Offline Kapalua
#1 Posted : 29 October 2017 09:15:00(UTC)
Kapalua
How do you clean your HO Marklin tracks?
I do the slow manual way with cotton ball and some alcohol but it is a slow tedious process.
I am looking for powered cleaning kit similar to a Dapol B800 but that can work with AC but haven't been able to find any yet.
#2 Posted : 29 October 2017 09:45:33(UTC)
I use cotton top and deep clean fat free spray for the electronic.
Notice the dirt on the cotton top after i did cleaned my K tracks.
MrB32
#3 Posted : 29 October 2017 10:22:26(UTC)
LUX does this type of things, I haven't tested them so cannot comment more on them.
http://www.lux-modellbau.de
I never had the need to invest in this, as i found that running trains regularly was enough to keep good connectivity.
I just use a märklin track cleaning car from time to time. It is equivalent to model 46042 (https://www.maerklin.de/de/produkte/details/article/46042/) which has 2 felt pads for the outer rails. Otherwise a bit of vacuuming from time to time.
I don't touch the point contacts unless there is something optically wrong with them (stuck scenery, glue etc..) in which case I use isopropyl alcohol on a cotton bud
#4 Posted : 29 October 2017 10:37:43(UTC)
You forgot oil and rubber messy after traction tyres on the locomotives.
MrB32
#5 Posted : 29 October 2017 10:40:27(UTC)
no I didn't forget, that is the point of the Marklin 46042... What I described is enough for my trains to run.
Offline Kapalua
#6 Posted : 29 October 2017 10:58:32(UTC)
Kapalua
Thanks for the information, looking at eBay I just found one Märklin 46049, same as 46042 I think but different colour. BigGrin
#7 Posted : 29 October 2017 11:50:39(UTC)
Guys, I don't want to seem petty but there are already over 30 topics on track cleaning.. Please have a look at the Similar topics list at the bottom of the page...
MrB32
#8 Posted : 29 October 2017 12:36:41(UTC)
I know, but there is nothing wrong with answering a question, isn't that the point of the forum?
#9 Posted : 31 October 2017 20:41:50(UTC)
Agreed. Often one gets the "find the old threads" advice and one sees the info there is 5-10 years old, so one naturally wonders, well, maybe a new technique/solution/best-practice has developed in the intervening years. Best case, the follow-on question is asked as a post to one of those existing threads (keeping the discussion going).. but often times old threads are locked on some forums (bad practice in my opinion), so we get into the habit of starting new threads. Then there is the "index" problem - you go to the index of a book and look up "item a" and rather than giving you a page, it says "see item b" and you wonder, would it not have just been more efficient to give the page number for "item b" here as the answer to "item a". Good times.
Offline midwestbls
#10 Posted : 31 October 2017 21:40:14(UTC)
midwestbls
I use the Centerline Products car. The HO "NMRA Standard" model can be ordered with Marklin couplers. The DC wheelsets are fine on Marklin track. This is a "wet" system, use the cleaning solution (goo gone) sparingly. But it does pick up some crud from the center studs as well as across turnouts.
https://www.centerline-p...scale-nmra-specification
thanks 2 users liked this useful post by midwestbls
Offline Kapalua
#11 Posted : 31 October 2017 22:44:10(UTC)
Kapalua
Awesome, will ask my brother who lives in Denver, CO to pick one up for me when he visits us during Christmas.
Found a video on how they are used, first time to see anything like this.
thanks 3 users liked this useful post by Kapalua
Offline waorb
#12 Posted : 01 November 2017 12:33:13(UTC)
waorb
Brazil
You have been a member since:: 31/05/2011(UTC)
Hello!
For you both that have the opportunity to buy in the USA, here's my 2 cents...
For almost a decade now (actually 9 years) I use this wagon, with the plus that it really looks like a real tank wagon:
CMX Track Cleaner
Great to clean all the layout from time-to-time with Isopropyl alcohol.
