Offline Gleisundzug1976
#1 Posted : 27 March 2011 12:02:42(UTC)
Gleisundzug1976
Hello.
I think my CS2 has a problem,it those not detect any funcion for the S88 module. Is there any test I can do for check it?
#2 Posted : 27 March 2011 20:19:59(UTC)
Gleisundzug1976
Originally Posted by: Gleisundzug1976 Go to Quoted Post
Hello.
Yes I did try with and without S88 module, and even any track connected. Same result. The info on WDP is all track's occupied. It seems the thae CS2 as a short circuit on the control module and send's back occupied informacion to the computer.
Offline supermoee
#3 Posted : 28 March 2011 14:09:11(UTC)
supermoee
if all tracks are shown as occupied after you connected the S88 module, than you have plugged in the S88 Module from the wrong side (check the flashes on the S88 module, they should show towards the CS2) or you plugged the connector turned by 180 degree.
rgds
Stephan
#4 Posted : 28 March 2011 14:40:41(UTC)
Gleisundzug1976
rgds
Stephan
Hi there,
The tracks are shown as occupied without the S88 connected or any track. I connected only the CS2 to the computer and all track are occupied.
Offline supermoee
#5 Posted : 29 March 2011 09:30:17(UTC)
supermoee
without S88 it is normal that all the track are occupied. Mine does too. As soon as you connect the S88 modules everything is ok
Without any S88 modules connected anyway it make no sense to evaluate the status of the contacts.
rgds
Stephan
#6 Posted : 29 March 2011 19:54:05(UTC)
Gleisundzug1976
rgds
Stephan
Hi there,
With our without any S88 connected the info from the CS2 to WDP is always occupied. I've tested with a reed and there no function from S88.
Inicialy when I connect the S88,and no wires connected, infos that all track are free, but when I connect a wire from some seccion that seccion, if with a trais there, it infos the the track is occupied. That's, I thing, the normal funcion, but in this moment even without the S88 connected, the CS2 infos that all track are ocuupied. So I only can think that the COM port for S88 is burnned.
Best Regards,
NR
CS2 Problem (Digital)
by David Dewar 27/09/2019 15:38:28(UTC)
Uhlenbrock 76500 and CS2 problem - Solved (Digital)
by PeFu 08/03/2017 00:35:09(UTC)
Marklin 60215 CS2 problem (Digital)
by daimonion 15/02/2015 14:58:59(UTC)
by Drongo 29/08/2014 08:19:45(UTC)
by monster134 27/01/2013 19:42:13(UTC)
CS2 problems with functions on BR 218 and BR 220 (Digital)
by nyc5450 18/01/2010 00:15:20(UTC)
CS2 problem again! (Digital)
by tekin65 16/01/2010 22:48:00(UTC)
37361 and CS2 Problem (Digital)
by gachar001 20/04/2009 23:06:29(UTC)
CS2 problem while shutting down (Digital)
by gachar001 13/04/2009 01:04:17(UTC)
by sudibarba 13/12/2008 01:18:29(UTC)
This page was generated in 0.464 seconds.
