Offline Adrian666
#1 Posted : 17 April 2025 13:08:25(UTC)
Adrian666
Romania
Hello guys, can you help me identify this loco? I received photos from a friend.
I want to know:
1)what model is it
2)it seems to have digital functions( i see the electronic part in one of the photos) - can be from factory or was added after , any idea if is delta or the new digital decodor?
3) do you notice any missing parts?
3db6d0ea-c59b-43d6-96f4-521c541725c7.jpg6f5db775-d698-4bfa-817d-08ffb87561e9.jpg8fa4adf3-1b3b-4cc2-8463-d691e2e7f8f8.jpg118e6f33-de0a-4641-b5c8-d60660cf0a09.jpg9808274f-97d8-47cf-88f9-82eaf2be29a0.jpg
thanks 1 user liked this useful post by Adrian666
#2 Posted : 17 April 2025 19:57:06(UTC)
Hi Adrian
I think
- the loco is a 3015 (after 1956)
- the pantographs are non standard
- I fail to see any electronic component so chances are it is a standard analogue loco
All this is to take with a grain of salt (no crisp pictures on my phone
Offline Adrian666
#3 Posted : 17 April 2025 20:06:05(UTC)
Adrian666
Romania
Hi Adrian
I think
Thanks Jean.
I think If You maximize photo 4 , where the loco is on a side You can see the electronics
Offline cintrans
#4 Posted : 18 April 2025 01:58:17(UTC)
cintrans
Aruba
the number 3015 on the side of the cab shows the lok is Marklin item # 3015 build between 1959 ~ 1964 (according to 3rail Wiki)
Seems someone put what looks like a 6080 delta decoder in it (and perhaps a new motor?) with the 8 toggle switches, a bit difficult to be sure, but as you said, you can see the switches on the underside.
Jean-Pierre
Offline Adrian666
#5 Posted : 18 April 2025 05:50:42(UTC)
Adrian666
Romania
thank you și much
Offline Adrian666
#6 Posted : 18 April 2025 09:12:31(UTC)
Adrian666
Romania
Jean-Pierre
I have someone told me is from 1965, what is the difference between the 2 versions 1959 and 1965?
Offline cintrans
#7 Posted : 18 April 2025 15:02:12(UTC)
cintrans
Aruba
Jean-Pierre
According to 3rail Wiki, there was no version produced in 1965, the next version was produced from 1976 ~ 1981 and has 13302 as operation number on the cab
There are 2 variants of the Marklin #3015: the 3015.10 and 3015.11, one is blue-green in color the other one pine-green. This info is from 3rail Wiki.
Jean-Pierre
Offline BenP
#8 Posted : 18 April 2025 15:37:30(UTC)
BenP
Is the friend's name eBay 😀
Offline Adrian666
#9 Posted : 18 April 2025 15:48:30(UTC)
Adrian666
Romania
Jean-Pierre,
Offline ccranium
#10 Posted : 19 April 2025 00:07:28(UTC)
ccranium
Hi Adrian,
Koll's says the inscription "3015" first appeared on the 3015.10 version in "Blue Green" with a silver-grey roof, 1959-1964
Then the .11 in "Fir Green" with a silver roof 1965-1975
And the kit 3915 would build a .11 1976-1978
Based on the images you posted I don't see a blue-ish hue to the color, so it may be a 3015.11 or a 3915 kit.
All 3 versions should have the "Type 6" pantographs with brown or green insulators; the ones in your images look like "Type 13".
I hope this helps.
Brian
This page was generated in 0.620 seconds.
