Offline nagato
#1 Posted : 31 October 2009 18:22:02(UTC)
nagato
I suspect that my Zephyr was designed for the Delta system because the horn, bell, diesel rumble and drum head light all work on the mobile station while the head lights and interior lights only work on analog. I wonder if anyone else has encountered this issue and would appreciate any advice.
Offline pa-pauls
#2 Posted : 31 October 2009 18:25:19(UTC)
pa-pauls
Hi Charlie and welcome to the forum !
This is all correct Smile Function's like the horn, bell and so on work only in a digital system like the mobile station, central station or alike wink
Pål Paulsen
Offline Ian555
#3 Posted : 31 October 2009 18:28:28(UTC)
Ian555
Hi Charlie,
Welcome to the forum.
Ian.
#4 Posted : 31 October 2009 18:53:19(UTC)
Hi and Welcome to the forum, Charlie.Smile
Offline Renato
#5 Posted : 31 October 2009 19:03:02(UTC)
Renato
Renato
#6 Posted : 31 October 2009 21:29:25(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by nagato
<br />I suspect that my Zephyr was designed for the Delta system because the horn, bell, diesel rumble and drum head light all work on the mobile station while the head lights and interior lights only work on analog.
Delta locos normally have 0 functions that can be controlled digitally.
The Mobile Station has 9 buttons to control 9 funtions - the light button is below the display. It should control the front light of the locomotive.
The train set 26600 has a second decoder in one of the coaches. This decoder controls 4 light functions.
Have you added the train using number 26600 from the database? If you do you might find 2 entries for your train in the loco list.
Offline nagato
#7 Posted : 01 November 2009 18:15:07(UTC)
nagato
Thank you very much for your response. I do have the Zephyr loaded as 26600 and have the right side of the second locomotive (facing the front of the locomotive) set uddddudud (u = up, d = down) with the single switch on the upper left corner of the right side set on. The four switches on the left hand side of the second locomotive are set ddud, which I think is what manual (60 3993 1099 lo) suggests. The switches on the observation car are udddudud with the drum head light to the right. The top rear light goes on and stays on with the horn, and the marker lights on either side of the back of the observation car only work while the bell is working. Charlie
#8 Posted : 01 November 2009 21:23:01(UTC)
If you set them both to the same address (loco address has 9 letters so I presume it's also udddudud), both loco and observation car will respond: light and sound will be switched at the same time.
I don't have the set, I don't have the manual.
According to Stummi, the default address for the loco is 7 (which would be duddudud).
If you want to switch functions independently, you must set different addresses for loco and car.
Offline BeginnR
#9 Posted : 26 November 2009 22:53:24(UTC)
BeginnR
Hello Nagato,
welcome to the forum!
As far as I remember, there is the Adress 7 for the WP Engine and the adress 6 for the decoder in the last car.
By calling 26600 in the Mobile Station you will only get control over the loco at Adress 7.
So, to control the lights and so on, you should choose Adress 6 and it should work then.
I am handling the CZ with the IB by choosing the loco (Adress 7) on the one control and the cars (Adress 6) on the second control. That does it.
Have fun with your CZ!
René
Greetings from Cologne
René
Offline klarinettmeister
#10 Posted : 29 November 2009 01:46:30(UTC)
klarinettmeister
Here is a tip:
I think it was very disturbing using 2 different adresses for the train. I use a CS and experimented. As some of you know, the old Big Boy 37990 has 2 (40,41 by default) adresses but the CS register it as 1 loco entry. As I already have 37990 Big Boy I added one more Big Boy in my loco list. Then I changed the adress for that entry that matched CZ. The adress should match the one in the loco and the adress in the end car should be changed to the next one. Otherwise you can´t drive the loco.
These are my adresses:
CS-entry: 05, Locomotive: 05, End car 06.
Then you have to change all the symbols so that it matches the functions.
F0: Front light
F1: Sound
F2: Bell
F3: Horn
F4: Deactivate acceleration/deceleration delay
F5: End car interior Lighting
F6: End car cabin lights and red marker lights
F7: End car rear red light
F8: End car red sign
26600 California Zephyr - User manual, spare parts (H0-scale)
by Kaspar 05/06/2023 19:10:17(UTC)
26600 California Zephyr set (H0-scale)
by Roger L 18/01/2022 15:55:33(UTC)
California Zephyr tribute by Hank Williams. (Prototype)
by NS1200 23/09/2017 16:51:38(UTC)
Eisenbahn-Romantik on the California Zephyr (Prototype)
by Western Pacific 23/06/2012 23:05:36(UTC)
California Zephyr Prices (H0-scale)
by Jeremy Palmer 26/02/2011 01:05:13(UTC)
California Zephyr report (Prototype)
by DamonKelly 13/01/2010 08:36:07(UTC)
by DamonKelly 28/04/2009 16:07:51(UTC)
This page was generated in 0.420 seconds.
