Offline Chas
#1 Posted : 26 May 2025 18:06:11(UTC)
Chas
Just bought megga cheap Atlas editions static z bundle . Any thoughts apart from sell it and make a profit?
Have Dremel and evil bits.(Plus a big hammer)
Milling/etc
Chas
thanks 1 user liked this useful post by Chas
Offline Carim
#2 Posted : 28 May 2025 10:10:15(UTC)
Carim
I haven't done this, but I have seen plenty of articles/YouTube videos showing people who have (although I can't remember any that showed how they did it). Perhaps you could have a go and post the process and results here?
Carim
Online Alsterstreek
#3 Posted : 28 May 2025 19:42:49(UTC)
Related 2009 ModelRail Forum post:
"But there is also the 'Atlas editions' collectable static model advertised quite widely with its accompanying Gresley teak coaches. I've been chopping one of these about recently to motorise it with encouraging results.
In this shot you can see where I have carved the inside of the cab and boiler to make room. I found that the Marklin motor was just a bit fat at the top and was splaying the cab sides out. The guys on trainboard were very helpful and assured ne that you could take a bit of meat off the outside of the motor without affecting the performance. The knife points to the area in question."
Source: https://www.modelrailfor...british-outline-z.37834/
Related 2018 JNS forum post:
I’ve also motorised one of the Atlas narrow gauge railcars.I took the diecast metal chassis out and removed the various protruding bits with a razor saw and a mill file. I then inverted it and put it back inside the shell. It's supported by the window glazing at just the right height. To power it I'm using is a Greenmax No.5716 20m mechanism, which has almost the same bogie wheelbase and overall wheelbase as the static chassis. The mech will simply attach to the metal chassis with double sided tape.
I dismantled the bogie frames and attached the sides to the Greenmax bogies using short lengths of 1mm brass wire to locate them and reinforce the glued joint.
Source: https://jnsforum.com/com...-editions-sncf-railcars/
Illustrated German blog entries, but apparently only for dummy locomotives or passenger wagons?
https://z-otti.de/catego...1-umbau-atlas-zackenbahn
https://z-otti.de/catego...ee-ram-edelweiss-waggons
Online Alsterstreek
#4 Posted : 28 May 2025 20:05:18(UTC)
Four years ago, a German hobbyist converted a TEE Edelweiss Z gauge 1:220 Atlas static model. Amongst other things, he recycled an E103 elcectric loco chassis and installed a bell armature motor with flyweight next to re-working the bogies - see German Youtube video documentation of the process:
Online Alsterstreek
#5 Posted : 28 May 2025 20:23:20(UTC)
Two different hobbyists motorized a Vindobona VT 18.16 Z gauge 1:220 and documented the conversion, respectively.
This gent recycled an electric loco chassis and a Roco twin shaft motor. In addition, the bogies were replaced - see German video:
And a German video by another hobbyist focusing on the electronic aspects:
Offline Chas
#6 Posted : 30 May 2025 13:20:37(UTC)
Chas
They arrived today and about 3 minutes later I have one running on a shorty chassis. They are older models with metal wheels. 2 screws later and removal of glazing (popped out), 1mm off each end of the existing axle covers and we are away! Few mods on the shorty axle to make it look like a fuel tank will come later. A megg cheap way of getting clothes on a shorty. DST to hold the body in the correct place. Takes 8510 curves no problem clears points etc. The others will take more work but the shorty will fit in all of them.
thanks 2 users liked this useful post by Chas
Offline Chas
#7 Posted : 08 June 2025 10:13:57(UTC)
Chas
Further on Shinkansen type are smaller width across the bogies and slide in behind the body bogies and are hidden. All the bottoms are different and some a nightmare to get off, no screws press fit glued. Extended marklin couplers from Rokuhan work straight off the peg. Marklin wheel sets fit if you cut down the axle frame. Rokuhan are wider width axle diameters than Marklin and means taking off more. Axles are held in with plastic clips which need the width reducing. Take the bogie off a shorty and it will screw to some bodies when shimmed out. You can extend the connecting wires to improve the electrical connection to the track. I had no need to cut down the shorty motor. If you use DST a totally interchangeable fleet on one shorty body or buy more shorty's. Pick and choose your body some are too small for a shorty ie Bayerische Ludwigsbahn, Marklin wheelsets will fit I think and I might look at putting the motor in one of the carriages and having the train as a dummy.
Offline Chas
#8 Posted : 17 June 2025 19:40:20(UTC)
Chas
Totally doable choose bo-bo configs, can be interchangeable, solder a length of wire on to the removed bogie to improve pick-up. "Ghost wagons!".
Forget the interchange of wheel sets, longer trains need a moving front bogie. chop it all off and use the 1-001
This page was generated in 0.677 seconds.
