Offline jonas_sthlm
#1 Posted : 10 March 2026 20:29:01(UTC)
jonas_sthlm
https://streaming.maerklin.de/public-media/mdt3/mDecoderTool3-v365-Setup.zip
CHANGELOG
Version 3.6.5 - 13.02.2026
- Feature: The mDecoderTool3 supports the new mSD3.5 and mLD3.5 decoders in H0/1/G gauge
- Feature: The mDecoderTool3 supports mLD3 track H0 revision F, mSD3 track 1/G revision G
- Feature: The mDecoderTool3 supports the mSD3 track H0 with PluX22 interface with RailCom as a serial decoder with Spielewelt
- Feature: The new special function "Derailleur flash" is available in mapping, for which the physical outputs and the SUSI functions F# can be selected and set
- Feature: Session-based logging has been introduced for application support. This log, which records events and messages during operation, can be used for remote diagnosis (directory: mDecoderTool3_Logging, path: environment variables TEMP or TMP)
- Modified: The decoder information in the "Information about Decoder" dialog has been grouped according to decoder hardware and decoder firmware
- Improvement: The selection of a central station as a programming path has been revised, improved, and optimized to include all stations when multiple networks are set up on one computer and when switching between central stations if there are several to choose from
- Improvement: In the format settings, mfx and mfx+ can now also be switched on/off
- Improvement: The decoder information about whether RailCom is supported is only displayed if, in addition to the decoder hardware, the decoder firmware also supports RailCom
- Improvement: Revised, standardized, and renamed some CV designations, texts, terms, and expressions in mDecoderTool3 and the decoder templates
- Improvement: The mDecoderTool3 includes the latest FTDI CDM driver 2.12.36.20 for the decoder programmer, which is installed during installation
- Improvement: The mDecoderTool3 includes the latest MSVC2010 SP1 Redistributable Package. If it is not already installed, it will start the installation if necessary
- Bugfix: Changes in the decoder project could be lost if the project file mdtp was blocked and could not be written when saving
- Bugfix: When converting projects, the 'old' CV values but the 'new' block IDs must be transferred in the data structure (fds)
- Bugfix: With the flag "Open the last project when starting" in the program settings, the last opened project was only opened when clicking on the start board button "Open an existing project" instead of when the program started, as expected
