Offline s_christos
#1 Posted : 23 August 2010 14:50:23(UTC)
s_christos
Is this motor really a breakthrough? I do not see many locos equipped with this.
#2 Posted : 23 August 2010 17:25:12(UTC)
Which version?
The original C-Sine introduced in 2000 was a good motor. Too expensive it seems.
The Compact C-Sine (CCS) was buggier than Maine in June. My locos run OK after I sent them back for the upgrade.
SDS is the current C-Sine. After the CCS desaster they needed a new name.
Still more expensive than normal motors and analog model railroaders hate it.
It seems the strategy is one decoder and one motor for all platforms. SDS is not wanted in the analog world, so many new items come without SDS.
The 03.10 and the Big Boy show that non-C-Sine motors can be really good.
Offline s_christos
#3 Posted : 23 August 2010 17:37:44(UTC)
s_christos
I only have one loco with C-Sine which I bought a week ago. The 39893 one.
The description of the product reads "controlled Softdrive Sine high-efficiency propulsion, a compact design, maintenance-free motor"
http://www.maerklin.com/...arch/product_search.html
Is this the compact one? Do I need to perform any repair?
For the time being it runs smoothly.
#4 Posted : 23 August 2010 18:22:39(UTC)
This is the latest design and should run very well. No repairs should be needed.
Offline Guus
#5 Posted : 23 August 2010 18:31:15(UTC)
Guus
Hi, your locomotive has the "new" SDS drive which shouldn't be affected by the sensitivity to "voltage drop" of the former small C-sine drives.
There's a list of models that were/ are affected on the Stummi forum: http://stummi.foren-city...n-entruckelt-werden.html (scroll down a bit to view the list)
As far as I understand this is an unofficial list but it should be fairly accurate.
Hope this answers your question.
Kind regards,
Guus
Offline Hemmerich
#6 Posted : 23 August 2010 23:46:15(UTC)
Hemmerich
Edited by user 19 November 2010 02:00:54(UTC)  | Reason: Not specified
Offline mvd71
#7 Posted : 24 August 2010 09:43:04(UTC)
I remember when the C-sine motor was first released. Everyone was very impressed with the performance. And as Lutz has pointed out, if you are enthusiastic enough you can retrofit it to other loco's.
We very quickly understood that it was just a brushless AC motor and as such nothing new in terms of technology, just new to the model railway fraternity.
I also have the new SDS motor, and again I'm pleased with how smooth and quiet it is. But I am disappointed with the act that you have to grease the worm gear every 20 hours of running, this halves the service interval for the loco and is contrary to the maintenance free philosophy of the Sine motor.
Cheers....
Mike.
#8 Posted : 24 August 2010 10:36:06(UTC)
I believe the original C-Sine motor was designed to fit to the same motor mounts as the older DCM 5 pole motor. The reason the Compact C-Sine/SDS motor was introduced was that the original C-Sine motor was too expensive to produce.
Offline TimR
#9 Posted : 24 August 2010 11:24:54(UTC)
TimR
Indonesia
As Mike mentioned on the post above mine,
despite the marketing talk, this is really a brushless AC motor made for MRR application,
but otherwise had been used in other hobbies, such as R/C airplanes.
Marklin was the first to bring it to MRR,
though I would believe that they subcontracted the production to an outside company to Marklin specification,
rather than developing an entire production line solely to produce it in-house.
Many specialist makers, like Maxon, for example, as mentioned in a previous thread, have been producing their own version of brushless AC motors way before Marklin start to market C-Sine.
Almost every new tooling models introduced since 2005, excepting a few like the BR03.10, are usually designed with the new SDS/Compact Sinus motor in mind.
For example; BR110/140/141, BR01, BR23, etc.
Now for older tooling models - those models which are originally introduced into the market as DCM "classic" propulsion, some have been upgraded, most haven't.
Some models that have been modified to accept the newer SDS are: BR152/189/182 (Taurus, EuroSprinters), V200, Ae8/14, and Ce6/8 III.
Now during the large Sinus era, there are more models that have been (factory converted) with large Sinus motors - ICE-1, Re460, Ae6/6, BR01.10, BR144, Franco-Costi, etc... but since this motor was dropped by Marklin (around 2006) - ALL new releases of these models since then would revert back to their original DCM motors.
Now collecting C-Sine models.
#10 Posted : 24 August 2010 14:24:49(UTC)
Tim,
BR 144 didn't come with large C-Sine, it came with compact C-Sine.
BR 151 had the large C-Sine, so did BR 152 and 182 and V 200 and also Ce 6/8 III (so Märklin made two or even three different trucks/frames for these locomotives).
