Offline Gerald Lynch
#1 Posted : 14 October 2025 22:19:01(UTC)
Gerald Lynch
Marklin 60976 Diesel sound decoder install to Marklin 30601.....
Have the new Marklin F7 #30601 that has a digital MFX decoder for headlights and directional control already factory installed.
This is an AC motor of course so no conversion kit would be necessary.
Looking to add sound using the Marklin 60976 Diesel sound decoder.....
Has anyone done this... thanks....
thanks 1 user liked this useful post by Gerald Lynch
Offline mvd71
#2 Posted : 15 October 2025 02:36:39(UTC)
It has a dc motor, not ac
#3 Posted : 15 October 2025 05:21:58(UTC)
Gerald Lynch
"It has a dc motor, not ac"
Well, it has the slider pickup for the center 'rail'.....which would be for AC.....
Offline Kiko
#4 Posted : 15 October 2025 05:53:33(UTC)
Kiko
The pickup shoe is for power to the decoder. The decoder has a rectifier and runs everything in DC (including the motor).
Andry
thanks 2 users liked this useful post by Kiko
Offline cintrans
#5 Posted : 16 October 2025 02:02:08(UTC)
cintrans
Aruba
The motor uses a permanent magnet, instead of the typical AC field wound magnet on AC motors, so that makes it a DC motor.
The slider is only a way to pick up current from the "third-rail"
Jean-Pierre
#6 Posted : 16 October 2025 07:35:28(UTC)
The Märklin standard motor from the analogue days is an AC/DC motor. The decoders for that type of motor feed DC to the motor.
The new standard type of motors in digital locos is a DC motor.
I learned on this forum that digital track current is "bipolar pulsed DC".
Threerail Märklin is not AC when you use digital control.
Tworail DCC is not DC - the track current is the same for tworail and threerail.
AC/DC motors have 3 connectors, DC motors usually have 2 connectors. There are decoders for both types of motors.
Offline blid
#7 Posted : 16 October 2025 14:02:39(UTC)
blid
I think it is very unfortunate that dealers and others use the notation AC for 3-rail and DC for 2-rail. Very confusing. Before the digital era it made some sense but was still not good. It is about time NMRA or NEM specify – say 3R for 3-rail and 2R for 2-rail.
thanks 4 users liked this useful post by blid
Offline owidgie
#8 Posted : 16 October 2025 20:36:24(UTC)
owidgie
Anyway, back on topic...
The 30601 would just take the simple decoder #60975/60976/60977. Any of these decoders are programmable with any sound you like. If used out of the box all of these decoders would have European sounds, so all of the sounds are wrong no matter what type of sounds come in it (electric, diesel or steam) so no need to critique the item number or sounds within them.
You would need any of those decoders programmed with a US diesel sounds.
After the decoder is programmed it is a simple 21-pin install (press on) and mount the speaker. That's it!
Your trouble would be programming the US diesel sounds. A Marklin decoder programming tool (60971) and the Marklin Decoder Tool (MDT/3) download is required to program a decoder. Programming through a CS3 is possible but a little more complicated than the decoder tool.
Rick
thanks 1 user liked this useful post by owidgie
#9 Posted : 04 November 2025 00:26:17(UTC)
Gerald Lynch
Rick
Just received the diesel sound #60976. Looks like thr mother board on thr 30601 needs to be swapped with the 60976 mother board.
It is NOT simply taking the 21 - pin decoder and pressing it on the existing mother board on the 30601....??
#10 Posted : 04 November 2025 07:34:43(UTC)
You don't have to swap the boards if you find a way to connect the speaker.
#11 Posted : 04 November 2025 17:13:32(UTC)
Gerald Lynch
That's the issue....the 'new' mother board has 2 connectors mounted on the board to plug the speakers to.....but the 'new' board isn't connected/wired to anything if just plug in the 'new' 21 - pin sound decoder into the existing mother board.... ??
thanks 2 users liked this useful post by Gerald Lynch
Offline owidgie
#12 Posted : 04 November 2025 20:01:51(UTC)
owidgie
Marklin Digital Newsletter July - August 2025 Vol 37 - No 4.pdf (1,022kb) downloaded 32 time(s).
Here is the Digital Club newsletter regarding this topic (sort of)
Only the speaker wires need to be soldered to the decoder mounting board in the upper left of the mounting board.
The correct solder pads for the speaker are the ones BELOW THE "+" - NOT the ones to the right. I am referencing the image on page 2 of the Digital Newsletter.
I have done this to mine with the F-7 sound file I created. I gave my profile a much better horn.
Rick
thanks 4 users liked this useful post by owidgie
#13 Posted : 04 November 2025 20:10:18(UTC)
With the MSD, speakers always had to be soldered.
MSD/3 introduced the plugs.
Soldering two wires for the speakers probably is easier than replacing the motherboard.
#14 Posted : 06 November 2025 03:05:46(UTC)
Gerald Lynch
Thank you all for the suggestions with this install.
Worked out fine....took a little time, would help if Marklin indicated the specifics of each solder pad. Used the original mother board and plugged in
the new 21-pin sound decoder...and soldered the speaker wires to the correct solder pads....
Also contacted Rick Sinclair....he quickly responded which is much appreciated ....
Again thanks...
Offline 4matic
#15 Posted : 09 January 2026 23:51:04(UTC)
4matic
I'm planning to do the same and searched before posing the question, many thanks Gerald.
The Digital news letter is very informative and using that I've changed some of the lighting functions on my BNSF GE ES44AC locs which is very cool, thank you Rick.
My question here is if the programming of the decoder can be done on the CS3? How to obtain typical American diesel loc sounds and program them to the decoder. I'm an apple only user and some checking shows that the marklin programmer and software is windows only.
thanks 1 user liked this useful post by 4matic
OceanSpiders 2.0
This page was generated in 0.709 seconds.
