Offline jonas_sthlm
#1 Posted : 10 March 2026 20:29:01(UTC)
jonas_sthlm
https://streaming.maerklin.de/public-media/mdt3/mDecoderTool3-v365-Setup.zip
CHANGELOG
Version 3.6.5 - 13.02.2026
Feature:
- The mDecoderTool3 supports the new mSD3.5 and mLD3.5 decoders in H0/1/G gauge
- The mDecoderTool3 supports mLD3 track H0 revision F, mSD3 track 1/G revision G
- The mDecoderTool3 supports the mSD3 track H0 with PluX22 interface with RailCom as a serial decoder with Spielewelt
- The new special function "Derailleur flash" is available in mapping, for which the physical outputs and the SUSI functions F# can be selected and set
- Session-based logging has been introduced for application support. This log, which records events and messages during operation, can be used for remote diagnosis (directory: mDecoderTool3_Logging, path: environment variables TEMP or TMP)
Modified:
- The decoder information in the "Information about Decoder" dialog has been grouped according to decoder hardware and decoder firmware
Improvement:
- The selection of a central station as a programming path has been revised, improved, and optimized to include all stations when multiple networks are set up on one computer and when switching between central stations if there are several to choose from
- In the format settings, mfx and mfx+ can now also be switched on/off
- The decoder information about whether RailCom is supported is only displayed if, in addition to the decoder hardware, the decoder firmware also supports RailCom
- Revised, standardized, and renamed some CV designations, texts, terms, and expressions in mDecoderTool3 and the decoder templates
- The mDecoderTool3 includes the latest FTDI CDM driver 2.12.36.20 for the decoder programmer, which is installed during installation
- The mDecoderTool3 includes the latest MSVC2010 SP1 Redistributable Package. If it is not already installed, it will start the installation if necessary
Bugfix:
- Changes in the decoder project could be lost if the project file mdtp was blocked and could not be written when saving
- When converting projects, the 'old' CV values but the 'new' block IDs must be transferred in the data structure (fds)
- With the flag "Open the last project when starting" in the program settings, the last opened project was only opened when clicking on the start board button "Open an existing project" instead of when the program started, as expected
- When deleting an action in mapping, everything must be removed in the background, i.e. action condition and trigger. Fragments could remain, which reduced the number of free mappings even though the action was deleted
- When resetting a function in mapping, the action may only be removed as a trigger if the action is not still triggered by another trigger
- As long as mDecoderTool3 itself is not correctly scalable (size of text, app, elements), prevent the scaling of texts