- Bugfix: When deleting an action in mapping, everything must be removed in the background, i.e. action condition and trigger. Fragments could remain, which reduced the number of free mappings even though the action was deleted
- Bugfix: When resetting a function in mapping, the action may only be removed as a trigger if the action is not still triggered by another trigger
- Bugfix: As long as mDecoderTool3 itself is not correctly scalable (size of text, app, elements), prevent the scaling of texts
thanks 2 users liked this useful post by jonas_sthlm
Offline jonas_sthlm
#2 Posted : 10 March 2026 20:38:55(UTC)
jonas_sthlm
receiving incremental file list
modpar.cs2
Anfahrt/
Anfahrt/slotpar.cs2
Anfahrt/Bremsen_auf/Standard/
Anfahrt/Bremsen_auf/Standard/Start.wav
Bremsen/
Bremsen/slotpar.cs2
Bremsen/Bremsbacken/Standard/
Bremsen/Bremsbacken/Standard/01Loop.wav
Bremsen/Bremsbacken/Standard/02Loop.wav
Bremsen/Bremsbacken/Standard/03Loop.wav
Bremsen/Bremsbacken/Standard/04Loop.wav
Bremsen/Bremsbacken/Standard/End.wav
Bremsen/Bremsbacken/Standard/Start.wav
Fahren/
Fahren/slotpar.cs2
rsync: failed to open "/cygdrive/C/Users/xxxxxx/Documents/Maerklin/Soundbibliothek/mBibliothek/Lautsprecher_Parameter/slotpar.cs2", continuing: Permission denied (13)
rsync: failed to open "/cygdrive/C/Users/xxxxxx/Documents/Maerklin/Soundbibliothek/mBibliothek/Lautsprecher_Parameter/Neutral_16kHz/Neutral_16kHz_reg.dsm", continuing: Permission denied (13)
Fahren/Schiene/4-Achser_01/
Fahren/Schiene/4-Achser_01/01Loop.wav
Fahren/Schiene/4-Achser_01/End.wav
Fahren/Schiene/4-Achser_01/Start.wav
Motor/Dampf/BR18.5/
Motor/Dampf/BR18.5/1_1_RSTART_.wav
Motor/Dampf/BR18.5/1_2_RALOOPa.wav
Motor/Dampf/BR18.5/1_2_RALOOPb.wav
Motor/Dampf/BR18.5/1_2_RALOOPc.wav
Motor/Dampf/BR18.5/1_2_RALOOPd.wav
Motor/Dampf/BR18.5/1_3_RAENDE_.wav
Motor/Dampf/BR18.5/255.slot
Motor/Dampf/BR18.5/2_1_LASTL_a.wav
Motor/Dampf/BR18.5/2_1_LASTL_b.wav
Motor/Dampf/BR18.5/2_1_LASTL_c.wav
Motor/Dampf/BR18.5/2_1_LASTL_d.wav
Motor/Dampf/BR18.5/2_2_NORML_a.wav
Motor/Dampf/BR18.5/2_2_NORML_b.wav
Motor/Dampf/BR18.5/2_2_NORML_c.wav
Motor/Dampf/BR18.5/2_2_NORML_d.wav
Motor/Dampf/BR18.5/2_3_LEERL_a.wav
Motor/Dampf/BR18.5/2_3_LEERL_b.wav
Motor/Dampf/BR18.5/2_3_LEERL_c.wav
Motor/Dampf/BR18.5/2_3_LEERL_d.wav
Motor/Dampf/BR18.5/2_4_LwNoLaa.wav
Motor/Dampf/BR18.5/2_4_LwNoLab.wav
Motor/Dampf/BR18.5/2_4_LwNoLac.wav
Motor/Dampf/BR18.5/2_4_LwNoLad.wav
Motor/Dampf/BR18.5/2_5_LwLaNoa.wav
Motor/Dampf/BR18.5/2_5_LwLaNob.wav
Motor/Dampf/BR18.5/2_5_LwLaNoc.wav
Motor/Dampf/BR18.5/2_5_LwLaNod.wav
Motor/Dampf/BR18.5/2_6_LwNoUna.wav
Motor/Dampf/BR18.5/2_6_LwNoUnb.wav
Motor/Dampf/BR18.5/2_6_LwNoUnc.wav
