Offline Eiger
#1 Posted : 14 May 2018 20:47:22(UTC)
Eiger
Hi, I just bought and old 7051 Crane. I have a small C Track starter set that comes with a transformer. The question is - how do I power this crane? Can it run from this transformer? I don't want to burn the crane out by plugging it into the wrong thing! Confused
John F
Cape Town - South Africa
Do your bit: www.greenpeace.org
Online JohnjeanB
#2 Posted : 14 May 2018 22:09:41(UTC)
Hi John
The 7051 Crane needs 16 VAC between the yellow plug and the brown plug. Other plugs (motor rotation, hook lift, solenoid) have to be connected to a pushbutton control (as for switches) with the control common connected to the brown plug / brown output of your transformer (not a switched power supply as provided now, because the crane is intended to operate with 16VAC, 50Hz).
Regarding your starter set and digital (if it is digital or delta), a strongly recommended practice is to assign the transformer used for digital exclusively to that purpose to reduce the risk of burning your digital output circuit (MS1 or MS2, or CS1, CS2). If you insist you can connect the 16 VAC of your transformer as described above at your own risk. One simple connection of it to any digital signal may destroy your digital power system but if you are sure they will never ever come in contact it will work.
If your starter set is neither digital nor delta but traditional 16 VAC then no restrictions.
PS I love this crane although I avoid using it with more recent HO stuf (scale, noise, tin plate)
Offline Eiger
#3 Posted : 15 May 2018 13:09:23(UTC)
Eiger
Hi John
Thanks Johnjean Smile
John F
Request Help with Wiring Joystick to Marklin 7051 Crane (General MRR)
by mjborelli 26/12/2022 01:42:54(UTC)
Marklin 7051 Crane (H0-scale)
by fossie 22/08/2021 10:05:08(UTC)
Joystick for Marklin 7051 crane (H0-scale)
by mjborelli 24/03/2019 01:49:34(UTC)
Availability of BRAWA Container Spreader for Marklin 7051 Crane (General MRR)
by mjborelli 10/03/2019 18:46:35(UTC)
Availability of Marklin 7051 Crane wiring cable (General MRR)
by mjborelli 02/03/2019 03:24:46(UTC)
by roncdn 16/06/2017 04:22:37(UTC)