Edited by user 11 March 2026 08:01:23(UTC)  | Reason: Not specified
thanks 2 users liked this useful post by jonas_sthlm
Offline jonas_sthlm
#2 Posted : 10 March 2026 20:38:55(UTC)
jonas_sthlm
receiving incremental file list
modpar.cs2
Anfahrt/
Anfahrt/slotpar.cs2
Anfahrt/Bremsen_auf/Standard/
Anfahrt/Bremsen_auf/Standard/Start.wav
Bremsen/
Bremsen/slotpar.cs2
Bremsen/Bremsbacken/Standard/
Bremsen/Bremsbacken/Standard/01Loop.wav
Bremsen/Bremsbacken/Standard/02Loop.wav
Bremsen/Bremsbacken/Standard/03Loop.wav
Bremsen/Bremsbacken/Standard/04Loop.wav
Bremsen/Bremsbacken/Standard/End.wav
Bremsen/Bremsbacken/Standard/Start.wav
Fahren/
Fahren/slotpar.cs2
Fahren/Schiene/4-Achser_01/
Fahren/Schiene/4-Achser_01/01Loop.wav
Fahren/Schiene/4-Achser_01/End.wav
Fahren/Schiene/4-Achser_01/Start.wav
Lautsprecher_Parameter/
Lautsprecher_Parameter/slotpar.cs2
Lautsprecher_Parameter/Neutral_16kHz/
Lautsprecher_Parameter/Neutral_16kHz/Neutral_16kHz_reg.dsm
Motor/Dampf/BR18.5/
Motor/Dampf/BR18.5/1_1_RSTART_.wav
Motor/Dampf/BR18.5/1_2_RALOOPa.wav
Motor/Dampf/BR18.5/1_2_RALOOPb.wav
Motor/Dampf/BR18.5/1_2_RALOOPc.wav
Motor/Dampf/BR18.5/1_2_RALOOPd.wav
Motor/Dampf/BR18.5/1_3_RAENDE_.wav
Motor/Dampf/BR18.5/255.slot
Motor/Dampf/BR18.5/2_1_LASTL_a.wav
Motor/Dampf/BR18.5/2_1_LASTL_b.wav
Motor/Dampf/BR18.5/2_1_LASTL_c.wav
Motor/Dampf/BR18.5/2_1_LASTL_d.wav
Motor/Dampf/BR18.5/2_2_NORML_a.wav
Motor/Dampf/BR18.5/2_2_NORML_b.wav
Motor/Dampf/BR18.5/2_2_NORML_c.wav
Motor/Dampf/BR18.5/2_2_NORML_d.wav
Motor/Dampf/BR18.5/2_3_LEERL_a.wav
Motor/Dampf/BR18.5/2_3_LEERL_b.wav
Motor/Dampf/BR18.5/2_3_LEERL_c.wav
Motor/Dampf/BR18.5/2_3_LEERL_d.wav
Motor/Dampf/BR18.5/2_4_LwNoLaa.wav
Motor/Dampf/BR18.5/2_4_LwNoLab.wav
Motor/Dampf/BR18.5/2_4_LwNoLac.wav
Motor/Dampf/BR18.5/2_4_LwNoLad.wav
Motor/Dampf/BR18.5/2_5_LwLaNoa.wav
Motor/Dampf/BR18.5/2_5_LwLaNob.wav
Motor/Dampf/BR18.5/2_5_LwLaNoc.wav
Motor/Dampf/BR18.5/2_5_LwLaNod.wav
Motor/Dampf/BR18.5/2_6_LwNoUna.wav
Motor/Dampf/BR18.5/2_6_LwNoUnb.wav
Motor/Dampf/BR18.5/2_6_LwNoUnc.wav
Motor/Dampf/BR18.5/2_6_LwNoUnd.wav
Motor/Dampf/BR18.5/2_7_LwUnNoa.wav
Motor/Dampf/BR18.5/2_7_LwUnNob.wav
Motor/Dampf/BR18.5/2_7_LwUnNoc.wav
Motor/Dampf/BR18.5/2_7_LwUnNod.wav
Motor/Dampf/BR18.5/2_8_GuLASTa.wav
Motor/Dampf/BR18.5/2_8_GuLASTb.wav
Motor/Dampf/BR18.5/2_8_GuLASTc.wav
Motor/Dampf/BR18.5/2_8_GuLASTd.wav
Motor/Dampf/BR18.5/2_9_GuLEERa.wav
Motor/Dampf/BR18.5/2_9_GuLEERb.wav
Motor/Dampf/BR18.5/2_9_GuLEERc.wav
Motor/Dampf/BR18.5/2_9_GuLEERd.wav
Motor/Dampf/BR18.5/3_1_LASTL_a.wav
Motor/Dampf/BR18.5/3_1_LASTL_b.wav
Motor/Dampf/BR18.5/3_1_LASTL_c.wav
Motor/Dampf/BR18.5/3_1_LASTL_d.wav
Motor/Dampf/BR18.5/3_2_NORML_a.wav
Motor/Dampf/BR18.5/3_2_NORML_b.wav
Motor/Dampf/BR18.5/3_2_NORML_c.wav
Motor/Dampf/BR18.5/3_2_NORML_d.wav
Motor/Dampf/BR18.5/3_3_LEERL_a.wav
Motor/Dampf/BR18.5/3_3_LEERL_b.wav
