2 Pages12>
Offline morsing
#1 Posted : 04 February 2020 15:42:40(UTC)
morsing
Rocrail isn't the easiest concept to get along with, but I am reading through the wiki and guides.
I managed to get a loco to runs through a route, but no more, and I don't know why.
As soon as I tell is to go, it puts the name of the loco in the destination block and turns the background yellow. Yellow means block is reserved it says. I've reset the blocks, and all locos, tried restarting, but it insists the block is reserved.
Get this in the trace:
20200204.144103.000 r4201a CFC17700 OLcDrive 0121 Setting state for "MY1121" from LC_INITDEST to LC_CHECKROUTE.
20200204.144104.101 r9999a MY1121 ORoute 0926 blockid [bk43] in route [NEWsdrfgd] is --from--
20200204.144104.101 r9999a MY1121 OBlock 3526 depart loco [MY1121] from block [bk43]
20200204.144104.101 r4202a CFC17700 OLcDrive 0142 setting signals...(useCurBlock4Signals=0)
20200204.144104.101 r4204a CFC17700 OLcDrive 0189 curBlock [bk43]
20200204.144104.101 r4204a CFC17700 OLcDrive 0195 next1Block [bk7]
20200204.144104.101 r4204a CFC17700 OLcDrive 0201 next1Route [NEWsdrfgd]
20200204.144104.101 r9999a CFC17700 OLcDrive 0231 no second next block available: YELLOW
20200204.144104.101 r9999a CFC17700 OLcDrive 0122 check signal pair: route=NEWsdrfgd block=bk43 fromTo=true signalpair=false sgpair=2
20200204.144104.101 r9999a CFC17700 OLcDrive 0376 set signals in block [bk7]
20200204.144104.101 r9999a CFC17700 OLcDrive 0122 check signal pair: route=NEWsdrfgd block=bk7 fromTo=true signalpair=true sgpair=2
20200204.144104.102 r4201a CFC17700 OLcDrive 0116 Setting state for "MY1121" from LC_CHECKROUTE to LC_PRE2GO.
20200204.144104.202 r4201a CFC17700 OLcDrive 0051 Setting state for [MY1121] from LC_PRE2GO to LC_GO.
Any help appreciated.
Marklin C-track + CS3+
Offline PMPeter
#2 Posted : 04 February 2020 15:55:32(UTC)
PMPeter
When you put Rocrail into Automatic and start a locomotive it should reserve the next 2 blocks available on a route for that locomotive and turn those 2 blocks yellow. If only the first block is available it will turn that block yellow. That can also happen if the first block is a Wait block and you have not selected to reserve the second block even if the first is a Wait.
If I understand correctly you select the loco to start, the blocks turn yellow (which is correct), but the loco does not move. What does it say for the loco: Wait, Auto, or something else?
Offline morsing
#3 Posted : 04 February 2020 16:04:43(UTC)
morsing
14:58:41 loco [MY1121] is in block [bk43] and should travel to [bk7]
And
MY1121 5 bk43 <0% >auto bk7
And then nothing. Lights are on on the loco and the block sensor can see it's there.
But I have tried lots of different things. Sometimes it says <wait, sometimes <auto... Either way, nothing ever happens.
thanks 1 user liked this useful post by morsing
rrf
Offline PMPeter
#4 Posted : 04 February 2020 16:22:26(UTC)
PMPeter
If it says Auto for your loco and reserves the next block, then Rocrail is functioning as it should, but your CS3 does not tell the loco to move. Have you checked whether you can turn the CS3 on and off from Rocrail? If that works then you at least know that the 2 are still communicating with each other.
Can you move the loco from Rocrail in Manual?
Offline morsing
#5 Posted : 04 February 2020 16:53:12(UTC)
morsing
Yes, manual works from Rocrail and the CS3.
I just tried a manual run, and it went to the destination block, and when it hit "In", it stopped and changed the lights over.