Walter
thanks 3 users liked this useful post by waorb
Offline Kapalua
#13 Posted : 01 November 2017 15:38:49(UTC)
Kapalua
Hello!
CMX Track Cleaner
Walter
That is one fine machine but I don't see the availability of Marklin Coupling but will find out.
Also available in the UK
http://www.digitrains.co...ho-clean-machine-ho.aspx
Update: Easiest solution for Marklin is to buy Kadee Long with NEM362 connector to your Marklin Locomotive that will take NEM362
https://www.ebay.com/itm...sid=p2057872.m2749.l2649
thanks 1 user liked this useful post by Kapalua
Offline sudibarba
#14 Posted : 02 November 2017 03:26:30(UTC)
sudibarba
A tightly woven rag (or micro fiber rag) folded over with NAPHA (lighter fluid) pored on it. Wipe the rails.
Easy, fast and easier and cheaper than any cleaning car.
Offline Kapalua
#15 Posted : 02 November 2017 08:50:57(UTC)
Kapalua
You're probably right but it wouldn't be as much fun than pushing or pulling a cleaning car with one of your locomotives.BigGrin
thanks 2 users liked this useful post by Kapalua
#16 Posted : 02 November 2017 13:14:09(UTC)
I use what I think DaleSchultz once wrote about; A simple wooden block that you rub against the track.
I tried with some home-built track cleaning waggons, but in the end I find that normal running is the best way to keep the track usable.
Normally it is not necessary to do anything about the center-studs.
If the layout has been without use for some time. (lately this can be MONTHS!) a good running with a heavy locomotive always puts things back to operational standard.
My train-room is located in the basement, has an air-dryer conected ALWAYS, and is pretty free of dust.
-But I want to stress that normally I dont have to do ANYthing. -Not even after months of standing still!
#17 Posted : 02 November 2017 21:18:42(UTC)
yup, I hardly have to clean mine, and here are my wooden blocks: https://cabin-layout.blo...-gone-track-cleaner.html
Offline Thewolf
#18 Posted : 03 November 2017 11:51:22(UTC)
Thewolf
Hi Dale,
Your product '' Crud B Gone '', is it possible to import it from USA to Canada ?
Thank you for you reply
Thewolf
Project The Richelieu Valley Railway-CS2-Track C- Itrain-Digital
#19 Posted : 03 November 2017 13:09:37(UTC)
Thewolf
Really? -It´s just a square block of wood?!?! -Or are you joking?
(Sorry, I didnt want to offend anybody, or steal business away from Dale ;-) )
#20 Posted : 03 November 2017 14:29:07(UTC)
well, its not just a block of wood, it took some work and tries to get the 'block of wood' to have the right size and track grooves... but it is not that difficult to make them once you get the table saw set up just right.
unfortunately I don't have any left to send to Canada...
These would perhaps make a really nice Märklin-users membership item..... but shipping around the world would be expensive. Perhaps someone on each continent can make them up...
Offline Thewolf
#21 Posted : 03 November 2017 16:59:24(UTC)
Thewolf
An error from me I believe
I had seen it but I had not good read...The truth is that I had not read the characteristics of this this product
https://www.ecstuning.co...-gone-12-oz/82142186158/
Thewolf
Offline sudibarba
#22 Posted : 05 November 2017 02:43:10(UTC)
sudibarba
I must over oil my Loks but I cannot believe anyone who has a fairlly large layout could clean
it with a track cleaning car. I have a lot of older style Loks with the various drum commutator
motors. They probably give more oil to the track.
Dale gave me one of his blocks when I visited him one time when he was still in Chelmsford, MA. USA.
It really works well for short areas but I could not do the time to do my whole layout. I know he has a lot
of older conversions so I was surprised to see that he had to clean seldom. I will have to ask him about this.
Of course I am now in Georgia so I won't see him soon in Maine.
I still think the fastest way to clean is with the right rag and Napha.
