Offline Zme
#1 Posted : 12 January 2023 06:55:00(UTC)
Zme
Hello everyone, hope you are well.
The latest edition of the Trainini publication may be downloaded from the link below:
https://www.trainini.eu/...Trainini_int_2022-12.pdf
Another great read, enjoy!
Take good care.
Dwight
thanks 4 users liked this useful post by Zme
Offline Toosmall
#2 Posted : 13 January 2023 11:55:30(UTC)
Toosmall
When building architectural models I always print off the elevations (all plans) to the correct scale. Stick styrene sheet behind. Then with scalpel blade mark the corners of all the openings.
Then score openings, maybe a few times. Then flex styrene sheet so scored line appears of the back of the sheet. You can then trace this line with scalpel blade, works easily.
Then flex sheet back & forth a few times and window or door opening piece is easy to push out.
If you need to keep a very thin piece of styrene between 2 openings, score those parallel lines first and a few extra times front and back. With a bit of practice keeping 1mm of styrene between 2 openings is not that difficult.
Swann Morton 10A blades are the best. You may knock the very point off, so replace blades as needed. They are a bit temperamental, a blade can last days or you can go through a dozen in a day.
Tidy up opening with blade, often just nick out the corners or scrape edges. Sand back face a touch if you need a perfectly flat surface.
I don't normally photograph them at the skeleton stage, 1:200 scale.
0.75mm high impact styrene sheet is a good thickness for 1:200 models. About $15 to $20 per sq metre. 1mm and 0.5mm are also handy but you only need the odd sheet. 1:100 scale often still use 0.75mm for most construction.
You can't have too many Evergreen strips!
Joining corners of walls etc, To make life easier stick a locating strip on the inside so the walls align in the corner more accurately. Often quicker than to fiddle holding 2 pieces.
Walls do bow in due to solvent drying overnight, so put in a floor and or ceiling, don't need to glue it or tack it very lightly, it is just a brace overnight to keep things square.
Offline Zme
#3 Posted : 13 January 2023 16:00:50(UTC)
Zme
Hello, hope all is well.
Thank you, very interesting and excellent outcome. It is easy to see you are an experienced builder! It must take a while to complete a complex structure this size. Impressive.
I still say, you could easily sell these. I am sure many in the “Z” hobby would support you.
Do you know if there are sources for this type of scaled building material in hard cardboard?
Take good care.
Dwight
Offline Toosmall
#4 Posted : 14 January 2023 11:11:31(UTC)
Toosmall
Architectural models are mostly pretty complex. They have got more complex over the years because the design of the building are pushing the boundaries of building codes.
Often the drawings are full of mistakes. It is nice when you get a decent set of plans. I just avoided many jobs as it is not worth the wasted time during construction.
I have always used high impact styrene sheet for the buildings and polycarbonate for the windows. Used 150g touch up spray cans for painting. A lot less cleaning up. You get good at stretching the contents of a can a long way. Also good at creating textures. The models do need to look crisp and sharp, so often a different style compared to a train layout model.
Architectural models are very expensive, but you are building the prototype in many respects of the real thing ironing out mistakes in the plans.
Complex buildings, even the builders are looking at the model to see where walls are. It took me a month to build up a 3d picture in my head, every level every wall was doing different things. My brain was hurting at the end of each day.
You can't mask a model like this so every part needs to be separate. It also had translucent glazing. I called it the model from hell.
Offline parakiet
#5 Posted : 15 January 2023 21:55:14(UTC)
parakiet
Years ago I got one from ebay.
Didn't work, sent it back. Got it back full of solder.. it drives but with full white lights...
Latest Trainini Update (Small scale)
by Zme 21/02/2026 16:26:43(UTC)
by Zme 07/01/2026 19:45:37(UTC)
by Zme 17/12/2025 16:50:28(UTC)
by Zme 18/11/2025 04:06:58(UTC)
by Zme 25/10/2025 19:19:18(UTC)
by Zme 21/09/2025 00:25:25(UTC)
by Zme 30/08/2025 17:23:24(UTC)
by Zme 22/07/2025 12:53:19(UTC)
by Zme 20/06/2025 06:07:03(UTC)
by Zme 20/05/2025 15:41:27(UTC)
by Zme 16/04/2025 02:09:46(UTC)
by Zme 25/03/2025 02:58:22(UTC)
by Zme 15/02/2025 18:31:44(UTC)
by Zme 06/01/2025 02:13:39(UTC)
Latest Trainini update (Small scale)
by Zme 25/12/2024 16:45:20(UTC)
by Zme 22/11/2024 04:35:50(UTC)
by Zme 05/11/2024 19:38:27(UTC)
by Zme 18/09/2024 18:36:16(UTC)
by Zme 21/08/2024 16:31:18(UTC)
by Zme 11/07/2024 03:51:08(UTC)
by Zme 13/06/2024 16:28:15(UTC)
by Zme 14/05/2024 21:54:51(UTC)
by Zme 18/04/2024 00:46:00(UTC)
by Zme 13/03/2024 21:17:29(UTC)
by Zme 22/02/2024 17:01:48(UTC)
by Zme 08/01/2024 22:14:00(UTC)
by Zme 12/12/2023 21:57:33(UTC)
by Zme 12/11/2023 01:19:08(UTC)
by Zme 13/10/2023 15:10:29(UTC)
by Zme 20/09/2023 01:28:45(UTC)
by Zme 10/08/2023 06:59:04(UTC)
by Zme 14/07/2023 05:03:05(UTC)
by Zme 14/06/2023 15:36:21(UTC)
by Zme 22/05/2023 06:25:00(UTC)
by Zme 12/04/2023 16:22:32(UTC)
by Zme 17/03/2023 15:32:04(UTC)
by Zme 08/02/2023 17:18:54(UTC)
by Zme 19/12/2022 16:51:28(UTC)
by Zme 18/11/2022 23:23:40(UTC)
The latest Trainini update (Small scale)
by Zme 20/10/2022 16:45:05(UTC)
by Zme 17/09/2022 17:13:14(UTC)
by Zme 10/08/2022 14:37:12(UTC)
by Zme 14/07/2022 00:23:27(UTC)
by Zme 18/06/2022 00:08:19(UTC)
by Zme 13/05/2022 00:50:53(UTC)
Latest Trainini Update (200th Issue) (Small scale)
by Zme 11/04/2022 16:23:42(UTC)
by Zme 09/03/2022 16:55:30(UTC)
by Zme 04/02/2022 00:05:31(UTC)
This page was generated in 0.333 seconds.