I then dragged it back to the the original block, and it changed lights and started going in the wrong direction, but that's just a matter of swapping direction, I assume.
Problem is, after that, I couldn't get it to move again. It's like it thinks it's gone somewhere else, and I can't get it to understand it's still in the same block.
I ran out of time, will look at it again after work.
Offline PMPeter
#6 Posted : 04 February 2020 17:32:14(UTC)
PMPeter
Something doesn't sound right here. In Rocrail Manual mode there should be no destination block. There should be no automatic changing of lights, etc. You should have total manual control of the locomotive and its functions, the same as if you were manually operating it from the CS3.
What you are describing sounds like you have Rocrail Automatic selected and rather than just starting the locomotive for Rocrail to determine where it is going you are manually selecting it to run to a certain block by dragging the loco icon to a certain block. Why it changes direction when it reaches the In sensor of that block is puzzling unless you have selected the block type as Terminal. This designation should only be used for a stub track off of a turntable or a stub track in a yard. If you have designated a Terminal block in anything else you will have a problem.
Perhaps you can post the Rocrail track plan showing where the problem occurs.
Offline Mark5
#7 Posted : 04 February 2020 17:37:38(UTC)
Mark5
It would be great if we could develop a rocrail FAQ that is specific to Marklin users and includes links to resources such as the Rocrail forum, english section.
Great to hear of others experiences using it on this thread. Thanks all.
Mark Five.
#8 Posted : 04 February 2020 19:38:20(UTC)
You have been a member since:: 04/02/2011(UTC)
Hi Morsing
As a Rocrail user I strongly suggest you go on the english speaking Rocrail forum.
In this you can post your Rocrail files and then get help. Marklin user forum is great but you cannot include those file so the help is reduced
From what you describe (block turning yellow) all is fine except the loco in the block maybe not the one receiving the order to go
Offline morsing
#9 Posted : 04 February 2020 20:04:11(UTC)
morsing
Hi Morsing
Ok, I will try. But this is what put me off last time I looked at it:
"Update the Rocrail installation. This is essential :!: Rocrail Update"
1) They don't use proper version numbers, they use some nightly build number system that doesn't add up
2) I use Debian and it's installed as a package and I would rather leave it that way
Offline PMPeter
#10 Posted : 04 February 2020 20:28:58(UTC)
PMPeter
Yes the Rocrail forum will insist that you have the latest nightly build installed before you post your files. This can certainly cause some problems that you are not expecting because if you haven't updated in quite a while various things may have changed that you need to correct first before going on with your actual problem. So my suggestion would be first to try and get your locomotive working satisfactorily through Rocrail with Automatic turned off. If you have control of it, its direction and speed and functions, then you know your communication is good. Once you are happy with manual control go back to Automatic and manually try to get it to go from block to block until you encounter a block that gives you a problem. If that doesn't work then I too agree that you should go to the Rocrail Forum, but you will need to have the latest build installed.
#11 Posted : 04 February 2020 20:32:27(UTC)
I'd be happy to include the Rocrail file format extension(s) so you can attach it to a post... Smile
Offline Martti Mäntylä
#12 Posted : 04 February 2020 22:35:44(UTC)
Martti Mäntylä
Reading this gives me the impression that you are using drag & drop automatic mode to run the loco. Did I understand correctly that the loco changes its direction twice: once when it hits the "in" sensor of the destination, and once again when you use the drag & drop to send it back? If so, then the logical direction of the loco does not match with the direction it should go, and it will stay put. You can try to change the logical direction before the second drag & drop to see if that helps.
In any case, I agree with Peter that something is not right. Check the destination block definitions!
- Martti M.
thanks 2 users liked this useful post by Martti Mäntylä
Offline morsing
#13 Posted : 05 February 2020 08:38:50(UTC)
morsing
I spent too much time on this yesterday with work etc, will do some testing over the weekend.
Can't remember the manual test, I didn't use drag-n-drop, maybe it was a different test were it stopped and changed lights.