Motor/Dampf/BR18.5/2_6_LwNoUnd.wav
Motor/Dampf/BR18.5/2_7_LwUnNoa.wav
Motor/Dampf/BR18.5/2_7_LwUnNob.wav
Motor/Dampf/BR18.5/2_7_LwUnNoc.wav
Motor/Dampf/BR18.5/2_7_LwUnNod.wav
Motor/Dampf/BR18.5/2_8_GuLASTa.wav
Motor/Dampf/BR18.5/2_8_GuLASTb.wav
Motor/Dampf/BR18.5/2_8_GuLASTc.wav
Motor/Dampf/BR18.5/2_8_GuLASTd.wav
Motor/Dampf/BR18.5/2_9_GuLEERa.wav
Motor/Dampf/BR18.5/2_9_GuLEERb.wav
Motor/Dampf/BR18.5/2_9_GuLEERc.wav
Motor/Dampf/BR18.5/2_9_GuLEERd.wav
Motor/Dampf/BR18.5/3_1_LASTL_a.wav
Motor/Dampf/BR18.5/3_1_LASTL_b.wav
Motor/Dampf/BR18.5/3_1_LASTL_c.wav
Motor/Dampf/BR18.5/3_1_LASTL_d.wav
Motor/Dampf/BR18.5/3_2_NORML_a.wav
Motor/Dampf/BR18.5/3_2_NORML_b.wav
Motor/Dampf/BR18.5/3_2_NORML_c.wav
Motor/Dampf/BR18.5/3_2_NORML_d.wav
Motor/Dampf/BR18.5/3_3_LEERL_a.wav
Motor/Dampf/BR18.5/3_3_LEERL_b.wav
Motor/Dampf/BR18.5/3_3_LEERL_c.wav
Motor/Dampf/BR18.5/3_3_LEERL_d.wav
Motor/Dampf/BR18.5/3_4_LwNoLaa.wav
Motor/Dampf/BR18.5/3_4_LwNoLab.wav
Motor/Dampf/BR18.5/3_4_LwNoLac.wav
Motor/Dampf/BR18.5/3_4_LwNoLad.wav
Motor/Dampf/BR18.5/3_5_LwLaNoa.wav
Motor/Dampf/BR18.5/3_5_LwLaNob.wav
Motor/Dampf/BR18.5/3_5_LwLaNoc.wav
Motor/Dampf/BR18.5/3_5_LwLaNod.wav
Motor/Dampf/BR18.5/3_6_LwNoUna.wav
Motor/Dampf/BR18.5/3_6_LwNoUnb.wav
Motor/Dampf/BR18.5/3_6_LwNoUnc.wav
Motor/Dampf/BR18.5/3_6_LwNoUnd.wav
Motor/Dampf/BR18.5/3_7_LwUnNoa.wav
Motor/Dampf/BR18.5/3_7_LwUnNob.wav
Motor/Dampf/BR18.5/3_7_LwUnNoc.wav
Motor/Dampf/BR18.5/3_7_LwUnNod.wav
Motor/Dampf/BR18.5/3_8_GuLASTa.wav
Motor/Dampf/BR18.5/3_8_GuLASTb.wav
Motor/Dampf/BR18.5/3_8_GuLASTc.wav
Motor/Dampf/BR18.5/3_8_GuLASTd.wav
Motor/Dampf/BR18.5/3_9_GuLEERa.wav
Motor/Dampf/BR18.5/3_9_GuLEERb.wav
Motor/Dampf/BR18.5/3_9_GuLEERc.wav
Motor/Dampf/BR18.5/3_9_GuLEERd.wav
Motor/Dampf/BR18.5/4_1_LASTL_a.wav
Motor/Dampf/BR18.5/4_1_LASTL_b.wav
Motor/Dampf/BR18.5/4_1_LASTL_c.wav
Motor/Dampf/BR18.5/4_1_LASTL_d.wav
Motor/Dampf/BR18.5/4_2_NORML_a.wav
Motor/Dampf/BR18.5/4_2_NORML_b.wav
Motor/Dampf/BR18.5/4_2_NORML_c.wav
Motor/Dampf/BR18.5/4_2_NORML_d.wav
Motor/Dampf/BR18.5/4_3_LEERL_a.wav
Motor/Dampf/BR18.5/4_3_LEERL_b.wav
Motor/Dampf/BR18.5/4_3_LEERL_c.wav
Motor/Dampf/BR18.5/4_3_LEERL_d.wav
Motor/Dampf/BR18.5/4_4_LwNoLaa.wav
Motor/Dampf/BR18.5/4_4_LwNoLab.wav
Motor/Dampf/BR18.5/4_4_LwNoLac.wav
Motor/Dampf/BR18.5/4_4_LwNoLad.wav
Motor/Dampf/BR18.5/4_5_LwLaNoa.wav
Motor/Dampf/BR18.5/4_5_LwLaNob.wav
Motor/Dampf/BR18.5/4_5_LwLaNoc.wav
Motor/Dampf/BR18.5/4_5_LwLaNod.wav
Motor/Dampf/BR18.5/4_6_LwNoUna.wav
Motor/Dampf/BR18.5/4_6_LwNoUnb.wav
Motor/Dampf/BR18.5/4_6_LwNoUnc.wav
Motor/Dampf/BR18.5/4_6_LwNoUnd.wav
Motor/Dampf/BR18.5/4_7_LwUnNoa.wav
