Offline sonra
#1 Posted : 06 July 2020 19:01:14(UTC)
sonra
Israel
Hi guys
try to find in this forum and JMRI forum with nothing to "fish"
I try to connect the JMRI control software to the CS3 but it does not work . Did someone use the CS3 with JMRI ?? try to use the TrainController in demo model and it work with out no problem
Regards Doron
Doron
Online pederbc
#2 Posted : 06 July 2020 19:43:16(UTC)
pederbc
There seems to be support for cs2, so I see no reason it shouldn’t work on cs3. See this page:
https://www.jmri.org/hel...ware/marklin/index.shtml
Br, Peder
Offline sonra
#3 Posted : 06 July 2020 20:29:54(UTC)
sonra
Israel
hi
Thanks for try to help but the facts are that it does not work with software A and works with software B so I suppose there is some problem and I try to use a network analyzer and saw that packets from software B ( (TrainControler) are transmitted in TCP protocol and from software A ( JMRI ) in UDP protocol so there is may be something that I have config in the JMRI so it will work
Doron
Doron
#4 Posted : 07 July 2020 08:08:46(UTC)
Originally Posted by: sonra Go to Quoted Post
... but it does not work ...
Not exactly the most descriptive....
The CS3 (and CS2) primarily use UDP
TCP may be seen in the context of a CS1 and/or a CS1 connecting to a CS2/3 as a slave.
With the preferences set correctly with Marklin, CS2 and the ip address you will see the state reflected under Active Profile when opening PanelPro
If you are already using a layout control software then JMRI is probably not much use.
JMRI has (had) a focus on the DecoderPro programming of decoders.
This function (including SoundPro) is not available for use with the CS2/3
This page was generated in 0.463 seconds.
