Poll Question : What Track Planing program do you use!
Choice Votes Statistics
  Total 22 100%
Guests can't see poll choices and poll results. Try login or register. Guests can't vote. Try login or register.
Offline garben
#1 Posted : 05 October 2025 21:53:14(UTC)
garben
I’m sure it’s been asked but is there a preferred track planning software program that the Marklin community likes? I would be using windows and looking at a combination of c and k track.
Thanks!
Offline Michael4
#2 Posted : 05 October 2025 23:30:04(UTC)
Michael4
I went with Railmodeller because at the time i understood it to be the only programme available that was Mac savvy and had the full M track library. This may have changed.
Offline Copenhagen
#3 Posted : 06 October 2025 08:24:48(UTC)
Copenhagen
I only have experience with Scarm so I can't say if it's better or worse than other programs. There is a learning curve and I also used youtube to learn about using it. I used it first to plan and build the main layout. Later I expanded the layout quite a bit and made some changes to the main layout. And finally I made a small change in the main layout. All over several years and only using C track.
There is a lot of fiddling and experimenting to do when making ends meet in complicated areas where you have to make use of all kind of small bits of track pieces of all kind of sizes and curve radii. Even when things don't look to fit exactly on the computer screen the C track has some flexibility so things can get connected. I also used the paste and copy and insert and move around functions in order to find the best solution for some of the complicated places in the layout... and a lot of trial and error on the "drawing board".
The ability to print track plans or parts of plan is also useful. Printing can also be done in full size which I have used in smaller areas.
Offline applor
#4 Posted : 06 October 2025 08:46:19(UTC)
applor
Lots of great options... I used AnyRail
#5 Posted : 06 October 2025 13:48:27(UTC)
I designed my layout in WinTrack, and was very happy with it. That´s almost 20 years ago, and I dont know much about what has happened on the scene since then.
I understand that Märklins planning software is actually a modified WinTrack version
I have tried to use SCARM a couple of times to try out some ideas, geometries, etc. I dont really like that too much...
Offline Ewillis
#6 Posted : 07 October 2025 00:54:41(UTC)
Ewillis
+1 for Anyrail, very intuitive and covers all track types.
Offline jonas_sthlm
#7 Posted : 07 October 2025 08:25:43(UTC)
jonas_sthlm
me too, +1 for Anyrail
Offline BenPerr
#8 Posted : 07 October 2025 22:38:39(UTC)
BenPerr
I use WinTrack and did a pretty comprehensive layout with it using 8 layers. I like the ability to see the height of the tracks when doing framework - helps with the perspective and building the woodframe.
It does all the Marklin tracks and the decors using their CDs (yes, you have to buy CDs...) is pretty comprehensive.
As we are on the same timezone, I can organize a quick overview of how it works through either Zoom or Team - PM me if you are interested.
thanks 1 user liked this useful post by BenPerr
#9 Posted : 08 October 2025 13:29:17(UTC)
Because you are using imgur instead of embedding your images in the message using the paperclip on the edit bar they are not visible to many of our members here in the UK as imgur has refused to comply with UK law on child safety on the internet.
In future embed your images by clicking on the paperclip and follow the instructions - they are quite simple instructions.
Offline BenPerr
#10 Posted : 08 October 2025 13:39:47(UTC)
BenPerr
Hi Alan,
Sorry, I did not know this & will use the paper clip going forward.
Thanks.
Offline scraigen
#11 Posted : 08 October 2025 14:56:57(UTC)
scraigen
The controls are not intuitive at all, the one labelled insert image is the one that we're not supposed to use.
Must build something
Marklin 60521 Track Planning software (Track plans)
by Hall3600 30/07/2021 01:05:36(UTC)
Raily Track planning Software (General MRR)
by nevw 07/02/2016 08:22:49(UTC)
SCARM track planning software reached v.0.9.22 (Model railroad software)
by Mixy 13/08/2013 11:07:03(UTC)
New track planning software (H0-scale)
by countrylink 01/10/2011 06:15:29(UTC)
XTrkCAD: Excellent Free Track Planning Software (Model railroad software)
by Roger E 11/09/2008 02:46:45(UTC)
Track planning software in Linux (Model railroad software)
by guimas 08/01/2008 12:16:30(UTC)
Track planning software (H0-scale)
by Darren W 10/12/2007 02:58:06(UTC)
Marklin / Wintrack Planning Software Help (Model railroad software)
by 5HorizonsRR 25/03/2006 00:37:26(UTC)
Marklin 60521 Track Planning software (Model railroad software)
by PeterNZ 19/06/2005 07:52:59(UTC)
by Ranjit 01/07/2003 04:27:13(UTC)
This page was generated in 0.360 seconds.