Motor/Dampf/BR18.5/4_7_LwUnNob.wav
Motor/Dampf/BR18.5/4_7_LwUnNoc.wav
Motor/Dampf/BR18.5/4_7_LwUnNod.wav
Motor/Dampf/BR18.5/4_8_GuLASTa.wav
Motor/Dampf/BR18.5/4_8_GuLASTb.wav
Motor/Dampf/BR18.5/4_8_GuLASTc.wav
Motor/Dampf/BR18.5/4_8_GuLASTd.wav
Motor/Dampf/BR18.5/4_9_GuLEERa.wav
Motor/Dampf/BR18.5/4_9_GuLEERb.wav
Motor/Dampf/BR18.5/4_9_GuLEERc.wav
Motor/Dampf/BR18.5/4_9_GuLEERd.wav
Motor/Dampf/BR18.5/5_1_LASTL_a.wav
Motor/Dampf/BR18.5/5_1_LASTL_b.wav
Motor/Dampf/BR18.5/5_1_LASTL_c.wav
Motor/Dampf/BR18.5/5_1_LASTL_d.wav
Motor/Dampf/BR18.5/5_2_NORML_a.wav
Motor/Dampf/BR18.5/5_2_NORML_b.wav
Motor/Dampf/BR18.5/5_2_NORML_c.wav
Motor/Dampf/BR18.5/5_2_NORML_d.wav
Motor/Dampf/BR18.5/5_3_LEERL_a.wav
Motor/Dampf/BR18.5/5_3_LEERL_b.wav
Motor/Dampf/BR18.5/5_3_LEERL_c.wav
Motor/Dampf/BR18.5/5_3_LEERL_d.wav
Motor/Dampf/BR18.5/5_4_LwNoLaa.wav
Motor/Dampf/BR18.5/5_4_LwNoLab.wav
Motor/Dampf/BR18.5/5_4_LwNoLac.wav
Motor/Dampf/BR18.5/5_4_LwNoLad.wav
Motor/Dampf/BR18.5/5_5_LwLaNoa.wav
Motor/Dampf/BR18.5/5_5_LwLaNob.wav
Motor/Dampf/BR18.5/5_5_LwLaNoc.wav
Motor/Dampf/BR18.5/5_5_LwLaNod.wav
Motor/Dampf/BR18.5/5_6_LwNoUna.wav
Motor/Dampf/BR18.5/5_6_LwNoUnb.wav
Motor/Dampf/BR18.5/5_6_LwNoUnc.wav
Motor/Dampf/BR18.5/5_6_LwNoUnd.wav
Motor/Dampf/BR18.5/5_7_LwUnNoa.wav
Motor/Dampf/BR18.5/5_7_LwUnNob.wav
Motor/Dampf/BR18.5/5_7_LwUnNoc.wav
Motor/Dampf/BR18.5/5_7_LwUnNod.wav
Motor/Dampf/BR18.5/5_8_GuLASTa.wav
Motor/Dampf/BR18.5/5_8_GuLASTb.wav
Motor/Dampf/BR18.5/5_8_GuLASTc.wav
Motor/Dampf/BR18.5/5_8_GuLASTd.wav
Motor/Dampf/BR18.5/5_9_GuLEERa.wav
Motor/Dampf/BR18.5/5_9_GuLEERb.wav
Motor/Dampf/BR18.5/5_9_GuLEERc.wav
Motor/Dampf/BR18.5/5_9_GuLEERd.wav
Motor/Dampf/BR18.5/6_1_LASTL_a.wav
Motor/Dampf/BR18.5/6_1_LASTL_b.wav
Motor/Dampf/BR18.5/6_1_LASTL_c.wav
Motor/Dampf/BR18.5/6_1_LASTL_d.wav
Motor/Dampf/BR18.5/6_2_NORML_a.wav
Motor/Dampf/BR18.5/6_2_NORML_b.wav
Motor/Dampf/BR18.5/6_2_NORML_c.wav
Motor/Dampf/BR18.5/6_2_NORML_d.wav
Motor/Dampf/BR18.5/6_3_LEERL_a.wav
Motor/Dampf/BR18.5/6_3_LEERL_b.wav
Motor/Dampf/BR18.5/6_3_LEERL_c.wav
Motor/Dampf/BR18.5/6_3_LEERL_d.wav
Motor/Dampf/BR18.5/6_4_LwNoLaa.wav
Motor/Dampf/BR18.5/6_4_LwNoLab.wav
Motor/Dampf/BR18.5/6_4_LwNoLac.wav
Motor/Dampf/BR18.5/6_4_LwNoLad.wav
Motor/Dampf/BR18.5/6_5_LwLaNoa.wav
Motor/Dampf/BR18.5/6_5_LwLaNob.wav
Motor/Dampf/BR18.5/6_5_LwLaNoc.wav
Motor/Dampf/BR18.5/6_5_LwLaNod.wav
Motor/Dampf/BR18.5/6_6_LwNoUna.wav
Motor/Dampf/BR18.5/6_6_LwNoUnb.wav
Motor/Dampf/BR18.5/6_6_LwNoUnc.wav
Motor/Dampf/BR18.5/6_6_LwNoUnd.wav
Motor/Dampf/BR18.5/6_7_LwUnNoa.wav
Motor/Dampf/BR18.5/6_7_LwUnNob.wav
Motor/Dampf/BR18.5/6_7_LwUnNoc.wav
Motor/Dampf/BR18.5/6_7_LwUnNod.wav
