, the marshalling yard operation
Notes:
- RR is easy to learn PROVIDED you start small, use the provided demo layout.
- RR allows can provide support with its forum (also in English)
- RR allows a fishbowl operation (all trains go where they can depending on track avaliability, permissions, length etc
- RR allows to create schedules (at a specific time, Train Y goes from A to X through blocks B? C?D?...
- RR starts by being simple with little parameters to enter and then offers you additional possibilities with more parameters
Sorry for being so long but there is no real limit to your dreams
You may start with RR, your usual PC and a cable (CAT5 in my case) and you pay RR ONLY when you are satisfied (what you want when you want)
I am just a regular RR user (not selling anything here
Just for the road, another video about shadow stations and Faller Car System
Esu mobile control 51100 (Digital)
by mvd71 27/03/2024 04:42:40(UTC)
Controlling a second layout. (Digital)
by Model Railway shed D 23/02/2024 15:08:20(UTC)
Marklin 88320 and control tracks (Small scale)
by Steve444 21/02/2024 03:13:12(UTC)
CS3 Cannot edit control boards when connected via Browser (Digital)
by malsnake 17/02/2024 03:51:24(UTC)
43630 I.C. digitalcab control car (Digital)
by marklinist5999 23/01/2024 14:31:29(UTC)
HO Cab Control Cars for HAG BLS Auto Transport Train? (Prototype)
by 5HorizonsRR 20/01/2024 20:29:25(UTC)
sw layout control (Model railroad software)
by fvelazdem 03/01/2024 13:51:05(UTC)
Cab Control Car No. 43831 - Assistance Please (General MRR)
by camcath 10/12/2023 08:06:46(UTC)
remote/relay power controller? (Model railroad wiring)
by MikeEK 27/11/2023 09:34:43(UTC)
Unable to get more than 12 functions Using Control Unit 6021 (General MRR)
by waterslip 20/11/2023 14:37:35(UTC)
New software: TrainControl for Marklin Central Station 2 and 3 (Model railroad software)
by moman2 10/11/2023 23:20:03(UTC)
Confused over point control box (General MRR)
by Model Railway shed D 03/11/2023 11:12:14(UTC)
Two connecting tracks and power control sticks (322979) on same track (Digital)
by trainman11 26/10/2023 12:41:04(UTC)
Z gauge controls (Small scale)
by Stowbooty 23/09/2023 00:10:30(UTC)
Controlling points please help. (General MRR)
by Model Railway shed D 22/09/2023 11:25:29(UTC)
Need updates for my MS2 Controller- Fort Wayne, Indiana (Digital)
by vnangli 10/09/2023 19:33:14(UTC)
ESU Command Control and MARKLIN 241A (Digital)
by Jaguar 04/08/2023 19:49:56(UTC)
67013 controller (General MRR)
by MikeEK 31/07/2023 10:23:03(UTC)
Help with IR controller Startset 29163 (Digital)
by Steveknz 14/07/2023 09:15:42(UTC)
Marklin Circuit Track and Train Controller (Model railroad software)
by garben 20/06/2023 17:17:09(UTC)
Use of Signals instead of Stop Markers in Train Controller (Model railroad software)
by garben 19/05/2023 20:18:57(UTC)
Train Controller and Marklin 3 Aspect signal. (Model railroad software)
by garben 14/05/2023 16:20:47(UTC)
Connector and cable for analog controlboard (General MRR)
by einotuominen 13/05/2023 12:01:16(UTC)
Alterative controller for Marklin 74861 turntable (General MRR)
by rustya 02/05/2023 02:19:02(UTC)
Train Controller Gold sees Blocks only on the Direct S88 (Model railroad software)
by punksie1 28/04/2023 21:49:51(UTC)
Rocrail skips action control (Model railroad software)
by einotuominen 12/04/2023 13:01:38(UTC)
Control Station CS-2 (General MRR)
by LT.Iglehart 15/03/2023 16:40:14(UTC)
Having passengers lights control when loco is starting (Digital)
by Puttputtmaru 15/03/2023 15:05:41(UTC)
digital 74461 with 72710 controlbox (General MRR)
by gladop 10/03/2023 23:14:20(UTC)
Marklin 39621 Lockup on 6021 controller layout (Digital)
by SteveK-O 03/03/2023 15:46:46(UTC)
RailControl Pro — CS2 and CS3 controller for iPhone, iPad and Mac (Model railroad software)
by northstar 24/02/2023 15:29:28(UTC)
Two new digital cab control (Digital)
by Goofy 22/01/2023 08:35:09(UTC)
Help! xmas tree layout controller frozen (Digital)
by JetForMe 25/12/2022 10:55:08(UTC)
Better quality controller (Small scale)
by Donb 23/12/2022 19:43:04(UTC)
Transformer Control of Marklin 3088 Engine & 1071 Motor (General MRR)
by mjborelli 05/12/2022 19:32:12(UTC)
Using MS2 to control Brawa LOK with Brawa Premium-Digitaldecoder version 3.0 (Digital)
by Johnny rum rider 20/11/2022 14:20:16(UTC)
Das LoDi-Con, new wireles controller, compatible with CS2/3 and several other systems (News from Märklin and others)
by bph 26/10/2022 21:20:06(UTC)
Speed control problem (H0-scale)
by Sebastian_asd 07/10/2022 16:13:52(UTC)
MFX and 6021 controller (Digital)
by cintrans 16/07/2022 01:37:41(UTC)
What do you control yours turnout and signals? (Digital)
by Goofy 11/07/2022 08:35:18(UTC)
Marklin Speed Controller (Small scale)
by dannyboyz 30/06/2022 22:48:28(UTC)
Setting control address (Digital)
by Keyser 27/06/2022 20:21:49(UTC)
Viessmann Regular or Multiplexer signals (in a computer controlled layout) (Digital)
by pmgsr 24/04/2022 21:21:35(UTC)
Some Newbie Questions about Analogue Control of Devices (H0-scale)
by AlanC 09/04/2022 16:25:33(UTC)
Central Station, Mobile Station & 32 Volt controller not working? (General MRR)
by mattj70 06/04/2022 05:43:05(UTC)
How many engines can two MS2 control? (Digital)
by mrunix 31/03/2022 22:53:32(UTC)
6021 control (H0-scale)
by wally45 13/03/2022 16:44:03(UTC)
motorising 7186 turntable with Fleischmann 6915 turn control (H0-scale)
by gus1 28/02/2022 19:47:40(UTC)
Gaugemaster controller (Small scale)
by Snowfun 13/02/2022 17:04:02(UTC)
Locomotives controlled by CS3+ loose settings (light, sound ...) after restart of CS3+ & speedchange (Digital)
by HaraldOnline 24/01/2022 09:05:57(UTC)
This page was generated in 0.572 seconds.