Motor/Dampf/BR18.5/3_3_LEERL_c.wav
Motor/Dampf/BR18.5/3_3_LEERL_d.wav
Motor/Dampf/BR18.5/3_4_LwNoLaa.wav
Motor/Dampf/BR18.5/3_4_LwNoLab.wav
Motor/Dampf/BR18.5/3_4_LwNoLac.wav
Motor/Dampf/BR18.5/3_4_LwNoLad.wav
Motor/Dampf/BR18.5/3_5_LwLaNoa.wav
Motor/Dampf/BR18.5/3_5_LwLaNob.wav
Motor/Dampf/BR18.5/3_5_LwLaNoc.wav
Motor/Dampf/BR18.5/3_5_LwLaNod.wav
Motor/Dampf/BR18.5/3_6_LwNoUna.wav
Motor/Dampf/BR18.5/3_6_LwNoUnb.wav
Motor/Dampf/BR18.5/3_6_LwNoUnc.wav
Motor/Dampf/BR18.5/3_6_LwNoUnd.wav
Motor/Dampf/BR18.5/3_7_LwUnNoa.wav
Motor/Dampf/BR18.5/3_7_LwUnNob.wav
Motor/Dampf/BR18.5/3_7_LwUnNoc.wav
Motor/Dampf/BR18.5/3_7_LwUnNod.wav
Motor/Dampf/BR18.5/3_8_GuLASTa.wav
Motor/Dampf/BR18.5/3_8_GuLASTb.wav
Motor/Dampf/BR18.5/3_8_GuLASTc.wav
Motor/Dampf/BR18.5/3_8_GuLASTd.wav
Motor/Dampf/BR18.5/3_9_GuLEERa.wav
Motor/Dampf/BR18.5/3_9_GuLEERb.wav
Motor/Dampf/BR18.5/3_9_GuLEERc.wav
Motor/Dampf/BR18.5/3_9_GuLEERd.wav
Motor/Dampf/BR18.5/4_1_LASTL_a.wav
Motor/Dampf/BR18.5/4_1_LASTL_b.wav
Motor/Dampf/BR18.5/4_1_LASTL_c.wav
Motor/Dampf/BR18.5/4_1_LASTL_d.wav
Motor/Dampf/BR18.5/4_2_NORML_a.wav
Motor/Dampf/BR18.5/4_2_NORML_b.wav
Motor/Dampf/BR18.5/4_2_NORML_c.wav
Motor/Dampf/BR18.5/4_2_NORML_d.wav
Motor/Dampf/BR18.5/4_3_LEERL_a.wav
Motor/Dampf/BR18.5/4_3_LEERL_b.wav
Motor/Dampf/BR18.5/4_3_LEERL_c.wav
Motor/Dampf/BR18.5/4_3_LEERL_d.wav
Motor/Dampf/BR18.5/4_4_LwNoLaa.wav
Motor/Dampf/BR18.5/4_4_LwNoLab.wav
Motor/Dampf/BR18.5/4_4_LwNoLac.wav
Motor/Dampf/BR18.5/4_4_LwNoLad.wav
Motor/Dampf/BR18.5/4_5_LwLaNoa.wav
Motor/Dampf/BR18.5/4_5_LwLaNob.wav
Motor/Dampf/BR18.5/4_5_LwLaNoc.wav
Motor/Dampf/BR18.5/4_5_LwLaNod.wav
Motor/Dampf/BR18.5/4_6_LwNoUna.wav
Motor/Dampf/BR18.5/4_6_LwNoUnb.wav
Motor/Dampf/BR18.5/4_6_LwNoUnc.wav
Motor/Dampf/BR18.5/4_6_LwNoUnd.wav
Motor/Dampf/BR18.5/4_7_LwUnNoa.wav
Motor/Dampf/BR18.5/4_7_LwUnNob.wav
Motor/Dampf/BR18.5/4_7_LwUnNoc.wav
Motor/Dampf/BR18.5/4_7_LwUnNod.wav
Motor/Dampf/BR18.5/4_8_GuLASTa.wav
Motor/Dampf/BR18.5/4_8_GuLASTb.wav
Motor/Dampf/BR18.5/4_8_GuLASTc.wav
Motor/Dampf/BR18.5/4_8_GuLASTd.wav
Motor/Dampf/BR18.5/4_9_GuLEERa.wav
Motor/Dampf/BR18.5/4_9_GuLEERb.wav
Motor/Dampf/BR18.5/4_9_GuLEERc.wav
Motor/Dampf/BR18.5/4_9_GuLEERd.wav
Motor/Dampf/BR18.5/5_1_LASTL_a.wav
Motor/Dampf/BR18.5/5_1_LASTL_b.wav
Motor/Dampf/BR18.5/5_1_LASTL_c.wav
Motor/Dampf/BR18.5/5_1_LASTL_d.wav
Motor/Dampf/BR18.5/5_2_NORML_a.wav
Motor/Dampf/BR18.5/5_2_NORML_b.wav
Motor/Dampf/BR18.5/5_2_NORML_c.wav
Motor/Dampf/BR18.5/5_2_NORML_d.wav
Motor/Dampf/BR18.5/5_3_LEERL_a.wav
Motor/Dampf/BR18.5/5_3_LEERL_b.wav
Motor/Dampf/BR18.5/5_3_LEERL_c.wav
Motor/Dampf/BR18.5/5_3_LEERL_d.wav
Motor/Dampf/BR18.5/5_4_LwNoLaa.wav
Motor/Dampf/BR18.5/5_4_LwNoLab.wav
Motor/Dampf/BR18.5/5_4_LwNoLac.wav
Motor/Dampf/BR18.5/5_4_LwNoLad.wav
Motor/Dampf/BR18.5/5_5_LwLaNoa.wav
Motor/Dampf/BR18.5/5_5_LwLaNob.wav
Motor/Dampf/BR18.5/5_5_LwLaNoc.wav
Motor/Dampf/BR18.5/5_5_LwLaNod.wav