Motor/Dampf/BR18.5/6_8_GuLASTa.wav
Motor/Dampf/BR18.5/6_8_GuLASTb.wav
Motor/Dampf/BR18.5/6_8_GuLASTc.wav
Motor/Dampf/BR18.5/6_8_GuLASTd.wav
Motor/Dampf/BR18.5/6_9_GuLEERa.wav
Motor/Dampf/BR18.5/6_9_GuLEERb.wav
Motor/Dampf/BR18.5/6_9_GuLEERc.wav
Motor/Dampf/BR18.5/6_9_GuLEERd.wav
Motor/Dampf/BR18.5/7_1_LASTL_a.wav
Motor/Dampf/BR18.5/7_1_LASTL_b.wav
Motor/Dampf/BR18.5/7_1_LASTL_c.wav
Motor/Dampf/BR18.5/7_1_LASTL_d.wav
Motor/Dampf/BR18.5/7_2_NORML_a.wav
Motor/Dampf/BR18.5/7_2_NORML_b.wav
Motor/Dampf/BR18.5/7_2_NORML_c.wav
Motor/Dampf/BR18.5/7_2_NORML_d.wav
Motor/Dampf/BR18.5/7_3_LEERL_a.wav
Motor/Dampf/BR18.5/7_3_LEERL_b.wav
Motor/Dampf/BR18.5/7_3_LEERL_c.wav
Motor/Dampf/BR18.5/7_3_LEERL_d.wav
Motor/Dampf/BR18.5/7_4_LwNoLaa.wav
Motor/Dampf/BR18.5/7_4_LwNoLab.wav
Motor/Dampf/BR18.5/7_4_LwNoLac.wav
Motor/Dampf/BR18.5/7_4_LwNoLad.wav
Motor/Dampf/BR18.5/7_5_LwLaNoa.wav
Motor/Dampf/BR18.5/7_5_LwLaNob.wav
Motor/Dampf/BR18.5/7_5_LwLaNoc.wav
Motor/Dampf/BR18.5/7_5_LwLaNod.wav
Motor/Dampf/BR18.5/7_6_LwNoUna.wav
Motor/Dampf/BR18.5/7_6_LwNoUnb.wav
Motor/Dampf/BR18.5/7_6_LwNoUnc.wav
Motor/Dampf/BR18.5/7_6_LwNoUnd.wav
Motor/Dampf/BR18.5/7_7_LwUnNoa.wav
Motor/Dampf/BR18.5/7_7_LwUnNob.wav
Motor/Dampf/BR18.5/7_7_LwUnNoc.wav
Motor/Dampf/BR18.5/7_7_LwUnNod.wav
Motor/Dampf/BR18.5/7_8_GuLASTa.wav
Motor/Dampf/BR18.5/7_8_GuLASTb.wav
Motor/Dampf/BR18.5/7_8_GuLASTc.wav
Motor/Dampf/BR18.5/7_8_GuLASTd.wav
Motor/Dampf/BR18.5/7_9_GuLEERa.wav
Motor/Dampf/BR18.5/7_9_GuLEERb.wav
Motor/Dampf/BR18.5/7_9_GuLEERc.wav
Motor/Dampf/BR18.5/7_9_GuLEERd.wav
Motor/Dampf/BR18.5/8_1_LASTL_a.wav
Motor/Dampf/BR18.5/8_1_LASTL_b.wav
Motor/Dampf/BR18.5/8_1_LASTL_c.wav
Motor/Dampf/BR18.5/8_1_LASTL_d.wav
Motor/Dampf/BR18.5/8_2_NORML_a.wav
Motor/Dampf/BR18.5/8_2_NORML_b.wav
Motor/Dampf/BR18.5/8_2_NORML_c.wav
Motor/Dampf/BR18.5/8_2_NORML_d.wav
Motor/Dampf/BR18.5/8_3_LEERL_a.wav
Motor/Dampf/BR18.5/8_3_LEERL_b.wav
Motor/Dampf/BR18.5/8_3_LEERL_c.wav
Motor/Dampf/BR18.5/8_3_LEERL_d.wav
Motor/Dampf/BR18.5/8_4_LwNoLaa.wav
Motor/Dampf/BR18.5/8_4_LwNoLab.wav
Motor/Dampf/BR18.5/8_4_LwNoLac.wav
Motor/Dampf/BR18.5/8_4_LwNoLad.wav
Motor/Dampf/BR18.5/8_5_LwLaNoa.wav
Motor/Dampf/BR18.5/8_5_LwLaNob.wav
Motor/Dampf/BR18.5/8_5_LwLaNoc.wav
Motor/Dampf/BR18.5/8_5_LwLaNod.wav
Motor/Dampf/BR18.5/8_6_LwNoUna.wav
Motor/Dampf/BR18.5/8_6_LwNoUnb.wav
Motor/Dampf/BR18.5/8_6_LwNoUnc.wav
Motor/Dampf/BR18.5/8_6_LwNoUnd.wav
Motor/Dampf/BR18.5/8_7_LwUnNoa.wav
Motor/Dampf/BR18.5/8_7_LwUnNob.wav
Motor/Dampf/BR18.5/8_7_LwUnNoc.wav
Motor/Dampf/BR18.5/8_7_LwUnNod.wav
Motor/Dampf/BR18.5/8_8_GuLASTa.wav
Motor/Dampf/BR18.5/8_8_GuLASTb.wav