It's must be something simple causing this, I have read the step-by-step start-up guide several times, but it's not very good at explaining.
I still don't understand the '<', '>' & '-' signs in the loco status window. Nor really what the difference between 'auto' and 'wait' is and these things don't seem to be in the Rocrail wiki.
At one point the trace window did tell me the block didn't accept trains in the direction I was coming from, so that was helpful, but I haven't had that since. I'm sure it's just a direction problem somewhere, but it's odd how I can sometimes go from block 1 to 2, and it seems to kinda want to go from 2 to 1 after that, but nothing else, and I can't get it to accept picking up the loco and manually placing it.
At the moment I only have one route set-up, between adjacent blocks '7' and '43' and back. I believe I have set the entry direction correctly.
I will post up some screenshots later in the week or over the weekend.
Thanks.
P.S. Found this, will have a read: https://wiki.rocrail.net/doku.php?id=loc-tab-en
Offline PMPeter
#14 Posted : 05 February 2020 16:25:11(UTC)
PMPeter
I agree that it appears to be a setting that is ticked or a definition of a block type that is causing you this problem.
Some basic Rocrail info to help you out:
1. You can use Rocrail in 2 modes: Manual and Automatic. In Manual you have total control of the locomotive as far as direction, speed and functions are concerned. It acts like any other controller such as your CS3. It does not go to any assigned block nor does anything unless you tell it to. In Automatic you have 2 choices. You can either select the locomotive and ask Rocrail to Start it or drag the loco icon to a desired block. Rocrail will then select an available route, start the loco and take it to the next block(s) at the speeds and with the functions set up for the block(s) or Route. The loco will keep running in this mode until you stop Automatic mode for that loco or perhaps it enters a Terminal block. If you use the other alternative of dragging the loco icon to a specific block you need to make sure that the "Swap loco entry" has the loco direction defined properly with the actual direction of the loco on the track and that this direction will take you to the desired block. If the direction is wrong either physically or for getting to the desired block, the loco will just sit there.
2. The symbol ">" means the loco is set for Forward direction.
3. The symbol "<" means the loco is set for "Reverse" direction.
4. In Automatic mode "Wait" means that the loco is either waiting for a Route/Block to clear so that it can be reserved, or it is in a Block that has the Wait function enabled (such as a station track). The Wait time is defined either by the loco settings or the Block settings. Once the Wait time has timed out the loco continues on in Automatic mode.
5. In Automatic mode "Auto" means the loco has been assigned a route and should move. If it doesn't, it either isn't getting the signal (give it a nudge) or it is facing the wrong direction or in some occasions the loco has wrongly been defined to run in Reverse.
Hope this helps.
#15 Posted : 05 February 2020 23:44:45(UTC)
Why can you not run the train back down the track?
I suspect the reason it won't run after you manually move it using "the hand of god" it looses track of where the loco is and thinks it is still at its destination. Now there is something it knows is at the source point it shows the track as occupied, but it doesn't know it is the same loco.
#16 Posted : 06 February 2020 15:01:11(UTC)
Hi Morsing
Yes Rr forum want you to use a recent version (no you don’t have to change every day)
IMO on a simple layout the version is not critical so if Juhan is kind enough to make the forum accept XML file them you can copy the files:
- plan.xml
- rocview.ini
- rocrail.ini
- locofile.xml
- occ.xml
I willbe glad to look into it
Note to Juhan: apparently rocview. ini and rocrail.ini are xml / text-like files. Here is a sample
<?xml version="1.0" encoding="UTF-8"?>
<rocrail planfile="C:\Users\Jean\Documents\Rocrail\BeauSoleil 03-02-2020 AufstellBk.xml" locs="locofile.xml" autosave="0" analyseplan="true" occupancy="occ.xml" backup="true" maxbackup="100" backuppath="backup" keypath="lic.dat" libpath="." imgpath="images" iconpath="icons" issuepath="issues" soundpath="sounds" soundplayer="" soundplayerlocation="false" xmlscriptpath="." decpath="decspecs" ptiid="" lciid="" dpiid="" sviid="" sciid="" fsutf8="true" scsensor="" createmodplan="false" resetspfx="false" aboxhome="abox" poweroffonexit="true" poweronatinit="false" shutdownonexit="false" nodevcheck="true" autosaveonmodify="false">
<ctrl sgevents="false" swti...