Märklin made two different frames for the new BR 218 Diesel locos: one for SDS, one for normal motors. I think they did the same for BR 23.
By using a normal and cheaper motor for all models, they need only one frame for both Märklin and Trix.
Offline sjlauritsen
#11 Posted : 24 August 2010 18:59:40(UTC)
sjlauritsen
Hemmerich wrote:
The C-Sine motor is now succeeded by the SDS (Softdrive Sinus) in recent models; a more compact version. Performance is excellent; the almost only drawback is it's regulation at very low voltages (and thus not very suitable for pure DC operation).
I have heard that Märklin will use standard motors (i.e. the motors in the Trix locomotives) in the future and move away from the SDS since they require a lot of extra circuits and stuff to work. I don't know if this is true, but perhaps anyone knows a little more about it and can either confirm or reject this rumour?
Søren from Denmark
Offline pa-pauls
#12 Posted : 24 August 2010 23:06:06(UTC)
pa-pauls
Hi Søren,
I can ask at the factory in september Wink
Pål Paulsen
#13 Posted : 24 August 2010 23:44:00(UTC)
I don't have inside information.
But just look through the 2010 new items brochure.
New moulds (all without C-Sine):
BR 89.3/wü. T3
DHG 500
BR 03.10
BR 491
BR 420/ET 20
TGV
New releases without C-Sine that previously had C-Sine:
BR E 50
BR 01.10
BR 103.1
BR 110.3
BR 140
BR 294
BR Ae 8/14
Some new models still come with C-Sine (BR 218, Rh. 1216, E 44).
Maybe this is just an acceptance test. It will be interesting to see reviews of the new 110.3, 140, E 50, and Ae 8/14.
It will be interesting to see the 2011 new items brochure.
Offline TimR
#14 Posted : 25 August 2010 01:36:33(UTC)
TimR
Indonesia
H0 wrote:
Tim,
Thanks for the correction, Tom...
I think I meant to write BR194 (39223).
Quite true..
Given Marklin's situation (they had plenty of reasonably good looking models originally made with DCM in mind); designing new trucks with some or little modification to the frame is cheaper as opposed to totally new construction with entirely new frame.
This way plenty of models can get "Sinus-ed" without Marklin spending too much on development. I think this was the original intention of the large Sinus models, only that the cost of the motor become its achilles heel.
Offline TimR
#15 Posted : 25 August 2010 01:44:14(UTC)
TimR
Indonesia
It will be interesting to compare those new models to the previous versions that already got SDS.
My feeling is that there won't be much different in characteristics for all practical purposes, given that some models with high quality can motors (BR05 streamlined, BR03.10, and BR45) already have SDS-like quietness and smoothness.
And it will be ironic if due to market sense (it's simply a cheaper solution), Marklin might kill SDS in favor of these motors.
Offline Marty
#16 Posted : 25 August 2010 01:46:23(UTC)
Marty
Tom,
Why is the SDS disliked in the analog world? I thought it performs equally well in both analog and digital environments...
Marty
#17 Posted : 25 August 2010 02:10:27(UTC)
Lutz (Hemmerich) answered that already partially.
Trains start moving too late (require too much voltage) and stop too fast when power is cut off.
Recent models come with flywheels; I think this improved operation a little bit.
SDS is also disliked in the digital world: some chaps just won't buy it.
Part of the problem: load regulation in the decoder is turned off.
The digital decoder feeds analog speed information into a driver PCB that converts the signal back to digital and creates the load regulated output for the motor.
Very complicated and not the best slow speed characteristics even when running digital.
Old C-Sine used special decoders with a direct connection to the driver and had much better slow speed characteristics.
It's a bit louder that the SDS.
Offline Marty
#18 Posted : 25 August 2010 02:30:44(UTC)
Marty
Thanks for the insight, Tom. Despite these drawbacks, I have no plans to sell my E40 (39140). Overall, it is a great model, and one of my favorites in my locomotive fleet. Smile
Marty
Offline applor
#19 Posted : 25 August 2010 04:40:43(UTC)
applor
Some of the original C-Sine models are real beauties. 39195 E91 is one of my favourites. Being an electric, you only really need a horn anyways.
#20 Posted : 25 August 2010 11:41:38(UTC)
It´s not only simply a cheaper solution, it´s also a cheaper solution because it is simple! hehe...
Regarding analogue driving characteristics; I only own one SDS-equipped loco (BR150). My main problem is with its inertia; It´s absolutly nil. Thats not good, as any loss of power gives a full stop instantly.
Actually... My BR80 has the same problem; Any loco with wormdrive and insuficient flywheel would show the same problem.
