Offline Bill L
#1 Posted : 10 January 2024 21:19:20(UTC)
Bill L
The new 38440 UP GE ES44AC has smaller diameter AC wheel flanges compared to the AC flanges made previously before approx 2010. Marklin is trying to make them closer to the DC wheel flanges (smaller diameter) that run well on the C-tracks. They discontinued the metal M tracks. The 38440 stops on my metal M track double slip switches 5207 and 5128 because the wheel flanges are smaller in diameter and the edges are not able to make contact with the power conducting metal contacts at the bottom next to the plastic track in the switches. So the edge of the wheel flange does not touch/contact the base metal shiny (chrome colored) plate. I thought the locomotive was long enough to have other wheels touching the rails to make electrical ground contact, but that does not seem to be the case. Probably poor power contact from the other axles to the chassis for ground contact. I have adjusted the shoe but that does not appear to be the problem for power contact.
Any one have any solutions? Thanks. Half my layout is K track also, so I can only run this lok on the K track sections. C track was commercialized after my layout was laid, so I do not have C track on my layout.
thanks 1 user liked this useful post by Bill L
#2 Posted : 10 January 2024 23:20:08(UTC)
Hello Bill
I cannot say for sure about wheel flanges not making contact with M DSSs 5207 and 5128.
I can only point out that early models of 5207 and 5128 has a switch change of polarity that - in your case - could be defective. This is only an assumption on my part.
The other point worth checking is: do both bogies pick the ground? (If not, it may explain the stalling and is easy to correct.
Offline Bill L
#3 Posted : 11 January 2024 02:52:44(UTC)
Bill L
Thanks Jean.
All 6 axles are grounded. I just measured them. Let me number them. From the front, Axles 1, 2, and 3 in the first bogie, and axles 4, 5, 6 in the second bogie.
Axles 1, 3, 4 and 6 are geared. Axles 2 and 5 are free turning.
Axles 3 and 4 have all 4 wheels with tires, (4 tires total on 2 powered axles), so probably cannot get power from the rails. Axles 1, 2, 5, and 6 can pick up power from the rails.
Distance between axle 1 and axle 4 is about 6 1/4 inches.
Distance between axle 1 and axle 3 is about 1 13/16 inches.
Distance between axle 1 and axle 6 is about 7 inches.
I have a section on the layout where the TWO metal M 5207 double slip switches are connected by a M track 5110 (7/8 inches long) in between. That puts the distance spacing between the centers of the 2 x 5207 where the plastic tracks are, at about 7-8 inches, so that explains why the locomotive stops with loss of power and does not have ground track rail current. I think that explains it. Both bogies are on the tracks with no rail current. I push it a little and the lights light up and it moves on.
My old ALCO PA also have 6 axles and they run fine in this area. These were made by Marklin in the early 2000s and the AC wheels had larger diameter wheel flanges and the edges of the wheel could get current from the bottom shiny metal contacts.
So it looks like these loks will only be run on my K tracks, which is fine. This lok is very heavy and has a lot (and I mean a lot) of plastic parts for details, so be very careful in handling this lok.
Again, Thank you Jean.
thanks 3 users liked this useful post by Bill L
Offline Bill L
#4 Posted : 11 January 2024 04:36:50(UTC)
Bill L
There is a black metal philips screw right underneath the rear coupler assembly and it is grounded, so I will connect a brown thin wire from the screw and pass it next to the plastic coupler in the rear and connect and wire it to the metal coupler of my metal tin-plate freight car that it will pull. If this solves the problem, I may have to design a metal coupler to fit the plastic coupler press-in square hole, and then wire it. I think this may work.
#5 Posted : 11 January 2024 10:56:14(UTC)
Hi Bill
Why not using regular current-conducting couplers for this. It may connect ground from other cars.
Re your issue I also looked at the storage capacitors Märklin 60974. They plug on the SUSI interface of the mLD3, mSD3 decoders but it seems it does not plug and plays with your loco.
Offline analogmike
#6 Posted : 11 January 2024 13:46:04(UTC)
analogmike
Hello Bill,
Your post prompted me to look at my DSS. There are older versions where the ground rail in the center is metal not plastic. When I built my layout I only used the metal type to prevent stalling of short 6 wheel switcher loks. Although this may not be your problem, I hope it can shed some light on the issue.
thanks 10 users liked this useful post by analogmike
Offline Bill L
#7 Posted : 12 January 2024 03:25:30(UTC)
Bill L
Jean thanks, I like your current-conducting coupler suggestion. Will give it a try.
Thanks analogmike. I did not realize there was an earlier version of the 5207 where the rail at the center of the double slip switch is metal. Yours matches the one shown in the Marklin 1961/62 catalog that I have. Mine matches those in the catalog 1997/98 where the 5207 is all black and all plastic in the center. So basically no rail current (ground) contact to the wheels. I will just have to run the lok on my K track.
Also, one thing I noticed, following the numbering convention I used of axles in post 3 above, I noticed that the pivot for the front and rear bogies are not above the #2 and #5 axles but above #3 and #4 axles. So, I noticed that because of the heavy nature of this lok the weight pushes down on the #3 and #4 axles, but causes the axles #1 and #6 to lift up easily of the bogies and derail on not-levelled tracks. My metal M tracks are bumpy. My ALCO PA loks have pivots above the #2 and #5 axles and run beautifully on my metal M tracks, including 5207, even at high speeds.
So I will run this lok on my K track only and be happy with that.
thanks 2 users liked this useful post by Bill L
Offline eduard71
#8 Posted : 15 January 2024 19:57:33(UTC)
eduard71
Chile
Hello Bill,
If you plan to buy more new generation Marklin locomotives the best thing you can do is to change all the M track for K or C. New models are more delicate to tolerances. Actually many instructions from new locomotives states the model could have problems with M track.
On the other hand if you have many old locomotives and you are no willing to increase your collection with new models then stay with M track.
Eduardo
thanks 3 users liked this useful post by eduard71
Offline Bill L
#9 Posted : 18 January 2024 09:13:22(UTC)
Bill L
I agree with you Eduardo totally, that the newer marklin locomotive models are much more delicate to tolerances and that they will run much better on C track.
I do have a lot of older pre-1990 locomotives and cars that make a good clickity and clackity noise on the metal M tracks and the sound really soothes me and helps me in reducing my work stress environment when I come back home at night. My father ran these older loks in the 60s on metal M tracks and brings back good memories.
Offline Bill L
#10 Posted : 23 November 2024 06:49:28(UTC)
Bill L
Please see post #43 in https://www.marklin-user...3-Maerklin-ES44AC-Models
I did some wheel exchange modifications and the lok runs well now on all my metal M tracks including the 5207 metal M track double slip switches.
Very happy with this modification.
This page was generated in 0.362 seconds.