Motor/Dampf/BR18.5/5_6_LwNoUna.wav
Motor/Dampf/BR18.5/5_6_LwNoUnb.wav
Motor/Dampf/BR18.5/5_6_LwNoUnc.wav
Motor/Dampf/BR18.5/5_6_LwNoUnd.wav
Motor/Dampf/BR18.5/5_7_LwUnNoa.wav
Motor/Dampf/BR18.5/5_7_LwUnNob.wav
Motor/Dampf/BR18.5/5_7_LwUnNoc.wav
Motor/Dampf/BR18.5/5_7_LwUnNod.wav
Motor/Dampf/BR18.5/5_8_GuLASTa.wav
Motor/Dampf/BR18.5/5_8_GuLASTb.wav
Motor/Dampf/BR18.5/5_8_GuLASTc.wav
Motor/Dampf/BR18.5/5_8_GuLASTd.wav
Motor/Dampf/BR18.5/5_9_GuLEERa.wav
Motor/Dampf/BR18.5/5_9_GuLEERb.wav
Motor/Dampf/BR18.5/5_9_GuLEERc.wav
Motor/Dampf/BR18.5/5_9_GuLEERd.wav
Motor/Dampf/BR18.5/6_1_LASTL_a.wav
Motor/Dampf/BR18.5/6_1_LASTL_b.wav
Motor/Dampf/BR18.5/6_1_LASTL_c.wav
Motor/Dampf/BR18.5/6_1_LASTL_d.wav
Motor/Dampf/BR18.5/6_2_NORML_a.wav
Motor/Dampf/BR18.5/6_2_NORML_b.wav
Motor/Dampf/BR18.5/6_2_NORML_c.wav
Motor/Dampf/BR18.5/6_2_NORML_d.wav
Motor/Dampf/BR18.5/6_3_LEERL_a.wav
Motor/Dampf/BR18.5/6_3_LEERL_b.wav
Motor/Dampf/BR18.5/6_3_LEERL_c.wav
Motor/Dampf/BR18.5/6_3_LEERL_d.wav
Motor/Dampf/BR18.5/6_4_LwNoLaa.wav
Motor/Dampf/BR18.5/6_4_LwNoLab.wav
Motor/Dampf/BR18.5/6_4_LwNoLac.wav
Motor/Dampf/BR18.5/6_4_LwNoLad.wav
Motor/Dampf/BR18.5/6_5_LwLaNoa.wav
Motor/Dampf/BR18.5/6_5_LwLaNob.wav
Motor/Dampf/BR18.5/6_5_LwLaNoc.wav
Motor/Dampf/BR18.5/6_5_LwLaNod.wav
Motor/Dampf/BR18.5/6_6_LwNoUna.wav
Motor/Dampf/BR18.5/6_6_LwNoUnb.wav
Motor/Dampf/BR18.5/6_6_LwNoUnc.wav
Motor/Dampf/BR18.5/6_6_LwNoUnd.wav
Motor/Dampf/BR18.5/6_7_LwUnNoa.wav
Motor/Dampf/BR18.5/6_7_LwUnNob.wav
Motor/Dampf/BR18.5/6_7_LwUnNoc.wav
Motor/Dampf/BR18.5/6_7_LwUnNod.wav
Motor/Dampf/BR18.5/6_8_GuLASTa.wav
Motor/Dampf/BR18.5/6_8_GuLASTb.wav
Motor/Dampf/BR18.5/6_8_GuLASTc.wav
Motor/Dampf/BR18.5/6_8_GuLASTd.wav
Motor/Dampf/BR18.5/6_9_GuLEERa.wav
Motor/Dampf/BR18.5/6_9_GuLEERb.wav
Motor/Dampf/BR18.5/6_9_GuLEERc.wav
Motor/Dampf/BR18.5/6_9_GuLEERd.wav
Motor/Dampf/BR18.5/7_1_LASTL_a.wav
Motor/Dampf/BR18.5/7_1_LASTL_b.wav
Motor/Dampf/BR18.5/7_1_LASTL_c.wav
Motor/Dampf/BR18.5/7_1_LASTL_d.wav
Motor/Dampf/BR18.5/7_2_NORML_a.wav
Motor/Dampf/BR18.5/7_2_NORML_b.wav
Motor/Dampf/BR18.5/7_2_NORML_c.wav
Motor/Dampf/BR18.5/7_2_NORML_d.wav
Motor/Dampf/BR18.5/7_3_LEERL_a.wav
Motor/Dampf/BR18.5/7_3_LEERL_b.wav
Motor/Dampf/BR18.5/7_3_LEERL_c.wav
Motor/Dampf/BR18.5/7_3_LEERL_d.wav
Motor/Dampf/BR18.5/7_4_LwNoLaa.wav
Motor/Dampf/BR18.5/7_4_LwNoLab.wav
Motor/Dampf/BR18.5/7_4_LwNoLac.wav
Motor/Dampf/BR18.5/7_4_LwNoLad.wav
Motor/Dampf/BR18.5/7_5_LwLaNoa.wav
Motor/Dampf/BR18.5/7_5_LwLaNob.wav
Motor/Dampf/BR18.5/7_5_LwLaNoc.wav
Motor/Dampf/BR18.5/7_5_LwLaNod.wav
Motor/Dampf/BR18.5/7_6_LwNoUna.wav
Motor/Dampf/BR18.5/7_6_LwNoUnb.wav
Motor/Dampf/BR18.5/7_6_LwNoUnc.wav
Motor/Dampf/BR18.5/7_6_LwNoUnd.wav
Motor/Dampf/BR18.5/7_7_LwUnNoa.wav
Motor/Dampf/BR18.5/7_7_LwUnNob.wav
Motor/Dampf/BR18.5/7_7_LwUnNoc.wav
Motor/Dampf/BR18.5/7_7_LwUnNod.wav
Motor/Dampf/BR18.5/7_8_GuLASTa.wav