Motor/Dampf/BR18.5/8_8_GuLASTc.wav
Motor/Dampf/BR18.5/8_8_GuLASTd.wav
Motor/Dampf/BR18.5/8_9_GuLEERa.wav
Motor/Dampf/BR18.5/8_9_GuLEERb.wav
Motor/Dampf/BR18.5/8_9_GuLEERc.wav
Motor/Dampf/BR18.5/8_9_GuLEERd.wav
Motor/Dampf/BR18.5/9_1_ZYLAB_a.wav
Motor/Dampf/BR18.5/9_1_ZYLAB_b.wav
Motor/Dampf/BR18.5/9_1_ZYLAB_c.wav
Motor/Dampf/BR18.5/9_1_ZYLAB_d.wav
Motor/Dampf/BR18.5/9_2_ZYLLASa.wav
Motor/Dampf/BR18.5/9_2_ZYLLASb.wav
Motor/Dampf/BR18.5/9_2_ZYLLASc.wav
Motor/Dampf/BR18.5/9_2_ZYLLASd.wav
Motor/Dampf/BR18.5/9_3_ZYLNORa.wav
Motor/Dampf/BR18.5/9_3_ZYLNORb.wav
Motor/Dampf/BR18.5/9_3_ZYLNORc.wav
Motor/Dampf/BR18.5/9_3_ZYLNORd.wav
Motor/Dampf/BR18.5/slotpar.cs2
Motor/Diesel/G2000/
Motor/Diesel/G2000/1_1_1_VSTART_s.wav
Motor/Diesel/G2000/1_1_2_VSLOOPa_s.wav
Motor/Diesel/G2000/1_1_3_VSENDE_s.wav
Motor/Diesel/G2000/1_1_4_VANLAS_.wav
Motor/Diesel/G2000/1_2_1_AMOAUS_.wav
Motor/Diesel/G2000/1_2_2_ASTART_s.wav
Motor/Diesel/G2000/1_2_3_A_LOOPa_s.wav
Motor/Diesel/G2000/1_2_4_A_ENDE__s.wav
Motor/Diesel/G2000/1_3_1_LELAL_a.wav
Motor/Diesel/G2000/1_3_1_LELAL_b.wav
Motor/Diesel/G2000/1_3_1_LELAL_c.wav
Motor/Diesel/G2000/1_3_1_LELAL_d.wav
Motor/Diesel/G2000/1_3_2_GuLEL1a.wav
Motor/Diesel/G2000/1_3_2_GuLEL1b.wav
Motor/Diesel/G2000/1_3_2_GuLEL1c.wav
Motor/Diesel/G2000/1_3_2_GuLEL1d.wav
Motor/Diesel/G2000/1_3_3_GuLEN1a.wav
Motor/Diesel/G2000/1_3_3_GuLEN1b.wav
Motor/Diesel/G2000/1_3_3_GuLEN1c.wav
Motor/Diesel/G2000/1_3_3_GuLEN1d.wav
Motor/Diesel/G2000/1_3_4_GuN1LEa.wav
Motor/Diesel/G2000/1_3_5_GuU1LEa.wav
Motor/Diesel/G2000/1_4_1_LASTL_a.wav
Motor/Diesel/G2000/1_4_1_LASTL_b.wav
Motor/Diesel/G2000/1_4_1_LASTL_c.wav
Motor/Diesel/G2000/1_4_1_LASTL_d.wav
Motor/Diesel/G2000/slotpar.cs2
Motor/Elektro/BR110_BR115_E10/
Motor/Elektro/BR110_BR115_E10/1_1_1_VSTART__s.wav
Motor/Elektro/BR110_BR115_E10/1_1_2_VSLOOPa_s.wav
Motor/Elektro/BR110_BR115_E10/1_1_3_VSENDE__s.wav
Motor/Elektro/BR110_BR115_E10/1_1_4_VANLAS__s.wav
Motor/Elektro/BR110_BR115_E10/1_2_1_AMOAUS__s.wav
Motor/Elektro/BR110_BR115_E10/1_2_2_ASTART__s.wav
Motor/Elektro/BR110_BR115_E10/1_2_3_A_LOOPa_s.wav
Motor/Elektro/BR110_BR115_E10/1_2_4_A_ENDE__s.wav
Motor/Elektro/BR110_BR115_E10/1_3_1_LELAL_a_s.wav
Motor/Elektro/BR110_BR115_E10/1_3_2_GuLEL1a_s.wav
Motor/Elektro/BR110_BR115_E10/1_3_3_GuLEN1a_s.wav
Motor/Elektro/BR110_BR115_E10/1_3_4_GuN1LEa_s.wav
Motor/Elektro/BR110_BR115_E10/1_3_5_GuU1LEa_s.wav
Motor/Elektro/BR110_BR115_E10/1_4_1_LASTL_a.wav
Motor/Elektro/BR110_BR115_E10/1_4_1_LASTL_b.wav
Motor/Elektro/BR110_BR115_E10/1_4_1_LASTL_c.wav
Motor/Elektro/BR110_BR115_E10/1_4_1_LASTL_d.wav
Motor/Elektro/BR110_BR115_E10/1_4_8_GuLASTa_s.wav
