Offline rhfil
#1 Posted : 28 October 2025 18:04:40(UTC)
rhfil
There has been some discussion of non-Marklin locos reacting oddly with Marklin Braking Modules 72442. They seem to go into analog mode - reversing direction and going into high speed. Has anyone discovered a solution to the problem? I have seen some discussion which suggests changing a cv in the locos can prevent the problem. Which cv and what setting?
#2 Posted : 28 October 2025 19:22:48(UTC)
With DCC protocol this is the following process:
CV 29 at value 6
CV 50 Bit 1: analog DC on 1 or you write value 6 with DCC protocol too.
CV 27 at value 48 ( check after Bit 4 and 5). Value at 48 are for the fx/mfx. If you read Bit 4 it´s for the DC standard polarity against the direction of travel. Bit 5 are DC standard polarity with the direction of travel.
This is what you set with Märklins sound decoder.
What other manufacture says it stand in theirs manual how to set.
Hopeful will this help if not less you try with Viessmanns brake modul instead?
#3 Posted : 01 November 2025 02:25:57(UTC)
Hi Richard,
The best solution is to avoid braking modules. As you suspect, the expected behaviour is not well defined, mostly because it is an analog control mechanism in a digital environment. The whole idea behind digital control is full control of the loco at any time, by a central controller. Braking modules are a 'hack' born of a lack of understanding/software to make the loco slow and stop digitally.
#4 Posted : 01 November 2025 11:11:57(UTC)
Hi Richard,
That´s way I do not use brake modul.
For many years ago when Märklin did used C90 decoder I did tested a Märklin brake modul but did found out lot of work must done and lot of planning to install brake moduls for a big layout.
The second problem are cost of the products.
Just 5 track install and with brake moduls its hugh of prices!
The third problem are to use 28 or 126 speed steps.
In this way you have to set value correct and the distance of the break must fit perfect.
If you control your train via cab control by increase or decline speed step you have fully control better way and you play as locomotive engineer as prototype too.
Offline BenP
#5 Posted : 01 November 2025 12:18:52(UTC)
BenP
There is no need for braking modules when driving digitally. Loc decoders do this, or the control station.
(Tell this to your train club ;-)
Ben
Ben van der Pluijm--
Offline mmervine
#6 Posted : 01 November 2025 14:10:50(UTC)
mmervine
To ensure good brake module performance, make sure the DC analog mode is disabled on your decoder. Each manufacturer approaches this differently. A friend of mine did some detective work and found the following:
Loksound 5 CV27=24
Zimo CV27=24
D&H CV27=48
Piko CV27=48
The difference is what bits are use to disable DC analog.
mark
thanks 1 user liked this useful post by mmervine
Help in Setting CV values for Marklin decoder 60972 to handle Marklin braking module 72441/72442 (Digital)
by Bill L 08/12/2021 22:27:35(UTC)
This page was generated in 0.294 seconds.
