Offline malcolmd
#1 Posted : 16 July 2009 16:55:00(UTC)
malcolmd
Is it possible to simply install a 51961 Hamo magnet and retain the delta decoder?
If so, I need to know which of the available green, blue, black and brown wires (from the decoder) are used and to where do they connect.
Or do I need to also change the decoder for the Lokpilot V3?
Thanks in advance.
Malcolm.
Malcolm Davison
Digital Novice
Brisbane
Offline dntower85
#2 Posted : 16 July 2009 17:02:31(UTC)
dntower85
If you install the magnet then you need to install the decoder, the preformance and control go way up and power consumption go down.
And I think the delta decoder is designed to magnetic field of coil to change direction.
DT
#3 Posted : 16 July 2009 18:33:58(UTC)
A Delta decoder can be modified to run DC motors, but I think it's not worth the while.
Offline malcolmd
#4 Posted : 17 July 2009 10:58:56(UTC)
malcolmd
Thanks again.
Cheers.
Malcolm Davison
Digital Novice
Brisbane
This page was generated in 0.260 seconds.