Motor/Elektro/BR110_BR115_E10/1_4_9_GuNOHoa_s.wav
Motor/Elektro/BR110_BR115_E10/1_4_A_GuNOTia_s.wav
Motor/Elektro/BR110_BR115_E10/1_4_B_GuLEERa_s.wav
Motor/Elektro/BR110_BR115_E10/1_5_1_LASTL_a_s.wav
Motor/Elektro/BR110_BR115_E10/1_6_1_LASTL_a_s.wav
Motor/Elektro/BR110_BR115_E10/1_7_1_LASTL_a_s.wav
Motor/Elektro/BR110_BR115_E10/1_8_1_LASTL_a_s.wav
Motor/Elektro/BR110_BR115_E10/1_9_1_LASTL_a_s.wav
Motor/Elektro/BR110_BR115_E10/1_A_1_LASTL_a_s.wav
Motor/Elektro/BR110_BR115_E10/253.slot
Motor/Elektro/BR110_BR115_E10/2_1_1_VSTART_.wav
Motor/Elektro/BR110_BR115_E10/2_1_2_VSLOOPa_s.wav
Motor/Elektro/BR110_BR115_E10/2_1_3_VSENDE_.wav
Motor/Elektro/BR110_BR115_E10/2_1_4_VANLAS_.wav
Motor/Elektro/BR110_BR115_E10/2_2_1_AMOAUS_.wav
Motor/Elektro/BR110_BR115_E10/2_2_2_ASTART__s.wav
Motor/Elektro/BR110_BR115_E10/2_2_3_A_LOOPa_s.wav
Motor/Elektro/BR110_BR115_E10/2_2_4_A_ENDE_.wav
Motor/Elektro/BR110_BR115_E10/2_3_1_LELAL_a.wav
Motor/Elektro/BR110_BR115_E10/2_3_1_LELAL_b.wav
Motor/Elektro/BR110_BR115_E10/2_3_1_LELAL_c.wav
Motor/Elektro/BR110_BR115_E10/2_3_1_LELAL_d.wav
Motor/Elektro/BR110_BR115_E10/2_3_2_GuLEL1a.wav
Motor/Elektro/BR110_BR115_E10/2_3_3_GuLEN1a.wav
Motor/Elektro/BR110_BR115_E10/2_3_4_GuN1LEa.wav
Motor/Elektro/BR110_BR115_E10/2_3_5_GuU1LEa.wav
Motor/Elektro/BR110_BR115_E10/2_4_1_LASTL_a.wav
Motor/Elektro/BR110_BR115_E10/2_4_1_LASTL_b.wav
Motor/Elektro/BR110_BR115_E10/2_4_1_LASTL_c.wav
Motor/Elektro/BR110_BR115_E10/2_4_1_LASTL_d.wav
Motor/Elektro/BR110_BR115_E10/2_4_8_GuLASTa.wav
Motor/Elektro/BR110_BR115_E10/2_4_9_GuNOHoa.wav
Motor/Elektro/BR110_BR115_E10/2_4_A_GuNOTia.wav
Motor/Elektro/BR110_BR115_E10/2_4_B_GuLEERa.wav
Motor/Elektro/BR110_BR115_E10/2_5_1_LASTL_a.wav
Motor/Elektro/BR110_BR115_E10/2_5_1_LASTL_b.wav
Motor/Elektro/BR110_BR115_E10/2_5_1_LASTL_c.wav
Motor/Elektro/BR110_BR115_E10/2_5_1_LASTL_d.wav
Motor/Elektro/BR110_BR115_E10/2_5_8_GuLASTa_s.wav
Motor/Elektro/BR110_BR115_E10/2_5_9_GuNOHoa_s.wav
Motor/Elektro/BR110_BR115_E10/2_5_A_GuNOTia_s.wav
Motor/Elektro/BR110_BR115_E10/2_5_B_GuLEERa_s.wav
Motor/Elektro/BR110_BR115_E10/2_6_1_LASTL_a_s.wav
Motor/Elektro/BR110_BR115_E10/2_7_1_LASTL_a_s.wav
Motor/Elektro/BR110_BR115_E10/2_8_1_LASTL_a_s.wav
Motor/Elektro/BR110_BR115_E10/2_9_1_LASTL_a_s.wav
Motor/Elektro/BR110_BR115_E10/2_A_1_LASTL_a_s.wav
Motor/Elektro/BR110_BR115_E10/slotpar.cs2
Multitext/
Multitext/slotpar.cs2
Multitext/Multibahnhofsansage/DE_Emmerich_BaselBaden_11St/
Multitext/Multibahnhofsansage/DE_Emmerich_BaselBaden_11St/01.wav
Multitext/Multibahnhofsansage/DE_Emmerich_BaselBaden_11St/02.wav