-So the mechanical problem is probably not with the SDS itself, but with it´s implementation.
If Märklin wants to see how to get it right, they should look at the Roco swiss crocodile...
Even if Märklin started producing SDS-locos with acceptable inertia, I would still try to avoid them because of the unserviceable motor and electronic parts... -But at least I would be able to use the new locos from M. again! ;-)
Offline Hemmerich
#21 Posted : 25 August 2010 17:45:53(UTC)
Hemmerich
Edited by user 19 November 2010 02:01:27(UTC)  | Reason: Not specified
Offline jeehring
#22 Posted : 31 August 2010 23:02:46(UTC)
jeehring
....(...).....It's a bit louder that the SDS.
Several untruths are developed in this thread....OhMyGod Sad Crying
No, the large C-Sine isn't louder/noisy than SDS .....
Large C sine was designed as a successor of DCM motor for direct straight transmission between the motor and wheels (with straight cogwheels / gearwheels). It is this type of transmission which is sometimes noisy or louder...Not the motor itself.
(often more noisy than other type of transmission with centrally positionned motor + 2 transmission shafts and worms...)
My opinion about large C-sine and SDS motors : ask any electric motors manufacturers in the world , they 'll explain how better are those motors comparing with traditionnal motors with commutator + brushes....(they are also more expensive for the moment, which is the main reason why other train-manufacturers didn't offer it,....helped by narrow-mind customers making the buzz on Internet because frustated that it is offered by Marklin only , also by Micro-Metakit apparently on some of their models, and not by their favorite 2 rails loco manufacturers.......)
Of course, in the beginning any brand-new-model with any brand-new-cheap-motor will work well....But after having work xxx /700/1000 hours - if they can ! - you might find some differences...
In 2010 I 'm only buying models with SDS motors...with probably only one exception : The New PRR F7 at the very end of the year....I hope I could continue in 2011...
Edited by user 02 September 2010 15:53:15(UTC)  | Reason: Not specified
Offline TimR
#23 Posted : 01 September 2010 04:55:49(UTC)
TimR
Indonesia
The drivetrain design (those damn cogwheels Smile) is the culprit, which is why generally in terms of noise level, the same model fitted with large Sinus is only marginally quieter than its DCM equivalent - its superior advantage is in torque, consistency, and maintenance.
For all practical purpose of the average MRR customer (those who doesn't care too much about the techy bits), they only care about the qualitative feature of the end product - so from this respect, it's true that a model with large C-Sine is noisier than SDS, regardless of what actually making it noisy...
I think this is what the original quote was referring to.
I'm trying to make the same commitment (and hope Marklin got the picture), though a few can motor models is swaying me over...BigGrin
it's hard not for me not to droll over 26557...
Edited by user 01 September 2010 14:35:05(UTC)  | Reason: Not specified
#24 Posted : 01 September 2010 10:20:06(UTC)
Maybe I'll go the opposite direction in 2011: no SDS (with very few exceptions).
Märklin could make this easy for me.
Offline mvd71
#25 Posted : 01 September 2010 11:51:00(UTC)
It might be interesting to know that the C-Sine ALWAYS has been a brushless DC motor and was even patented as such. BigGrin
Exactly! And that is why Marklin described it as a Sine motor operating on three phase principalsConfused
#26 Posted : 01 September 2010 12:01:30(UTC)
Hi All,
Tim quotes
For all practical purpose of the average MRR customer (those who doesn't care too much about the techy bits), they only care about the qualitative feature of the end product......
Please count me in on that, I wouldn't know one end of a motor from the other.
But I know that I have a few SDS models, and I think they are marvellous. I also, like Eric, have a 39195, and that has a different motor - that's marvellous too.
I also have a streamline BR03 - 37914, I think it is pretty much older style motor and drive train. I put some modelling clay inside the body to absorb the noise, I guess it is the drive train that resonates in there.
Anyway, thanks for the topic, I might learn something.
Offline Guus
#27 Posted : 01 September 2010 13:04:49(UTC)
Guus
In my opinion the original C-sinus motor and its successor the SDS motor are one of the best propulsion systems for model trains. Their extremely smooth and powerful driving characteristics are just wonderful. There are however very good alternatives, like the Faulhaber motor for instance which may be more suitable for every ones needs(AC and DC) and most probably a little less expensive motor to equip model locomotives with.
Kind regards,
Guus
#28 Posted : 01 September 2010 21:55:06(UTC)
The streamlined BR 03.10 has a thin metal cover with the shape of a bell - and it chimes like a bell.
