Offline Kristaki
#1 Posted : 16 October 2025 14:07:17(UTC)
Kristaki
Hello i have the locomotive 37467 and finally i changed my ecos esu for marklin console the simple one.
i installed the 37467 which worked first then i noticed no lights and only go ahead i cant go back or options none... then i did her a reinitialise now nothing works only go ahead...
i unplugged all and delete loco and readded but not owrking
its adress 46... how can i have since i reinisilised it haev the decoder working properly with this loco and it functions..?
i changed 46 to 47 before because i had already a 46 rec460 so then i changed the other loco from 46 to 39 and tried wit this 37467 with adress 46 but NO result i put her working and goes super fast and only the button stop respond..
how to put back properly this locomotive anyone has some tips ty
Best Regards
Christian
Offline rhfil
#2 Posted : 16 October 2025 16:31:47(UTC)
rhfil
First of all, which Marklin controller do you have. "Simple one" is not a model number.
Offline Kristaki
#3 Posted : 16 October 2025 16:39:31(UTC)
Kristaki
https://swissbahn.ch/aus...e-lok-4001883374673.html
This model of locomotive and is a mfx tells in box
Offline rhfil
#4 Posted : 16 October 2025 17:05:18(UTC)
rhfil
And if you read the previous comments you would know that an mfx decoder is read automatically by most of Marklin current controllers though I am not sure if "simple one" is a current controller model. Also, a current Marklin controller will give priority to the mfx protocol for controlling the loco and ignore the others. Once again, do some reading.
Online marklinist5999
#5 Posted : 16 October 2025 17:22:09(UTC)
Is your Marklin controller a MS2 Kristaki?
Offline Kristaki
#6 Posted : 16 October 2025 18:05:50(UTC)
Kristaki
is a mfx on the box but the control station dont detect the mfx which is adress also 46 fabric told in manual... its telling mm2 on the control station is why is confusing she works now but not like others if u click a button its not respondig or u cant slow it down ... in any case i tried to look in the dtabase but is not there . i ahve 2 otehrs models they got fine installed from database..
i do read rhfil but this loco is acting very weird... on the box mister marklinist5999 which replied to me also is telling mfx and not ms2
Offline rhfil
#7 Posted : 16 October 2025 18:30:34(UTC)
rhfil
What model Marklin controller do you have? The mfx address is created when the controller searches through assigned mfx addresses and assigns an unused one to the loco. It then waits for the human controller to complete the contact. You are failing in your role.
#8 Posted : 16 October 2025 18:42:00(UTC)
Christian,
from the behaviour described, it sounds like an old Maerklin analog locomotive being run on a digital layout. The analog models would not respond to controls and would take off at top speed and the only way to stop them was to press the stop button. Some of the early models (1990s) had lights which only functioned via the decoder (function on/off).
Can you open the locomotive and post a photo of the chassis with the PC board? It would help us identify the nature of the model.
A new 37467 would have a mfx decoder similar to the 37460 or 37464.
Can you also post a photo of your controller or it's box as identifying that would help us better evaluate the issue.
Take a track section made up of 2-3 straight sections and connect to your Mobile Station.
Plug Track box into AC (wall)
Press "Stop"
Place locomotive on track
Press "Stop" again
Allow MS to scan for locomotive (Should check mfx, dcc and then MM) (OEM order)
If locomotive simply starts moving, then it is either analog or the decoder is stuck in analog mode.
Offline Kristaki
#9 Posted : 16 October 2025 18:42:07(UTC)
Kristaki
its the marklin 29000 u mean this with controler hte control station?
thanks 1 user liked this useful post by Kristaki
Offline Kristaki
#10 Posted : 16 October 2025 18:45:29(UTC)
Kristaki
Hello Mike
yes then u might be right can be analog or old system.. but when i open it is with electronic... i bought it a good 4 years ago.... is brand new also yes when i put it on track i undo stop even i dont add it she goes but just before this message she worked but dont respond properly ok i will take some pictures
in a store she seems to ahve worked but here no way lol was on a bigger marklin station in store...
let me go take pictures
Offline Kristaki
#11 Posted : 16 October 2025 18:50:25(UTC)
Kristaki
these pictures of the loc an manual
sounds works lights but seems to work half:(
#12 Posted : 16 October 2025 18:53:43(UTC)
A few more questions to gain more information:
1) Do you have an analog (classic) transformer (66471 or earlier)? to test the model in analog? If yes, connect a few track sections and place the locomotive on the track and run it for 5-10 seconds
Put the locomotive back on the digital layout (alone) and let the controller detect it.
2) If no, do you have a 9V battery and can you connect one wire to the slider and the other to one of the wheels
Let the battery power the locomotive for 5-10 seconds and then remove wires from locomotive
Place locomotive back on track and allow the controller to detect it again.
As you just bought the controller, perhaps your dealer could help you. Can you bring the locomotive and your controller to the shop?