Edited by user 06 February 2020 21:52:35(UTC)  | Reason: Not specified
Offline morsing
#17 Posted : 09 February 2020 11:18:06(UTC)
morsing
Hi, I couldn't find all the files you asked for but:
http://www.morsing.cc/Trains/plan.xml
http://www.morsing.cc/Trains/occ.xml
http://www.morsing.cc/Trains/rocrail.ini
Another problem that has now started is that the sensors in RocRail are no longer activated. They work fine on the CS3, just nothing happens on RocRail.
Yesterday, by magic, the train actually went from bk7 to bk43, except it didn't stop because Rocrail no longer sees the sensors. But after that, I couldn't get it to move again.
Can someone explain how all the + - < > need to be set on the loco from, to block and speed, combined with the < > in the blocks for the train to move? I'm sure the only problem here is my lack of understanding, and reading the Rocrail Wiki still hasn't made me come to any epiphany.
Also, what 'mode' do I set it to? I keep flicking between auto modes, to try to activate it. Maybe the problem some of the time is it's in half-automatic mode rather than fully automatic? How do I set it to fully automatic?
#18 Posted : 09 February 2020 12:20:24(UTC)
Hi Morsing
I have loaded your plan file and your rocrail.ini files but what I get is a truncated plan.
It may be because I don't receive the files normally so as to download then. I will send you my email per PM so that you may send them in a conventional way.
It looks like this:
So from what I see
- the plan is not healthy
- I see only 2 blocks and a missing track piece (double slip switch). Rocrail can only move trains from one bloc to another if there is a direct way (no direction change)
So to get further I need to have your real files sent by email
#19 Posted : 09 February 2020 12:39:35(UTC)
Hi Juhan
XML File downloading:
I order to retrieve Morsing's files, when I click on the file it opens a new tab with html view of the file. So I selected the content and recreated the file (copy-paste into an xml editor and save the file. Doing this apparently may have truncated the file. Is there a way to attach an xml file to a message in this forum?
Thank you for your help
Offline morsing
#20 Posted : 09 February 2020 12:48:39(UTC)
morsing
Hi Morsing
It looks like this:
So from what I see
Hi, that looks nothing like my plan. Can you not right click and save?
#21 Posted : 09 February 2020 13:34:04(UTC)
Hi Morsing (again)
I suggest to start from a working demo plan as it can be downloaded from here https://wiki.rocrail.net/doku.php?id=download-int at about mid page.
Before this you need to save your work by copying all 5 files to a back-up durectory (plan.xml, rocrail.ini, rocview.ini, locofile.xml, occ.xml)
Then load it in your rocrail working directory while Rocrail is not started and then start Rocrail.
Recommended practice:
- each block must have a sensor on each side at least (usually ENTER sensor and IN sensor)
- make a simple layout representing your layout (typically a loop of track or more.
- all tracks are by default bi-directional. If you wish Rocrail not to consider both directions, insert a special track in the way between 2 block (track plan/edit panel then right click were you want to insert the direction track and select Add Item Track/Direction.
- possibly add branch lines (ending with a buffer and a block (with one or 2 sensors). The block in this branch line must tick "terminal station" (or at least "allow change direction") in its properties.
Rocrail will do for you all the final checking and create the routes. Check to Step by step tutorial here https://wiki.rocrail.net/doku.ph...bystep-en#the_track-plan
Rocrail can analyse your project or clean it using file/router/routing. Attention it wil erase all routes and create new and clean ones. It will also program all track symbols so that when a route is selected, all symbols used by that route will turn yellow. So periodically save your work by saving the 5 files mentioned.
