Offline 3gleise
#1 Posted : 31 October 2018 22:26:16(UTC)
3gleise
good evening,
on a locomotive I install a 60985 sound decoder but I have a problem with the sound of the brakes.
I have a mobile station 60657 and I can not find where to set the sound.
can I solve the problem with the programmer 60971? and how to proceed
thank youSad
Offline ktsolias
#2 Posted : 01 November 2018 09:12:17(UTC)
ktsolias
The 60971 decoder programmer is a great piece of hardware.
The CS3 is again a great piece of hardware
The mLD/3 and mSD/3 decoders are great
BUT THERE IS A BIG PROBLEM:
The software who supports all these is rubbish. In my opinion is not in beta either.
The documentation that support all these actually does not exist at all!!!!
The only documentation is how to connect the wires !!!!!
I am looking on the excellent documentation of ESU to find information's ......
PLEASE MARKLIN GIVE TO US DOCUMENTATION FOR YOUR PRODUCTS and IMPROVE THE SOFTWARE NOW!!!!
Costas
#3 Posted : 01 November 2018 09:27:39(UTC)
We have many threads about how to get the decoder play the sound of squealing brakes: run very fast and brake very hard.
Do not activate any functions beside the operating sounds.
Did you create the sound project yourself? The brake sound may not be configured correctly.
It should be setup correctly if you just downloaded a sound project from Märklin.
Offline Donb
#4 Posted : 02 November 2018 16:38:17(UTC)
Donb
Instructions on how to use the decoder programmer 60971 are found in the book " Digital Controll with CS3", 03082/03092
Quite complete.
Best Regards,
Don
TFT ECOS, C track and Z scale, mostly DB/DR and SBB, SJ
thanks 3 users liked this useful post by Donb
Offline Donb
#5 Posted : 04 December 2018 04:01:35(UTC)
Donb
I have been working with the Marklin Decoder tool 60971.
My project was to replace the stock sound decoder in StartUp model # 36627 with a mSD3 (60977) decoder to:
1) use DCC ( the stock decoder does not support DCC)
2) hopefully improve the running characteristics of this loco. When starting from a stop, it hesitates and is not smooth on throttle.
The software is rather straightforward, and the sound library (after downloading the update) has many more entries than I’ll ever use. What took the most time for me was that I had to translate the sound entries as they are all listed in German. No problem.
I uploaded the completed project onto the new mSD3 decoder, after I had updated the decoder software.
The loco now drives much better, no more hesitation at start and smoother on throttle. Also, the sounds are improved. One of the many settings is you can set the headlights to follow Rule 17, so that they dim a little when the loco comes to a stop. Very nice.
I also plugged the stock decoder into the 60971 to see if it could be read, and nope. Not supported, which is disappointing. Might be an older mSD decoder.
One thing I cannot figure out, and that is I want to set F5 and F6 to turn off the Front and Rear headlights respectively. I cant seem to figure out how to set up the function keys to do this. Anyone know?
Best Regards,
Don
#6 Posted : 04 December 2018 08:29:12(UTC)
This can easily be done with ESU V4 decoders, but I don't know if the msd/3 has sophisticated function mapping to achieve this.
Märklin locos usually have a lot "bird seed" on the loco PCB to achieve the light functions with F6 and F8.
Check with the old decoder what F6 and F8 do. You can then use F5 and F6 instead.
Alternative:
You can easily set F5 to activate lights for one direction only.
You can easily set F6 to activate lights for the other direction only.
But F0 will then override F5 or F6.
Maybe this is what you want. Or at least sufficient for your needs.
If white and red lights are controlled by a single function output then there is no "programming only" solution to switch them separately. A bit of soldering will be needed.
Does rule 17 apply to German or Swiss locos?
Offline ktsolias
#7 Posted : 04 December 2018 11:17:03(UTC)
ktsolias
It is possible with the mSd 3 decoders
As much as I can understand you want the red taillights on and the white lights off, independent of each other
1. And to F5 and F6 the frond and rear lights respectively
2. Set the Condition for both functions to Neg. Level
3. May be there are conflicts with the F0 and how the red taillights are triggered. In Marklin most of the time is done by hardware mapping...
There is another easier possibility to disconnect the red lights from the white ones and connect them to the AUX 3 or AUX 4 if available and control them directly from F5 and F6. Of course to do that you have to override the hardware mapping.
Good luck
Costas
Offline Donb
#8 Posted : 04 December 2018 17:29:12(UTC)
Donb
I set up F5,F6 per Costa's suggestion, and yes F0 overrides this. If I leave F0 off, then I can select which headlights to leave on (also per Tom's suggestion). But the rear talights shut off too. Would like to have them stay on. So maybe some soldering will be involved, but not sure I am that interested. I only want to be able to shut off the forward headlights for "push' configuration.
I cannot read the old decoder with the Decoder Programmer, not supported, so I cannot see how F6,F8 were set up unfortunatly. I'll have to experiment with the configuration settings of the lights and see if one of the settitngs triggers the loco board 'bird seed" (circled).
[img=null]locopcb[/img]locopcb.jpg
What are the three solder tabs (arrow)? Is this the Aux 1,2,3?
Best Regards,
Don
#9 Posted : 04 December 2018 18:30:06(UTC)
The decoder can be read with a CS2, probably also with a CS1. The CS3 should sooner or later also be able.
If you do not have any CS, then maybe another forum member with a CS and a 36627 can tell us what F6 and F8 do with the original decoder.
Typically this would be a pair like AUX1 and AUX2 - or a pair like AUX3 and AUX4 - or a pair of SUSI functions. These are the three patterns I have seen with Märklin locos so far, but other methods are also possible.
Offline Donb
#10 Posted : 05 December 2018 02:35:23(UTC)
Donb
Well that worked!
I don't have a Maerklin CS, but using the 60971 I configured F6 and F8 to controll Output 1 and Output 2, and now it works great, same as OEM setup. The headlights turn off and the red tail lights remain on in either direction, all while F0 is on. Perfect!
One day I may try diffent function button assignments (ie: F5,F6) and see if it still works.
Thanks once again for your assistance, Tom!
Cheers!
Best Regards,
Don
Guest (12)
This page was generated in 0.382 seconds.
