Offline dominator
#1 Posted : 10 April 2020 02:00:57(UTC)
dominator
I was curious about the flickering light fix for the 3090 decoder mentioned below. I think mine has a 3080 decoder and it must be an early version as quite a few of the electrical bits are quite large.
Is there a fix for this flickering?
br86 3696 front bulb.jpgbayonet bulb shown.
many thanks
Dereck
PS its a nice loco but it does run like a it has a Delta Decoder
Offline mvd71
#2 Posted : 10 April 2020 02:37:32(UTC)
Hi Derek,
The decoder you have is a 6080, and it has the same driving characteristics as a delta because it is the same design in its motor output.
The light bulbs would need to be replaced to have a ground wire rather than grounding through the chassis, then follow modification 2 on the following website https://www.pallund.dk/convert2.htm
Cheers....
Offline dominator
#3 Posted : 10 April 2020 06:26:50(UTC)
dominator
Thanks Mike. Yes 6080. I put 3080 by mistake. Thanks for that. I will check it out. Might have time to look at it a bit later. Have many jobs to do around the house, not that I have been greatly motivated on some days.
All the best
Dereck
#4 Posted : 10 April 2020 08:14:24(UTC)
All the best
Dereck
Supposed to be some rainy days coming up, so that will help BigGrin BigGrin BigGrin
Offline mvd71
#5 Posted : 10 April 2020 09:37:20(UTC)
What else are we going to do with the next 12 days?
This page was generated in 0.268 seconds.