If the plan is not healthy (i.e.: not suitable for operation, it will indicated in the lower left corner of the screen what the problems are.
In your case with the plan I have received it says:
13:14:40 Plan is NOT healthy. See previous ERROR lines.
13:14:40 ERROR: plan position[15-3-0] object[tk] id[tk13] overlaps object[bk] id[bk2]
13:14:40 ERROR: plan position[14-3-0] object[tk] id[tk3] overlaps object[bk] id[bk2]
13:14:40 ERROR: plan position[13-3-0] object[tk] id[tk2] overlaps object[bk] id[bk2]
Where all positions indicate the x (horizontal), y (vertical), z (layer) of the problematic entry. Example plan position[15-3-0] shows that item in the 15 th row and 3rd line is problematic.
My advice is to start from a simple and healthy plan, save all files, make a limited number of changes, test for health, simulate the operation (by activating sensors and starting trains, or use the drag and drop. once tested OK then save all files and make new changes.
cheers
Offline PMPeter
#22 Posted : 09 February 2020 16:30:03(UTC)
PMPeter
I agree with Jean that you need to get a simple plan working and that you are probably not getting some of the basic settings correct.
Regarding your comments about Modes there really are only 2 - Manual and Automatic. When you first power up Rocrail you will have Power Off and Manual Mode by default. When you turn Power On you should have manual control of the locos that you have configured for Rocrail control. Again I suggest that you try to move the loco on the loco control panel by selecting it to go forward, reverse, adjust speed by moving the slider up and down and check all of the functions. If you do not have this Manual control you will not be able to get the Automatic mode to operate properly.
Please confirm that this works for you and then we can move on to the Automatic settings.
Offline morsing
#23 Posted : 10 February 2020 09:14:10(UTC)
morsing
It's just that my whole station is screwed down, so it's not that easy just starting over. I have only set-up one bi-directional route between two adjacent blocks, one being a end bit, maybe I need to define it as a dead end?
My version of RocRail does not have File -> Router -> Routing, I have seen that mentioned on the Wiki as well.
Henrik
P.S. Our garage roof blew off yesterday and the rain drenched the inside. My train setup is in there, so spent the day rescuing what we could. Might have to cut out new baseboards if they warp :-(
Offline PMPeter
#24 Posted : 10 February 2020 15:29:25(UTC)
PMPeter
Sorry to hear about your roof. That puts a crimp on model railroading!!
I don't think Jean was talking about physically ripping up your track and rearranging it. I think he was talking about simplifying your Rocrail track plan for part of your layout. After 6 years I still do not have my total physical track layout in Rocrail. I add blocks as I get other areas working properly.
If you have a stub track (end bit) that block needs to be defined as a "Terminal Station" in the Block properties.
#25 Posted : 10 February 2020 18:33:29(UTC)
Hi Henrik
Sorry for your garage roof. I hope the damage will be minor
In the meantime you will be able to play with Rocrail using simulation
#26 Posted : 11 February 2020 08:05:53(UTC)
Oh Dear !
So sorry to hear that.Crying
PJSad
Offline morsing
#27 Posted : 11 February 2020 11:52:49(UTC)
morsing
I can only count myself lucky that I was actually in the garage when it happened. If not, there would have been severe damage to a lot of things. Swift operation with help from my wife saw most things only damp rather than wet.
So, just tried Virtual running, and it works a treat. Back and forth to the little loco's heart's content. Only thing I need to do is swap placing at each end, I don't even have to click the sensors..
And running the train has always worked in manual mode, no problem there.
It was slightly odd when the sensors suddenly wasn't working in Rocrail, my the train wouldn't run even before that.
To correct some of the plan errors reported, what do the location numbers mean? " Track symbol in 35-15 overlaps with another one"?
As mentioned before, I don't have a routing tool in the file menu. Also, there is no-where I can find to set a block as an end station?
