Offline MHauge
#1 Posted : 06 April 2006 22:13:43(UTC)
MHauge
I just bought a nice old M 3029 lok.biggrin
But it's analogue, so got to put a decoder in it.[:(]
My dealer talked about a M 60760 decoder with engine upgrade so it would be a 5 headed rotor, but was not sure it would fit, he has asked M what loks it is for - they won't tell him...
Is this the right set for this loko ?
His price for the decoder was around 45 €, is this an ok price for it ?
It's going to be my first conversion - so hope it will be good.
Michael
Märklin C-tracks, Mobile Station, Danish Ep 4
Offline MHauge
#2 Posted : 06 April 2006 22:18:38(UTC)
MHauge
Or how about an MFX decoder - would the 60921 be the right one ?
I think it's an DCM engine, but have not opened it yet.
Michael
Offline MHauge
#3 Posted : 06 April 2006 22:44:15(UTC)
MHauge
Just opened it up.
Not DCM, guess it's a SFCM.
So MFX:60923 ?
Delta:66032 ?
How about normal Digital ?
Michael
Offline MärCo
#4 Posted : 06 April 2006 22:44:58(UTC)
MärCo
I think it is overkill. A 3029 is too small for a decoder. A 66032 could be build in, but you have to make the frame a bit wider under the boiler. Actually, you only wish to control the motor with 66032. It is possible to remove the parts of 66032 that controls lights and so on. But you have to find out which parts that are.
Absolutly AFB-NOHAB fan ;-)
#5 Posted : 06 April 2006 22:59:37(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by MHauge
<br />My dealer asked M what loks it is for - they won't tell him ...
Huh ... ??????
Offline MHauge
#6 Posted : 07 April 2006 00:06:33(UTC)
MHauge
I wondered about that too, he says he both called them and emailed them, they would not tell him.
On Märklins homepage there is no info about which engines/loks it's for either.
I was just thinking about buing a Hamo magnet and a lokpilot mfx or lokpilot micro to put in it.
Would cost around the same as the set my dealer showed me, then it would still be the 3 headed rotor, but i guess that would be ok ?
Michael
Offline pat
#7 Posted : 07 April 2006 01:41:21(UTC)
pat
In my 3029 I put in a cheap little pd101 decoder that works fine only no lightsSmile
worse things happen at sea
Offline rschaffr
#8 Posted : 07 April 2006 02:24:36(UTC)
rschaffr
I have tried a few conversions retaining the 3 pole rotor and have never liked the way they ran in digital. One was with a Uhlenbrock 75200 and the other was a Lenz and HAMO conversion. They were a few of my early experiments, and I now always go for the 5 pole motor, regardless of what decoder I use. For that little lok, you don't have a lot of space. I would get the motor parts for the upgrade and try the new ESU micro decoder.
-Ron
#9 Posted : 07 April 2006 02:52:32(UTC)
Michael, I'm sure Jorge will have an perfect solution for you ... [:p]
Offline MHauge
#10 Posted : 07 April 2006 06:44:02(UTC)
MHauge
<br />I would get the motor parts for the upgrade and try the new ESU micro decoder.
Do i need anything else than the decoder and hamo magnet ?
Michael
Offline rschaffr
#11 Posted : 07 April 2006 07:02:35(UTC)
rschaffr
Actually, the LokSound series of decoders (including the micro) can be operate the AC motor without modification. I have never done this, but it may be an option you would want to consider. If you were not happy with the performance, you could use the same decoder and put the HAMO magnet in the engine to convert it to DC. See page 8 of the manual at http://www.loksound.de/download...ung_Auflage_IV_ebook.pdf
-Ron
Offline MHauge
#12 Posted : 07 April 2006 07:39:27(UTC)
MHauge
The LokSound is a bit expensive, so i think i'll go with a LokPilot instead, but that requires a hamo magnet.
Don't think there is room for the speaker either.
Michael
Offline MHauge
#13 Posted : 07 April 2006 08:02:15(UTC)
MHauge
Strange:
ESU states that the 3029 should have the ESU 51962 (Märklin 235690) Hamo magnet.
Märklin states it has the 200680 rotor, so it should have the ESU 51961 (Märklin 220450) Hamo magnet.
Who is right ?
Michael
Offline Lars Westerlind
#14 Posted : 07 April 2006 09:47:56(UTC)
Lars Westerlind
I did this a long time ago, see
https://www.marklin-user...digital/DI3029LE130.html
It certainly is a SFCM. I'm sure that modern decoders will give a better (more silent) result. Some kind of extra weight in front will come in handy.
