Joined: 24/05/2009(UTC) Posts: 42 Location: Brisbane, Queensland
Is it possible to simply install a 51961 Hamo magnet and retain the delta decoder? If so, I need to know which of the available green, blue, black and brown wires (from the decoder) are used and to where do they connect. Or do I need to also change the decoder for the Lokpilot V3? Thanks in advance.
Malcolm. |
Malcolm Davison Digital Novice Brisbane Australia |
Joined: 08/01/2006(UTC) Posts: 2,218 Location: Shady Shores, TX - USA
If you install the magnet then you need to install the decoder, the preformance and control go way up and power consumption go down. And I think the delta decoder is designed to magnetic field of coil to change direction. |
DT Now powered by ECoS II unit#2, RocRail
era - some time in the future when the space time continuum is disrupted and ICE 3 Trains run on the same rails as the Adler and BR18's. |
Joined: 16/02/2004(UTC) Posts: 15,451 Location: DE-NW
A Delta decoder can be modified to run DC motors, but I think it's not worth the while. |
