Offline disavelo
#1 Posted : 20 August 2017 11:23:27(UTC)
disavelo
Hej
I want to install digital telex couplers E 117 993 in a (selfmade) locomotive, and to connect them to an ESU lokpilot V4.0 (F1 and F2). Is a resistance in the circuit(s) needed ? Confused
Søren
#2 Posted : 03 September 2017 12:00:09(UTC)
Hi Søren
I use the same telex coupler with Märklin loco decoder, and for the telex output, I use the dim function with 100 (out of 256 power range)
I further limit the time to 9 seconds. All this is done with a CS2. I don't think a resistor would help much.
Probably the same is feasible with your ESULokpilot.
Good luck
Guest (4)
Digital Telex Couplers ... Compatible? (H0-scale)
by Night Train 06/06/2005 02:09:38(UTC)
This page was generated in 0.198 seconds.