The closest Maerklin dealer (specialist) is probably Anton Furger in Visp
Sion has "Au modelisme" and "Hobby Centre".
Please post the photos requested so that I can better address your particular situation rather than generalities.
Offline Kristaki
#13 Posted : 16 October 2025 19:01:24(UTC)
Kristaki
oh yes i have lot of old tracks lol i just opened the box after 40 years of not use... i will test or try what u did i must look to reconnect is long years not used lol but i was a good one in past when i was a kid with analogic and digital right now a noob:(
yes i have sent pics above and yes i will see the guy of the store wednesday and i haver the marklin 29000 package i bought... i had an ecos esu bought 5 years ago also issues i took decision to sell it too complciated to start in digital... better to start from 29000 has a noob...:)
but u so kind of u replys is appreciated guyz
#14 Posted : 16 October 2025 19:17:36(UTC)
Looking at the photos, the details are pretty similar to the 37462 that I have here. My decoder has a green PC board, but the details are the same.
Based on that information, my assessment is that your model is fully OEM and corresponds to what I would expect from a factory model.
The 29000 Set contained a 60657 controller (Mobile Station 2+).
I am going to ask you to check your MS2 library. Click "Shift" and then scroll using the dial.
See if you have a registry for MM46 or 460 105-0 SBB. If yes, select that one and then click on Shift and then "Wrench" and then scroll down to "Remove Loco"
Then allow the MS2 to detect the locomotive again.
#15 Posted : 16 October 2025 19:19:53(UTC)
Do you have other locomotives? Are they working with the MS2?
If other locomotives work, then the problem is more likely with the loco than with the MS2 or setup.
MC
Offline Kristaki
#16 Posted : 16 October 2025 19:23:56(UTC)
Kristaki
oh yes i have the rb103 and another re 460 jubilee digital both got detected by database i found them with the box number but i will fast eat and look what u said on the control to find this in the locomotive database correct? and hwat means wrench in engish?
i let u know later i will do this then u ask me if i understand good to redetect it automatically correct
Offline Kristaki
#17 Posted : 16 October 2025 20:14:06(UTC)
Kristaki
image0 (5).jpegi took a picture of the otehr 2 locs i have with this one 37467 i told you i will go now to see to add the one u tell me and rmeove it and try to readd it has u so gently explained me
the other 2 didnt gave any problem i took the numbers u se eon box and aparently worked nice:) now this 37467 is not in the database dont ask me why lol:(
i go test i tell u soon if went good
Offline Kristaki
#18 Posted : 16 October 2025 20:22:13(UTC)
Kristaki
dear mike i looked but i find no infos on the search u tol dme to find in the database library of locomotives....
i ahve the 29000 set has mfx mm2 and dcc search just for info
the 29000 controle station i bought from the store maybe is not fully update... by the way i saw in google that it has 1000 of htem in the list but i see only a 90 or 100 max 200... maybe is why?
Offline rhfil
#19 Posted : 16 October 2025 21:44:27(UTC)
rhfil
29000 is not the controller number but the starter set number. The set includes a MS2 controller, Marklin number 60657, and an instructional manual. You might want to read it.
#20 Posted : 16 October 2025 22:50:00(UTC)
The 29000 should be updated to include the models you have. When I got my 29000, it was to supplement/replace the older gray MS2 that I had.
I was not able to update the original one, as I don't have a Central Station and there is no local dealer who could assist.
I opted for the newer one to be able to access up to 32 functions for most models.
@Kristaki Wrench is the red tool symbol next to the white locomotive on the bottom right button
Offline rhfil
#21 Posted : 16 October 2025 23:00:03(UTC)
rhfil
The current software for the MS2 is 5.3. Not that you really need it for the older locomotives you have. I learned recently that if it is a pre-mfx Marklikn locomotive it uses MM and not DCC so none of the ones you have should recognize the DCC protocol. Only the most recent Marklin locomotives seem to recognize the DCC protocol. There is a way to turn off the mfx protocol in the MS2. Here is one of the tutorials from what I consider to being the best source for all Marklkin information:
#22 Posted : 17 October 2025 11:50:49(UTC)
Note that mfx locos are not included in the database of any controller, neither MS nor CS. They are supposed to register automatically using mfx.
The MS2 may require an update to support mfx+ decoders (1.83) or to support more than 16 functions per mfx loco (3.55), but version 1.83 should be enough to register any Märklin mfx loco.
I have no idea what new features came with version 5.x over 4.x and the improvements of 4.x over 3.55 are not worth much hassle.
So even with version 5.3, you will not find 37467 or 37462 in the loco database when trying to add a loco from the database.