#28 Posted : 11 February 2020 12:15:28(UTC)
These are x and y coordinates (it may be clearer when you select the grid to be displayed. Anyway at the bottom of your screen the coordinates of the selected black are displayed.
It is in the command group to verify you program (healthyness, to clean it, etc)
There is surely an equivalent (in the "file" tab) but the name has been changed.
Otherwise loading the last version of Rocrail is very easy. All you need to do is:
- to select your operating system (Windows, Mac OS, Linux)
- to select the format (32 or 64 bits)
- load the exe file and execute it
- answer some easy questions (use defaults works well)
I did renew my Rocrail version and it took me 2 minutes, not more (no uninstall needed)
I recommend you keep a copy of the software version you use. That way you can go back if you have problems with a version.
cheers
#29 Posted : 11 February 2020 12:38:03(UTC)
A simple way to have the loco change direction when entering a dead end is to create a function (going into TABLES/ACTIONS) with a name like LOCOSWAP. TYPE: locomotive; COMMAND: swap; ID: left blank
Next is to insert in blocks of deadends an ACTION LOCOSWAP with STATE: in and TIMER: 2000
The result is: any loco entering any block (during the "in" phase) where this ACTION is will change direction after 2 seconds (TIMER=2000)
Offline PMPeter
#30 Posted : 11 February 2020 15:21:13(UTC)
PMPeter
If you right click on the Block that is your end block and click on Properties you will receive a list of items for customizing that Block. One of those items will be Terminal Station. This needs to be selected to define that Block as an end point and allow the loco to automatically reverse direction.
Offline morsing
#31 Posted : 12 February 2020 08:40:51(UTC)
morsing
My version does not have the routing menu and it does not have the terminal station setting either.
I looked at upgrading but the only downloads available are from 2010, I can't see that being any newer than mine.
https://launchpad.net/rocrail/+download
#32 Posted : 12 February 2020 11:38:34(UTC)
Hi Henrik
The link for all download is here https://wiki.rocrail.net/rocrail-snapshot/
The link for the 64 bits version for Windows is here https://wiki.rocrail.net/rocrail...ot/rocrail-475-win64.exe
Those allow you to load todays version Feb 12, 2020
I am sure you have the equivalent of the router subdirectory. It was called differently before.
You have buffers on your version:
- set track plan into edit mode
- right click on the point where you want to insert a buffer
- select track/buffer
Offline morsing
#33 Posted : 12 February 2020 11:41:13(UTC)
morsing
Thanks, but as soon as I click on Linux, it goes to that weird place from 2010.
I will upgrade RocView though, if that will help, but RocView and RocRail will probably just be even more out of sync, version-wise.
P.S. Aha! Upgrading RocView made both "Router" and "Terminal Station" appear!
P.P.S. The entries in the Router menu do nothing, and Terminal Station is greyed out.
#34 Posted : 13 February 2020 00:45:52(UTC)
Martti Mäntylä
The download page your got to is the current one, with most recent build of the system. Never mind the title that speaks of 2010.
Router won't work unless you give it a healthy plan. "Terminal station" is greyed if you have selected the "Allow change direction" option - these options are mutually exclusive.
- Martti M.
Offline morsing
#35 Posted : 23 February 2020 12:23:52(UTC)
morsing
Garage roof covered up, had a friend come round yesterday to play with this RocRail things.
I now know what the problem is, it's what I suspected all along:
*** I do not understand how it works! ***
And reading the Wiki doesn't really seem to help either.
Once again, randomly, 1-in-20 times, we got the loco to run through the route, only half the times it tried running in the wrong direction.
So, what the problem is here is the "Swap placing" and "Swap block enter side".
So:
1) Does the little block arrow always have to point in the loco's exit direction out of the block?
2) Once the enter side it correct, how can you tell if the "placing" is correct? Nothing seems to indicate the placing, or is it one of the symbols in the loco list? If so, how should it be set?