Motor/Dampf/BR18.5/7_8_GuLASTb.wav
Motor/Dampf/BR18.5/7_8_GuLASTc.wav
Motor/Dampf/BR18.5/7_8_GuLASTd.wav
Motor/Dampf/BR18.5/7_9_GuLEERa.wav
Motor/Dampf/BR18.5/7_9_GuLEERb.wav
Motor/Dampf/BR18.5/7_9_GuLEERc.wav
Motor/Dampf/BR18.5/7_9_GuLEERd.wav
Motor/Dampf/BR18.5/8_1_LASTL_a.wav
Motor/Dampf/BR18.5/8_1_LASTL_b.wav
Motor/Dampf/BR18.5/8_1_LASTL_c.wav
Motor/Dampf/BR18.5/8_1_LASTL_d.wav
Motor/Dampf/BR18.5/8_2_NORML_a.wav
Motor/Dampf/BR18.5/8_2_NORML_b.wav
Motor/Dampf/BR18.5/8_2_NORML_c.wav
Motor/Dampf/BR18.5/8_2_NORML_d.wav
Motor/Dampf/BR18.5/8_3_LEERL_a.wav
Motor/Dampf/BR18.5/8_3_LEERL_b.wav
Motor/Dampf/BR18.5/8_3_LEERL_c.wav
Motor/Dampf/BR18.5/8_3_LEERL_d.wav
Motor/Dampf/BR18.5/8_4_LwNoLaa.wav
Motor/Dampf/BR18.5/8_4_LwNoLab.wav
Motor/Dampf/BR18.5/8_4_LwNoLac.wav
Motor/Dampf/BR18.5/8_4_LwNoLad.wav
Motor/Dampf/BR18.5/8_5_LwLaNoa.wav
Motor/Dampf/BR18.5/8_5_LwLaNob.wav
Motor/Dampf/BR18.5/8_5_LwLaNoc.wav
Motor/Dampf/BR18.5/8_5_LwLaNod.wav
Motor/Dampf/BR18.5/8_6_LwNoUna.wav
Motor/Dampf/BR18.5/8_6_LwNoUnb.wav
Motor/Dampf/BR18.5/8_6_LwNoUnc.wav
Motor/Dampf/BR18.5/8_6_LwNoUnd.wav
Motor/Dampf/BR18.5/8_7_LwUnNoa.wav
Motor/Dampf/BR18.5/8_7_LwUnNob.wav
Motor/Dampf/BR18.5/8_7_LwUnNoc.wav
Motor/Dampf/BR18.5/8_7_LwUnNod.wav
Motor/Dampf/BR18.5/8_8_GuLASTa.wav
Motor/Dampf/BR18.5/8_8_GuLASTb.wav
Motor/Dampf/BR18.5/8_8_GuLASTc.wav
Motor/Dampf/BR18.5/8_8_GuLASTd.wav
Motor/Dampf/BR18.5/8_9_GuLEERa.wav
Motor/Dampf/BR18.5/8_9_GuLEERb.wav
Motor/Dampf/BR18.5/8_9_GuLEERc.wav
Motor/Dampf/BR18.5/8_9_GuLEERd.wav
Motor/Dampf/BR18.5/9_1_ZYLAB_a.wav
Motor/Dampf/BR18.5/9_1_ZYLAB_b.wav
Motor/Dampf/BR18.5/9_1_ZYLAB_c.wav
Motor/Dampf/BR18.5/9_1_ZYLAB_d.wav
Motor/Dampf/BR18.5/9_2_ZYLLASa.wav
Motor/Dampf/BR18.5/9_2_ZYLLASb.wav
Motor/Dampf/BR18.5/9_2_ZYLLASc.wav
Motor/Dampf/BR18.5/9_2_ZYLLASd.wav
Motor/Dampf/BR18.5/9_3_ZYLNORa.wav
Motor/Dampf/BR18.5/9_3_ZYLNORb.wav
Motor/Dampf/BR18.5/9_3_ZYLNORc.wav
Motor/Dampf/BR18.5/9_3_ZYLNORd.wav
Motor/Dampf/BR18.5/slotpar.cs2
Motor/Diesel/G2000/
Motor/Diesel/G2000/1_1_1_VSTART_s.wav
Motor/Diesel/G2000/1_1_2_VSLOOPa_s.wav
Motor/Diesel/G2000/1_1_3_VSENDE_s.wav
Motor/Diesel/G2000/1_1_4_VANLAS_.wav
Motor/Diesel/G2000/1_2_1_AMOAUS_.wav
Motor/Diesel/G2000/1_2_2_ASTART_s.wav
Motor/Diesel/G2000/1_2_3_A_LOOPa_s.wav
Motor/Diesel/G2000/1_2_4_A_ENDE__s.wav
Motor/Diesel/G2000/1_3_1_LELAL_a.wav
Motor/Diesel/G2000/1_3_1_LELAL_b.wav
Motor/Diesel/G2000/1_3_1_LELAL_c.wav
Motor/Diesel/G2000/1_3_1_LELAL_d.wav
Motor/Diesel/G2000/1_3_2_GuLEL1a.wav
Motor/Diesel/G2000/1_3_2_GuLEL1b.wav
Motor/Diesel/G2000/1_3_2_GuLEL1c.wav
Motor/Diesel/G2000/1_3_2_GuLEL1d.wav
Motor/Diesel/G2000/1_3_3_GuLEN1a.wav
Motor/Diesel/G2000/1_3_3_GuLEN1b.wav
Motor/Diesel/G2000/1_3_3_GuLEN1c.wav
Motor/Diesel/G2000/1_3_3_GuLEN1d.wav
Motor/Diesel/G2000/1_3_4_GuN1LEa.wav
Motor/Diesel/G2000/1_3_5_GuU1LEa.wav
Motor/Diesel/G2000/1_4_1_LASTL_a.wav
Motor/Diesel/G2000/1_4_1_LASTL_b.wav