Offline Kristaki
#23 Posted : 17 October 2025 12:29:22(UTC)
Kristaki
T’y also to u for u reply! At this stage with all infos i will go to store and update this ms2! I really like this logo! I send a pic also of my future boards lot of Space I have much to learn of digital has i can see but with patience be good!:) IMG_1576.jpeg
#24 Posted : 17 October 2025 12:48:57(UTC)
Based on my experience, updating the MS2 will most likely not make any difference for registering loco 37647.
I recommend to also take the loco to the dealer. Registering the loco on the dealer's MS or CS could make a difference as the loco must register again with your MS2.
Offline rhfil
#25 Posted : 17 October 2025 16:23:36(UTC)
rhfil
You could be wrong about the database and my evidence is that a newly issued locomotive will be registered on a CS3 without any icon. And then in the next update the icon is added to the database. Also, I have found that other than the name of the loco any changes you make to the loco information are only in the CS3. The cv's in the loco remain unchanged. I run my locos on three different layouts with three different CS3+s and while I change the long whistle from switched to timed it resorts back to switched on the other CS3+s. But changing the name remains changed. Which kind of makes sense so that if you do a factory reset of the loco it restores everything to the factory settings stored in the loco unless you have a hardwire connection to the internet. Otherwise that would be required to do a loco reset. And to avoid any penis envy, two of the CS3's and layouts are not mine.
Offline Kristaki
#26 Posted : 19 October 2025 08:39:58(UTC)
Kristaki
Ok ty for u reply i will investigate but this console in 29000 package is nice. I found a great store here in Swiss which will look what happen to this loc is an issue on it it’s not taking the mfx and is new even with reset not working.
Have a good day. I start to build my layout this week I finally have more ways here:)
#27 Posted : 19 October 2025 10:07:31(UTC)
Try to reset locomotive is not possible in the adress 46?
Your model have mfx protocol and I cannot find if this loco support DCC protocol too..
I suggest you check your MS2 if the system are set only at mfx protocol?
Your MS2 need also set at MM so you can use the adress 46 by seek in the MS2 list.
The model 37467 cannot find anymore time at Märklins homepage.
#28 Posted : 20 October 2025 08:48:50(UTC)
The database lists all non-mfx Märklin locos and only non-mfx locos; it is used to add locos from database.
The loco icon collection is the icon collection, it is not the database.
Evidence dismissed.
The CS2 loco edit screen uses yellow text for settings that are stored in the loco decoder and white text for settings stored in the CS2 (or was it the other way around?). The loco configuration screen contains a wild mix of both types.
Loco name, sound volume, and max. speed are stored in the loco.
There are settings for acceleration and braking delay stored in the loco and there are settings for acceleration and braking delay stored in the CS2.
Offline Kristaki
#29 Posted : 20 October 2025 11:37:08(UTC)
Kristaki
Hey goofy ty! I will do a last try on it looking and redoing protocols or then I go to store at last option is very strange issue this loc is new:)
Offline rhfil
#30 Posted : 20 October 2025 17:31:13(UTC)
rhfil
"The database lists all non-mfx Märklin locos and only non-mfx locos; it is used to add locos from database.
Evidence dismissed."
Conclusions can be dismissed. Since, as far as I can tell, all mfx locomotives had an MM address and now also a dcc address, they would also be included in the database otherwise someone who had mfx turned off in his controller would not be able to add one of the newly issued locos which have mfx.
I assume when you state: "Loco name, sound volume, and max. speed are stored in the loco." you are stating that the information stored in the loco can be changed. It is interesting that Marklin does not protect those cvs but does the others. I wonder what their rationale was. One of my Marklin locos is the 39241 an SNCF loco with station announcements in German. I tell people it comes from the period of the German occupation. But I wish I could change it easily.
#31 Posted : 21 October 2025 08:27:29(UTC)
Not all mfx locos had MM addresses.
When you disable mfx, you have to register those Märklin locos manually because they cannot be found in the database. You will then have 28 function keys with an F symbol and you have to change them all to proper icons, remove those that are not available, and change some to momentarily.
It would be good for people who do not use mfx to have them in the database, but Märklin don't to that.
Offline rhfil
#32 Posted : 21 October 2025 16:37:31(UTC)
rhfil
Did they have the protocol but no assigned address? In my experience every loco has some assigned address when it is shipped. Oh, not sure about the early ones with dip switches. They might have been shipped set for analog. I am new to the hobby so mostly have purchased the older locos used. Only one was not in the data base.
#33 Posted : 22 October 2025 01:01:13(UTC)
In Post #11, Kristaki posted a photo of the instructions, clearly showing the MM address of 46 and the mfx address for the 37467
MC
#34 Posted : 22 October 2025 08:33:19(UTC)
The mfx address is a number; the mfx address is never shown in the manual because the controller assigns it automatically when the loco registers with the controller.
Offline Kristaki
#35 Posted : 22 October 2025 10:50:19(UTC)
Kristaki
On box shows mec but is also an adress in any case i will go to a store to look this weird issueimage2 (1).jpeg
This page was generated in 0.890 seconds.