3) Why can't RocRail figure out when it needs to change direction? "Allow change direction" is set in the block, why do I have to do it by manual control?
Offline PMPeter
#36 Posted : 23 February 2020 16:07:16(UTC)
PMPeter
1. When you drag a loco icon into a block for the start of Automatic control of that loco, the arrow shown in the block needs to agree with the physical forward direction of the chosen loco. If it is opposite then you have 2 choices: a) Rotate the loco to agree with the Rocrail block direction. b) In Rocrail in the Block Properties select "Swap block enter side".
2. For most cases the loco symbol for the locomotive direction should be > for the forward direction.
3. Rocrail will automatically change direction if you have a block defined as a Terminal Station, or if you have defined a train as a shuttle train and defined the blocks that the shuttle goes from and to.
Offline morsing
#37 Posted : 26 February 2020 21:37:22(UTC)
morsing
What's wrong with this picture (hint: Train ain't going nowhere):
Offline PMPeter
#38 Posted : 26 February 2020 22:25:51(UTC)
PMPeter
That's an easy answer. You have the loco in Block 7. The block arrow indicates that your locomotive is positioned to head out to the left towards blocks 43, 44 and 45 and perhaps others on the left hand side that cannot be seen on your screen shot. Yet you have selected the destination block 9 on the right hand side. In Automatic mode the loco will not move because it cannot reach block 9 based on the track plan visible.
Offline morsing
#39 Posted : 26 February 2020 22:31:14(UTC)
morsing
... Yet you have selected the destination block 9 on the right hand side. In Automatic mode the loco will not move because it cannot reach block 9 based on the track plan visible.
Thanks, but... I haven't. Look at the server window at the bottom left. I selected block 43, which it seemed to accept, so no idea why it put block 9 on the loco.
Is there anything else wrong?
Offline PMPeter
#40 Posted : 26 February 2020 22:42:12(UTC)
PMPeter
Because the first command it was given was to go to Block 9, followed by 3 commands to go to block 43. Until the first command is reset it will not follow through on the next 3. In the loco window it is very clear that its destination is block 9. Reset all, redrag the loco icon to block 7, make sure the Block 7 arrow and locomotive forward direction are the same and then switch to Automatic and drag the loco icon from block 7 to block 43 and it should move.
Offline morsing
#41 Posted : 26 February 2020 22:57:22(UTC)
morsing
Ah! Thanks a lot, that could be the cause of a lot of my problems! Don't know why the documentation doesn't mention this...
The only problem is why it didn't go to 9 in the first place, but that might be another directional issue.
Is there a way to see the destination queue for a loco?
Offline PMPeter
#42 Posted : 26 February 2020 23:11:49(UTC)
PMPeter
It could not go to block 9 from the initial command because the loco direction was set to exit from the left. In Rocrail unless you define a loco as bi-directional commuter loco or shuttle or it enters a Terminal Station block, the loco will always want to go in the forward direction. Since I can only see the screenshot that you provided, there is no possibility for that loco to go from Block 7 to Block 9 in the forward direction. You would need to manually turn your loco around and would need to Swap the block enter side of Block 7.
If you manually drag the loco icon to a destination block, that block should show up in the loco panel. If you just want the loco to start in Automatic with no specific destination and you have Reserve Second Next Block activated you should always see the next 2 blocks the loco is destined for by their yellow colour, which change to blue when the Enter sensor is activated and pink when the In sensor has been reached and then the next block turns yellow. This goes on until you reach a Wait block.
Offline applor
#43 Posted : 27 February 2020 03:42:56(UTC)
applor
Just to re-iterate what Peter is saying:
The arrow in the block is the direction the train is facing and must travel (irrespective of whether the loco itself is set to move forward/reverse, that is called swap placing - dont use it unless you want the train in reverse)
If the arrow is pointing in the wrong direction, simply right click on the loco and select 'swap block enter side' - assuming the loco is correctly placed on the track.