Motor/Diesel/G2000/1_4_1_LASTL_c.wav
Motor/Diesel/G2000/1_4_1_LASTL_d.wav
Motor/Diesel/G2000/slotpar.cs2
Motor/Elektro/BR110_BR115_E10/
Motor/Elektro/BR110_BR115_E10/1_1_1_VSTART__s.wav
Motor/Elektro/BR110_BR115_E10/1_1_2_VSLOOPa_s.wav
Motor/Elektro/BR110_BR115_E10/1_1_3_VSENDE__s.wav
Motor/Elektro/BR110_BR115_E10/1_1_4_VANLAS__s.wav
Motor/Elektro/BR110_BR115_E10/1_2_1_AMOAUS__s.wav
Motor/Elektro/BR110_BR115_E10/1_2_2_ASTART__s.wav
Motor/Elektro/BR110_BR115_E10/1_2_3_A_LOOPa_s.wav
Motor/Elektro/BR110_BR115_E10/1_2_4_A_ENDE__s.wav
Motor/Elektro/BR110_BR115_E10/1_3_1_LELAL_a_s.wav
Motor/Elektro/BR110_BR115_E10/1_3_2_GuLEL1a_s.wav
Motor/Elektro/BR110_BR115_E10/1_3_3_GuLEN1a_s.wav
Motor/Elektro/BR110_BR115_E10/1_3_4_GuN1LEa_s.wav
Motor/Elektro/BR110_BR115_E10/1_3_5_GuU1LEa_s.wav
Motor/Elektro/BR110_BR115_E10/1_4_1_LASTL_a.wav
Motor/Elektro/BR110_BR115_E10/1_4_1_LASTL_b.wav
Motor/Elektro/BR110_BR115_E10/1_4_1_LASTL_c.wav
Motor/Elektro/BR110_BR115_E10/1_4_1_LASTL_d.wav
Motor/Elektro/BR110_BR115_E10/1_4_8_GuLASTa_s.wav
Motor/Elektro/BR110_BR115_E10/1_4_9_GuNOHoa_s.wav
Motor/Elektro/BR110_BR115_E10/1_4_A_GuNOTia_s.wav
Motor/Elektro/BR110_BR115_E10/1_4_B_GuLEERa_s.wav
Motor/Elektro/BR110_BR115_E10/1_5_1_LASTL_a_s.wav
Motor/Elektro/BR110_BR115_E10/1_6_1_LASTL_a_s.wav
Motor/Elektro/BR110_BR115_E10/1_7_1_LASTL_a_s.wav
Motor/Elektro/BR110_BR115_E10/1_8_1_LASTL_a_s.wav
Motor/Elektro/BR110_BR115_E10/1_9_1_LASTL_a_s.wav
Motor/Elektro/BR110_BR115_E10/1_A_1_LASTL_a_s.wav
Motor/Elektro/BR110_BR115_E10/253.slot
Motor/Elektro/BR110_BR115_E10/2_1_1_VSTART_.wav
Motor/Elektro/BR110_BR115_E10/2_1_2_VSLOOPa_s.wav
Motor/Elektro/BR110_BR115_E10/2_1_3_VSENDE_.wav
Motor/Elektro/BR110_BR115_E10/2_1_4_VANLAS_.wav
Motor/Elektro/BR110_BR115_E10/2_2_1_AMOAUS_.wav
Motor/Elektro/BR110_BR115_E10/2_2_2_ASTART__s.wav
Motor/Elektro/BR110_BR115_E10/2_2_3_A_LOOPa_s.wav
Motor/Elektro/BR110_BR115_E10/2_2_4_A_ENDE_.wav
Motor/Elektro/BR110_BR115_E10/2_3_1_LELAL_a.wav
Motor/Elektro/BR110_BR115_E10/2_3_1_LELAL_b.wav
Motor/Elektro/BR110_BR115_E10/2_3_1_LELAL_c.wav
Motor/Elektro/BR110_BR115_E10/2_3_1_LELAL_d.wav
Motor/Elektro/BR110_BR115_E10/2_3_2_GuLEL1a.wav
Motor/Elektro/BR110_BR115_E10/2_3_3_GuLEN1a.wav
Motor/Elektro/BR110_BR115_E10/2_3_4_GuN1LEa.wav
Motor/Elektro/BR110_BR115_E10/2_3_5_GuU1LEa.wav
Motor/Elektro/BR110_BR115_E10/2_4_1_LASTL_a.wav
Motor/Elektro/BR110_BR115_E10/2_4_1_LASTL_b.wav
Motor/Elektro/BR110_BR115_E10/2_4_1_LASTL_c.wav
Motor/Elektro/BR110_BR115_E10/2_4_1_LASTL_d.wav
Motor/Elektro/BR110_BR115_E10/2_4_8_GuLASTa.wav
Motor/Elektro/BR110_BR115_E10/2_4_9_GuNOHoa.wav
Motor/Elektro/BR110_BR115_E10/2_4_A_GuNOTia.wav
Motor/Elektro/BR110_BR115_E10/2_4_B_GuLEERa.wav
Motor/Elektro/BR110_BR115_E10/2_5_1_LASTL_a.wav
Motor/Elektro/BR110_BR115_E10/2_5_1_LASTL_b.wav
Motor/Elektro/BR110_BR115_E10/2_5_1_LASTL_c.wav
Motor/Elektro/BR110_BR115_E10/2_5_1_LASTL_d.wav