/Lars
#15 Posted : 07 April 2006 12:48:12(UTC)
I just did a conversion on a loco (3037) with a SFCM. I used a LokpilotV2 and Hamo magnet 51961.
see: https://www.marklin-user...ault.aspx?g=posts&t=4310
The result is much smoother than using a delta 66032, though you have to fiddle with the cv values to get the best running.
Offline MHauge
#16 Posted : 07 April 2006 19:51:11(UTC)
MHauge
Just bought a Uhlenbrock 76200 decoder for it, that does not require any engine parts, so should be easy to install.
I'll let you know how it goes, perhaps even with a photo or two..
Michael
Offline MHauge
#17 Posted : 07 April 2006 21:36:40(UTC)
MHauge
Im in the process of installing the decoder, but my german is to bad for this.
I dont realy understand the instructions.
Anyone installed this decoder ?
The text is :
Trennen Sie die Verbindung zwischen den Motorschild und der Feldspuhle auf. Die beiden Drähte in dem Leitungsende, das von der Feldspuhle kommt, müssen miteinander verlötet bleiben. Isolieren Sie das Leitungsende. Es wird für den Betrieb mit dem Decoder nicht mehr benötigt. Trennen Sie alle andere Leitungsverbindungen zwischen dem Motorschild und dem Lokchassis auf.
Die Leitungen des Decoders werden wie folgt angeschlossen: die beiden weissen Leitungen an die Zuleitungen für Feldspule, die grüne und die blaue Leitung an die beiden Anschlüsse am motorschild, die braune Leitung an Masse und die rote Leitung direct an den Schleifer. Die Entstörelemente verbleiben am Motor.
As far as i understand it:
Red to middle-rail.
Brown to ground/wheels.
Blue+green to engine.
But what about the two white ones ?
And the coil at the end of the engine should be shorted ?
And the wire going from coil to engine shold be cut ?
Like this picture
Michael
Offline rschaffr
#18 Posted : 07 April 2006 21:50:06(UTC)
rschaffr
I am at work and don't have my notes or the diagram in front of me, but my recollection (on the 75200) is that the center tap from the field coil is spliced together, and the white wires go to the end taps from the field coil. Other than that, what you say is correct. You may have to futz with the blue and green to get the directon to correspond to the lights.
-Ron
Offline MHauge
#19 Posted : 07 April 2006 22:21:29(UTC)
MHauge
Yoy mean the one white wire is connected to the two shorted ones, and the other to the cut wire, on the coil end ?
Michael
Offline rschaffr
#20 Posted : 07 April 2006 22:45:41(UTC)
rschaffr
No, the shorted ones are insulated and left alone (these are the double wire going to the brushplate now). Just remove them and make sure they remain in contact. I put a small piece of heatshrink over them to insure that they didn't contact anything. The two other (single) wires coming from the field coil go to the white wires from the decoder.
-Ron
Offline al_pignolo
#21 Posted : 07 April 2006 23:50:41(UTC)
al_pignolo
About installing Uhl 76200 I got all the informations in this topic:
https://www.marklin-user...ault.aspx?g=posts&t=2923
Bye.
Pietro
Offline MHauge
#22 Posted : 08 April 2006 09:08:56(UTC)
MHauge
I still don't get it.
On my engine there are 3 wires from the field coil, 2 was connected to the reversing-unit, the last one to one of the 2 engine connections.
So if 2 must be shorted, and not used, then only one left for the 2 white wires from decoder ?
Can someone make a picture/drawing of how it must be connected ?
Michael
Offline al_pignolo
#23 Posted : 08 April 2006 11:08:54(UTC)
al_pignolo
In that case you must solder two of the wires together. Now I don't remember wich ones but, to find them, you should see a picture in uhlembrock instructions, with the coil and the wires to solder.
If you still have problems, tomorrow I'll take a picture of one of my locos, hoping to help you.
Offline rschaffr
#24 Posted : 08 April 2006 16:50:11(UTC)
rschaffr
The wire(s) going to the engine brush plate is actually two wires, and these are the ones that should be kept together and isolated. The two going to the reversing unit are connected to the white wires.
-Ron
Offline MHauge
#25 Posted : 08 April 2006 18:53:14(UTC)
MHauge
Thanks for the help, it was the short one that was going to the engine that confused me.
It's running fine in digital mode now Smile
Offline MHauge
#26 Posted : 12 April 2006 21:13:10(UTC)
MHauge
This loco pulls pretty nice, i just tryed putting 12 2-axled cars behind it.
It has a little problems in turns, but after all it only has one traction tyre.
With the 12 cars and my track cleaning car it wont move much, but that's not so strange, it's dragging those pads against the tracks..
Michael
This page was generated in 1.565 seconds.