Multitext/Multibahnhofsansage/DE_Emmerich_BaselBaden_11St/03.wav
Multitext/Multibahnhofsansage/DE_Emmerich_BaselBaden_11St/04.wav
Multitext/Multibahnhofsansage/DE_Emmerich_BaselBaden_11St/05.wav
Multitext/Multibahnhofsansage/DE_Emmerich_BaselBaden_11St/06.wav
Multitext/Multibahnhofsansage/DE_Emmerich_BaselBaden_11St/07.wav
Multitext/Multibahnhofsansage/DE_Emmerich_BaselBaden_11St/08.wav
Multitext/Multibahnhofsansage/DE_Emmerich_BaselBaden_11St/09.wav
Multitext/Multibahnhofsansage/DE_Emmerich_BaselBaden_11St/10.wav
Multitext/Multibahnhofsansage/DE_Emmerich_BaselBaden_11St/11.wav
Multitext/Multibahnhofsansage/DE_Emmerich_BaselBaden_11St/End.wav
Multitext/Multibahnhofsansage/DE_Emmerich_BaselBaden_11St/Links.wav
Multitext/Multibahnhofsansage/DE_Emmerich_BaselBaden_11St/Rechts.wav
Multitext/Multibahnhofsansage/DE_Emmerich_BaselBaden_11St/Start.wav
Multitext/Multibahnhofsansage/DE_Emmerich_BaselBaden_11St/slotpar.cs2
Pantosteuerung_LGB/
Pantosteuerung_LGB/slotpar.cs2
Pantosteuerung_LGB/slottype.cs2
Schalten/
Schalten/slotpar.cs2
Schalten/Schaltwerk/BR103_E03/
Schalten/Schaltwerk/BR103_E03/01gen.wav
Schalten/Schaltwerk/BR103_E03/slotpar.cs2
Sounds/
Sounds/slotpar.cs2
Sounds/Horn_kurz/UIC_tief/
Sounds/Horn_kurz/UIC_tief/Start.wav
Sounds/Horn_lang/UIC_tief/
Sounds/Horn_lang/UIC_tief/01Loop.wav
Sounds/Horn_lang/UIC_tief/End.wav
Sounds/Horn_lang/UIC_tief/Start.wav
Sounds/Pfeife_kurz/BR18_01/
Sounds/Pfeife_kurz/BR18_01/Start.wav
Sounds/Pfeife_lang/BR18_03/
Sounds/Pfeife_lang/BR18_03/01Loop.wav
Sounds/Pfeife_lang/BR18_03/End.wav
Sounds/Pfeife_lang/BR18_03/Start.wav
Zufall/
Zufall/Slotpar.cs2
Zufall/slottype.cs2
Zufall/Multiansage_Bahnsteig/DE_Einsteigen_EpIII/
Zufall/Multiansage_Bahnsteig/DE_Einsteigen_EpIII/Slot01.wav
Zufall/Multiansage_Bahnsteig/DE_Einsteigen_EpIII/Slot02.wav
Zufall/Multiansage_Bahnsteig/DE_Einsteigen_EpIII/Slot03.wav
Zufall/Multiansage_Bahnsteig/DE_Einsteigen_EpIII/Slot04.wav
Zufall/Multiansage_Bahnsteig/DE_Einsteigen_EpIII/Slot05.wav
Zufall/Multiansage_Bahnsteig/DE_Einsteigen_EpIII/Slot06.wav
Zufall/Multiansage_Bahnsteig/DE_Einsteigen_EpIII/Slotpar.cs2
Zusatzmotor/
Zusatzmotor/slotpar.cs2
Zusatzmotor/slottype.cs2
sent 104,203 bytes received 926,574 bytes 187,414.00 bytes/sec
total size is 1,029,595,804 speedup is 998.85
sent 27 bytes received 207 bytes 156.00 bytes/sec
total size is 0 speedup is 0.00
The download is ended.
#3 Posted : 11 March 2026 05:19:23(UTC)
At last!
It has been years since 3.6.0 was released. They don't have a "check for updates" link like the LokProgrammer software does.
Thank you for posting this for me.
This page was generated in 0.798 seconds.