Motor/Elektro/BR110_BR115_E10/2_5_8_GuLASTa_s.wav
Motor/Elektro/BR110_BR115_E10/2_5_9_GuNOHoa_s.wav
Motor/Elektro/BR110_BR115_E10/2_5_A_GuNOTia_s.wav
Motor/Elektro/BR110_BR115_E10/2_5_B_GuLEERa_s.wav
Motor/Elektro/BR110_BR115_E10/2_6_1_LASTL_a_s.wav
Motor/Elektro/BR110_BR115_E10/2_7_1_LASTL_a_s.wav
Motor/Elektro/BR110_BR115_E10/2_8_1_LASTL_a_s.wav
Motor/Elektro/BR110_BR115_E10/2_9_1_LASTL_a_s.wav
Motor/Elektro/BR110_BR115_E10/2_A_1_LASTL_a_s.wav
Motor/Elektro/BR110_BR115_E10/slotpar.cs2
Multitext/
Multitext/slotpar.cs2
Multitext/Multibahnhofsansage/DE_Emmerich_BaselBaden_11St/
Multitext/Multibahnhofsansage/DE_Emmerich_BaselBaden_11St/01.wav
Multitext/Multibahnhofsansage/DE_Emmerich_BaselBaden_11St/02.wav
Multitext/Multibahnhofsansage/DE_Emmerich_BaselBaden_11St/03.wav
Multitext/Multibahnhofsansage/DE_Emmerich_BaselBaden_11St/04.wav
Multitext/Multibahnhofsansage/DE_Emmerich_BaselBaden_11St/05.wav
Multitext/Multibahnhofsansage/DE_Emmerich_BaselBaden_11St/06.wav
Multitext/Multibahnhofsansage/DE_Emmerich_BaselBaden_11St/07.wav
Multitext/Multibahnhofsansage/DE_Emmerich_BaselBaden_11St/08.wav
Multitext/Multibahnhofsansage/DE_Emmerich_BaselBaden_11St/09.wav
Multitext/Multibahnhofsansage/DE_Emmerich_BaselBaden_11St/10.wav
Multitext/Multibahnhofsansage/DE_Emmerich_BaselBaden_11St/11.wav
Multitext/Multibahnhofsansage/DE_Emmerich_BaselBaden_11St/End.wav
Multitext/Multibahnhofsansage/DE_Emmerich_BaselBaden_11St/Links.wav
Multitext/Multibahnhofsansage/DE_Emmerich_BaselBaden_11St/Rechts.wav
Multitext/Multibahnhofsansage/DE_Emmerich_BaselBaden_11St/Start.wav
Multitext/Multibahnhofsansage/DE_Emmerich_BaselBaden_11St/slotpar.cs2
Pantosteuerung_LGB/
Pantosteuerung_LGB/slotpar.cs2
Pantosteuerung_LGB/slottype.cs2
Schalten/
Schalten/slotpar.cs2
Schalten/Schaltwerk/BR103_E03/
Schalten/Schaltwerk/BR103_E03/01gen.wav
Schalten/Schaltwerk/BR103_E03/slotpar.cs2
Sounds/
Sounds/slotpar.cs2
Sounds/Horn_kurz/UIC_tief/
Sounds/Horn_kurz/UIC_tief/Start.wav
Sounds/Horn_lang/UIC_tief/
Sounds/Horn_lang/UIC_tief/01Loop.wav
Sounds/Horn_lang/UIC_tief/End.wav
Sounds/Horn_lang/UIC_tief/Start.wav
Sounds/Pfeife_kurz/BR18_01/
Sounds/Pfeife_kurz/BR18_01/Start.wav
Sounds/Pfeife_lang/BR18_03/
Sounds/Pfeife_lang/BR18_03/01Loop.wav
Sounds/Pfeife_lang/BR18_03/End.wav
Sounds/Pfeife_lang/BR18_03/Start.wav
Zufall/
Zufall/Slotpar.cs2
Zufall/slottype.cs2
Zufall/Multiansage_Bahnsteig/DE_Einsteigen_EpIII/
Zufall/Multiansage_Bahnsteig/DE_Einsteigen_EpIII/Slot01.wav
Zufall/Multiansage_Bahnsteig/DE_Einsteigen_EpIII/Slot02.wav
Zufall/Multiansage_Bahnsteig/DE_Einsteigen_EpIII/Slot03.wav
Zufall/Multiansage_Bahnsteig/DE_Einsteigen_EpIII/Slot04.wav
Zufall/Multiansage_Bahnsteig/DE_Einsteigen_EpIII/Slot05.wav
Zufall/Multiansage_Bahnsteig/DE_Einsteigen_EpIII/Slot06.wav
Zufall/Multiansage_Bahnsteig/DE_Einsteigen_EpIII/Slotpar.cs2
Zusatzmotor/
Zusatzmotor/slotpar.cs2