The 5-pole motor and standard gear in this model is not really quiet - but with this loco it's about as bad as it can get.
#29 Posted : 02 September 2010 06:48:22(UTC)
Thankyou Tom, mine sounds normal then.
Offline poppa-7
#30 Posted : 20 February 2013 04:55:22(UTC)
poppa-7
Hi Members Love
Dear ESU Members
I have a Marklin 39223 E194 locomotive with a C-Sinus motor that runs like a dream but would like to upgrade it to full sound. I understand that I cannot just fit a 62464 M4 decoder like 5 pole motor locomotives. I have thought of an ESU decoder but I have yet to find any info on the procedure.Drool
Any ideas please.
RussellBlushing
#31 Posted : 20 February 2013 06:08:45(UTC)
That looks like one of the original C-Sine motors
http://medienpdb.maerkli...s/1/pdf/39223_explo.pdf?
I would guess that you could install a separate sound decoder that would provide sounds but would not have any effect on the motor or lights.
I guess that you could simply detach the speaker from the decoder and use the one from the sound decoder.
If you have any questions about using ESU with C-sine motors, I would contact ESU, Tom Catherall (tom(at)marklin.com) or service(at)maerklin.de
#32 Posted : 20 February 2013 06:55:11(UTC)
Mike is it just me or is the pdf file just a Märklin logo ?
C-Sine motor:
Märklin Softdrive C Sine motor with control board (PWM)
#33 Posted : 20 February 2013 08:25:45(UTC)
Mike is it just me or is the pdf file just a Märklin logo?
They (Märklin) don't allow direct links to their files; copy the link address and paste it into the URL field of your browser.
#34 Posted : 21 February 2013 06:43:56(UTC)
Just use right click and select "Open in New Tab" or "Open in New Window"
MC
Offline trainsman2001
#35 Posted : 22 February 2013 13:56:43(UTC)
trainsman2001
Hi Guys since the topic of C-Sine motors is being addressed, I have an opportunity to purchase a 39050 BR05 or 39010 BR01, both which have the SDS motor. Has anyone had particular problems with either or both of these locos? They are being sold as either new or like new.
#36 Posted : 22 February 2013 14:49:14(UTC)
I have the 39050 and the similar 39011,if you can buy both of them,they are perfect.
Offline NZMarklinist
#37 Posted : 22 February 2013 15:17:06(UTC)
NZMarklinist
Hi Members Love
Dear ESU Members
Any ideas please.
RussellBlushing
Hello Russell,
I have a few of the original CSine powered Loks as well as 39223. I haven't run any of them enough to be bored of just a whistle or horn and as they are ELoks I haven't worried too much. Suffice to say it is a bit of a major but do abble according to Dennis. Talk to him when in Akl for the Mini Euro Convention at Easter.
I also have the Imo Trains V200 (270) 39820 which I believe was the last large CSine Lok produced. It has a 21pin MFX decoder with sounds.
To convert 39223 and the like you almost have to do away with the decoder board, however in some cases it holds an led headlamp or two, which makes this a bit hard. In the end it's just a wiring job, but knowing the config is the secret. Setting the decoder up to match the motor is another secret to a succesful conversion Wink
Glen
Auckland NZ
#38 Posted : 22 February 2013 16:31:06(UTC)
With a C Sine motor, you also need a motor driver PCB mounted between decoder and motor.
Märklin made three locos with big C Sine and 21MTC interface, but AFAIK these boards with the motor drivers are not available as spare parts.
#39 Posted : 22 February 2013 18:16:27(UTC)
trainsman2001
Thanks foumaro, hopefully I can purchase at least one of the locos mentioned and I opologize for forgotting to sign my original post on this subject.............Sandy
C-Sine Motors (General MRR)
by Markey 01/01/2024 10:11:58(UTC)
Marklin 39161 - Br 42.90 with c-sine motor (Digital)
by ocram63_uk 03/08/2023 15:18:44(UTC)
c-sine motor (H0-scale)
by db ice3 24/12/2014 10:03:25(UTC)
Märklin E 94 004 slow motion with the C-sine motor, a rail4you.ch DsM 2.0 driver board (Digital)
by Moritz-BR365 24/10/2014 12:14:17(UTC)
Ae 3/6 With C-Sine motor? (Digital)
by Dave Banks 18/06/2010 13:05:33(UTC)
item 39120 compact c-sine motor (H0-scale)
by spitzenklasse 10/04/2008 20:31:07(UTC)
Continuous disappointment w. compact c-sine motors (Digital)
Belarus svgeorgiad 17/03/2007 11:58:27(UTC)
This page was generated in 1.583 seconds.