Eric
Help with Marklin Track Cleaning cars (H0-scale)
by jimwallace1652 11/04/2024 23:55:53(UTC)
Marklin HO 46049 Track Cleaning Car 3-Rail (General MRR)
by mjborelli 19/02/2023 23:19:59(UTC)
Track cleaning machine (Big scale)
by nygma 21/05/2019 19:01:28(UTC)
Science of track cleaning (General MRR)
by Danlake 19/05/2019 09:26:10(UTC)
Track cleaning car comparison - Lux vs Dapol (H0-scale)
by Minok 10/03/2019 22:46:06(UTC)
LUX Track Cleaning Car 9130 (Reviews of rolling stock)
by PMPeter 13/12/2018 22:34:32(UTC)
Track cleaning (z scale) (Small scale)
by Trainiac 23/06/2018 15:39:07(UTC)
Marklin Track Cleaning Car (Small scale)
by BillO 02/11/2016 03:05:17(UTC)
Track Cleaning Car (H0-scale)
by Jabez 12/09/2016 23:23:57(UTC)
Track cleaning (General MRR)
by Varun R 24/05/2015 06:16:24(UTC)
Marklin German Track Cleaning Car of the DB (H0-scale)
by baggio 28/03/2015 18:08:24(UTC)
by db ice3 11/02/2015 11:43:33(UTC)
Märklin 46010 Track Cleaning Wagon (General MRR)
by Shamu 27/08/2014 12:15:50(UTC)
M-Track Cleaning (H0-scale)
by Makistrain 21/01/2014 23:13:12(UTC)
Track Cleaning Idea- is it pratical? (H0-scale)
by Harvey 15/10/2013 03:23:58(UTC)
Advice on Track Cleaning Product (H0-scale)
by Mike M 07/09/2013 23:25:39(UTC)
Track cleaning - Chemicals and metods (General MRR)
by Martin T 09/07/2013 09:39:24(UTC)
Can anyone identify this track cleaning car? (General MRR)
by kc6uvm_George 21/11/2012 20:33:27(UTC)
Cleaning Track Pads on 46042 Track Cleaning Car (General MRR)
by petestra 20/03/2012 16:16:37(UTC)
by swanpondwv 19/12/2011 01:53:43(UTC)
Track cleaning (Small scale)
by Jon11 25/08/2011 00:33:25(UTC)
HO track cleaning pads (H0-scale)
by Tex 11/08/2011 04:32:19(UTC)
ANY GOOD Z SCALE TRACK CLEANING CARS (Small scale)
by darticus 09/12/2010 02:18:44(UTC)
Track Cleaning Cars (H0-scale)
by Ranjit 21/10/2009 22:50:07(UTC)
Home madeTrack Cleaning Car (General MRR)
by FMS 31/05/2009 00:08:21(UTC)
Track cleaning cars (Small scale)
by ozzman 17/12/2008 01:21:51(UTC)
What track cleaning car would you suggest? (H0-scale)
by Eisenhower 10/11/2008 23:18:49(UTC)
Pulling Power for track cleaning (H0-scale)
by Martin T 03/09/2007 18:07:14(UTC)
C-Track Cleaning (including roadbed) (H0-scale)
by pmgsr 29/06/2007 17:09:50(UTC)
Track Cleaning (General MRR)
by bobhunt 07/02/2007 10:53:25(UTC)
Track cleaning... (General MRR)
by shaygetz 22/12/2006 05:38:02(UTC)
46042 Track Cleaning Car (H0-scale)
by MHauge 30/11/2005 08:09:17(UTC)
Track cleaning car (H0-scale)
by Winst0n 27/01/2004 17:17:35(UTC)
Track cleaning cars (H0-scale)
by PeFu 26/09/2003 12:09:42(UTC)
K + M HO Track Cleaning (H0-scale)
by Ranjit 24/06/2003 00:14:26(UTC)
by capn_tinkydink 26/01/2002 04:01:08(UTC)
This page was generated in 0.978 seconds.