Zusatzmotor/slottype.cs2
sent 104,203 bytes received 926,574 bytes 187,414.00 bytes/sec
total size is 1,029,595,804 speedup is 998.85
sent 27 bytes received 207 bytes 156.00 bytes/sec
total size is 0 speedup is 0.00
The download is ended.
Edited by user 11 March 2026 07:36:40(UTC)  | Reason: Not specified
#3 Posted : 11 March 2026 05:19:23(UTC)
At last!
It has been years since 3.6.0 was released. They don't have a "check for updates" link like the LokProgrammer software does.
Thank you for posting this for me.
Offline jonas_sthlm
#4 Posted : 11 March 2026 07:39:02(UTC)
jonas_sthlm
I’m a bit curious about the purpose of these empty files.
It showed up a few weeks ago and I removed them, but now it’s come back empty again.
The program still won’t open in two separate windows Mad I haven’t had the chance to check if it still crashes when CS3 is closed while the program is still running.
It seems more like an update in preparation for the mLD3.5 and mSD3.5 decoder releases, but there are no Equalizer settings available for sound decoders.
Maybe something will happen soon with a CS3 update.
Offline jonas_sthlm
#5 Posted : 11 March 2026 08:49:31(UTC)
jonas_sthlm
It still crashes (Not Responding) if CS3 shutdown before.
So the objectivity of users in reporting requests and bugs has gone out the window.
thanks 3 users liked this useful post by jonas_sthlm
Offline bph
#6 Posted : 11 March 2026 12:59:50(UTC)
Had a quick look and, when I made a quick mSD3.5 project, and it returned an error when the size was above 64Mbit.....?
could be that it's just an error and will be fixed in a later update?
and in a config file, the mSD3.5 are ID'd as a mSD4.
wonder what the new funtion "Derailleur flash" does?
Offline rhfil
#7 Posted : 11 March 2026 13:17:32(UTC)
rhfil
Not sure if this applies to those empty files but they are usually created in anticipation of something being placed in them and then able to easily find them. People always forget that computers are really stupid and without very clear directions on where to find what they are looking for they are unlikely to find it. Having folders for specific tyoes of information narrows the searchl
Offline jonas_sthlm
#8 Posted : 11 March 2026 13:44:38(UTC)
jonas_sthlm
The new “Dynamic Speaker Management” feature is available exclusively on the 3.5 decoder.
Then it replaces the equalizer settings under sound like mSD3 has.
Edited by user 12 March 2026 10:57:24(UTC)  | Reason: Not specified
Offline jonas_sthlm
#9 Posted : 11 March 2026 14:13:03(UTC)
jonas_sthlm
Can it be some gear flash like Swedish Du engine room?
Offline bph
#10 Posted : 11 March 2026 14:50:14(UTC)
In German, they call it "Schaltwerk blitzen", so yes, one possibility could be some light flashes synchronised? to gear change sounds on electric locomotives etc?
This page was generated in 1.212 seconds.
