Offline Akai
#1 Posted : 30 November 2014 17:50:41(UTC)
Akai
Hello
I¨m new here and got one idea, would be good if Märklin could produce one curved turnout. For radius 600mm, both for C and K track.
It would be easy to build one station and lay out one in an 600mm curv.
Better work with the bigger radius and the wide radius turnout.
The Best
#2 Posted : 30 November 2014 18:54:09(UTC)
If you have enough money and no patience for M* coming up with a new curved wide-radius C-track turnout, try "Weichen-Walter" in Germany - see hyperlink:
http://weichen-walter.de...-weichen/detail/ibw.html
Offline Hackcell
#3 Posted : 30 November 2014 19:33:24(UTC)
Hackcell
Costa Rica
The R4/R5 curved turnout looks awesome. I wonder if it's possible to install a motor and a decoder in it.
Danilo Jiménez
Costa Rica, pura vida!!
Offline Akai
#4 Posted : 30 November 2014 20:39:49(UTC)
Akai
Hello
Thank you Alsterstreek, yes Walther-weichen are fine but not cheap. Do they work and do locomotives run well ?. Anyone ?.
I like to see my Märklin locos run on finescale track,and working for that.
#5 Posted : 30 November 2014 21:06:07(UTC)
Some of the turnouts presented on that website come pre-equipped. Since he works on order, it should not be a problem to order fully equipped with motor and decoder.
No idea. Some people on German fora expressed satisfaction...
When I myself fiddled around with the R1 curved layout - sawing off C-track and connecting it again with K-track connectors, I never had operational problems.
#6 Posted : 30 November 2014 22:02:48(UTC)
Hello
Weichen walter also supply the centre stud strip for use with Peco code 75 or code 100 track (and other makes, but you have to let them know at time of ordering). They have a photo collection of how to lay the strip and track on their web site. I have bought about 10 metres worth of stud strip from them, It is supplied as etched nickel-silver, and needs to be cut out of the plate, rather like an etched brass kit.
So it would be possible to lay your own track using Peco track, or hand lay track starting with something like a Templot trackplan, setting the sleeper spacing to something suitable for the Weichan Walter stud strips. Templot is free - your PC just needs to be connected to the internet when you start the program.
M-track Curved Turnout Derailment: Fixed (H0-scale)
by dlwestphalen 19/11/2023 19:45:09(UTC)
C track curved turnouts - single track to four (H0-scale)
by einotuominen 31/10/2023 07:38:03(UTC)
Incorporating Marklin 24771 and 24772 -C-Track Right and Left Wide Radius Curved Turnouts (H0-scale)
by michelvr 10/12/2017 15:15:27(UTC)
Kittel tends to short out on curved turnouts...?? (H0-scale)
by Joseph Meiring 31/12/2014 16:46:08(UTC)
Problems with curved turnouts (General MRR)
by obiwan 05/03/2013 12:45:11(UTC)
24671 and 24672 curved turnouts not responding on MS2 (Digital)
by Huntix 02/01/2013 21:19:05(UTC)
Small success with old Thunderboxes on Curved turnouts + pics (H0-scale)
by trainbuff 05/04/2010 06:54:41(UTC)
Catenary on pairs of curved turnouts? (H0-scale)
by RayF 16/12/2008 20:52:22(UTC)
M Track curved turnouts (H0-scale)
by Dick 24/09/2006 00:39:02(UTC)
K-track curved turnouts (H0-scale)
by jte 23/09/2006 13:34:56(UTC)
This page was generated in 0.444 seconds.