To set a destination, you right click on the loco and choose 'set destination'. The block chosen must have a valid route from where it currently is.
Then, once you start auto mode it will set that block as its destination.
Otherwise if you start auto mode normally it will randomly choose a destination based on routes available and other things you can set (such as train type, block length etc)
Also handy, if you set a loco destination and change your mind but the train is still in its original block, you right click and select 'soft reset loco auto mode'
It's documented, though it can be hard to understand or hard to find.
https://wiki.rocrail.net/doku.php?id=direction-en
Offline morsing
#44 Posted : 27 February 2020 08:32:30(UTC)
morsing
Thanks, this has been extremely helpful. It makes sense now, about bi-directional locos.
And I had read that page multiple times and while it does mention features or "how" the Wiki rarely mention "why" or "when". It like they assume you are already a real life train driver.
More testing later today...
Offline morsing
#45 Posted : 03 March 2020 10:55:35(UTC)
morsing
To keep a long story short, I upgraded RocRail as well, finally, fixed some problems, and the "router" now works! Excellent.
I'm getting to grips with the directional thing, although still not quite sure about block enter side / logical swap / train direction. Sometimes I have to set the block arrow to point away from where I want to go, and it then swaps it when I start going. Odd.
I still have some problems though, some sort of permission issue.
I can merrily got back and forth between bk43 / bk7 / bk9 in the diagram posted further up, but if I try to go to bk8 or bk9, nothing happens. It's very frustrating that it logs so much info, but not why it won't go. Log say "Go", but nothing moves.
In the interest of teaching a man to fish, how can I troubleshoot why a train just doesn't move? It sets all the points correctly, and it doesn't complain if I drive it there half-automatically, but it won't go to or *from* bk8 or bk9 automatically.
Offline PMPeter
#46 Posted : 03 March 2020 15:46:51(UTC)
PMPeter
Now that you have updated Rocrail I would suggest that you create an "Issue" on the Rocrail forum and send them the Issue files with a detailed description as to what the problem is. Without seeing the files and your actual Block, Loco and Route properties and settings, it is very hard to comment much further.
I am also confused by your statement that you can go back and forth between bk43 / bk7 / bk9, but you can't go to bk8 or bk9. So can you or can you not go to bk9?
I am going out on a limb here that perhaps the Routes to or from bk8 and bk9 have not been created. You can check this in the Routes Table. If for example there is no Route identified to go from bk9 to bk8 you can ask it to go but it will not. You would manually have to create that Route since the automatic Route generator would not see this as a standard route. So check all of the possible Routes that you are trying to use and see if they exist.
Offline morsing
#47 Posted : 03 March 2020 16:22:51(UTC)
morsing
Thanks but, as above, I'd rather learn how to fix it than someone fix it for me.
Sorry, the second bk9 should have been bk37.
The routes are definitely there, the routes are what sets the points, which works. Also, half-automatic running works and even in automatic it says it's all ready to go, it just doesn't go...
I'll poke around some more.
P.S. It's probably just a directional problem (again), reading through this: https://forum.rocrail.ne...7315b65d7664c2f98907cb8e
Offline PMPeter
#48 Posted : 03 March 2020 18:18:42(UTC)
PMPeter
What is your definition of half automatic?
Offline morsing
#49 Posted : 03 March 2020 20:02:34(UTC)
morsing
I drag the train to another block, Rocrail sets all the points correctly, but I have to set the throttle either in Rocrail or using the big red knob...
Offline PMPeter
#50 Posted : 03 March 2020 20:13:46(UTC)
PMPeter
That in itself does not sound correct. When you are in Automatic mode and drag the loco from its current block to a destination block you should not have to touch the throttle. The loco speed is determined by whatever the Rocrail speed settings are for the departing block, destination block or the loco default. If you are controlling the loco speed using either the Rocrail throttle or the big red knob, something is set up incorrectly.
Guest (8)
2 Pages12>
This page was generated in 1.262 seconds.
